[SCM] PostGIS branch stable-3.6 updated. 3.6.4-112-g767fa40644
Sun Aug 9 09:59:04 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  767fa40644253281f6d4e8b06811489b0a0f9b0d (commit)
       via  53e273faeb440176eee83f76319b48afb0b86834 (commit)
      from  74d5114fc42452ba69ce0b9fd4ec5fa26bfee87a (commit)
revisions in full, below.
commit 767fa40644253281f6d4e8b06811489b0a0f9b0d
Merge: 74d5114fc4 53e273faeb
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Aug 9 09:59:03 2026 -0700
    Merge pull request 'flatgeobuf: validate input buffers before decoding (stable-3.6)' (!674) from Komzpa/postgis:fix/flatgeobuf-input-validation-36-20260809 into stable-3.6
    ## Summary
    - backpatch the merged master FlatGeobuf input validation fix from https://gitea.osgeo.org/postgis/postgis/pulls/669 to stable-3.6
    - reject oversized string and datetime property lengths before copying decoded values
    - reject truncated/oversized size-prefixed FlatGeobuf buffers and adjacent malformed geometry/index metadata
    - add the 3.6.5 NEWS entry with separate reporter credits for Mehmet Ince and for Sarath Kumar / IITM Pravartak Security Team
    ## Validation
    - utils/check_news.sh .
    - git diff --check gitea/stable-3.6...HEAD
    - git clang-format gitea/stable-3.6 --diff -- deps/flatgeobuf/flatgeobuf_c.cpp deps/flatgeobuf/geometryreader.cpp postgis/flatgeobuf.c postgis/lwgeom_in_flatgeobuf.c
    Focused regression was not run locally because this isolated stable worktree is not configured and has no generated regress/core check target.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/674
commit 53e273faeb440176eee83f76319b48afb0b86834
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Aug 8 15:23:44 2026 +0400
    Validate FlatGeobuf size-prefixed header and feature buffers against the remaining bytea before FlatBuffers decodes them. Reject malformed variable-length property values and adjacent malformed geometry/index metadata before copying or advancing through decoder state.
    Also handle NULL bytea input to ST_FromFlatGeobuf explicitly, preserving its existing empty-set behavior for NULL input.
    (cherry picked from commit 0a7c72a9102033c8b6ddb4f3875cc0741d3baa0a)
diff --git a/NEWS b/NEWS
index 9d85ad8261..1314c3c807 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,11 @@ PostGIS 3.6.5
 * Fixes *
+- GT-674, [flatgeobuf] Validate size-prefixed buffers and variable-length property
+  values before decoding
+  (reported by Mehmet Ince;
+  reported by Sarath Kumar, IITM Pravartak Security Team;
+  fixed by Darafei Praliaskouski)
 - GT-619, Make interrupt regression tests compare timeout latency to
   same-machine uninterrupted runtime, avoiding false failures under
   slow CI load (Darafei Praliaskouski)
diff --git a/deps/flatgeobuf/flatgeobuf_c.cpp b/deps/flatgeobuf/flatgeobuf_c.cpp
index 16a259375b..a5b121f942 100644
--- a/deps/flatgeobuf/flatgeobuf_c.cpp
+++ b/deps/flatgeobuf/flatgeobuf_c.cpp
@@ -28,12 +28,14 @@
 #include "geometryreader.h"
 #include "packedrtree.h"
+#include <exception>
 using namespace flatbuffers;
 using namespace FlatGeobuf;
 typedef flatgeobuf_ctx ctx;
-uint8_t flatgeobuf_magicbytes[] = { 0x66, 0x67, 0x62, 0x03, 0x66, 0x67, 0x62, 0x01 };
+uint8_t flatgeobuf_magicbytes[] = {0x66, 0x67, 0x62, 0x03, 0x66, 0x67, 0x62, 0x01};
 uint8_t FLATGEOBUF_MAGICBYTES_SIZE = sizeof(flatgeobuf_magicbytes);
 struct FeatureItem : FlatGeobuf::Item {
@@ -41,20 +43,30 @@ struct FeatureItem : FlatGeobuf::Item {
 	uint64_t offset;
-int flatgeobuf_encode_header(ctx *ctx)
+static size_t
+flatgeobuf_size_prefixed_verifier_length(uoffset_t size)
+	return (size_t)size + sizeof(uoffset_t);
+int
+flatgeobuf_encode_header(ctx *ctx)
 	FlatBufferBuilder fbb;
 	fbb.TrackMinAlign(8);
 	// inspect first geometry
-	if (ctx->lwgeom != NULL) {
+	if (ctx->lwgeom != NULL)
 		if (lwgeom_has_srid(ctx->lwgeom))
 			ctx->srid = ctx->lwgeom->srid;
 		ctx->has_z = lwgeom_has_z(ctx->lwgeom);
 		ctx->has_m = lwgeom_has_m(ctx->lwgeom);
 		ctx->lwgeom_type = ctx->lwgeom->type;
-		ctx->geometry_type = (uint8_t) GeometryWriter::get_geometrytype(ctx->lwgeom);
-	} else {
+		ctx->geometry_type = (uint8_t)GeometryWriter::get_geometrytype(ctx->lwgeom);
+	else
 		LWDEBUG(2, "ctx->lwgeom is null");
 		ctx->geometry_type = 0;
@@ -64,10 +76,12 @@ int flatgeobuf_encode_header(ctx *ctx)
 	std::vector<flatbuffers::Offset<FlatGeobuf::Column>> columns;
 	std::vector<flatbuffers::Offset<FlatGeobuf::Column>> *pColumns = nullptr;
-	if (ctx->columns_size > 0) {
-		for (uint16_t i = 0; i < ctx->columns_size; i++) {
+	if (ctx->columns_size > 0)
+		for (uint16_t i = 0; i < ctx->columns_size; i++)
 			auto c = ctx->columns[i];
-			columns.push_back(CreateColumnDirect(fbb, c->name, (ColumnType) c->type));
+			columns.push_back(CreateColumnDirect(fbb, c->name, (ColumnType)c->type));
 	if (columns.size() > 0)
@@ -79,7 +93,8 @@ int flatgeobuf_encode_header(ctx *ctx)
 	std::vector<double> envelope;
 	std::vector<double> *pEnvelope = nullptr;
-	if (ctx->has_extent) {
+	if (ctx->has_extent)
 		envelope.push_back(ctx->xmin);
 		envelope.push_back(ctx->ymin);
 		envelope.push_back(ctx->xmax);
@@ -88,21 +103,32 @@ int flatgeobuf_encode_header(ctx *ctx)
 	if (envelope.size() > 0)
 		pEnvelope = &envelope;
-	const auto header = CreateHeaderDirect(
-		fbb, ctx->name, pEnvelope, (GeometryType) ctx->geometry_type, ctx->has_z, ctx->has_m, ctx->has_t, ctx->has_tm, pColumns, ctx->features_count, ctx->index_node_size, crs);
+	const auto header = CreateHeaderDirect(fbb,
+					       ctx->name,
+					       pEnvelope,
+					       (GeometryType)ctx->geometry_type,
+					       ctx->has_z,
+					       ctx->has_m,
+					       ctx->has_t,
+					       ctx->has_tm,
+					       pColumns,
+					       ctx->features_count,
+					       ctx->index_node_size,
+					       crs);
 	fbb.FinishSizePrefixed(header);
 	const auto buffer = fbb.GetBufferPointer();
 	const auto size = fbb.GetSize();
 	LWDEBUGF(2, "header size %d (with size prefix)", size);
-	Verifier verifier(buffer, size - sizeof(uoffset_t));
-	if (VerifySizePrefixedHeaderBuffer(verifier)) {
+	Verifier verifier(buffer, size);
+	if (!VerifySizePrefixedHeaderBuffer(verifier))
 		lwerror("buffer did not pass verification");
 		return -1;
-	ctx->buf = (uint8_t *) lwrealloc(ctx->buf, ctx->offset + size);
+	ctx->buf = (uint8_t *)lwrealloc(ctx->buf, ctx->offset + size);
 	LWDEBUGF(2, "copying to ctx->buf at offset %llu", ctx->offset);
 	memcpy(ctx->buf + ctx->offset, buffer, size);
@@ -111,7 +137,8 @@ int flatgeobuf_encode_header(ctx *ctx)
 	return 0;
-int flatgeobuf_encode_feature(ctx *ctx)
+int
+flatgeobuf_encode_feature(ctx *ctx)
 	Offset<Geometry> geometry = 0;
@@ -119,13 +146,15 @@ int flatgeobuf_encode_feature(ctx *ctx)
-	if (ctx->lwgeom != NULL && !lwgeom_is_empty(ctx->lwgeom)) {
+	if (ctx->lwgeom != NULL && !lwgeom_is_empty(ctx->lwgeom))
 		LWDEBUGG(3, ctx->lwgeom, "GeometryWriter input LWGEOM");
-		if (ctx->lwgeom_type != ctx->lwgeom->type) {
+		if (ctx->lwgeom_type != ctx->lwgeom->type)
 			lwerror("mixed geometry type is not supported");
 			return -1;
-		GeometryWriter writer(fbb, ctx->lwgeom, (GeometryType) ctx->geometry_type, ctx->has_z, ctx->has_m);
+		GeometryWriter writer(fbb, ctx->lwgeom, (GeometryType)ctx->geometry_type, ctx->has_z, ctx->has_m);
 		geometry = writer.write(0);
 	if (ctx->properties_len > 0)
@@ -140,21 +169,24 @@ int flatgeobuf_encode_feature(ctx *ctx)
 	LWDEBUGF(3, "encode_feature size %u", size);
-	if (VerifySizePrefixedFeatureBuffer(verifier)) {
+	if (!VerifySizePrefixedFeatureBuffer(verifier))
 		return -1;
 	LWDEBUGF(3, "reallocating ctx->buf to size %llu", ctx->offset + size);
-	ctx->buf = (uint8_t * ) lwrealloc(ctx->buf, ctx->offset + size);
 	LWDEBUGF(3, "copying feature to ctx->buf at offset %llu", ctx->offset);
-	if (ctx->create_index) {
-		auto item = (flatgeobuf_item *) lwalloc(sizeof(flatgeobuf_item));
+	if (ctx->create_index)
+		auto item = (flatgeobuf_item *)lwalloc(sizeof(flatgeobuf_item));
 		memset(item, 0, sizeof(flatgeobuf_item));
 			auto gbox = lwgeom_get_bbox(ctx->lwgeom);
 			item->xmin = gbox->xmin;
 			item->xmax = gbox->xmax;
@@ -171,15 +203,15 @@ int flatgeobuf_encode_feature(ctx *ctx)
 	return 0;
-void flatgeobuf_create_index(ctx *ctx)
+void
+flatgeobuf_create_index(ctx *ctx)
 	// convert to structure expected by packedrtree
 	std::vector<std::shared_ptr<Item>> items;
-	for (uint64_t i = 0; i < ctx->features_count; i++) {
+	for (uint64_t i = 0; i < ctx->features_count; i++)
 		const auto item = std::make_shared<FeatureItem>();
-		item->nodeItem = {
-			ctx->items[i]->xmin, ctx->items[i]->ymin, ctx->items[i]->xmax, ctx->items[i]->ymax
+		item->nodeItem = {ctx->items[i]->xmin, ctx->items[i]->ymin, ctx->items[i]->xmax, ctx->items[i]->ymax};
 		item->offset = ctx->items[i]->offset;
 		item->size = ctx->items[i]->size;
 		items.push_back(item);
@@ -196,30 +228,32 @@ void flatgeobuf_create_index(ctx *ctx)
 	// allocate new buffer and write magicbytes
 	auto oldbuf = ctx->buf;
 	auto oldoffset = ctx->offset;
-	ctx->buf = (uint8_t *) lwalloc(sizeof(signed int) + FLATGEOBUF_MAGICBYTES_SIZE);
+	ctx->buf = (uint8_t *)lwalloc(sizeof(signed int) + FLATGEOBUF_MAGICBYTES_SIZE);
 	memcpy(ctx->buf + sizeof(signed int), flatgeobuf_magicbytes, FLATGEOBUF_MAGICBYTES_SIZE);
 	ctx->offset = sizeof(signed int) + FLATGEOBUF_MAGICBYTES_SIZE;
 	// write new header
 	flatgeobuf_encode_header(ctx);
 	// calculate new offsets
 	uint64_t featureOffset = 0;
-	for (auto item : items) {
+	for (auto item : items)
 		auto featureItem = std::static_pointer_cast<FeatureItem>(item);
 		featureItem->nodeItem.offset = featureOffset;
 		featureOffset += featureItem->size;
 	// create and write index
 	PackedRTree tree(items, extent, ctx->index_node_size);
-	const auto writeData = [&ctx] (const void *data, const size_t size) {
+	const auto writeData = [&ctx](const void *data, const size_t size) {
 		memcpy(ctx->buf + ctx->offset, data, size);
 		ctx->offset += size;
 	tree.streamWrite(writeData);
 	// read items and write in sorted order
-		ctx->buf = (uint8_t *) lwrealloc(ctx->buf, ctx->offset + featureItem->size);
+		ctx->buf = (uint8_t *)lwrealloc(ctx->buf, ctx->offset + featureItem->size);
 		LWDEBUGF(2, "copy from offset %llu", featureItem->offset);
 		memcpy(ctx->buf + ctx->offset, oldbuf + featureItem->offset, featureItem->size);
 		ctx->offset += featureItem->size;
@@ -227,14 +261,16 @@ void flatgeobuf_create_index(ctx *ctx)
 	lwfree(oldbuf);
-int flatgeobuf_decode_feature(ctx *ctx)
+int
+flatgeobuf_decode_feature(ctx *ctx)
 	LWDEBUGF(2, "reading size prefix at %llu", ctx->offset);
 	auto size = flatbuffers::GetPrefixedSize(ctx->buf + ctx->offset);
 	LWDEBUGF(2, "size is %u (without size prefix)", size);
-	Verifier verifier(ctx->buf + ctx->offset, size);
+	Verifier verifier(ctx->buf + ctx->offset, flatgeobuf_size_prefixed_verifier_length(size));
 		return -1;
@@ -245,34 +281,46 @@ int flatgeobuf_decode_feature(ctx *ctx)
 	const auto geometry = feature->geometry();
-	if (geometry != nullptr) {
-		LWDEBUGF(3, "Constructing GeometryReader with geometry_type %d has_z %d haz_m %d", ctx->geometry_type, ctx->has_z, ctx->has_m);
-		GeometryReader reader(geometry, (GeometryType) ctx->geometry_type, ctx->has_z, ctx->has_m);
+	if (geometry != nullptr)
+		LWDEBUGF(3,
+			 "Constructing GeometryReader with geometry_type %d has_z %d haz_m %d",
+			 ctx->geometry_type,
+			 ctx->has_z,
+			 ctx->has_m);
+		GeometryReader reader(geometry, (GeometryType)ctx->geometry_type, ctx->has_z, ctx->has_m);
 		ctx->lwgeom = reader.read();
 		if (ctx->srid > 0)
 			lwgeom_set_srid(ctx->lwgeom, ctx->srid);
 		LWDEBUGG(3, ctx->lwgeom, "GeometryReader output LWGEOM");
-	} else {
+	else
 		ctx->lwgeom = NULL;
-	if (feature->properties() != nullptr && feature->properties()->size() != 0) {
-		ctx->properties = (uint8_t *) feature->properties()->data();
+	if (feature->properties() != nullptr && feature->properties()->size() != 0)
+		ctx->properties = (uint8_t *)feature->properties()->data();
 		ctx->properties_len = feature->properties()->size();
-	} else {
+	else
 		ctx->properties_len = 0;
 	return 0;
-int flatgeobuf_decode_header(ctx *ctx)
+int
+flatgeobuf_decode_header(ctx *ctx)
 		return -1;
@@ -283,7 +331,7 @@ int flatgeobuf_decode_header(ctx *ctx)
 	auto header = GetHeader(ctx->buf + ctx->offset);
-	ctx->geometry_type = (uint8_t) header->geometry_type();
+	ctx->geometry_type = (uint8_t)header->geometry_type();
 	ctx->features_count = header->features_count();
 	ctx->has_z = header->has_z();
 	ctx->has_m = header->has_m();
@@ -294,24 +342,41 @@ int flatgeobuf_decode_header(ctx *ctx)
 	if (crs != nullptr)
 		ctx->srid = crs->code();
 	auto columns = header->columns();
-	if (columns != nullptr) {
+	if (columns != nullptr)
 		auto size = columns->size();
-		ctx->columns = (flatgeobuf_column **) lwalloc(sizeof(flatgeobuf_column *) * size);
+		ctx->columns = (flatgeobuf_column **)lwalloc(sizeof(flatgeobuf_column *) * size);
 		ctx->columns_size = size;
-		for (uint32_t i = 0; i < size; i++) {
+		for (uint32_t i = 0; i < size; i++)
 			auto column = columns->Get(i);
-			ctx->columns[i] = (flatgeobuf_column *) lwalloc(sizeof(flatgeobuf_column));
+			ctx->columns[i] = (flatgeobuf_column *)lwalloc(sizeof(flatgeobuf_column));
 			memset(ctx->columns[i], 0, sizeof(flatgeobuf_column));
 			ctx->columns[i]->name = column->name()->c_str();
-			ctx->columns[i]->type = (uint8_t) column->type();
+			ctx->columns[i]->type = (uint8_t)column->type();
 	LWDEBUGF(2, "ctx->geometry_type: %d", ctx->geometry_type);
 	LWDEBUGF(2, "ctx->columns_len: %d", ctx->columns_size);
-	if (ctx->index_node_size > 0 && ctx->features_count > 0) {
-		auto treeSize = PackedRTree::size(ctx->features_count, ctx->index_node_size);
+	if (ctx->index_node_size > 0 && ctx->features_count > 0)
+		uint64_t treeSize;
+		try
+			treeSize = PackedRTree::size(ctx->features_count, ctx->index_node_size);
+		catch (const std::exception &e)
+			lwerror("flatgeobuf: invalid packed rtree metadata: %s", e.what());
+			return -1;
+		if (treeSize > ctx->size - ctx->offset)
+			lwerror("flatgeobuf: packed rtree exceeds remaining input");
+			return -1;
 		LWDEBUGF(2, "Adding tree size %llu to offset", treeSize);
 		ctx->offset += treeSize;
diff --git a/deps/flatgeobuf/geometryreader.cpp b/deps/flatgeobuf/geometryreader.cpp
index 06f30b1f16..413e56257c 100644
--- a/deps/flatgeobuf/geometryreader.cpp
+++ b/deps/flatgeobuf/geometryreader.cpp
@@ -27,92 +27,105 @@
-LWPOINT *GeometryReader::readPoint()
+LWPOINT *
+GeometryReader::readPoint()
 	POINTARRAY *pa;
 	POINT4D pt;
 	pa = ptarray_construct_empty(m_has_z, m_has_m, 1);
-	if (m_geometry->xy() == nullptr || m_geometry->xy()->size() == 0) {
+	if (m_geometry->xy() == nullptr || m_geometry->xy()->size() == 0)
 		return lwpoint_construct(0, NULL, pa);
-	const auto xy = m_geometry->xy()->data();
+	const auto xy = m_geometry->xy();
-	double x = xy[m_offset + 0];
-	double y = xy[m_offset + 1];
+	double x = xy->Get(m_offset + 0);
+	double y = xy->Get(m_offset + 1);
 	double z = 0;
 	double m = 0;
 	if (m_has_z)
-		z = m_geometry->z()->data()[m_offset];
+		z = m_geometry->z()->Get(m_offset);
 	if (m_has_m)
-		m = m_geometry->m()->data()[m_offset];
+		m = m_geometry->m()->Get(m_offset);
-	pt = (POINT4D) { x, y, z, m };
+	pt = (POINT4D){x, y, z, m};
 	ptarray_append_point(pa, &pt, LW_TRUE);
-POINTARRAY *GeometryReader::readPA()
+POINTARRAY *
+GeometryReader::readPA()
 	POINTARRAY *pa;
 	POINT4D pt;
-	uint32_t npoints;
-	const double *xy = m_geometry->xy()->data();
-	const double *z = m_has_z ? m_geometry->z()->data() : nullptr;
-	const double *m = m_has_m ? m_geometry->m()->data() : nullptr;
+	const auto z = m_has_z ? m_geometry->z() : nullptr;
+	const auto m = m_has_m ? m_geometry->m() : nullptr;
 	pa = ptarray_construct_empty(m_has_z, m_has_m, m_length);
-	for (uint32_t i = m_offset; i < m_offset + m_length; i++) {
-		double xv = xy[i * 2 + 0];
-		double yv = xy[i * 2 + 1];
+	for (uint32_t i = m_offset; i < m_offset + m_length; i++)
+		double xv = xy->Get(i * 2 + 0);
+		double yv = xy->Get(i * 2 + 1);
 		double zv = 0;
 		double mv = 0;
 		if (m_has_z)
-			zv = z[i];
+			zv = z->Get(i);
 		if (m_has_m)
-			mv = m[i];
-		pt = (POINT4D) { xv, yv, zv, mv };
+			mv = m->Get(i);
+		pt = (POINT4D){xv, yv, zv, mv};
 	return pa;
-LWMPOINT *GeometryReader::readMultiPoint()
+LWMPOINT *
+GeometryReader::readMultiPoint()
 	POINTARRAY *pa = readPA();
 	return lwmpoint_construct(0, pa);
-LWLINE *GeometryReader::readLineString()
+LWLINE *
+GeometryReader::readLineString()
 	return lwline_construct(0, NULL, pa);
-LWMLINE *GeometryReader::readMultiLineString()
+LWMLINE *
+GeometryReader::readMultiLineString()
 	auto ends = m_geometry->ends();
+	const uint32_t totalPoints = m_length;
 	uint32_t ngeoms = 1;
 	if (ends != nullptr && ends->size() > 1)
 		ngeoms = ends->size();
 	auto *lwmline = lwmline_construct_empty(0, m_has_z, m_has_m);
-	if (ngeoms > 1) {
-		for (uint32_t i = 0; i < ngeoms; i++) {
+	if (ngeoms > 1)
+		for (uint32_t i = 0; i < ngeoms; i++)
 			const auto e = ends->Get(i);
+			if (e < m_offset || e > totalPoints)
+				lwerror("flatgeobuf: invalid geometry ends");
 			m_length = e - m_offset;
 			lwmline_add_lwline(lwmline, lwline_construct(0, NULL, pa));
 			m_offset = e;
-	} else {
+	else
@@ -120,86 +133,125 @@ LWMLINE *GeometryReader::readMultiLineString()
 	return lwmline;
-LWPOLY *GeometryReader::readPolygon()
+LWPOLY *
+GeometryReader::readPolygon()
 	const auto ends = m_geometry->ends();
 	uint32_t nrings = 1;
 		nrings = ends->size();
-	auto **ppa = (POINTARRAY **) lwalloc(sizeof(POINTARRAY *) * nrings);
-	if (nrings > 1) {
-		for (uint32_t i = 0; i < nrings; i++) {
+	auto **ppa = (POINTARRAY **)lwalloc(sizeof(POINTARRAY *) * nrings);
+	if (nrings > 1)
+		for (uint32_t i = 0; i < nrings; i++)
 			ppa[i] = readPA();
 			m_offset = e;
-	} else {
+	else
 		ppa[0] = readPA();
 	return lwpoly_construct(0, NULL, nrings, ppa);
-LWMPOLY *GeometryReader::readMultiPolygon()
+LWMPOLY *
+GeometryReader::readMultiPolygon()
 	auto parts = m_geometry->parts();
+	if (parts == nullptr)
+		lwerror("flatgeobuf: missing geometry parts");
 	auto *mp = lwmpoly_construct_empty(0, m_has_z, m_has_m);
-	for (uoffset_t i = 0; i < parts->size(); i++) {
-		GeometryReader reader { parts->Get(i), GeometryType::Polygon, m_has_z, m_has_m };
-		const auto p = (LWPOLY *) reader.read();
+	for (uoffset_t i = 0; i < parts->size(); i++)
+		GeometryReader reader{parts->Get(i), GeometryType::Polygon, m_has_z, m_has_m};
+		const auto p = (LWPOLY *)reader.read();
 		lwmpoly_add_lwpoly(mp, p);
 	return mp;
-LWCOLLECTION *GeometryReader::readGeometryCollection()
+LWCOLLECTION *
+GeometryReader::readGeometryCollection()
 	auto *gc = lwcollection_construct_empty(COLLECTIONTYPE, 0, m_has_z, m_has_m);
 		auto part = parts->Get(i);
-		GeometryReader reader { part, part->type(), m_has_z, m_has_m };
+		GeometryReader reader{part, part->type(), m_has_z, m_has_m};
 		const auto g = reader.read();
 		lwcollection_add_lwgeom(gc, g);
 	return gc;
-LWGEOM *GeometryReader::read()
+LWGEOM *
+GeometryReader::read()
 	// nested types
-	switch (m_geometry_type) {
-		case GeometryType::GeometryCollection: return (LWGEOM *) readGeometryCollection();
-		case GeometryType::MultiPolygon: return (LWGEOM *) readMultiPolygon();
-		/*case GeometryType::CompoundCurve: return readCompoundCurve();
-		case GeometryType::CurvePolygon: return readCurvePolygon();
-		case GeometryType::MultiCurve: return readMultiCurve();
-		case GeometryType::MultiSurface: return readMultiSurface();
-		case GeometryType::PolyhedralSurface: return readPolyhedralSurface();*/
-		default: break;
+	switch (m_geometry_type)
+	case GeometryType::GeometryCollection:
+		return (LWGEOM *)readGeometryCollection();
+	case GeometryType::MultiPolygon:
+		return (LWGEOM *)readMultiPolygon();
+	/*case GeometryType::CompoundCurve: return readCompoundCurve();
+	case GeometryType::CurvePolygon: return readCurvePolygon();
+	case GeometryType::MultiCurve: return readMultiCurve();
+	case GeometryType::MultiSurface: return readMultiSurface();
+	case GeometryType::PolyhedralSurface: return readPolyhedralSurface();*/
+	default:
+		break;
 	// if not nested must have geometry data
 	const auto pXy = m_geometry->xy();
-	const auto xySize = pXy->size();
-	m_length = xySize / 2;
+	if (pXy == nullptr)
+		lwerror("flatgeobuf: missing geometry coordinates");
-		case GeometryType::Point: return (LWGEOM *) readPoint();
-		case GeometryType::MultiPoint: return (LWGEOM *) readMultiPoint();
-		case GeometryType::LineString: return (LWGEOM *) readLineString();
-		case GeometryType::MultiLineString: return (LWGEOM *) readMultiLineString();
-		case GeometryType::Polygon: return (LWGEOM *) readPolygon();
-		case GeometryType::CircularString: return readSimpleCurve<OGRCircularString>(true);
-		case GeometryType::Triangle: return readTriangle();
-		case GeometryType::TIN: return readTIN();
-		default:
-			lwerror("flatgeobuf: GeometryReader::read: Unknown type %d", (int) m_geometry_type);
+	const auto xySize = pXy->size();
+	if (xySize % 2 != 0)
+		lwerror("flatgeobuf: invalid xy coordinate count");
+	m_length = xySize / 2;
+	if (m_has_z && (m_geometry->z() == nullptr || m_geometry->z()->size() < m_length))
+		lwerror("flatgeobuf: invalid z coordinate count");
+	if (m_has_m && (m_geometry->m() == nullptr || m_geometry->m()->size() < m_length))
+		lwerror("flatgeobuf: invalid m coordinate count");
+	case GeometryType::Point:
+		return (LWGEOM *)readPoint();
+	case GeometryType::MultiPoint:
+		return (LWGEOM *)readMultiPoint();
+	case GeometryType::LineString:
+		return (LWGEOM *)readLineString();
+	case GeometryType::MultiLineString:
+		return (LWGEOM *)readMultiLineString();
+	case GeometryType::Polygon:
+		return (LWGEOM *)readPolygon();
+	case GeometryType::CircularString: return readSimpleCurve<OGRCircularString>(true);
+	case GeometryType::Triangle: return readTriangle();
+	case GeometryType::TIN: return readTIN();
+	default:
+		lwerror("flatgeobuf: GeometryReader::read: Unknown type %d", (int)m_geometry_type);
 	return nullptr;
\ No newline at end of file
diff --git a/postgis/flatgeobuf.c b/postgis/flatgeobuf.c
index dc4621ebad..ee0ce6b50c 100644
--- a/postgis/flatgeobuf.c
+++ b/postgis/flatgeobuf.c
@@ -33,7 +33,122 @@
 #include "utils/datetime.h"
 #include "utils/jsonb.h"
-static uint8_t get_column_type(Oid typoid) {
+static uint16_t
+flatgeobuf_le16(uint16_t v)
+#if IS_BIG_ENDIAN
+	return (uint16_t)((v << 8) | (v >> 8));
+#else
+	return v;
+#endif
+static uint32_t
+flatgeobuf_le32(uint32_t v)
+#if IS_BIG_ENDIAN
+	return ((v & UINT32_C(0x000000ff)) << 24) | ((v & UINT32_C(0x0000ff00)) << 8) |
+	       ((v & UINT32_C(0x00ff0000)) >> 8) | ((v & UINT32_C(0xff000000)) >> 24);
+#else
+	return v;
+#endif
+static uint64_t
+flatgeobuf_le64(uint64_t v)
+#if IS_BIG_ENDIAN
+	return ((v & UINT64_C(0x00000000000000ff)) << 56) | ((v & UINT64_C(0x000000000000ff00)) << 40) |
+	       ((v & UINT64_C(0x0000000000ff0000)) << 24) | ((v & UINT64_C(0x00000000ff000000)) << 8) |
+	       ((v & UINT64_C(0x000000ff00000000)) >> 8) | ((v & UINT64_C(0x0000ff0000000000)) >> 24) |
+	       ((v & UINT64_C(0x00ff000000000000)) >> 40) | ((v & UINT64_C(0xff00000000000000)) >> 56);
+#else
+	return v;
+#endif
+static void
+flatgeobuf_write_le16(uint8_t *dst, uint16_t v)
+	v = flatgeobuf_le16(v);
+	memcpy(dst, &v, sizeof(v));
+static void
+flatgeobuf_write_le32(uint8_t *dst, uint32_t v)
+	v = flatgeobuf_le32(v);
+static void
+flatgeobuf_write_le64(uint8_t *dst, uint64_t v)
+	v = flatgeobuf_le64(v);
+static uint16_t
+flatgeobuf_read_le16(const uint8_t *src)
+	uint16_t v;
+	memcpy(&v, src, sizeof(v));
+	return flatgeobuf_le16(v);
+static uint32_t
+flatgeobuf_read_le32(const uint8_t *src)
+	uint32_t v;
+	return flatgeobuf_le32(v);
+static uint64_t
+flatgeobuf_read_le64(const uint8_t *src)
+	uint64_t v;
+	return flatgeobuf_le64(v);
+static float
+flatgeobuf_read_float_le(const uint8_t *src)
+	uint32_t bits = flatgeobuf_read_le32(src);
+	float value;
+	memcpy(&value, &bits, sizeof(value));
+	return value;
+static double
+flatgeobuf_read_double_le(const uint8_t *src)
+	uint64_t bits = flatgeobuf_read_le64(src);
+	double value;
+	return value;
+static void
+flatgeobuf_write_float_le(uint8_t *dst, float value)
+	uint32_t bits;
+	memcpy(&bits, &value, sizeof(bits));
+	flatgeobuf_write_le32(dst, bits);
+static void
+flatgeobuf_write_double_le(uint8_t *dst, double value)
+	uint64_t bits;
+	flatgeobuf_write_le64(dst, bits);
+static uint8_t
+get_column_type(Oid typoid)
 	switch (typoid)
 	case BOOLOID:
@@ -61,11 +176,11 @@ static uint8_t get_column_type(Oid typoid) {
 	case TIMESTAMPTZOID:
 		return flatgeobuf_column_type_datetime;
-	elog(ERROR, "flatgeobuf: get_column_type: '%d' column type not supported",
-		typoid);
+	elog(ERROR, "flatgeobuf: get_column_type: '%d' column type not supported", typoid);
-static void inspect_table(struct flatgeobuf_agg_ctx *ctx)
+static void
+inspect_table(struct flatgeobuf_agg_ctx *ctx)
 	flatgeobuf_column *c;
 	flatgeobuf_column **columns;
@@ -83,18 +198,24 @@ static void inspect_table(struct flatgeobuf_agg_ctx *ctx)
 	// inspect columns
 	// NOTE: last element will be unused if geom attr is found
-	for (int i = 0; i < natts; i++) {
+	for (int i = 0; i < natts; i++)
 		Oid typoid = getBaseType(TupleDescAttr(tupdesc, i)->atttypid);
 		const char *key = TupleDescAttr(tupdesc, i)->attname.data;
 		POSTGIS_DEBUGF(2, "inspecting column definition for %s with oid %d", key, typoid);
-		if (ctx->geom_name == NULL) {
-			if (!geom_found && typoid == postgis_oid(GEOMETRYOID)) {
+		if (ctx->geom_name == NULL)
+			if (!geom_found && typoid == postgis_oid(GEOMETRYOID))
 				ctx->geom_index = i;
 				geom_found = true;
 				continue;
-		} else {
-			if (!geom_found && strcmp(key, ctx->geom_name) == 0) {
+		else
+			if (!geom_found && strcmp(key, ctx->geom_name) == 0)
 				geom_found = true;
 				continue;
@@ -102,7 +223,7 @@ static void inspect_table(struct flatgeobuf_agg_ctx *ctx)
 		POSTGIS_DEBUGF(2, "creating column definition for %s with oid %d", key, typoid);
-		c = (flatgeobuf_column *) palloc0(sizeof(flatgeobuf_column));
+		c = (flatgeobuf_column *)palloc0(sizeof(flatgeobuf_column));
 		c->name = pstrdup(key);
 		c->type = get_column_type(typoid);
 		columns[columns_size] = c;
@@ -112,21 +233,25 @@ static void inspect_table(struct flatgeobuf_agg_ctx *ctx)
 	if (!geom_found)
 		elog(ERROR, "no geom column found");
-	if (columns_size > 0) {
+	if (columns_size > 0)
 		ctx->ctx->columns = columns;
 		ctx->ctx->columns_size = columns_size;
 // ensure properties has room for at least size
-static void ensure_properties_size(struct flatgeobuf_agg_ctx *ctx, size_t size)
+static void
+ensure_properties_size(struct flatgeobuf_agg_ctx *ctx, size_t size)
-	if (ctx->ctx->properties_size == 0) {
+	if (ctx->ctx->properties_size == 0)
 		ctx->ctx->properties_size = 1024 * 4;
 		POSTGIS_DEBUGF(2, "flatgeobuf: properties buffer to size %d", ctx->ctx->properties_size);
 		ctx->ctx->properties = palloc(ctx->ctx->properties_size);
-	if (ctx->ctx->properties_size < size) {
+	if (ctx->ctx->properties_size < size)
 		ctx->ctx->properties_size = ctx->ctx->properties_size * 2;
 		POSTGIS_DEBUGF(2, "flatgeobuf: reallocating properties buffer to size %d", ctx->ctx->properties_size);
 		ctx->ctx->properties = repalloc(ctx->ctx->properties, ctx->ctx->properties_size);
@@ -135,13 +260,16 @@ static void ensure_properties_size(struct flatgeobuf_agg_ctx *ctx, size_t size)
 // ensure items have room for at least ctx->ctx->features_count + 1
-static void ensure_items_len(struct flatgeobuf_agg_ctx *ctx)
+static void
+ensure_items_len(struct flatgeobuf_agg_ctx *ctx)
-	if (ctx->ctx->features_count == 0) {
+	if (ctx->ctx->features_count == 0)
 		ctx->ctx->items_len = 32;
 		ctx->ctx->items = palloc(sizeof(flatgeobuf_item *) * ctx->ctx->items_len);
-	if (ctx->ctx->items_len < (ctx->ctx->features_count + 1)) {
+	if (ctx->ctx->items_len < (ctx->ctx->features_count + 1))
 		ctx->ctx->items_len = ctx->ctx->items_len * 2;
 		POSTGIS_DEBUGF(2, "flatgeobuf: reallocating items to len %lld", ctx->ctx->items_len);
 		ctx->ctx->items = repalloc(ctx->ctx->items, sizeof(flatgeobuf_item *) * ctx->ctx->items_len);
@@ -149,7 +277,8 @@ static void ensure_items_len(struct flatgeobuf_agg_ctx *ctx)
-static void encode_properties(flatgeobuf_agg_ctx *ctx)
+static void
+encode_properties(flatgeobuf_agg_ctx *ctx)
 	uint16_t ci = 0;
 	size_t offset = 0;
@@ -167,19 +296,21 @@ static void encode_properties(flatgeobuf_agg_ctx *ctx)
 	double double_value;
 	char *string_value;
-	//Jsonb *jb;
+	// Jsonb *jb;
-	for (i = 0; i < (uint32_t) ctx->tupdesc->natts; i++) {
+	for (i = 0; i < (uint32_t)ctx->tupdesc->natts; i++)
 		if (ctx->geom_index == i)
 			continue;
 		datum = GetAttributeByNum(ctx->row, i + 1, &isnull);
 		if (isnull)
 			continue;
 		ensure_properties_size(ctx, offset + sizeof(ci));
-		memcpy(ctx->ctx->properties + offset, &ci, sizeof(ci));
+		flatgeobuf_write_le16(ctx->ctx->properties + offset, ci);
 		offset += sizeof(ci);
 		typoid = getBaseType(TupleDescAttr(ctx->tupdesc, i)->atttypid);
-		switch (typoid) {
+		switch (typoid)
 		case BOOLOID:
 			byte_value = DatumGetBool(datum) ? 1 : 0;
 			ensure_properties_size(ctx, offset + sizeof(byte_value));
@@ -189,38 +320,38 @@ static void encode_properties(flatgeobuf_agg_ctx *ctx)
 		case INT2OID:
 			short_value = DatumGetInt16(datum);
 			ensure_properties_size(ctx, offset + sizeof(short_value));
-			memcpy(ctx->ctx->properties + offset, &short_value, sizeof(short_value));
+			flatgeobuf_write_le16(ctx->ctx->properties + offset, (uint16_t)short_value);
 			offset += sizeof(short_value);
 			break;
 		case INT4OID:
 			int_value = DatumGetInt32(datum);
 			ensure_properties_size(ctx, offset + sizeof(int_value));
-			memcpy(ctx->ctx->properties + offset, &int_value, sizeof(int_value));
+			flatgeobuf_write_le32(ctx->ctx->properties + offset, (uint32_t)int_value);
 			offset += sizeof(int_value);
 			break;
 		case INT8OID:
 			long_value = DatumGetInt64(datum);
 			ensure_properties_size(ctx, offset + sizeof(long_value));
-			memcpy(ctx->ctx->properties + offset, &long_value, sizeof(long_value));
+			flatgeobuf_write_le64(ctx->ctx->properties + offset, (uint64_t)long_value);
 			offset += sizeof(long_value);
 			break;
 		case FLOAT4OID:
 			float_value = DatumGetFloat4(datum);
 			ensure_properties_size(ctx, offset + sizeof(float_value));
-			memcpy(ctx->ctx->properties + offset, &float_value, sizeof(float_value));
+			flatgeobuf_write_float_le(ctx->ctx->properties + offset, float_value);
 			offset += sizeof(float_value);
 			break;
 		case FLOAT8OID:
 			double_value = DatumGetFloat8(datum);
 			ensure_properties_size(ctx, offset + sizeof(double_value));
-			memcpy(ctx->ctx->properties + offset, &double_value, sizeof(double_value));
+			flatgeobuf_write_double_le(ctx->ctx->properties + offset, double_value);
 			offset += sizeof(double_value);
 			break;
 		case TEXTOID:
 			string_value = text_to_cstring(DatumGetTextP(datum));
 			len = strlen(string_value);
 			ensure_properties_size(ctx, offset + sizeof(len));
-			memcpy(ctx->ctx->properties + offset, &len, sizeof(len));
+			flatgeobuf_write_le32(ctx->ctx->properties + offset, len);
 			offset += sizeof(len);
 			ensure_properties_size(ctx, offset + len);
 			memcpy(ctx->ctx->properties + offset, string_value, len);
@@ -238,45 +369,70 @@ static void encode_properties(flatgeobuf_agg_ctx *ctx)
 			EncodeDateTime(&tm, fsec, true, tz, tzn, USE_ISO_DATES, string_value);
 			offset += len;
 			break;
-		// TODO: handle date/time types
-		// case JSONBOID:
-		// 	jb = DatumGetJsonbP(datum);
-		// 	string_value = JsonbToCString(NULL, &jb->root, VARSIZE(jb));
-		// 	len = strlen(string_value);
-		// 	memcpy(data + offset, &len, sizeof(len));
-		// 	offset += sizeof(len);
-		// 	memcpy(data + offset, string_value, len);
-		// 	offset += len;
-		// 	break;
+			// TODO: handle date/time types
+			// case JSONBOID:
+			// 	jb = DatumGetJsonbP(datum);
+			// 	string_value = JsonbToCString(NULL, &jb->root, VARSIZE(jb));
+			// 	len = strlen(string_value);
+			// 	memcpy(data + offset, &len, sizeof(len));
+			// 	offset += sizeof(len);
+			// 	memcpy(data + offset, string_value, len);
+			// 	offset += len;
+			// 	break;
 		ci++;
-	if (offset > 0) {
+	if (offset > 0)
 		POSTGIS_DEBUGF(3, "offset %ld", offset);
 		ctx->ctx->properties_len = offset;
-void flatgeobuf_check_magicbytes(struct flatgeobuf_decode_ctx *ctx)
+void
+flatgeobuf_check_magicbytes(struct flatgeobuf_decode_ctx *ctx)
-	uint8_t *buf = ctx->ctx->buf + ctx->ctx->offset;
+	uint8_t *buf;
 	uint32_t i;
+	if (ctx->ctx->offset > ctx->ctx->size || FLATGEOBUF_MAGICBYTES_SIZE > ctx->ctx->size - ctx->ctx->offset)
+		elog(ERROR, "Data is not FlatGeobuf");
+	buf = ctx->ctx->buf + ctx->ctx->offset;
 	for (i = 0; i < FLATGEOBUF_MAGICBYTES_SIZE / 2; i++)
 		if (buf[i] != flatgeobuf_magicbytes[i])
 	ctx->ctx->offset += FLATGEOBUF_MAGICBYTES_SIZE;
-static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values, bool *isnull)
+void
+flatgeobuf_check_sizeprefix(flatgeobuf_ctx *ctx)
+	uint64_t remaining;
+	uint32_t size;
+	if (ctx->offset > ctx->size)
+		elog(ERROR, "flatgeobuf: read past end of input");
+	remaining = ctx->size - ctx->offset;
+	if (remaining < sizeof(uint32_t))
+		elog(ERROR, "flatgeobuf: truncated size prefix");
+	size = flatgeobuf_read_le32(ctx->buf + ctx->offset);
+	if ((uint64_t)size > remaining - sizeof(uint32_t))
+		elog(ERROR, "flatgeobuf: size prefix exceeds remaining input");
+static void
+decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values, bool *isnull)
 	uint16_t i, ci;
 	flatgeobuf_column *column;
@@ -289,10 +445,11 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 	if (size > 0 && size < (sizeof(uint16_t) + sizeof(uint8_t)))
 		elog(ERROR, "flatgeobuf: decode_properties: Unexpected properties data size %d", size);
-	while (offset + 1 < size) {
+	while (offset + 1 < size)
 		if (offset + sizeof(uint16_t) > size)
 			elog(ERROR, "flatgeobuf: decode_properties: Unexpected offset %d", offset);
-		memcpy(&i, data + offset, sizeof(uint16_t));
+		i = flatgeobuf_read_le16(data + offset);
 		ci = i + 2;
 		offset += sizeof(uint16_t);
 		if (i >= ctx->ctx->columns_size)
@@ -300,7 +457,8 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 		column = ctx->ctx->columns[i];
 		type = column->type;
 		isnull[ci] = false;
-		switch (type) {
+		switch (type)
 		case flatgeobuf_column_type_bool: {
 			uint8_t value;
 			if (offset + sizeof(uint8_t) > size)
@@ -332,7 +490,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			int16_t value;
 			if (offset + sizeof(int16_t) > size)
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for short value");
-			memcpy(&value, data + offset, sizeof(int16_t));
+			value = (int16_t)flatgeobuf_read_le16(data + offset);
 			values[ci] = Int16GetDatum(value);
 			offset += sizeof(int16_t);
 			break;
@@ -341,7 +499,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			uint16_t value;
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for ushort value");
-			memcpy(&value, data + offset, sizeof(uint16_t));
+			value = flatgeobuf_read_le16(data + offset);
 			values[ci] = UInt16GetDatum(value);
 			break;
@@ -350,7 +508,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			int32_t value;
 			if (offset + sizeof(int32_t) > size)
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for int value");
-			memcpy(&value, data + offset, sizeof(int32_t));
+			value = (int32_t)flatgeobuf_read_le32(data + offset);
 			values[ci] = Int32GetDatum(value);
 			offset += sizeof(int32_t);
 			break;
@@ -359,8 +517,8 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			uint32_t value;
 			if (offset + sizeof(uint32_t) > size)
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for uint value");
-			memcpy(&value, data + offset, sizeof(uint32_t));
-			values[ci] = Int64GetDatum((int64_t)(uint64_t) value);
+			value = flatgeobuf_read_le32(data + offset);
+			values[ci] = Int64GetDatum((int64_t)(uint64_t)value);
 			offset += sizeof(uint32_t);
 			break;
@@ -368,7 +526,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			int64_t value;
 			if (offset + sizeof(int64_t) > size)
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for long value");
-			memcpy(&value, data + offset, sizeof(int64_t));
+			value = (int64_t)flatgeobuf_read_le64(data + offset);
 			values[ci] = Int64GetDatum(value);
 			offset += sizeof(int64_t);
 			break;
@@ -377,7 +535,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			uint64_t value;
 			if (offset + sizeof(uint64_t) > size)
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for ulong value");
-			memcpy(&value, data + offset, sizeof(uint64_t));
+			value = flatgeobuf_read_le64(data + offset);
 			values[ci] = UInt64GetDatum(value);
 			offset += sizeof(uint64_t);
 			break;
@@ -386,7 +544,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			float value;
 			if (offset + sizeof(float) > size)
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for float value");
-			memcpy(&value, data + offset, sizeof(float));
+			value = flatgeobuf_read_float_le(data + offset);
 			values[ci] = Float4GetDatum(value);
 			offset += sizeof(float);
 			break;
@@ -395,7 +553,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			double value;
 			if (offset + sizeof(double) > size)
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for double value");
-			memcpy(&value, data + offset, sizeof(double));
+			value = flatgeobuf_read_double_le(data + offset);
 			values[ci] = Float8GetDatum(value);
 			offset += sizeof(double);
 			break;
@@ -404,9 +562,11 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			uint32_t len;
 			if (offset + sizeof(len) > size)
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for string value");
-			memcpy(&len, data + offset, sizeof(uint32_t));
+			len = flatgeobuf_read_le32(data + offset);
-			values[ci] = PointerGetDatum(cstring_to_text_with_len((const char *) data + offset, len));
+			if (len > size - offset)
+				elog(ERROR, "flatgeobuf: decode_properties: string length exceeds buffer");
+			values[ci] = PointerGetDatum(cstring_to_text_with_len((const char *)data + offset, len));
 			offset += len;
 			break;
@@ -426,12 +586,14 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			DateTimeErrorExtra extra;
 #endif
-				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for string value");
+				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for datetime value");
-			buf = palloc0(len + 1);
-			memcpy(buf, (const char *) data + offset, len);
-			ParseDateTime((const char *) buf, workbuf, sizeof(workbuf), field, ftype, MAXDATEFIELDS, &nf);
+				elog(ERROR, "flatgeobuf: decode_properties: datetime length exceeds buffer");
+			buf = palloc0((Size)len + 1);
+			memcpy(buf, (const char *)data + offset, len);
+			ParseDateTime((const char *)buf, workbuf, sizeof(workbuf), field, ftype, MAXDATEFIELDS, &nf);
 #if POSTGIS_PGSQL_VERSION >= 160
 			DecodeDateTime(field, ftype, nf, &dtype, tm, &fsec, &tzp, &extra);
@@ -456,28 +618,33 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			elog(ERROR, "flatgeobuf: decode_properties: Unknown type %d", type);
-void flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx)
+void
+flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx)
 	HeapTuple heapTuple;
 	uint32_t natts = ctx->tupdesc->natts;
 	Datum *values = palloc0(natts * sizeof(Datum));
 	bool *isnull = palloc(natts * sizeof(bool));
-	for (uint32_t j = 0; j < natts; j++) isnull[j] = true;
+	for (uint32_t j = 0; j < natts; j++)
+		isnull[j] = true;
 	isnull[0] = false;
 	values[0] = Int32GetDatum(ctx->fid);
+	flatgeobuf_check_sizeprefix(ctx->ctx);
 	if (flatgeobuf_decode_feature(ctx->ctx))
 		elog(ERROR, "flatgeobuf_decode_feature: unsuccessful");
-	if (ctx->ctx->lwgeom != NULL) {
+	if (ctx->ctx->lwgeom != NULL)
 		values[1] = PointerGetDatum(geometry_serialize(ctx->ctx->lwgeom));
 		isnull[1] = false;
-	} else {
+	else
 		POSTGIS_DEBUG(3, "geometry is null");
 		isnull[1] = true;
@@ -491,7 +658,11 @@ void flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx)
 	POSTGIS_DEBUGF(3, "fid now %d", ctx->fid);
-	if (ctx->ctx->offset == ctx->ctx->size) {
+	if (ctx->ctx->offset > ctx->ctx->size)
+		elog(ERROR, "flatgeobuf_decode_row: read past end of input");
+	if (ctx->ctx->offset == ctx->ctx->size)
 		POSTGIS_DEBUGF(3, "reached end at %lld", ctx->ctx->offset);
 		ctx->done = true;
@@ -500,7 +671,8 @@ void flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx)
  * Initialize aggregation context.
-struct flatgeobuf_agg_ctx *flatgeobuf_agg_ctx_init(const char *geom_name, const bool create_index)
+struct flatgeobuf_agg_ctx *
+flatgeobuf_agg_ctx_init(const char *geom_name, const bool create_index)
 	struct flatgeobuf_agg_ctx *ctx;
 	size_t size = VARHDRSZ + FLATGEOBUF_MAGICBYTES_SIZE;
@@ -524,7 +696,8 @@ struct flatgeobuf_agg_ctx *flatgeobuf_agg_ctx_init(const char *geom_name, const
  * Allocates a new feature, increment feature counter and
  * encode properties into it.
-void flatgeobuf_agg_transfn(struct flatgeobuf_agg_ctx *ctx)
+void
+flatgeobuf_agg_transfn(struct flatgeobuf_agg_ctx *ctx)
 	LWGEOM *lwgeom = NULL;
 	bool isnull = false;
@@ -535,8 +708,9 @@ void flatgeobuf_agg_transfn(struct flatgeobuf_agg_ctx *ctx)
 		inspect_table(ctx);
 	datum = GetAttributeByNum(ctx->row, ctx->geom_index + 1, &isnull);
-	if (!isnull) {
-		gs = (GSERIALIZED *) PG_DETOAST_DATUM_COPY(datum);
+	if (!isnull)
+		gs = (GSERIALIZED *)PG_DETOAST_DATUM_COPY(datum);
 		lwgeom = lwgeom_from_gserialized(gs);
 	ctx->ctx->lwgeom = lwgeom;
@@ -555,15 +729,19 @@ void flatgeobuf_agg_transfn(struct flatgeobuf_agg_ctx *ctx)
  * Encode into Data message and return it packed as a bytea.
-uint8_t *flatgeobuf_agg_finalfn(struct flatgeobuf_agg_ctx *ctx)
+uint8_t *
+flatgeobuf_agg_finalfn(struct flatgeobuf_agg_ctx *ctx)
 	POSTGIS_DEBUGF(3, "called at offset %lld", ctx->ctx->offset);
 	if (ctx == NULL)
 		flatgeobuf_agg_ctx_init(NULL, false);
 	// header only result
 		flatgeobuf_encode_header(ctx->ctx);
-	} else if (ctx->ctx->create_index) {
+	else if (ctx->ctx->create_index)
 		ctx->ctx->index_node_size = 16;
 		flatgeobuf_create_index(ctx->ctx);
diff --git a/postgis/flatgeobuf.h b/postgis/flatgeobuf.h
index c3b13cb6cc..ddad548556 100644
--- a/postgis/flatgeobuf.h
+++ b/postgis/flatgeobuf.h
@@ -43,8 +43,7 @@
 #include "lwgeom_log.h"
 #include "flatgeobuf_c.h"
-typedef struct flatgeobuf_agg_ctx
+typedef struct flatgeobuf_agg_ctx {
 	flatgeobuf_ctx *ctx;
 	const char *geom_name;
 	uint32_t geom_index;
@@ -52,13 +51,11 @@ typedef struct flatgeobuf_agg_ctx
 	HeapTupleHeader row;
 } flatgeobuf_agg_ctx;
 flatgeobuf_agg_ctx *flatgeobuf_agg_ctx_init(const char *geom_name, const bool create_index);
 void flatgeobuf_agg_transfn(flatgeobuf_agg_ctx *ctx);
 uint8_t *flatgeobuf_agg_finalfn(flatgeobuf_agg_ctx *ctx);
-typedef struct flatgeobuf_decode_ctx
+typedef struct flatgeobuf_decode_ctx {
 	TupleDesc tupdesc;
 	Datum result;
@@ -68,6 +65,7 @@ typedef struct flatgeobuf_decode_ctx
 } flatgeobuf_decode_ctx;
 void flatgeobuf_check_magicbytes(struct flatgeobuf_decode_ctx *ctx);
+void flatgeobuf_check_sizeprefix(flatgeobuf_ctx *ctx);
 void flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx);
 #endif
diff --git a/postgis/lwgeom_in_flatgeobuf.c b/postgis/lwgeom_in_flatgeobuf.c
index 235fbbeed8..a71a30abbc 100644
--- a/postgis/lwgeom_in_flatgeobuf.c
+++ b/postgis/lwgeom_in_flatgeobuf.c
@@ -22,7 +22,6 @@
 #include <assert.h>
 #include "postgres.h"
@@ -36,8 +35,11 @@
 #include <utils/builtins.h>
 #include "flatgeobuf.h"
-static char *get_pgtype(uint8_t column_type) {
-	switch (column_type) {
+static char *
+get_pgtype(uint8_t column_type)
+	switch (column_type)
 		return "boolean";
 	case flatgeobuf_column_type_byte:
@@ -71,11 +73,21 @@ static const char *
 flatgeobuf_type_name(uint8_t fgb_type)
 	/* Names match FlatGeobuf::EnumNamesColumnType() in header_generated.h */
-	static const char * const names[] = {
-		"Byte", "UByte", "Bool", "Short", "UShort",
-		"Int", "UInt", "Long", "ULong",
-		"Float", "Double", "String", "Json", "DateTime", "Binary"
+	static const char *const names[] = {"Byte",
+					    "UByte",
+					    "Bool",
+					    "Short",
+					    "UShort",
+					    "Int",
+					    "UInt",
+					    "Long",
+					    "ULong",
+					    "Float",
+					    "Double",
+					    "String",
+					    "Json",
+					    "DateTime",
+					    "Binary"};
 	if (fgb_type >= sizeof(names) / sizeof(names[0]))
 		return "unknown";
 	return names[fgb_type];
@@ -106,8 +118,7 @@ flatgeobuf_type_compatible(uint8_t fgb_type, Oid pgtype)
 	case flatgeobuf_column_type_string:
 		return pgtype == TEXTOID || pgtype == VARCHAROID;
 	case flatgeobuf_column_type_datetime:
-		return pgtype == DATEOID || pgtype == TIMEOID ||
-		       pgtype == TIMESTAMPOID || pgtype == TIMESTAMPTZOID;
+		return pgtype == DATEOID || pgtype == TIMEOID || pgtype == TIMESTAMPOID || pgtype == TIMESTAMPTZOID;
 	case flatgeobuf_column_type_json:
 		return pgtype == JSONBOID;
 	case flatgeobuf_column_type_binary:
@@ -117,7 +128,8 @@ flatgeobuf_type_compatible(uint8_t fgb_type, Oid pgtype)
 PG_FUNCTION_INFO_V1(pgis_tablefromflatgeobuf);
-Datum pgis_tablefromflatgeobuf(PG_FUNCTION_ARGS)
+Datum
+pgis_tablefromflatgeobuf(PG_FUNCTION_ARGS)
 	struct flatgeobuf_decode_ctx *ctx;
 	text *schema_input;
@@ -150,14 +162,16 @@ Datum pgis_tablefromflatgeobuf(PG_FUNCTION_ARGS)
 	ctx->ctx->offset = 0;
 	flatgeobuf_check_magicbytes(ctx);
 	flatgeobuf_decode_header(ctx->ctx);
 	initStringInfo(&sql);
-	appendStringInfo(&sql, "create table %s.%s (id int, geom geometry",
-		quote_identifier(schema), quote_identifier(table));
+	appendStringInfo(
+	    &sql, "create table %s.%s (id int, geom geometry", quote_identifier(schema), quote_identifier(table));
 	POSTGIS_DEBUGF(2, "found %d columns", ctx->ctx->columns_size);
-	for (i = 0; i < ctx->ctx->columns_size; i++) {
+	for (i = 0; i < ctx->ctx->columns_size; i++)
 		flatgeobuf_column *column = ctx->ctx->columns[i];
 		const char *name = column->name;
 		uint8_t column_type = column->type;
@@ -187,7 +201,8 @@ Datum pgis_tablefromflatgeobuf(PG_FUNCTION_ARGS)
 // https://stackoverflow.com/questions/11740256/refactor-a-pl-pgsql-function-to-return-the-output-of-various-select-queries
 PG_FUNCTION_INFO_V1(pgis_fromflatgeobuf);
-Datum pgis_fromflatgeobuf(PG_FUNCTION_ARGS)
+Datum
+pgis_fromflatgeobuf(PG_FUNCTION_ARGS)
 	FuncCallContext *funcctx;
@@ -197,7 +212,8 @@ Datum pgis_fromflatgeobuf(PG_FUNCTION_ARGS)
-	if (SRF_IS_FIRSTCALL()) {
+	if (SRF_IS_FIRSTCALL())
 		funcctx = SRF_FIRSTCALL_INIT();
 		oldcontext = MemoryContextSwitchTo(funcctx->multi_call_memory_ctx);
@@ -205,8 +221,14 @@ Datum pgis_fromflatgeobuf(PG_FUNCTION_ARGS)
 		if (get_call_result_type(fcinfo, NULL, &tupdesc) != TYPEFUNC_COMPOSITE)
 			ereport(ERROR,
-					(errcode(ERRCODE_FEATURE_NOT_SUPPORTED),
-					 errmsg("first argument of function must be composite type")));
+				(errcode(ERRCODE_FEATURE_NOT_SUPPORTED),
+				 errmsg("first argument of function must be composite type")));
+		if (PG_ARGISNULL(1))
+			MemoryContextSwitchTo(oldcontext);
+			SRF_RETURN_DONE(funcctx);
 		data = PG_GETARG_BYTEA_PP(1);
@@ -223,18 +245,21 @@ Datum pgis_fromflatgeobuf(PG_FUNCTION_ARGS)
 		funcctx->user_fctx = ctx;
-		if (ctx->ctx->size == 0) {
+		if (ctx->ctx->size == 0)
 			POSTGIS_DEBUG(2, "no data");
 		POSTGIS_DEBUGF(2, "header decoded now at offset %lld", ctx->ctx->offset);
-		if (ctx->ctx->size == ctx->ctx->offset) {
+		if (ctx->ctx->size == ctx->ctx->offset)
 			POSTGIS_DEBUGF(2, "no feature data offset %lld", ctx->ctx->offset);
@@ -246,8 +271,9 @@ Datum pgis_fromflatgeobuf(PG_FUNCTION_ARGS)
 			ereport(ERROR,
 				(errcode(ERRCODE_DATATYPE_MISMATCH),
 				 errmsg("flatgeobuf: column count mismatch: "
-				        "file has %u columns, target type has %d",
-				        ctx->ctx->columns_size, tupdesc->natts - 2)));
+					"file has %u columns, target type has %d",
+					ctx->ctx->columns_size,
+					tupdesc->natts - 2)));
 		for (uint16_t col_i = 0; col_i < ctx->ctx->columns_size; col_i++)
@@ -257,10 +283,10 @@ Datum pgis_fromflatgeobuf(PG_FUNCTION_ARGS)
 				ereport(ERROR,
 					 errmsg("flatgeobuf: column \"%s\" type mismatch: "
-					        "file type \"%s\" is not compatible with PostgreSQL type %s",
-					        col->name,
-					        flatgeobuf_type_name(col->type),
-					        format_type_be(pgtype))));
+						"file type \"%s\" is not compatible with PostgreSQL type %s",
+						col->name,
+						flatgeobuf_type_name(col->type),
+						format_type_be(pgtype))));
@@ -269,11 +295,14 @@ Datum pgis_fromflatgeobuf(PG_FUNCTION_ARGS)
 	funcctx = SRF_PERCALL_SETUP();
 	ctx = funcctx->user_fctx;
-	if (!ctx->done) {
+	if (!ctx->done)
 		flatgeobuf_decode_row(ctx);
 		POSTGIS_DEBUG(2, "Calling SRF_RETURN_NEXT");
 		SRF_RETURN_NEXT(funcctx, ctx->result);
-	} else {
+	else
 		POSTGIS_DEBUG(2, "Calling SRF_RETURN_DONE");
diff --git a/regress/core/flatgeobuf.sql b/regress/core/flatgeobuf.sql
index df46eca1e4..6d8ba9148e 100644
--- a/regress/core/flatgeobuf.sql
+++ b/regress/core/flatgeobuf.sql
@@ -158,6 +158,35 @@ select 'E1', id, bool_1, ST_AsText(geom), bool_2 from ST_FromFlatGeobuf(null::fl
     ) q)
+select '--- Type mismatch detection ---';
+-- Setup: a long (bigint) column and a text column in separate tables
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_mm_long', (select ST_AsFlatGeobuf(q) fgb from (select
+    null::geometry, null::bigint as val) q));
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_mm_text', (select ST_AsFlatGeobuf(q) fgb from (select
+    null::geometry, null::text as val) q));
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_mm_twocols', (select ST_AsFlatGeobuf(q) fgb from (select
+    null::geometry, null::bigint as val1, null::bigint as val2) q));
+-- Type mismatch: file has bigint (long), target expects text
+select 'MM1' from ST_FromFlatGeobuf(null::flatgeobuf_mm_text, (
+    select ST_AsFlatGeobuf(q) fgb from (select null::geometry, 42::bigint as val) q));
+-- Count mismatch: file has 2 property columns, target type has 1
+select 'MM2' from ST_FromFlatGeobuf(null::flatgeobuf_mm_long, (
+    select ST_AsFlatGeobuf(q) fgb from (select null::geometry, 42::bigint as val1, 43::bigint as val2) q));
+select '--- Malformed input detection ---';
+-- Magic bytes plus a truncated size prefix.
+select 'MI1' from ST_FromFlatGeobuf(null::flatgeobuf_t1, '\x6667620366676201010203'::bytea);
+-- Valid magic bytes plus a header size prefix that exceeds the remaining input.
+select 'MI2' from ST_FromFlatGeobuf(null::flatgeobuf_t1, '\x6667620366676201ffffffff'::bytea);
+-- NULL bytea input should be handled by STRICT rather than reaching the C decoder.
+select 'MI3', count(*) from ST_FromFlatGeobuf(null::flatgeobuf_t1, null::bytea);
 select '--- Quoted identifiers ---';
 -- Verify that special characters in column names are properly quoted
@@ -181,3 +210,6 @@ drop table if exists public.flatgeobuf_t1;
 drop table if exists public.flatgeobuf_a1;
 drop table if exists public.flatgeobuf_e1;
 drop table if exists public.flatgeobuf_qi;
+drop table if exists public.flatgeobuf_mm_long;
+drop table if exists public.flatgeobuf_mm_text;
+drop table if exists public.flatgeobuf_mm_twocols;
diff --git a/regress/core/flatgeobuf_expected b/regress/core/flatgeobuf_expected
index c93738ff9a..b9ef9de1be 100644
--- a/regress/core/flatgeobuf_expected
+++ b/regress/core/flatgeobuf_expected
@@ -24,6 +24,13 @@ ERROR:  mixed geometry type is not supported
 A1|0||t|1|2|3|4|1.2|1.3|2016-06-23 03:44:52.134125+00|hello
 --- Exotic roundtrips ---
 E1|0|t|POINT(1.1 2.1)|f
+--- Type mismatch detection ---
+ERROR:  flatgeobuf: column "val" type mismatch: file type "Long" is not compatible with PostgreSQL type text
+ERROR:  flatgeobuf: column count mismatch: file has 2 columns, target type has 1
+--- Malformed input detection ---
+ERROR:  flatgeobuf: truncated size prefix
+ERROR:  flatgeobuf: size prefix exceeds remaining input
+MI3|0
 QI1
 QI2
Summary of changes:
 NEWS                               |   5 +
 deps/flatgeobuf/flatgeobuf_c.cpp   | 177 +++++++++++++-------
 deps/flatgeobuf/geometryreader.cpp | 174 +++++++++++++-------
 postgis/flatgeobuf.c               | 328 ++++++++++++++++++++++++++++---------
 postgis/flatgeobuf.h               |   8 +-
 postgis/lwgeom_in_flatgeobuf.c     |  85 ++++++----
 regress/core/flatgeobuf.sql        |  32 ++++
 regress/core/flatgeobuf_expected   |   7 +
 8 files changed, 591 insertions(+), 225 deletions(-)
hooks/post-receive
