[PostGIS] #6109: Out-of-bounds heap read in BOX2D_out and BOX2D_expand on 65-byte box2d under ASAN
trac at osgeo.org
Sun Aug 9 12:20:15 PDT 2026
under ASAN
Reporter: dtighe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: postgis | Version: 3.6.x
Resolution: | Keywords:
Comment (by Darafei Praliaskouski <me@…>):
In [changeset:"83bd420abaffd72fea9f51b5ab773584edf9b176/git" 83bd420/git]:
{{{#!CommitTicketReference repository="git"
revision="83bd420abaffd72fea9f51b5ab773584edf9b176"
Fix out-of-bounds read in BOX2D_out and BOX2D_expand
box2d is declared with internallength=65 (postgis.sql.in), which is 7
bytes short of sizeof(GBOX) (72). Copying the full GBOX struct (72 bytes)
via
memcpy in BOX2D_out and BOX2D_expand causes a 7-byte out-of-bounds heap
read under ASAN. Reference: #6109
This change fixes this by copying only up to offsetof(GBOX, zmin), which
contains all
2D box fields (xmin, xmax, ymin, ymax, flags, SRID) within the 65-byte
payload.
This also memzeros the target buffer out as a defensive measure where it
wasn't
done previously.
Add regression test regress/core/box2d.sql (these fail under ASAN today).
References #6109 for PostGIS 3.7.0
Closes https://gitea.osgeo.org/postgis/postgis/pulls/628 for PostGIS 3.7.0
(cherry picked from commit 31aec6787f974c94ff5fa0180969d73dd1817e14)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6109#comment:5>
