[SCM] PostGIS branch master updated. 3.7.0beta1-262-g1847fb9ffe
Sun Aug 9 04:02:50 PDT 2026
the project "PostGIS".
       via  1847fb9ffe953944a68a07a060e4a7278cb555e3 (commit)
       via  00418cb248d6d73f07f1e64cbeff23c251ce021d (commit)
      from  9e462475410a58876992c2f7ea61fda4ac403ca8 (commit)
revisions in full, below.
commit 1847fb9ffe953944a68a07a060e4a7278cb555e3
Merge: 9e46247541 00418cb248
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Aug 9 04:02:48 2026 -0700
    Merge pull request 'ci: run the guarded suites when the regression harness itself changes' (!655) from Komzpa/postgis:ci/skip-gate-harness-globs-20260801 into master
    The skip gate lets a pull request opt out of the expensive suites when nothing it touched can affect them. Its always-run list covered build system and CI configuration but not the **harness those suites execute**: a change to `regress/run_test.pl`, `regress/runtest.mk` or a hook under `regress/hooks/` skipped every suite that would have exercised it. The harness was the one component CI could not test.
    `fuzzers/**` is in the same class for a different reason: `GNUmakefile.in` makes `check` depend on `check-fuzzers`, so a broken fuzzer breaks the same `make check` the suites run.
    Verified by asking the gate directly rather than by inspection. With `regress/run_test.pl` as the only changed path:
    | suite | before | after |
    | install | skip | run |
    | extension-upgrade | skip | run |
    | cluster-upgrade | skip | run |
    | preinstall | skip | run |
    `regress/runtest.mk`, `regress/hooks/**` and `fuzzers/**` flip the same way.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/655
commit 00418cb248d6d73f07f1e64cbeff23c251ce021d
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Aug 1 04:47:30 2026 +0400
    it touched can affect them. The list of always-run paths covered build system
    and CI configuration but not the harness those suites execute: a change to
    regress/run_test.pl, regress/runtest.mk or a hook under regress/hooks/ skipped
    every suite that would have exercised it, so the harness was the one component
    CI could not test.
    fuzzers/** is in the same class for a different reason: GNUmakefile.in makes
    check depend on check-fuzzers, so a broken fuzzer breaks the same make check
    the suites run.
    Verified by asking the gate directly: with regress/run_test.pl as the only
    changed path, install, extension-upgrade, cluster-upgrade and preinstall all
    answered skip before this change and all answer run after it.
diff --git a/ci/ci_need_suite.py b/ci/ci_need_suite.py
index 3af7434ea3..75547bee84 100755
--- a/ci/ci_need_suite.py
+++ b/ci/ci_need_suite.py
@@ -30,6 +30,11 @@ CI_AND_BUILD_GLOBS = (
     "*/Makefile.in",
     "macros/**",
     "build-aux/**",
+    "regress/run_test.pl",
+    "regress/runtest.mk",
+    "regress/hooks/**",
+    "regress/utils/**",
+    "fuzzers/**",
 CORE_GLOBS = (
Summary of changes:
 ci/ci_need_suite.py | 5 +++++
 1 file changed, 5 insertions(+)
hooks/post-receive
