[PostGIS] #6038: Using public.geometry_columns causes 'could not open relation with OID 188954716' after drop geometry tables
trac at osgeo.org
Sun Aug 9 12:19:17 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 3.7.0
Component: topology | Version: master
Resolution: fixed | Keywords:
Comment (by Darafei Praliaskouski <me@…>):
In [changeset:"554b59c0a95b7ccf7121f80fe6e3fa41d7cbd800/git"
554b59c0/git]:
{{{#!CommitTicketReference repository="git"
revision="554b59c0a95b7ccf7121f80fe6e3fa41d7cbd800"
postgis: avoid stale geometry_columns relation lookups
Filter stale pg_class rows from geometry_columns by re-resolving visible
schema-qualified names before exposing metadata, while keeping
inaccessible schemas on OID-based privilege checks that do not resolve
hidden names. Require the current SELECT privilege result in both visible
and hidden paths so stale snapshots do not keep exposing metadata after
relation drops or SELECT revokes.
Closes #6038
Closes https://github.com/postgis/postgis/pull/915
(cherry picked from commit 6f11ffd051915508ef244399043b484a2de46295)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6038#comment:13>
