[SCM] PostGIS branch stable-3.5 updated. 3.5.7-116-gcaa0c3af04
git at osgeo.org
git at osgeo.org
Sun Aug 9 12:23:52 PDT 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
via caa0c3af04b9c8b45f9a9f614cb72f6de818d215 (commit)
via 9d49a515e4c78ae6bf35b388b3b39b1967dc4276 (commit)
via 92d30eae25c47cee853b28dbd7743dd071697dad (commit)
via e3054500426f982dfed92019de14323af4fddb78 (commit)
via d8c292cc72989b8f151a20ee7ddce73f8a2784a4 (commit)
via 098022a23bb5d7a1b972a28ce1d7b2e28aaffef5 (commit)
via 1e6f4705182158387fe8196f0b0dc0d0e1b336fe (commit)
via c52193773b8a51f7337862f0f1d57ae1e9297438 (commit)
via c21ca8c0e75b387beca871a4463e4c483e5d3fff (commit)
via b0faff81f08df5c3e6be4119e678c5453d9ce622 (commit)
from 63b3c2e2b3e8b9850b3a2524682cb6788d3f8bf8 (commit)
revisions in full, below.
commit caa0c3af04b9c8b45f9a9f614cb72f6de818d215
Merge: 63b3c2e2b3 9d49a515e4
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Aug 9 12:23:50 2026 -0700
Merge pull request 'Backport correctness and input-safety fixes to stable-3.5' (!685) from Komzpa/postgis:fix/stable-3.5-backpatch-sweep-20260810 into stable-3.5
Malformed FlatGeobuf headers or features can contain a truncated size-prefixed buffer. This backport checks that the prefix is present and that the declared payload fits in the supplied buffer before decoding it; verification now covers the complete prefixed buffer.
It also rejects truncated encoded-polyline varints before any byte is read past the input, frees temporary geometries in the stable `ST_DWithin` implementation, and stops generated extension upgrade scripts from running `ANALYZE` inside their transaction.
`geometry_columns` can retain a stale relation row after a relation is dropped or SELECT privilege is revoked. This adds the visibility-safe re-resolution and focused regression from [Trac ticket 6038](https://trac.osgeo.org/postgis/ticket/6038).
`BOX2D_out` and `BOX2D_expand` now copy only the materialized 2D payload instead of reading past it; the focused regression comes from [Trac ticket 6109](https://trac.osgeo.org/postgis/ticket/6109).
`ST_Normalize` now uses the LWGEOM fallback for TIN and PolyhedralSurface inputs, preserving TRIANGLE children instead of letting GEOS conversion change their type.
Sources:
- https://gitea.osgeo.org/postgis/postgis/commit/0a7c72a9102033c8b6ddb4f3875cc0741d3baa0a
- https://gitea.osgeo.org/postgis/postgis/commit/491813e413afff546779b988e79ad7eb20559c46
- https://gitea.osgeo.org/postgis/postgis/commit/94cc593de819c917edc0d0a49c9c2ee76a5f88ce
- https://gitea.osgeo.org/postgis/postgis/commit/248b014b9805911792e2fcc097ce7c0cde422308
- https://gitea.osgeo.org/postgis/postgis/commit/6f11ffd051915508ef244399043b484a2de46295
- https://gitea.osgeo.org/postgis/postgis/commit/31aec6787f974c94ff5fa0180969d73dd1817e14
- https://gitea.osgeo.org/postgis/postgis/commit/1f6aabb0f4fb5845d31b38d0afc69ea6e466fcef
- https://gitea.osgeo.org/postgis/postgis/commit/80a8dcabf7d9f0b19abae1d853571473cbd9c075
The FlatGeobuf change is a narrow semantic port because the vendored dependency differs on this branch. The encoded-polyline and upgrade commits retain upstream authorship; `ST_DWithin` is adapted only for its earlier stable source location.
Validation: `git diff --check`; built and staged against PostgreSQL 15; focused `regress/core/regress_management`, `regress/core/box2d`, and `regress/core/normalize` passed the create and upgrade paths with 0 failures.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/685
commit 9d49a515e4c78ae6bf35b388b3b39b1967dc4276
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Aug 9 22:58:41 2026 +0400
Fix ST_Normalize TIN child normalization
Squashed manual backport of the surface-normalization fallback and its TIN child correction; excludes unrelated example-test changes.\n\nPorted-from: 1f6aabb0f4fb5845d31b38d0afc69ea6e466fcef\nPorted-from: 80a8dcabf7d9f0b19abae1d853571473cbd9c075
(cherry picked from commit c01443760cbc487739d8b64b8960339df2086643)
diff --git a/NEWS b/NEWS
index e519bc665a..b8f98932aa 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,8 @@ PostGIS 3.5.8
* Bug Fixes *
+ - GT-675, Preserve TRIANGLE children while normalizing malformed TINs
+ (Darafei Praliaskouski)
- #6038, Avoid stale geometry_columns relation lookups after relations are
dropped or SELECT privilege is revoked (Darafei Praliaskouski)
- #6109, Avoid out-of-bounds reads in BOX2D_out and BOX2D_expand
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index 102ed604dc..98db684702 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -32,6 +32,7 @@
#include <stdarg.h>
#include <stdlib.h>
+#include <string.h>
LWTIN* lwtin_from_geos(const GEOSGeometry* geom, uint8_t want3d);
@@ -524,6 +525,7 @@ LWGEOM2GEOS(const LWGEOM* lwgeom, uint8_t autofix)
case MULTILINETYPE:
case MULTIPOLYGONTYPE:
case TINTYPE:
+ case POLYHEDRALSURFACETYPE:
case COLLECTIONTYPE:
int geostype;
@@ -657,6 +659,89 @@ get_result_srid(size_t count, const char* funcname, ...)
return srid;
+static int
+lwgeom_geos_normalize_unsupported_type(uint8_t type)
+ return type == POLYHEDRALSURFACETYPE || type == TINTYPE;
+static int
+lwgeom_geos_normalize_needs_lwgeom(const LWGEOM *geom)
+ uint32_t i;
+ LWCOLLECTION *col;
+ if (lwgeom_geos_normalize_unsupported_type(geom->type))
+ return LW_TRUE;
+ if (!lwtype_is_collection(geom->type))
+ return LW_FALSE;
+ col = (LWCOLLECTION *)geom;
+ for (i = 0; i < col->ngeoms; i++)
+ if (lwgeom_geos_normalize_needs_lwgeom(col->geoms[i]))
+ return LW_TRUE;
+ return LW_FALSE;
+static int
+lwgeom_compare_by_xdr_ewkb(const void *a, const void *b)
+ const LWGEOM *ga = *(const LWGEOM *const *)a;
+ const LWGEOM *gb = *(const LWGEOM *const *)b;
+ char *wa = lwgeom_to_hexwkb_buffer(ga, WKB_EXTENDED | WKB_XDR);
+ char *wb = lwgeom_to_hexwkb_buffer(gb, WKB_EXTENDED | WKB_XDR);
+ int cmp = strcmp(wa, wb);
+ lwfree(wa);
+ lwfree(wb);
+ return cmp;
+static LWGEOM *
+lwgeom_normalized_triangle_or_clone(const LWGEOM *triangle_in, LWGEOM *normalized)
+ LWPOLY *poly;
+ LWTRIANGLE *triangle;
+ POINTARRAY *points;
+ if (normalized && normalized->type == TRIANGLETYPE)
+ return normalized;
+ if (!normalized || normalized->type != POLYGONTYPE)
+ lwgeom_free(normalized);
+ return lwgeom_clone_deep(triangle_in);
+ poly = lwgeom_as_lwpoly(normalized);
+ if (poly->nrings != 1 || !poly->rings[0])
+ points = ptarray_clone_deep(poly->rings[0]);
+ triangle = lwtriangle_construct(poly->srid, NULL, points);
+ return lwtriangle_as_lwgeom(triangle);
+static LWGEOM *
+lwgeom_normalize_lwgeom(const LWGEOM *geom)
+ uint32_t i;
+ return lwgeom_clone_deep(geom);
+ col = lwcollection_clone_deep((LWCOLLECTION *)geom);
+ LWGEOM *normalized = lwgeom_normalize(col->geoms[i]);
+ if (col->type == TINTYPE && col->geoms[i]->type == TRIANGLETYPE)
+ normalized = lwgeom_normalized_triangle_or_clone(col->geoms[i], normalized);
+ lwgeom_free(col->geoms[i]);
+ col->geoms[i] = normalized;
+ if (col->ngeoms > 1)
+ qsort(col->geoms, col->ngeoms, sizeof(LWGEOM *), lwgeom_compare_by_xdr_ewkb);
+ lwgeom_drop_bbox((LWGEOM *)col);
+ return (LWGEOM *)col;
LWGEOM*
lwgeom_normalize(const LWGEOM* geom)
@@ -666,6 +751,8 @@ lwgeom_normalize(const LWGEOM* geom)
GEOSGeometry* g;
if (srid == SRID_INVALID) return NULL;
+ if (lwgeom_geos_normalize_needs_lwgeom(geom))
+ return lwgeom_normalize_lwgeom(geom);
initGEOS(lwnotice, lwgeom_geos_error);
diff --git a/regress/core/normalize.sql b/regress/core/normalize.sql
index 02aac6518b..547b353a44 100644
--- a/regress/core/normalize.sql
+++ b/regress/core/normalize.sql
@@ -5,3 +5,11 @@ select 1, ST_AsText(ST_Normalize(
select 2, ST_AsText(ST_Normalize(
'POLYGON((0 10,0 0,10 0,10 10,0 10),(4 2,2 2,2 4,4 4,4 2),(6 8,8 8,8 6,6 6,6 8))'
::geometry));
+select 3, GeometryType(ST_Normalize('POLYHEDRALSURFACE(((0 0,2 0,0 2,0 0)),((10 10,11 10,10 11,10 10)))'::geometry));
+select 4, GeometryType(ST_Normalize('TIN(((0 0,2 0,0 2,0 0)),((10 10,11 10,10 11,10 10)))'::geometry));
+select 5, GeometryType(ST_GeometryN(ST_Normalize('GEOMETRYCOLLECTION(POLYHEDRALSURFACE(((0 0,2 0,0 2,0 0))))'::geometry), 1));
+with normalized as (
+ select ST_Normalize(ST_GeomFromWKB(decode('0110000000010000000111000000010000000500000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000','hex'))) as geom
+select 6, GeometryType(normalized.geom), GeometryType((dumped).geom) from normalized cross join lateral ST_Dump(normalized.geom) as dumped;
diff --git a/regress/core/normalize_expected b/regress/core/normalize_expected
index 36d32a2f7c..c42004281b 100644
--- a/regress/core/normalize_expected
+++ b/regress/core/normalize_expected
@@ -1,2 +1,6 @@
1|GEOMETRYCOLLECTION(MULTILINESTRING((2 2,3 3),(0 0,1 1)),POINT(2 3))
2|POLYGON((0 0,0 10,10 10,10 0,0 0),(6 6,8 6,8 8,6 8,6 6),(2 2,4 2,4 4,2 4,2 2))
+3|POLYHEDRALSURFACE
+4|TIN
+5|POLYHEDRALSURFACE
+6|TIN|TRIANGLE
commit 92d30eae25c47cee853b28dbd7743dd071697dad
Date: Sun Aug 9 22:56:08 2026 +0400
NEWS: reference BOX2D out-of-bounds fix
index af41e5fe4f..e519bc665a 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,8 @@ PostGIS 3.5.8
+ - #6109, Avoid out-of-bounds reads in BOX2D_out and BOX2D_expand
+ (Dennis Tighe, Google)
- GT-669, Reject truncated size-prefixed header and feature buffers
before decoding (Darafei Praliaskouski)
- Stop the extension upgrade script running ANALYZE inside its transaction,
commit e3054500426f982dfed92019de14323af4fddb78
Author: Dennis Tighe <dtighe at google.com>
Date: Wed Jul 29 17:49:01 2026 -0700
Fix out-of-bounds read in BOX2D_out and BOX2D_expand
box2d is declared with internallength=65 (postgis.sql.in), which is 7
bytes short of sizeof(GBOX) (72). Copying the full GBOX struct (72 bytes) via
memcpy in BOX2D_out and BOX2D_expand causes a 7-byte out-of-bounds heap
read under ASAN. Reference: #6109
This change fixes this by copying only up to offsetof(GBOX, zmin), which contains all
2D box fields (xmin, xmax, ymin, ymax, flags, SRID) within the 65-byte payload.
This also memzeros the target buffer out as a defensive measure where it wasn't
done previously.
Add regression test regress/core/box2d.sql (these fail under ASAN today).
References #6109 for PostGIS 3.7.0
Closes https://gitea.osgeo.org/postgis/postgis/pulls/628 for PostGIS 3.7.0
(cherry picked from commit 31aec6787f974c94ff5fa0180969d73dd1817e14)
diff --git a/postgis/lwgeom_box.c b/postgis/lwgeom_box.c
index 98b39ed955..f53424507a 100644
--- a/postgis/lwgeom_box.c
+++ b/postgis/lwgeom_box.c
@@ -100,9 +100,15 @@ Datum BOX2D_out(PG_FUNCTION_ARGS)
int size = 0;
GBOX *box = (GBOX *)PG_GETARG_POINTER(0);
- /* Avoid unaligned access to the gbox struct */
+ /* Avoid unaligned access to the gbox struct.
+ * box2d can be 65 bytes, which is 7 bytes short of sizeof(GBOX) (72)
+ * so just copy the required part (xy/min, xy/max) and zero the rest
+ * (matches BOX2d_expand).
GBOX box_aligned;
- memcpy(&box_aligned, box, sizeof(GBOX));
+ memset(&box_aligned, 0, sizeof(box_aligned));
+ memcpy(&box_aligned, box, offsetof(GBOX, zmin));
size = 4;
size += lwprint_double(box_aligned.xmin, precision, &tmp[size]);
@@ -387,8 +393,10 @@ PG_FUNCTION_INFO_V1(BOX2D_expand);
Datum BOX2D_expand(PG_FUNCTION_ARGS)
- GBOX *result = (GBOX *)palloc(sizeof(GBOX));
- memcpy(result, box, sizeof(GBOX));
+ /* box2d is 65 bytes (7 bytes short of sizeof(GBOX)) and is a purely
+ * 2D box; copy only the 2D header */
+ GBOX *result = (GBOX *)palloc0(sizeof(GBOX));
+ memcpy(result, box, offsetof(GBOX, zmin));
if (PG_NARGS() == 2)
diff --git a/regress/core/box2d.sql b/regress/core/box2d.sql
new file mode 100644
index 0000000000..746f778603
--- /dev/null
+++ b/regress/core/box2d.sql
@@ -0,0 +1,8 @@
+-- box2d output / expand must not read past a materialised box2d value.
+-- see #6109
+SELECT 'out', ('LINESTRING(0 0,1 1)'::geometry::box2d)::text;
+SELECT 'out_3d', ('LINESTRING Z (0 0 9,2 3 9)'::geometry::box2d)::text;
+SELECT 'roundtrip', 'BOX(1.5 2.5,3.5 4.5)'::box2d::text;
+SELECT 'extent', ST_Extent(g)::text FROM (VALUES ('POINT(0 0)'::geometry),('POINT(5 7)'::geometry)) v(g);
+SELECT 'expand_d', ST_Expand('LINESTRING(0 0,10 10)'::geometry::box2d, 1)::text;
+SELECT 'expand_dxdy',ST_Expand('LINESTRING(0 0,10 10)'::geometry::box2d, 2, 3)::text;
diff --git a/regress/core/box2d_expected b/regress/core/box2d_expected
index 0000000000..e6ce8e0b6d
--- /dev/null
+++ b/regress/core/box2d_expected
@@ -0,0 +1,6 @@
+out|BOX(0 0,1 1)
+out_3d|BOX(0 0,2 3)
+roundtrip|BOX(1.5 2.5,3.5 4.5)
+extent|BOX(0 0,5 7)
+expand_d|BOX(-1 -1,11 11)
+expand_dxdy|BOX(-2 -3,12 13)
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 3dd65b92fc..425250c825 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -31,6 +31,7 @@ TESTS += \
$(top_srcdir)/regress/core/bestsrid \
$(top_srcdir)/regress/core/binary \
$(top_srcdir)/regress/core/boundary \
+ $(top_srcdir)/regress/core/box2d \
$(top_srcdir)/regress/core/chaikin \
$(top_srcdir)/regress/core/filterm \
$(top_srcdir)/regress/core/cluster \
commit d8c292cc72989b8f151a20ee7ddce73f8a2784a4
Date: Fri Jun 19 23:42:36 2026 +0400
postgis: avoid stale geometry_columns relation lookups
Filter stale pg_class rows from geometry_columns by re-resolving visible schema-qualified names before exposing metadata, while keeping inaccessible schemas on OID-based privilege checks that do not resolve hidden names. Require the current SELECT privilege result in both visible and hidden paths so stale snapshots do not keep exposing metadata after relation drops or SELECT revokes.
Closes #6038
Closes https://github.com/postgis/postgis/pull/915
(cherry picked from commit 6f11ffd051915508ef244399043b484a2de46295)
index 22b62abacf..af41e5fe4f 100644
--- a/NEWS
+++ b/NEWS
* Bug Fixes *
+ - #6038, Avoid stale geometry_columns relation lookups after relations are
+ dropped or SELECT privilege is revoked (Darafei Praliaskouski)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 5041271f42..0e617212fa 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6428,7 +6428,40 @@ CREATE OR REPLACE VIEW geometry_columns AS
) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"]))
AND NOT c.relname = 'raster_columns'::name AND t.typname = 'geometry'::name
- AND NOT pg_is_other_temp_schema(c.relnamespace) AND has_table_privilege(c.oid, 'SELECT'::text);
+ AND NOT pg_is_other_temp_schema(c.relnamespace)
+ -- A stale MVCC snapshot can still see a dropped pg_class row (#6038).
+ -- Re-resolve the qualified relation name only when the schema is visible,
+ -- because to_regclass reports permission errors for inaccessible schemas.
+ -- Without schema visibility, keep the old OID-based privilege semantics.
+ -- Keep the visible-schema SELECT check in the same CASE branch as the
+ -- re-resolution guard so PostgreSQL cannot evaluate it for a stale OID.
+ AND CASE WHEN has_schema_privilege(c.relnamespace, 'USAGE'::text)
+ THEN CASE WHEN pg_catalog.to_regclass(pg_catalog.format('%I.%I', n.nspname, c.relname)) = c.oid
+ THEN pg_catalog.has_table_privilege(c.oid, 'SELECT')
+ ELSE false
+ END
+ ELSE pg_catalog.has_table_privilege(c.oid, 'SELECT')
+ END
+ AND (
+ EXISTS (
+ SELECT 1
+ FROM pg_roles
+ WHERE rolname = current_user
+ AND rolsuper
+ OR EXISTS (
+ SELECT 1
+ FROM pg_roles
+ WHERE rolname = 'pg_read_all_data'
+ AND pg_has_role(current_user, oid, 'USAGE')
+ OR EXISTS (
+ SELECT 1
+ FROM aclexplode(COALESCE(c.relacl, acldefault('r', c.relowner))) AS acl
+ WHERE acl.privilege_type = 'SELECT'
+ AND (acl.grantee = 0 OR pg_has_role(acl.grantee, 'USAGE'))
-- TODO: support RETURNING and raise a WARNING
CREATE OR REPLACE RULE geometry_columns_insert AS
diff --git a/regress/core/regress_management.sql b/regress/core/regress_management.sql
index c92b7aad0a..2b5027bd4e 100644
--- a/regress/core/regress_management.sql
+++ b/regress/core/regress_management.sql
@@ -4,5 +4,65 @@ SET client_min_messages TO warning;
CREATE TABLE test_pt(gid SERIAL PRIMARY KEY, geom geometry);
INSERT INTO test_pt(geom) VALUES(ST_GeomFromEWKT('SRID=4326;POINT M(1 2 3)'));
SELECT populate_geometry_columns('test_pt'::regclass);
+SELECT '#6038.before', srid FROM geometry_columns WHERE f_table_schema = 'public' AND f_table_name = 'test_pt' AND f_geometry_column = 'geom';
SELECT 'The result: ' || DropGeometryTable('test_pt');
+SELECT '#6038.after', count(*) FROM geometry_columns WHERE f_table_schema = 'public' AND f_table_name = 'test_pt' AND f_geometry_column = 'geom';
+DO $$
+DECLARE
+ can_switch_role boolean;
+BEGIN
+ SELECT rolsuper INTO can_switch_role
+ FROM pg_roles
+ WHERE rolname = current_user;
+ IF can_switch_role THEN
+ DROP SCHEMA IF EXISTS test6038_private CASCADE;
+ DROP TABLE IF EXISTS public.test6038_visible_geom;
+ DROP ROLE IF EXISTS test6038_invisible;
+ DROP ROLE IF EXISTS test6038_visible;
+ CREATE ROLE test6038_invisible;
+ CREATE ROLE test6038_visible;
+ GRANT test6038_invisible TO CURRENT_USER;
+ GRANT test6038_visible TO CURRENT_USER;
+ CREATE TABLE public.test6038_visible_geom(geom geometry(Point, 4326));
+ GRANT SELECT ON public.test6038_visible_geom TO test6038_visible;
+ CREATE SCHEMA test6038_private;
+ CREATE TABLE test6038_private.hidden_geom(geom geometry(Point, 4326));
+ REVOKE ALL ON SCHEMA test6038_private FROM PUBLIC;
+ GRANT SELECT ON test6038_private.hidden_geom TO test6038_invisible;
+ EXECUTE 'SET LOCAL ROLE test6038_visible';
+ IF 1 != (SELECT count(*) FROM geometry_columns WHERE f_table_schema = 'public' AND f_table_name = 'test6038_visible_geom') THEN
+ RAISE EXCEPTION 'geometry_columns did not expose currently selectable table in visible schema';
+ END IF;
+ EXECUTE 'RESET ROLE';
+ REVOKE SELECT ON public.test6038_visible_geom FROM test6038_visible;
+ IF 0 != (SELECT count(*) FROM geometry_columns WHERE f_table_schema = 'public' AND f_table_name = 'test6038_visible_geom') THEN
+ RAISE EXCEPTION 'geometry_columns exposed metadata after SELECT was revoked in visible schema';
+ END IF;
+ -- The view must not resolve names inside schemas hidden from the caller.
+ EXECUTE 'SET LOCAL ROLE test6038_invisible';
+ IF 1 != (SELECT count(*) FROM geometry_columns WHERE f_table_schema = 'test6038_private') THEN
+ RAISE EXCEPTION 'geometry_columns did not preserve OID-based SELECT visibility in hidden schema';
+ END IF;
+ REVOKE SELECT ON test6038_private.hidden_geom FROM test6038_invisible;
+ IF 0 != (SELECT count(*) FROM geometry_columns WHERE f_table_schema = 'test6038_private') THEN
+ RAISE EXCEPTION 'geometry_columns exposed hidden-schema metadata after SELECT was revoked';
+ END IF;
+ DROP SCHEMA test6038_private CASCADE;
+ DROP TABLE public.test6038_visible_geom;
+ DROP ROLE test6038_invisible;
+ DROP ROLE test6038_visible;
+ END IF;
+END
SELECT 'Unexistant: ' || DropGeometryTable('unexistent'); -- see ticket #861
diff --git a/regress/core/regress_management_expected b/regress/core/regress_management_expected
index e27f7f0ef5..ac137e244f 100644
--- a/regress/core/regress_management_expected
+++ b/regress/core/regress_management_expected
@@ -1,3 +1,5 @@
1
+#6038.before|4326
The result: public.test_pt dropped.
+#6038.after|0
Unexistant: public.unexistent dropped.
commit 098022a23bb5d7a1b972a28ce1d7b2e28aaffef5
Date: Sun Aug 9 22:23:44 2026 +0400
NEWS: reference backported issue numbers
index ffbed1084b..22b62abacf 100644
--- a/NEWS
+++ b/NEWS
@@ -3,13 +3,13 @@ PostGIS 3.5.8
* Bug Fixes *
- - [flatgeobuf] Reject truncated size-prefixed header and feature buffers
+ - GT-669, Reject truncated size-prefixed header and feature buffers
where it can deadlock with autovacuum (Darafei Praliaskouski)
- OSSFuzz 5877056525893632, reject truncated encoded polyline input
- - Fix temporary geometry leaks in ST_DWithin (Darafei Praliaskouski)
+ - GT-677, Fix temporary geometry leaks in ST_DWithin (Darafei Praliaskouski)
- GT-619, Make interrupt regression tests compare timeout latency to
same-machine uninterrupted runtime, avoiding false failures under
slow CI load (Darafei Praliaskouski)
commit 1e6f4705182158387fe8196f0b0dc0d0e1b336fe
Date: Sun Aug 9 22:18:32 2026 +0400
flatgeobuf: validate size-prefixed decode buffers
Ported-from: https://gitea.osgeo.org/postgis/postgis/commit/0a7c72a9102033c8b6ddb4f3875cc0741d3baa0a
index b3ff3ede2a..ffbed1084b 100644
--- a/NEWS
+++ b/NEWS
* Bug Fixes *
+ - [flatgeobuf] Reject truncated size-prefixed header and feature buffers
+ before decoding (Darafei Praliaskouski)
diff --git a/deps/flatgeobuf/flatgeobuf_c.cpp b/deps/flatgeobuf/flatgeobuf_c.cpp
index ad5c40c76f..4bb40ff6e1 100644
--- a/deps/flatgeobuf/flatgeobuf_c.cpp
+++ b/deps/flatgeobuf/flatgeobuf_c.cpp
@@ -41,6 +41,20 @@ struct FeatureItem : FlatGeobuf::Item {
uint64_t offset;
+static bool
+flatgeobuf_size_prefixed_buffer_size(const ctx *ctx, uoffset_t *size)
+ uint64_t remaining;
+ if (ctx->offset > ctx->size)
+ return false;
+ remaining = ctx->size - ctx->offset;
+ if (remaining < sizeof(uoffset_t))
+ return false;
+ *size = flatbuffers::GetPrefixedSize(ctx->buf + ctx->offset);
+ return *size <= remaining - sizeof(uoffset_t);
int flatgeobuf_encode_header(ctx *ctx)
FlatBufferBuilder fbb;
@@ -230,11 +244,15 @@ void flatgeobuf_create_index(ctx *ctx)
int flatgeobuf_decode_feature(ctx *ctx)
LWDEBUGF(2, "reading size prefix at %ld", ctx->offset);
- auto size = flatbuffers::GetPrefixedSize(ctx->buf + ctx->offset);
+ uoffset_t size;
+ if (!flatgeobuf_size_prefixed_buffer_size(ctx, &size)) {
+ lwerror("flatgeobuf: size prefix exceeds remaining input");
+ return -1;
LWDEBUGF(2, "size is %ld (without size prefix)", size);
- Verifier verifier(ctx->buf + ctx->offset, size);
- if (VerifySizePrefixedFeatureBuffer(verifier)) {
+ Verifier verifier(ctx->buf + ctx->offset, size + sizeof(uoffset_t));
+ if (!VerifySizePrefixedFeatureBuffer(verifier)) {
lwerror("buffer did not pass verification");
return -1;
@@ -268,11 +286,15 @@ int flatgeobuf_decode_feature(ctx *ctx)
int flatgeobuf_decode_header(ctx *ctx)
+ uoffset_t size;
+ return -1;
- if (VerifySizePrefixedHeaderBuffer(verifier)) {
+ if (!VerifySizePrefixedHeaderBuffer(verifier)) {
return -1;
@@ -317,4 +339,4 @@ int flatgeobuf_decode_header(ctx *ctx)
return 0;
\ No newline at end of file
commit c52193773b8a51f7337862f0f1d57ae1e9297438
Date: Sun Aug 2 20:03:01 2026 +0400
Do not ANALYZE inside the extension upgrade transaction
spatial_ref_sys.sql ends with
ON CONFLICT (srid) DO NOTHING;
COMMIT;
ANALYZE "spatial_ref_sys";
The ANALYZE sits after COMMIT on purpose: run standalone it refreshes the
statistics of a table that just gained thousands of rows, outside any
transaction. The extension build strips BEGIN and COMMIT because those are
not allowed in extension scripts, and left the ANALYZE behind — so it ends up
*inside* the upgrade's transaction, takes ShareUpdateExclusiveLock on
spatial_ref_sys, and can deadlock against autovacuum analysing the same table:
ERROR: deadlock detected
DETAIL: Process A waits for ShareUpdateExclusiveLock on relation ...;
blocked by process B. Process B waits for ShareLock on
transaction ...; blocked by process A.
CONTEXT: SQL statement "ANALYZE "spatial_ref_sys""
extension script file "postgis--ANY--3.7.0dev.sql"
That aborts ALTER EXTENSION postgis UPDATE, so a user upgrading a busy
database can simply lose the upgrade. It also accounts for three of the
eleven most recent Woodpecker pipeline failures, in regress/test-install and
regress/test-upgrades, on ordinary amd64 rows rather than emulated ones.
Strip the ANALYZE along with the transaction control it was written to follow.
The standalone spatial_ref_sys.sql keeps it; autovacuum analyses the table on
its own schedule, so the extension script does not need to.
(cherry picked from commit 248b014b9805911792e2fcc097ce7c0cde422308)
index e029329e40..b3ff3ede2a 100644
--- a/NEWS
+++ b/NEWS
* Bug Fixes *
+ - Stop the extension upgrade script running ANALYZE inside its transaction,
+ where it can deadlock with autovacuum (Darafei Praliaskouski)
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 88ef35afdf..fbf3bd09aa 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -104,9 +104,21 @@ sql/$(EXTENSION)--unpackaged.sql: Makefile | sql
sql:
mkdir -p $@
-#strip BEGIN/COMMIT since these are not allowed in extensions
+# Strip BEGIN/COMMIT since these are not allowed in extensions, and the trailing
+# ANALYZE with them. In spatial_ref_sys.sql that ANALYZE deliberately sits *after*
+# COMMIT, so run standalone it refreshes statistics outside any transaction. Removing
+# only the COMMIT moves it inside the extension's transaction, where it takes
+# ShareUpdateExclusiveLock on spatial_ref_sys and can deadlock against autovacuum
+# doing the same work:
+# ERROR: deadlock detected
+# CONTEXT: SQL statement "ANALYZE "spatial_ref_sys""
+# extension script file "postgis--ANY--<version>.sql"
+# That aborts ALTER EXTENSION postgis UPDATE on any busy database. Autovacuum will
+# analyse the table on its own schedule, so the extension script does not need to.
sql/spatial_ref_sys.sql: ../../spatial_ref_sys.sql | sql
- $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
+ $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g ; s/^ANALYZE "spatial_ref_sys";\s*$$//g' $< > $@
sql/spatial_ref_sys_config_dump.sql: ../../spatial_ref_sys.sql ../../utils/create_spatial_ref_sys_config_dump.pl | sql
$(PERL) @top_srcdir@/utils/create_spatial_ref_sys_config_dump.pl $< > $@
commit c21ca8c0e75b387beca871a4463e4c483e5d3fff
Date: Sat Aug 8 12:22:14 2026 +0400
fix(liblwgeom): reject truncated encoded polylines
(cherry picked from commit 491813e413afff546779b988e79ad7eb20559c46)
index 0b80b36dfc..e029329e40 100644
--- a/NEWS
+++ b/NEWS
* Bug Fixes *
+ - OSSFuzz 5877056525893632, reject truncated encoded polyline input
diff --git a/liblwgeom/cunit/cu_in_encoded_polyline.c b/liblwgeom/cunit/cu_in_encoded_polyline.c
index 6af16b9a23..9cd4a7e1fe 100644
--- a/liblwgeom/cunit/cu_in_encoded_polyline.c
+++ b/liblwgeom/cunit/cu_in_encoded_polyline.c
@@ -62,6 +62,13 @@ static void in_encoded_polyline_test_close_points(void)
"SRID=4326;LINESTRING(38.903876 55.336448,38.903875 55.336448)");
+static void in_encoded_polyline_test_truncated_input(void)
+ /* A latitude without a longitude and an unterminated latitude varint. */
+ CU_ASSERT_PTR_NULL(lwgeom_from_encoded_polyline("A", 5));
+ CU_ASSERT_PTR_NULL(lwgeom_from_encoded_polyline("`", 5));
** Used by test harness to register the tests in this file.
@@ -72,4 +79,5 @@ void in_encoded_polyline_suite_setup(void)
PG_ADD_TEST(suite, in_encoded_polyline_test_geoms);
PG_ADD_TEST(suite, in_encoded_polyline_test_precision);
PG_ADD_TEST(suite, in_encoded_polyline_test_close_points);
+ PG_ADD_TEST(suite, in_encoded_polyline_test_truncated_input);
diff --git a/liblwgeom/lwin_encoded_polyline.c b/liblwgeom/lwin_encoded_polyline.c
index 2bb9f73417..d1af103eab 100644
--- a/liblwgeom/lwin_encoded_polyline.c
+++ b/liblwgeom/lwin_encoded_polyline.c
@@ -29,6 +29,7 @@
#include <stdint.h>
#include "liblwgeom.h"
+#include "lwgeom_log.h"
#include "../postgis_config.h"
LWGEOM*
@@ -52,6 +53,11 @@ lwgeom_from_encoded_polyline(const char *encodedpolyline, int precision)
int res = 0;
char shift = 0;
do {
+ if (idx >= length) {
+ lwerror("lwgeom_from_encoded_polyline: input is truncated");
+ ptarray_free(pa);
+ return NULL;
byte = encodedpolyline[idx++] - 63;
res |= (byte & 0x1F) << shift;
shift += 5;
@@ -62,6 +68,11 @@ lwgeom_from_encoded_polyline(const char *encodedpolyline, int precision)
shift = 0;
res = 0;
do {
+ ptarray_free(pa);
+ return NULL;
shift += 5;
commit b0faff81f08df5c3e6be4119e678c5453d9ce622
Date: Sun Aug 9 22:02:03 2026 +0400
postgis: free ST_DWithin temporary geometries
Ported-from: https://gitea.osgeo.org/postgis/postgis/commit/94cc593de819c917edc0d0a49c9c2ee76a5f88ce
index 2e79c51e5a..0b80b36dfc 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,7 @@ PostGIS 3.5.8
* Bug Fixes *
+ - Fix temporary geometry leaks in ST_DWithin (Darafei Praliaskouski)
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 0db1ce0b6f..a2b647ba57 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -751,6 +751,8 @@ Datum LWGEOM_dwithin(PG_FUNCTION_ARGS)
mindist = lwgeom_mindistance2d_tolerance(lwgeom1, lwgeom2, tolerance);
+ lwgeom_free(lwgeom1);
+ lwgeom_free(lwgeom2);
PG_FREE_IF_COPY(geom1, 0);
PG_FREE_IF_COPY(geom2, 1);
Summary of changes:
NEWS | 13 +++++
deps/flatgeobuf/flatgeobuf_c.cpp | 36 ++++++++++---
extensions/postgis/Makefile.in | 16 +++++-
liblwgeom/cunit/cu_in_encoded_polyline.c | 8 +++
liblwgeom/lwgeom_geos.c | 87 ++++++++++++++++++++++++++++++++
liblwgeom/lwin_encoded_polyline.c | 11 ++++
postgis/lwgeom_box.c | 16 ++++--
postgis/lwgeom_functions_basic.c | 2 +
postgis/postgis.sql.in | 35 ++++++++++++-
regress/core/box2d.sql | 8 +++
regress/core/box2d_expected | 6 +++
regress/core/normalize.sql | 8 +++
regress/core/normalize_expected | 4 ++
regress/core/regress_management.sql | 60 ++++++++++++++++++++++
regress/core/regress_management_expected | 2 +
regress/core/tests.mk.in | 1 +
16 files changed, 299 insertions(+), 14 deletions(-)
create mode 100644 regress/core/box2d.sql
create mode 100644 regress/core/box2d_expected
hooks/post-receive
