the project "PostGIS".
via c4a86675c184162314980fe99a0145374a290df5 (commit)
via e4296995284f2a1637685621b3b689bef01fd7f8 (commit)
from 57b24bd4050d2dfbccc4992fc22ca54f6be41414 (commit)
revisions in full, below.
commit c4a86675c184162314980fe99a0145374a290df5
Merge: 57b24bd405 e429699528
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Aug 9 12:17:21 2026 -0700
Merge pull request 'regress: keep upgrade assertions with their cleanup hook' (!689) from Komzpa/postgis:fix/regress-upgrade-hook-cleanup-20260810 into master
The hook deduplication in `check-locked-upgrade` is the actual regression fix: core tests already add `hook-after-upgrade.sql` through `RUNTESTFLAGS_INTERNAL`, so the target must not add it a second time.
Keep that guard, but put the SQL-object-resolution assertions back in `hook-after-upgrade.sql`, immediately before the schema and helper cleanup they depend on. The assertion-only hook introduced by the preceding change is removed; it did not add coverage and obscured the lifecycle of the fixtures.
Validation: `git diff --check`; GNU Make dry expansion of `check-locked-upgrade` with the core flags contains one after-upgrade hook.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/689
commit e4296995284f2a1637685621b3b689bef01fd7f8
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Aug 9 23:11:56 2026 +0400
The assertions need the upgrade fixtures and belong immediately before their cleanup. Keep the check-locked-upgrade hook deduplication from the preceding fix, but remove the assertion-only hook split.
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 18e5d96aa3..1bf0f01bc7 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -24,7 +24,6 @@ current_dir := $(dir $(abspath $(lastword $(MAKEFILE_LIST))))
RUNTESTFLAGS_INTERNAL += \
--after-create-db-script $(top_srcdir)/regress/hooks/hook-after-create-db.sql \
--before-upgrade-script $(top_srcdir)/regress/hooks/hook-before-upgrade.sql \
- --after-upgrade-script $(top_srcdir)/regress/hooks/hook-after-upgrade-sql-object-resolution.sql \
--after-upgrade-script $(top_srcdir)/regress/hooks/hook-after-upgrade.sql \
--after-create-script $(top_srcdir)/regress/hooks/hook-after-create.sql \
--before-uninstall-script $(top_srcdir)/regress/hooks/hook-before-uninstall.sql
diff --git a/regress/hooks/hook-after-upgrade-sql-object-resolution.sql b/regress/hooks/hook-after-upgrade-sql-object-resolution.sql
deleted file mode 100644
index 4685f6ad63..0000000000
--- a/regress/hooks/hook-after-upgrade-sql-object-resolution.sql
+++ /dev/null
@@ -1,28 +0,0 @@
--- These assertions require the fixtures created by hook-before-upgrade.sql.
-DO $$
-BEGIN
- IF EXISTS (SELECT 1 FROM upgrade_test_helper_overload_calls) THEN
- RAISE EXCEPTION 'upgrade helper overload was called';
- END IF;
-END;
-DROP FUNCTION _postgis_drop_function_by_identity(text, text);
-DROP FUNCTION _postgis_drop_function_by_signature(text);
-DROP TABLE upgrade_test_helper_overload_calls;
-DO LANGUAGE plpgsql $postgis_upgrade_test$
-BEGIN
- IF EXISTS (
- SELECT 1
- FROM postgis_upgrade_test_data.issue004_named_argument_operator_calls
- THEN
- RAISE EXCEPTION
- 'generated named-argument guard used the test text-array operator';
- END IF;
- -- The replacement must leave the supported function available.
- PERFORM ST_TileEnvelope(0, 0, 0);
-END
-$postgis_upgrade_test$;
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index 64ce9d770c..c4a9758876 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -10,6 +10,35 @@ DROP VIEW IF EXISTS upgrade_view_test_clusterkmeans;
DROP VIEW IF EXISTS upgrade_view_test_distance;
DROP TABLE IF EXISTS upgrade_test;
+-- These assertions require the fixtures created by hook-before-upgrade.sql.
+DO $$
+BEGIN
+ IF EXISTS (SELECT 1 FROM upgrade_test_helper_overload_calls) THEN
+ RAISE EXCEPTION 'upgrade helper overload was called';
+ END IF;
+END;
+DROP FUNCTION _postgis_drop_function_by_identity(text, text);
+DROP FUNCTION _postgis_drop_function_by_signature(text);
+DROP TABLE upgrade_test_helper_overload_calls;
+DO LANGUAGE plpgsql $postgis_upgrade_test$
+BEGIN
+ IF EXISTS (
+ SELECT 1
+ FROM postgis_upgrade_test_data.issue004_named_argument_operator_calls
+ THEN
+ RAISE EXCEPTION
+ 'generated named-argument guard used the test text-array operator';
+ END IF;
+ -- The replacement must leave the supported function available.
+ PERFORM ST_TileEnvelope(0, 0, 0);
+END
+$postgis_upgrade_test$;
-- Drop any upgrade test data
DROP SCHEMA IF EXISTS postgis_upgrade_test_data CASCADE;
Summary of changes:
regress/core/tests.mk.in | 1 -
.../hook-after-upgrade-sql-object-resolution.sql | 28 ---------------------
regress/hooks/hook-after-upgrade.sql | 29 ++++++++++++++++++++++
3 files changed, 29 insertions(+), 29 deletions(-)
delete mode 100644 regress/hooks/hook-after-upgrade-sql-object-resolution.sql
hooks/post-receive
