[SCM] PostGIS branch stable-3.2 updated. 3.2.10-106-gf35470a3c4
git at osgeo.org
git at osgeo.org
Sun Aug 9 13:11:44 PDT 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
via f35470a3c4707cd26572f0a30e0691eec9d1e57e (commit)
via 2bfc2afce16b9df485791a9287b03e9247b4605c (commit)
from 27960c7d1d9bfdc92398bde485e76ca9069c1f31 (commit)
revisions in full, below.
commit f35470a3c4707cd26572f0a30e0691eec9d1e57e
Merge: 27960c7d1d 2bfc2afce1
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Aug 9 13:11:43 2026 -0700
Merge pull request 'flatgeobuf: validate input buffers before decoding (stable-3.2)' (!694) from Komzpa/postgis:fix/stable-3.2-flatgeobuf-validation-20260810 into stable-3.2
## Summary
- backport the FlatGeobuf decoder hardening from [master PR 669](https://gitea.osgeo.org/postgis/postgis/pulls/669) to stable-3.2
- reject truncated or oversized size-prefixed buffers before FlatBuffers reads them
- validate variable-length properties, geometry metadata, and packed-RTree bounds before copying or advancing decode state
- retain the target branch's existing early size-prefix guard and add a branch-local `NEWS` entry with the reporter credits
## Provenance
This is a target-branch port of [master commit 0a7c72a](https://gitea.osgeo.org/postgis/postgis/commit/0a7c72a9102033c8b6ddb4f3875cc0741d3baa0a), which was already backported to [stable-3.6 PR 674](https://gitea.osgeo.org/postgis/postgis/pulls/674). The target's earlier minimal size-prefix fix overlaps this change, so the resulting commit is a faithful port rather than a clean cherry-pick.
## Validation
- `git diff --check upstream/stable-3.2...HEAD`
- `utils/check_news.sh .`
Focused regression was not run locally: this isolated worktree has no generated build tree or configured regression target.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/694
commit 2bfc2afce16b9df485791a9287b03e9247b4605c
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Aug 8 15:23:44 2026 +0400
Validate FlatGeobuf size-prefixed header and feature buffers against the
remaining bytea before FlatBuffers decodes them. Reject malformed
variable-length property values and malformed geometry/index metadata before
copying or advancing decoder state. Handle NULL bytea input to
ST_FromFlatGeobuf as an empty set.
Ported-from: https://gitea.osgeo.org/postgis/postgis/commit/0a7c72a9102033c8b6ddb4f3875cc0741d3baa0a
diff --git a/NEWS b/NEWS
index cf6a2cef9b..bace1e3892 100644
--- a/NEWS
+++ b/NEWS
@@ -9,8 +9,9 @@ PostGIS 3.2.11
dropped or SELECT privilege is revoked (Darafei Praliaskouski)
- #6109, Avoid out-of-bounds reads in BOX2D_out and BOX2D_expand
(Dennis Tighe, Google)
- - GT-669, Reject truncated size-prefixed header and feature buffers
- before decoding (Darafei Praliaskouski)
+ - GT-669, Validate FlatGeobuf size-prefixed buffers and variable-length
+ property values before decoding (reported by Mehmet Ince; reported by
+ Sarath Kumar, IITM Pravartak Security Team; fixed by Darafei Praliaskouski)
- Stop the extension upgrade script running ANALYZE inside its transaction,
where it can deadlock with autovacuum (Darafei Praliaskouski)
- OSSFuzz 5877056525893632, reject truncated encoded polyline input
diff --git a/deps/flatgeobuf/flatgeobuf_c.cpp b/deps/flatgeobuf/flatgeobuf_c.cpp
index 72f7590a71..a5b121f942 100644
--- a/deps/flatgeobuf/flatgeobuf_c.cpp
+++ b/deps/flatgeobuf/flatgeobuf_c.cpp
@@ -28,310 +28,358 @@
#include "geometryreader.h"
#include "packedrtree.h"
+#include <exception>
using namespace flatbuffers;
using namespace FlatGeobuf;
typedef flatgeobuf_ctx ctx;
-uint8_t flatgeobuf_magicbytes[] = { 0x66, 0x67, 0x62, 0x03, 0x66, 0x67, 0x62, 0x01 };
+uint8_t flatgeobuf_magicbytes[] = {0x66, 0x67, 0x62, 0x03, 0x66, 0x67, 0x62, 0x01};
uint8_t FLATGEOBUF_MAGICBYTES_SIZE = sizeof(flatgeobuf_magicbytes);
struct FeatureItem : FlatGeobuf::Item {
- uoffset_t size;
- uint64_t offset;
+ uoffset_t size;
+ uint64_t offset;
-static bool
-flatgeobuf_size_prefixed_buffer_size(const ctx *ctx, uoffset_t *size)
+static size_t
+flatgeobuf_size_prefixed_verifier_length(uoffset_t size)
- uint64_t remaining;
- if (ctx->offset > ctx->size)
- return false;
- remaining = ctx->size - ctx->offset;
- if (remaining < sizeof(uoffset_t))
- return false;
- *size = flatbuffers::GetPrefixedSize(ctx->buf + ctx->offset);
- return *size <= remaining - sizeof(uoffset_t);
+ return (size_t)size + sizeof(uoffset_t);
-int flatgeobuf_encode_header(ctx *ctx)
+int
+flatgeobuf_encode_header(ctx *ctx)
- FlatBufferBuilder fbb;
- fbb.TrackMinAlign(8);
+ FlatBufferBuilder fbb;
+ fbb.TrackMinAlign(8);
- // inspect first geometry
- if (ctx->lwgeom != NULL) {
- if (lwgeom_has_srid(ctx->lwgeom))
- ctx->srid = ctx->lwgeom->srid;
+ // inspect first geometry
+ if (ctx->lwgeom != NULL)
+ if (lwgeom_has_srid(ctx->lwgeom))
+ ctx->srid = ctx->lwgeom->srid;
ctx->has_z = lwgeom_has_z(ctx->lwgeom);
ctx->has_m = lwgeom_has_m(ctx->lwgeom);
- ctx->lwgeom_type = ctx->lwgeom->type;
- ctx->geometry_type = (uint8_t) GeometryWriter::get_geometrytype(ctx->lwgeom);
- } else {
+ ctx->lwgeom_type = ctx->lwgeom->type;
+ ctx->geometry_type = (uint8_t)GeometryWriter::get_geometrytype(ctx->lwgeom);
+ else
LWDEBUG(2, "ctx->lwgeom is null");
ctx->geometry_type = 0;
- LWDEBUGF(2, "ctx->geometry_type %d", ctx->geometry_type);
+ LWDEBUGF(2, "ctx->geometry_type %d", ctx->geometry_type);
- std::vector<flatbuffers::Offset<FlatGeobuf::Column>> columns;
- std::vector<flatbuffers::Offset<FlatGeobuf::Column>> *pColumns = nullptr;
+ std::vector<flatbuffers::Offset<FlatGeobuf::Column>> columns;
+ std::vector<flatbuffers::Offset<FlatGeobuf::Column>> *pColumns = nullptr;
- if (ctx->columns_size > 0) {
- for (uint16_t i = 0; i < ctx->columns_size; i++) {
- auto c = ctx->columns[i];
- columns.push_back(CreateColumnDirect(fbb, c->name, (ColumnType) c->type));
- if (columns.size() > 0)
- pColumns = &columns;
+ if (ctx->columns_size > 0)
+ for (uint16_t i = 0; i < ctx->columns_size; i++)
+ auto c = ctx->columns[i];
+ columns.push_back(CreateColumnDirect(fbb, c->name, (ColumnType)c->type));
+ if (columns.size() > 0)
+ pColumns = &columns;
- flatbuffers::Offset<Crs> crs = 0;
- if (ctx->srid > 0)
- crs = CreateCrsDirect(fbb, nullptr, ctx->srid);
+ flatbuffers::Offset<Crs> crs = 0;
+ if (ctx->srid > 0)
+ crs = CreateCrsDirect(fbb, nullptr, ctx->srid);
- std::vector<double> envelope;
- std::vector<double> *pEnvelope = nullptr;
- if (ctx->has_extent) {
- envelope.push_back(ctx->xmin);
- envelope.push_back(ctx->ymin);
- envelope.push_back(ctx->xmax);
- envelope.push_back(ctx->ymax);
- if (envelope.size() > 0)
- pEnvelope = &envelope;
+ std::vector<double> envelope;
+ std::vector<double> *pEnvelope = nullptr;
+ if (ctx->has_extent)
+ envelope.push_back(ctx->xmin);
+ envelope.push_back(ctx->ymin);
+ envelope.push_back(ctx->xmax);
+ envelope.push_back(ctx->ymax);
+ if (envelope.size() > 0)
+ pEnvelope = &envelope;
- const auto header = CreateHeaderDirect(
- fbb, ctx->name, pEnvelope, (GeometryType) ctx->geometry_type, ctx->has_z, ctx->has_m, ctx->has_t, ctx->has_tm, pColumns, ctx->features_count, ctx->index_node_size, crs);
- fbb.FinishSizePrefixed(header);
- const auto buffer = fbb.GetBufferPointer();
- const auto size = fbb.GetSize();
+ const auto header = CreateHeaderDirect(fbb,
+ ctx->name,
+ pEnvelope,
+ (GeometryType)ctx->geometry_type,
+ ctx->has_z,
+ ctx->has_m,
+ ctx->has_t,
+ ctx->has_tm,
+ pColumns,
+ ctx->features_count,
+ ctx->index_node_size,
+ crs);
+ fbb.FinishSizePrefixed(header);
+ const auto buffer = fbb.GetBufferPointer();
+ const auto size = fbb.GetSize();
- LWDEBUGF(2, "header size %d (with size prefix)", size);
+ LWDEBUGF(2, "header size %d (with size prefix)", size);
- Verifier verifier(buffer, size - sizeof(uoffset_t));
- if (VerifySizePrefixedHeaderBuffer(verifier)) {
- lwerror("buffer did not pass verification");
- return -1;
+ Verifier verifier(buffer, size);
+ if (!VerifySizePrefixedHeaderBuffer(verifier))
+ lwerror("buffer did not pass verification");
+ return -1;
- ctx->buf = (uint8_t *) lwrealloc(ctx->buf, ctx->offset + size);
- LWDEBUGF(2, "copying to ctx->buf at offset %ld", ctx->offset);
+ ctx->buf = (uint8_t *)lwrealloc(ctx->buf, ctx->offset + size);
+ LWDEBUGF(2, "copying to ctx->buf at offset %llu", ctx->offset);
memcpy(ctx->buf + ctx->offset, buffer, size);
ctx->offset += size;
- return 0;
+ return 0;
-int flatgeobuf_encode_feature(ctx *ctx)
+int
+flatgeobuf_encode_feature(ctx *ctx)
- Offset<Geometry> geometry = 0;
- Offset<Vector<uint8_t>> properties = 0;
+ Offset<Geometry> geometry = 0;
+ Offset<Vector<uint8_t>> properties = 0;
- if (ctx->lwgeom != NULL && !lwgeom_is_empty(ctx->lwgeom)) {
- LWDEBUGG(3, ctx->lwgeom, "GeometryWriter input LWGEOM");
- if (ctx->lwgeom_type != ctx->lwgeom->type) {
- lwerror("mixed geometry type is not supported");
- return -1;
- GeometryWriter writer(fbb, ctx->lwgeom, (GeometryType) ctx->geometry_type, ctx->has_z, ctx->has_m);
- geometry = writer.write(0);
- if (ctx->properties_len > 0)
- properties = fbb.CreateVector<uint8_t>(ctx->properties, ctx->properties_len);
- FeatureBuilder builder(fbb);
- builder.add_geometry(geometry);
- builder.add_properties(properties);
- auto feature = builder.Finish();
- fbb.FinishSizePrefixed(feature);
+ if (ctx->lwgeom != NULL && !lwgeom_is_empty(ctx->lwgeom))
+ LWDEBUGG(3, ctx->lwgeom, "GeometryWriter input LWGEOM");
+ if (ctx->lwgeom_type != ctx->lwgeom->type)
+ lwerror("mixed geometry type is not supported");
+ return -1;
+ GeometryWriter writer(fbb, ctx->lwgeom, (GeometryType)ctx->geometry_type, ctx->has_z, ctx->has_m);
+ geometry = writer.write(0);
+ if (ctx->properties_len > 0)
+ properties = fbb.CreateVector<uint8_t>(ctx->properties, ctx->properties_len);
+ FeatureBuilder builder(fbb);
+ builder.add_geometry(geometry);
+ builder.add_properties(properties);
+ auto feature = builder.Finish();
+ fbb.FinishSizePrefixed(feature);
- LWDEBUGF(3, "encode_feature size %ld", size);
+ LWDEBUGF(3, "encode_feature size %u", size);
- if (VerifySizePrefixedFeatureBuffer(verifier)) {
- return -1;
+ if (!VerifySizePrefixedFeatureBuffer(verifier))
+ return -1;
- LWDEBUGF(3, "reallocating ctx->buf to size %ld", ctx->offset + size);
- ctx->buf = (uint8_t * ) lwrealloc(ctx->buf, ctx->offset + size);
- LWDEBUGF(3, "copying feature to ctx->buf at offset %ld", ctx->offset);
+ LWDEBUGF(3, "reallocating ctx->buf to size %llu", ctx->offset + size);
+ LWDEBUGF(3, "copying feature to ctx->buf at offset %llu", ctx->offset);
- if (ctx->create_index) {
- auto item = (flatgeobuf_item *) lwalloc(sizeof(flatgeobuf_item));
- memset(item, 0, sizeof(flatgeobuf_item));
- auto gbox = lwgeom_get_bbox(ctx->lwgeom);
- item->xmin = gbox->xmin;
- item->xmax = gbox->xmax;
- item->ymin = gbox->ymin;
- item->ymax = gbox->ymax;
- item->offset = ctx->offset;
- item->size = size;
- ctx->items[ctx->features_count] = item;
- ctx->offset += size;
+ if (ctx->create_index)
+ auto item = (flatgeobuf_item *)lwalloc(sizeof(flatgeobuf_item));
+ memset(item, 0, sizeof(flatgeobuf_item));
+ auto gbox = lwgeom_get_bbox(ctx->lwgeom);
+ item->xmin = gbox->xmin;
+ item->xmax = gbox->xmax;
+ item->ymin = gbox->ymin;
+ item->ymax = gbox->ymax;
+ item->offset = ctx->offset;
+ item->size = size;
+ ctx->items[ctx->features_count] = item;
+ ctx->offset += size;
ctx->features_count++;
- return 0;
+ return 0;
-void flatgeobuf_create_index(ctx *ctx)
+void
+flatgeobuf_create_index(ctx *ctx)
- // convert to structure expected by packedrtree
- std::vector<std::shared_ptr<Item>> items;
- for (uint64_t i = 0; i < ctx->features_count; i++) {
- const auto item = std::make_shared<FeatureItem>();
- item->nodeItem = {
- ctx->items[i]->xmin, ctx->items[i]->ymin, ctx->items[i]->xmax, ctx->items[i]->ymax
- item->offset = ctx->items[i]->offset;
- item->size = ctx->items[i]->size;
- items.push_back(item);
- // sort items
- hilbertSort(items);
- // calc extent
- auto extent = calcExtent(items);
- ctx->has_extent = true;
- ctx->xmin = extent.minX;
- ctx->ymin = extent.minY;
- ctx->xmax = extent.maxX;
- ctx->ymax = extent.maxY;
- // allocate new buffer and write magicbytes
- auto oldbuf = ctx->buf;
- auto oldoffset = ctx->offset;
- ctx->buf = (uint8_t *) lwalloc(sizeof(signed int) + FLATGEOBUF_MAGICBYTES_SIZE);
- memcpy(ctx->buf + sizeof(signed int), flatgeobuf_magicbytes, FLATGEOBUF_MAGICBYTES_SIZE);
- ctx->offset = sizeof(signed int) + FLATGEOBUF_MAGICBYTES_SIZE;
- // write new header
- flatgeobuf_encode_header(ctx);
- // calculate new offsets
- uint64_t featureOffset = 0;
- for (auto item : items) {
- auto featureItem = std::static_pointer_cast<FeatureItem>(item);
- featureItem->nodeItem.offset = featureOffset;
- featureOffset += featureItem->size;
- // create and write index
- PackedRTree tree(items, extent, ctx->index_node_size);
- const auto writeData = [&ctx] (const void *data, const size_t size) {
- memcpy(ctx->buf + ctx->offset, data, size);
- tree.streamWrite(writeData);
- // read items and write in sorted order
- ctx->buf = (uint8_t *) lwrealloc(ctx->buf, ctx->offset + featureItem->size);
- LWDEBUGF(2, "copy from offset %ld", featureItem->offset);
- memcpy(ctx->buf + ctx->offset, oldbuf + featureItem->offset, featureItem->size);
- ctx->offset += featureItem->size;
- lwfree(oldbuf);
+ // convert to structure expected by packedrtree
+ std::vector<std::shared_ptr<Item>> items;
+ for (uint64_t i = 0; i < ctx->features_count; i++)
+ const auto item = std::make_shared<FeatureItem>();
+ item->nodeItem = {ctx->items[i]->xmin, ctx->items[i]->ymin, ctx->items[i]->xmax, ctx->items[i]->ymax};
+ item->offset = ctx->items[i]->offset;
+ item->size = ctx->items[i]->size;
+ items.push_back(item);
+ // sort items
+ hilbertSort(items);
+ // calc extent
+ auto extent = calcExtent(items);
+ ctx->has_extent = true;
+ ctx->xmin = extent.minX;
+ ctx->ymin = extent.minY;
+ ctx->xmax = extent.maxX;
+ ctx->ymax = extent.maxY;
+ // allocate new buffer and write magicbytes
+ auto oldbuf = ctx->buf;
+ auto oldoffset = ctx->offset;
+ ctx->buf = (uint8_t *)lwalloc(sizeof(signed int) + FLATGEOBUF_MAGICBYTES_SIZE);
+ memcpy(ctx->buf + sizeof(signed int), flatgeobuf_magicbytes, FLATGEOBUF_MAGICBYTES_SIZE);
+ ctx->offset = sizeof(signed int) + FLATGEOBUF_MAGICBYTES_SIZE;
+ // write new header
+ flatgeobuf_encode_header(ctx);
+ // calculate new offsets
+ uint64_t featureOffset = 0;
+ for (auto item : items)
+ auto featureItem = std::static_pointer_cast<FeatureItem>(item);
+ featureItem->nodeItem.offset = featureOffset;
+ featureOffset += featureItem->size;
+ // create and write index
+ PackedRTree tree(items, extent, ctx->index_node_size);
+ const auto writeData = [&ctx](const void *data, const size_t size) {
+ memcpy(ctx->buf + ctx->offset, data, size);
+ tree.streamWrite(writeData);
+ // read items and write in sorted order
+ ctx->buf = (uint8_t *)lwrealloc(ctx->buf, ctx->offset + featureItem->size);
+ LWDEBUGF(2, "copy from offset %llu", featureItem->offset);
+ memcpy(ctx->buf + ctx->offset, oldbuf + featureItem->offset, featureItem->size);
+ ctx->offset += featureItem->size;
+ lwfree(oldbuf);
-int flatgeobuf_decode_feature(ctx *ctx)
+int
+flatgeobuf_decode_feature(ctx *ctx)
- LWDEBUGF(2, "reading size prefix at %ld", ctx->offset);
- uoffset_t size;
- if (!flatgeobuf_size_prefixed_buffer_size(ctx, &size))
+ LWDEBUGF(2, "reading size prefix at %llu", ctx->offset);
+ auto size = flatbuffers::GetPrefixedSize(ctx->buf + ctx->offset);
+ LWDEBUGF(2, "size is %u (without size prefix)", size);
+ Verifier verifier(ctx->buf + ctx->offset, flatgeobuf_size_prefixed_verifier_length(size));
return -1;
- LWDEBUGF(2, "size is %ld (without size prefix)", size);
- Verifier verifier(ctx->buf + ctx->offset, size + sizeof(uoffset_t));
- if (!VerifySizePrefixedFeatureBuffer(verifier)) {
- return -1;
+ ctx->offset += sizeof(uoffset_t);
- ctx->offset += sizeof(uoffset_t);
- auto feature = GetFeature(ctx->buf + ctx->offset);
- const auto geometry = feature->geometry();
- if (geometry != nullptr) {
- LWDEBUGF(3, "Constructing GeometryReader with geometry_type %d has_z %d haz_m %d", ctx->geometry_type, ctx->has_z, ctx->has_m);
- GeometryReader reader(geometry, (GeometryType) ctx->geometry_type, ctx->has_z, ctx->has_m);
- ctx->lwgeom = reader.read();
- lwgeom_set_srid(ctx->lwgeom, ctx->srid);
- LWDEBUGG(3, ctx->lwgeom, "GeometryReader output LWGEOM");
- } else {
- ctx->lwgeom = NULL;
- if (feature->properties() != nullptr && feature->properties()->size() != 0) {
- ctx->properties = (uint8_t *) feature->properties()->data();
- ctx->properties_len = feature->properties()->size();
- } else {
- ctx->properties_len = 0;
- return 0;
-int flatgeobuf_decode_header(ctx *ctx)
- uoffset_t size;
- return -1;
- if (!VerifySizePrefixedHeaderBuffer(verifier)) {
- return -1;
- LWDEBUGF(2, "reading header at %ld with size %ld", ctx->offset, size);
- auto header = GetHeader(ctx->buf + ctx->offset);
+ auto feature = GetFeature(ctx->buf + ctx->offset);
- ctx->geometry_type = (uint8_t) header->geometry_type();
- ctx->features_count = header->features_count();
+ const auto geometry = feature->geometry();
+ if (geometry != nullptr)
+ LWDEBUGF(3,
+ "Constructing GeometryReader with geometry_type %d has_z %d haz_m %d",
+ ctx->geometry_type,
+ ctx->has_z,
+ ctx->has_m);
+ GeometryReader reader(geometry, (GeometryType)ctx->geometry_type, ctx->has_z, ctx->has_m);
+ ctx->lwgeom = reader.read();
+ lwgeom_set_srid(ctx->lwgeom, ctx->srid);
+ LWDEBUGG(3, ctx->lwgeom, "GeometryReader output LWGEOM");
+ else
+ ctx->lwgeom = NULL;
+ if (feature->properties() != nullptr && feature->properties()->size() != 0)
+ ctx->properties = (uint8_t *)feature->properties()->data();
+ ctx->properties_len = feature->properties()->size();
+ else
+ ctx->properties_len = 0;
+ return 0;
+int
+flatgeobuf_decode_header(ctx *ctx)
+ return -1;
+ LWDEBUGF(2, "reading header at %llu with size %u", ctx->offset, size);
+ auto header = GetHeader(ctx->buf + ctx->offset);
+ ctx->geometry_type = (uint8_t)header->geometry_type();
+ ctx->features_count = header->features_count();
ctx->has_z = header->has_z();
- ctx->has_m = header->has_m();
- ctx->has_t = header->has_t();
- ctx->has_tm = header->has_tm();
- ctx->index_node_size = header->index_node_size();
- auto crs = header->crs();
- if (crs != nullptr)
- ctx->srid = crs->code();
- auto columns = header->columns();
- if (columns != nullptr) {
- auto size = columns->size();
- ctx->columns = (flatgeobuf_column **) lwalloc(sizeof(flatgeobuf_column *) * size);
- ctx->columns_size = size;
- for (uint32_t i = 0; i < size; i++) {
- auto column = columns->Get(i);
- ctx->columns[i] = (flatgeobuf_column *) lwalloc(sizeof(flatgeobuf_column));
- memset(ctx->columns[i], 0, sizeof(flatgeobuf_column));
- ctx->columns[i]->name = column->name()->c_str();
- ctx->columns[i]->type = (uint8_t) column->type();
+ ctx->has_m = header->has_m();
+ ctx->has_t = header->has_t();
+ ctx->has_tm = header->has_tm();
+ ctx->index_node_size = header->index_node_size();
+ auto crs = header->crs();
+ if (crs != nullptr)
+ ctx->srid = crs->code();
+ auto columns = header->columns();
+ if (columns != nullptr)
+ auto size = columns->size();
+ ctx->columns = (flatgeobuf_column **)lwalloc(sizeof(flatgeobuf_column *) * size);
+ ctx->columns_size = size;
+ for (uint32_t i = 0; i < size; i++)
+ auto column = columns->Get(i);
+ ctx->columns[i] = (flatgeobuf_column *)lwalloc(sizeof(flatgeobuf_column));
+ memset(ctx->columns[i], 0, sizeof(flatgeobuf_column));
+ ctx->columns[i]->name = column->name()->c_str();
+ ctx->columns[i]->type = (uint8_t)column->type();
LWDEBUGF(2, "ctx->geometry_type: %d", ctx->geometry_type);
LWDEBUGF(2, "ctx->columns_len: %d", ctx->columns_size);
- if (ctx->index_node_size > 0 && ctx->features_count > 0) {
- auto treeSize = PackedRTree::size(ctx->features_count, ctx->index_node_size);
- LWDEBUGF(2, "Adding tree size %ld to offset", treeSize);
- ctx->offset += treeSize;
+ if (ctx->index_node_size > 0 && ctx->features_count > 0)
+ uint64_t treeSize;
+ try
+ treeSize = PackedRTree::size(ctx->features_count, ctx->index_node_size);
+ catch (const std::exception &e)
+ lwerror("flatgeobuf: invalid packed rtree metadata: %s", e.what());
+ return -1;
+ if (treeSize > ctx->size - ctx->offset)
+ lwerror("flatgeobuf: packed rtree exceeds remaining input");
+ return -1;
+ LWDEBUGF(2, "Adding tree size %llu to offset", treeSize);
+ ctx->offset += treeSize;
- return 0;
+ return 0;
diff --git a/deps/flatgeobuf/geometryreader.cpp b/deps/flatgeobuf/geometryreader.cpp
index 4ed92021f0..413e56257c 100644
--- a/deps/flatgeobuf/geometryreader.cpp
+++ b/deps/flatgeobuf/geometryreader.cpp
@@ -27,179 +27,231 @@
-LWPOINT *GeometryReader::readPoint()
+LWPOINT *
+GeometryReader::readPoint()
- POINTARRAY *pa;
+ POINTARRAY *pa;
POINT4D pt;
- pa = ptarray_construct_empty(m_has_z, m_has_m, 1);
+ pa = ptarray_construct_empty(m_has_z, m_has_m, 1);
- if (m_geometry->xy() == nullptr || m_geometry->xy()->size() == 0) {
- return lwpoint_construct(0, NULL, pa);
+ if (m_geometry->xy() == nullptr || m_geometry->xy()->size() == 0)
+ return lwpoint_construct(0, NULL, pa);
- const auto xy = m_geometry->xy()->data();
+ const auto xy = m_geometry->xy();
- double x = xy[m_offset + 0];
- double y = xy[m_offset + 1];
- double z = 0;
- double m = 0;
+ double x = xy->Get(m_offset + 0);
+ double y = xy->Get(m_offset + 1);
+ double z = 0;
+ double m = 0;
- if (m_has_z)
- z = m_geometry->z()->data()[m_offset];
- if (m_has_m)
- m = m_geometry->m()->data()[m_offset];
+ if (m_has_z)
+ z = m_geometry->z()->Get(m_offset);
+ if (m_has_m)
+ m = m_geometry->m()->Get(m_offset);
- pt = (POINT4D) { x, y, z, m };
+ pt = (POINT4D){x, y, z, m};
ptarray_append_point(pa, &pt, LW_TRUE);
-POINTARRAY *GeometryReader::readPA()
+POINTARRAY *
+GeometryReader::readPA()
- POINTARRAY *pa;
+ POINTARRAY *pa;
POINT4D pt;
- uint32_t npoints;
- const double *xy = m_geometry->xy()->data();
- const double *z = m_has_z ? m_geometry->z()->data() : nullptr;
- const double *m = m_has_m ? m_geometry->m()->data() : nullptr;
+ const auto z = m_has_z ? m_geometry->z() : nullptr;
+ const auto m = m_has_m ? m_geometry->m() : nullptr;
pa = ptarray_construct_empty(m_has_z, m_has_m, m_length);
- for (uint32_t i = m_offset; i < m_offset + m_length; i++) {
- double xv = xy[i * 2 + 0];
- double yv = xy[i * 2 + 1];
- double zv = 0;
- double mv = 0;
- if (m_has_z)
- zv = z[i];
- if (m_has_m)
- mv = m[i];
- pt = (POINT4D) { xv, yv, zv, mv };
- ptarray_append_point(pa, &pt, LW_TRUE);
+ for (uint32_t i = m_offset; i < m_offset + m_length; i++)
+ double xv = xy->Get(i * 2 + 0);
+ double yv = xy->Get(i * 2 + 1);
+ double zv = 0;
+ double mv = 0;
+ if (m_has_z)
+ zv = z->Get(i);
+ if (m_has_m)
+ mv = m->Get(i);
+ pt = (POINT4D){xv, yv, zv, mv};
+ ptarray_append_point(pa, &pt, LW_TRUE);
return pa;
-LWMPOINT *GeometryReader::readMultiPoint()
+LWMPOINT *
+GeometryReader::readMultiPoint()
- POINTARRAY *pa = readPA();
+ POINTARRAY *pa = readPA();
return lwmpoint_construct(0, pa);
-LWLINE *GeometryReader::readLineString()
+LWLINE *
+GeometryReader::readLineString()
return lwline_construct(0, NULL, pa);
-LWMLINE *GeometryReader::readMultiLineString()
+LWMLINE *
+GeometryReader::readMultiLineString()
- auto ends = m_geometry->ends();
+ auto ends = m_geometry->ends();
+ const uint32_t totalPoints = m_length;
- uint32_t ngeoms = 1;
- if (ends != nullptr && ends->size() > 1)
+ uint32_t ngeoms = 1;
+ if (ends != nullptr && ends->size() > 1)
ngeoms = ends->size();
- auto *lwmline = lwmline_construct_empty(0, m_has_z, m_has_m);
- if (ngeoms > 1) {
- for (uint32_t i = 0; i < ngeoms; i++) {
+ auto *lwmline = lwmline_construct_empty(0, m_has_z, m_has_m);
+ if (ngeoms > 1)
+ for (uint32_t i = 0; i < ngeoms; i++)
const auto e = ends->Get(i);
+ if (e < m_offset || e > totalPoints)
+ lwerror("flatgeobuf: invalid geometry ends");
m_length = e - m_offset;
lwmline_add_lwline(lwmline, lwline_construct(0, NULL, pa));
m_offset = e;
- } else {
+ else
- return lwmline;
+ return lwmline;
-LWPOLY *GeometryReader::readPolygon()
+LWPOLY *
+GeometryReader::readPolygon()
- const auto ends = m_geometry->ends();
+ const auto ends = m_geometry->ends();
- uint32_t nrings = 1;
- nrings = ends->size();
+ uint32_t nrings = 1;
+ nrings = ends->size();
- auto **ppa = (POINTARRAY **) lwalloc(sizeof(POINTARRAY *) * nrings);
- if (nrings > 1) {
- for (uint32_t i = 0; i < nrings; i++) {
- const auto e = ends->Get(i);
- m_length = e - m_offset;
- ppa[i] = readPA();
- m_offset = e;
- } else {
- ppa[0] = readPA();
+ auto **ppa = (POINTARRAY **)lwalloc(sizeof(POINTARRAY *) * nrings);
+ if (nrings > 1)
+ for (uint32_t i = 0; i < nrings; i++)
+ const auto e = ends->Get(i);
+ m_length = e - m_offset;
+ ppa[i] = readPA();
+ m_offset = e;
+ else
+ ppa[0] = readPA();
- return lwpoly_construct(0, NULL, nrings, ppa);
+ return lwpoly_construct(0, NULL, nrings, ppa);
-LWMPOLY *GeometryReader::readMultiPolygon()
+LWMPOLY *
+GeometryReader::readMultiPolygon()
- auto parts = m_geometry->parts();
- auto *mp = lwmpoly_construct_empty(0, m_has_z, m_has_m);
- for (uoffset_t i = 0; i < parts->size(); i++) {
- GeometryReader reader { parts->Get(i), GeometryType::Polygon, m_has_z, m_has_m };
- const auto p = (LWPOLY *) reader.read();
- lwmpoly_add_lwpoly(mp, p);
- return mp;
+ auto parts = m_geometry->parts();
+ if (parts == nullptr)
+ lwerror("flatgeobuf: missing geometry parts");
+ auto *mp = lwmpoly_construct_empty(0, m_has_z, m_has_m);
+ for (uoffset_t i = 0; i < parts->size(); i++)
+ GeometryReader reader{parts->Get(i), GeometryType::Polygon, m_has_z, m_has_m};
+ const auto p = (LWPOLY *)reader.read();
+ lwmpoly_add_lwpoly(mp, p);
+ return mp;
-LWCOLLECTION *GeometryReader::readGeometryCollection()
+LWCOLLECTION *
+GeometryReader::readGeometryCollection()
- auto *gc = lwcollection_construct_empty(COLLECTIONTYPE, 0, m_has_z, m_has_m);
- auto part = parts->Get(i);
- GeometryReader reader { part, part->type(), m_has_z, m_has_m };
- const auto g = reader.read();
- lwcollection_add_lwgeom(gc, g);
- return gc;
+ auto *gc = lwcollection_construct_empty(COLLECTIONTYPE, 0, m_has_z, m_has_m);
+ auto part = parts->Get(i);
+ GeometryReader reader{part, part->type(), m_has_z, m_has_m};
+ const auto g = reader.read();
+ lwcollection_add_lwgeom(gc, g);
+ return gc;
-LWGEOM *GeometryReader::read()
+LWGEOM *
+GeometryReader::read()
- // nested types
- switch (m_geometry_type) {
- case GeometryType::GeometryCollection: return (LWGEOM *) readGeometryCollection();
- case GeometryType::MultiPolygon: return (LWGEOM *) readMultiPolygon();
- /*case GeometryType::CompoundCurve: return readCompoundCurve();
- case GeometryType::CurvePolygon: return readCurvePolygon();
- case GeometryType::MultiCurve: return readMultiCurve();
- case GeometryType::MultiSurface: return readMultiSurface();
- case GeometryType::PolyhedralSurface: return readPolyhedralSurface();*/
- default: break;
+ // nested types
+ switch (m_geometry_type)
+ case GeometryType::GeometryCollection:
+ return (LWGEOM *)readGeometryCollection();
+ case GeometryType::MultiPolygon:
+ return (LWGEOM *)readMultiPolygon();
+ /*case GeometryType::CompoundCurve: return readCompoundCurve();
+ case GeometryType::CurvePolygon: return readCurvePolygon();
+ case GeometryType::MultiCurve: return readMultiCurve();
+ case GeometryType::MultiSurface: return readMultiSurface();
+ case GeometryType::PolyhedralSurface: return readPolyhedralSurface();*/
+ default:
+ break;
- // if not nested must have geometry data
- const auto pXy = m_geometry->xy();
- const auto xySize = pXy->size();
- m_length = xySize / 2;
+ // if not nested must have geometry data
+ const auto pXy = m_geometry->xy();
+ if (pXy == nullptr)
+ lwerror("flatgeobuf: missing geometry coordinates");
- case GeometryType::Point: return (LWGEOM *) readPoint();
- case GeometryType::MultiPoint: return (LWGEOM *) readMultiPoint();
- case GeometryType::LineString: return (LWGEOM *) readLineString();
- case GeometryType::MultiLineString: return (LWGEOM *) readMultiLineString();
- case GeometryType::Polygon: return (LWGEOM *) readPolygon();
- case GeometryType::CircularString: return readSimpleCurve<OGRCircularString>(true);
- case GeometryType::Triangle: return readTriangle();
- case GeometryType::TIN: return readTIN();
- default:
- lwerror("flatgeobuf: GeometryReader::read: Unknown type %d", (int) m_geometry_type);
- return nullptr;
\ No newline at end of file
+ const auto xySize = pXy->size();
+ if (xySize % 2 != 0)
+ lwerror("flatgeobuf: invalid xy coordinate count");
+ m_length = xySize / 2;
+ if (m_has_z && (m_geometry->z() == nullptr || m_geometry->z()->size() < m_length))
+ lwerror("flatgeobuf: invalid z coordinate count");
+ if (m_has_m && (m_geometry->m() == nullptr || m_geometry->m()->size() < m_length))
+ lwerror("flatgeobuf: invalid m coordinate count");
+ case GeometryType::Point:
+ return (LWGEOM *)readPoint();
+ case GeometryType::MultiPoint:
+ return (LWGEOM *)readMultiPoint();
+ case GeometryType::LineString:
+ return (LWGEOM *)readLineString();
+ case GeometryType::MultiLineString:
+ return (LWGEOM *)readMultiLineString();
+ case GeometryType::Polygon:
+ return (LWGEOM *)readPolygon();
+ case GeometryType::CircularString: return readSimpleCurve<OGRCircularString>(true);
+ case GeometryType::Triangle: return readTriangle();
+ case GeometryType::TIN: return readTIN();
+ default:
+ lwerror("flatgeobuf: GeometryReader::read: Unknown type %d", (int)m_geometry_type);
+ return nullptr;
diff --git a/postgis/flatgeobuf.c b/postgis/flatgeobuf.c
index 6deece6999..0583b48ab4 100644
--- a/postgis/flatgeobuf.c
+++ b/postgis/flatgeobuf.c
@@ -34,7 +34,122 @@
#include "utils/datetime.h"
#include "utils/jsonb.h"
-static uint8_t get_column_type(Oid typoid) {
+static uint16_t
+flatgeobuf_le16(uint16_t v)
+#if IS_BIG_ENDIAN
+ return (uint16_t)((v << 8) | (v >> 8));
+#else
+ return v;
+#endif
+static uint32_t
+flatgeobuf_le32(uint32_t v)
+#if IS_BIG_ENDIAN
+ return ((v & UINT32_C(0x000000ff)) << 24) | ((v & UINT32_C(0x0000ff00)) << 8) |
+ ((v & UINT32_C(0x00ff0000)) >> 8) | ((v & UINT32_C(0xff000000)) >> 24);
+#else
+ return v;
+#endif
+static uint64_t
+flatgeobuf_le64(uint64_t v)
+#if IS_BIG_ENDIAN
+ return ((v & UINT64_C(0x00000000000000ff)) << 56) | ((v & UINT64_C(0x000000000000ff00)) << 40) |
+ ((v & UINT64_C(0x0000000000ff0000)) << 24) | ((v & UINT64_C(0x00000000ff000000)) << 8) |
+ ((v & UINT64_C(0x000000ff00000000)) >> 8) | ((v & UINT64_C(0x0000ff0000000000)) >> 24) |
+ ((v & UINT64_C(0x00ff000000000000)) >> 40) | ((v & UINT64_C(0xff00000000000000)) >> 56);
+#else
+ return v;
+#endif
+static void
+flatgeobuf_write_le16(uint8_t *dst, uint16_t v)
+ v = flatgeobuf_le16(v);
+ memcpy(dst, &v, sizeof(v));
+static void
+flatgeobuf_write_le32(uint8_t *dst, uint32_t v)
+ v = flatgeobuf_le32(v);
+static void
+flatgeobuf_write_le64(uint8_t *dst, uint64_t v)
+ v = flatgeobuf_le64(v);
+static uint16_t
+flatgeobuf_read_le16(const uint8_t *src)
+ uint16_t v;
+ memcpy(&v, src, sizeof(v));
+ return flatgeobuf_le16(v);
+static uint32_t
+flatgeobuf_read_le32(const uint8_t *src)
+ uint32_t v;
+ return flatgeobuf_le32(v);
+static uint64_t
+flatgeobuf_read_le64(const uint8_t *src)
+ uint64_t v;
+ return flatgeobuf_le64(v);
+static float
+flatgeobuf_read_float_le(const uint8_t *src)
+ uint32_t bits = flatgeobuf_read_le32(src);
+ float value;
+ memcpy(&value, &bits, sizeof(value));
+ return value;
+static double
+flatgeobuf_read_double_le(const uint8_t *src)
+ uint64_t bits = flatgeobuf_read_le64(src);
+ double value;
+ return value;
+static void
+flatgeobuf_write_float_le(uint8_t *dst, float value)
+ uint32_t bits;
+ memcpy(&bits, &value, sizeof(bits));
+ flatgeobuf_write_le32(dst, bits);
+static void
+flatgeobuf_write_double_le(uint8_t *dst, double value)
+ uint64_t bits;
+ flatgeobuf_write_le64(dst, bits);
+static uint8_t
+get_column_type(Oid typoid)
switch (typoid)
case BOOLOID:
@@ -62,11 +177,11 @@ static uint8_t get_column_type(Oid typoid) {
case TIMESTAMPTZOID:
return flatgeobuf_column_type_datetime;
- elog(ERROR, "flatgeobuf: get_column_type: '%d' column type not supported",
- typoid);
+ elog(ERROR, "flatgeobuf: get_column_type: '%d' column type not supported", typoid);
-static void inspect_table(struct flatgeobuf_agg_ctx *ctx)
+static void
+inspect_table(struct flatgeobuf_agg_ctx *ctx)
flatgeobuf_column *c;
flatgeobuf_column **columns;
@@ -84,18 +199,24 @@ static void inspect_table(struct flatgeobuf_agg_ctx *ctx)
// inspect columns
// NOTE: last element will be unused if geom attr is found
- for (int i = 0; i < natts; i++) {
+ for (int i = 0; i < natts; i++)
Oid typoid = getBaseType(TupleDescAttr(tupdesc, i)->atttypid);
const char *key = TupleDescAttr(tupdesc, i)->attname.data;
POSTGIS_DEBUGF(2, "inspecting column definition for %s with oid %d", key, typoid);
- if (ctx->geom_name == NULL) {
- if (!geom_found && typoid == postgis_oid(GEOMETRYOID)) {
+ if (ctx->geom_name == NULL)
+ if (!geom_found && typoid == postgis_oid(GEOMETRYOID))
ctx->geom_index = i;
geom_found = true;
continue;
- } else {
- if (!geom_found && strcmp(key, ctx->geom_name) == 0) {
+ else
+ if (!geom_found && strcmp(key, ctx->geom_name) == 0)
geom_found = true;
continue;
@@ -103,7 +224,7 @@ static void inspect_table(struct flatgeobuf_agg_ctx *ctx)
POSTGIS_DEBUGF(2, "creating column definition for %s with oid %d", key, typoid);
- c = (flatgeobuf_column *) palloc0(sizeof(flatgeobuf_column));
+ c = (flatgeobuf_column *)palloc0(sizeof(flatgeobuf_column));
c->name = pstrdup(key);
c->type = get_column_type(typoid);
columns[columns_size] = c;
@@ -113,21 +234,25 @@ static void inspect_table(struct flatgeobuf_agg_ctx *ctx)
if (!geom_found)
elog(ERROR, "no geom column found");
- if (columns_size > 0) {
+ if (columns_size > 0)
ctx->ctx->columns = columns;
ctx->ctx->columns_size = columns_size;
// ensure properties has room for at least size
-static void ensure_properties_size(struct flatgeobuf_agg_ctx *ctx, size_t size)
+static void
+ensure_properties_size(struct flatgeobuf_agg_ctx *ctx, size_t size)
- if (ctx->ctx->properties_size == 0) {
+ if (ctx->ctx->properties_size == 0)
ctx->ctx->properties_size = 1024 * 4;
POSTGIS_DEBUGF(2, "flatgeobuf: properties buffer to size %d", ctx->ctx->properties_size);
ctx->ctx->properties = palloc(ctx->ctx->properties_size);
- if (ctx->ctx->properties_size < size) {
+ if (ctx->ctx->properties_size < size)
ctx->ctx->properties_size = ctx->ctx->properties_size * 2;
POSTGIS_DEBUGF(2, "flatgeobuf: reallocating properties buffer to size %d", ctx->ctx->properties_size);
ctx->ctx->properties = repalloc(ctx->ctx->properties, ctx->ctx->properties_size);
@@ -136,21 +261,25 @@ static void ensure_properties_size(struct flatgeobuf_agg_ctx *ctx, size_t size)
// ensure items have room for at least ctx->ctx->features_count + 1
-static void ensure_items_len(struct flatgeobuf_agg_ctx *ctx)
+static void
+ensure_items_len(struct flatgeobuf_agg_ctx *ctx)
- if (ctx->ctx->features_count == 0) {
+ if (ctx->ctx->features_count == 0)
ctx->ctx->items_len = 32;
ctx->ctx->items = palloc(sizeof(flatgeobuf_item *) * ctx->ctx->items_len);
- if (ctx->ctx->items_len < (ctx->ctx->features_count + 1)) {
+ if (ctx->ctx->items_len < (ctx->ctx->features_count + 1))
ctx->ctx->items_len = ctx->ctx->items_len * 2;
- POSTGIS_DEBUGF(2, "flatgeobuf: reallocating items to len %ld", ctx->ctx->items_len);
+ POSTGIS_DEBUGF(2, "flatgeobuf: reallocating items to len %lld", ctx->ctx->items_len);
ctx->ctx->items = repalloc(ctx->ctx->items, sizeof(flatgeobuf_item *) * ctx->ctx->items_len);
ensure_items_len(ctx);
-static void encode_properties(flatgeobuf_agg_ctx *ctx)
+static void
+encode_properties(flatgeobuf_agg_ctx *ctx)
uint16_t ci = 0;
size_t offset = 0;
@@ -168,19 +297,21 @@ static void encode_properties(flatgeobuf_agg_ctx *ctx)
double double_value;
char *string_value;
- //Jsonb *jb;
+ // Jsonb *jb;
- for (i = 0; i < (uint32_t) ctx->tupdesc->natts; i++) {
+ for (i = 0; i < (uint32_t)ctx->tupdesc->natts; i++)
if (ctx->geom_index == i)
continue;
datum = GetAttributeByNum(ctx->row, i + 1, &isnull);
if (isnull)
continue;
ensure_properties_size(ctx, offset + sizeof(ci));
- memcpy(ctx->ctx->properties + offset, &ci, sizeof(ci));
+ flatgeobuf_write_le16(ctx->ctx->properties + offset, ci);
offset += sizeof(ci);
typoid = getBaseType(TupleDescAttr(ctx->tupdesc, i)->atttypid);
- switch (typoid) {
+ switch (typoid)
case BOOLOID:
byte_value = DatumGetBool(datum) ? 1 : 0;
ensure_properties_size(ctx, offset + sizeof(byte_value));
@@ -190,38 +321,38 @@ static void encode_properties(flatgeobuf_agg_ctx *ctx)
case INT2OID:
short_value = DatumGetInt16(datum);
ensure_properties_size(ctx, offset + sizeof(short_value));
- memcpy(ctx->ctx->properties + offset, &short_value, sizeof(short_value));
+ flatgeobuf_write_le16(ctx->ctx->properties + offset, (uint16_t)short_value);
offset += sizeof(short_value);
break;
case INT4OID:
int_value = DatumGetInt32(datum);
ensure_properties_size(ctx, offset + sizeof(int_value));
- memcpy(ctx->ctx->properties + offset, &int_value, sizeof(int_value));
+ flatgeobuf_write_le32(ctx->ctx->properties + offset, (uint32_t)int_value);
offset += sizeof(int_value);
break;
case INT8OID:
long_value = DatumGetInt64(datum);
ensure_properties_size(ctx, offset + sizeof(long_value));
- memcpy(ctx->ctx->properties + offset, &long_value, sizeof(long_value));
+ flatgeobuf_write_le64(ctx->ctx->properties + offset, (uint64_t)long_value);
offset += sizeof(long_value);
break;
case FLOAT4OID:
float_value = DatumGetFloat4(datum);
ensure_properties_size(ctx, offset + sizeof(float_value));
- memcpy(ctx->ctx->properties + offset, &float_value, sizeof(float_value));
+ flatgeobuf_write_float_le(ctx->ctx->properties + offset, float_value);
offset += sizeof(float_value);
break;
case FLOAT8OID:
double_value = DatumGetFloat8(datum);
ensure_properties_size(ctx, offset + sizeof(double_value));
- memcpy(ctx->ctx->properties + offset, &double_value, sizeof(double_value));
+ flatgeobuf_write_double_le(ctx->ctx->properties + offset, double_value);
offset += sizeof(double_value);
break;
case TEXTOID:
string_value = text_to_cstring(DatumGetTextP(datum));
len = strlen(string_value);
ensure_properties_size(ctx, offset + sizeof(len));
- memcpy(ctx->ctx->properties + offset, &len, sizeof(len));
+ flatgeobuf_write_le32(ctx->ctx->properties + offset, len);
offset += sizeof(len);
ensure_properties_size(ctx, offset + len);
memcpy(ctx->ctx->properties + offset, string_value, len);
@@ -239,45 +370,70 @@ static void encode_properties(flatgeobuf_agg_ctx *ctx)
EncodeDateTime(&tm, fsec, true, tz, tzn, USE_ISO_DATES, string_value);
offset += len;
break;
- // TODO: handle date/time types
- // case JSONBOID:
- // jb = DatumGetJsonbP(datum);
- // string_value = JsonbToCString(NULL, &jb->root, VARSIZE(jb));
- // len = strlen(string_value);
- // memcpy(data + offset, &len, sizeof(len));
- // offset += sizeof(len);
- // memcpy(data + offset, string_value, len);
- // offset += len;
- // break;
+ // TODO: handle date/time types
+ // case JSONBOID:
+ // jb = DatumGetJsonbP(datum);
+ // string_value = JsonbToCString(NULL, &jb->root, VARSIZE(jb));
+ // len = strlen(string_value);
+ // memcpy(data + offset, &len, sizeof(len));
+ // offset += sizeof(len);
+ // memcpy(data + offset, string_value, len);
+ // offset += len;
+ // break;
ci++;
- if (offset > 0) {
+ if (offset > 0)
POSTGIS_DEBUGF(3, "offset %ld", offset);
ctx->ctx->properties_len = offset;
-void flatgeobuf_check_magicbytes(struct flatgeobuf_decode_ctx *ctx)
+void
+flatgeobuf_check_magicbytes(struct flatgeobuf_decode_ctx *ctx)
- uint8_t *buf = ctx->ctx->buf + ctx->ctx->offset;
+ uint8_t *buf;
uint32_t i;
+ if (ctx->ctx->offset > ctx->ctx->size || FLATGEOBUF_MAGICBYTES_SIZE > ctx->ctx->size - ctx->ctx->offset)
+ elog(ERROR, "Data is not FlatGeobuf");
+ buf = ctx->ctx->buf + ctx->ctx->offset;
for (i = 0; i < FLATGEOBUF_MAGICBYTES_SIZE / 2; i++)
if (buf[i] != flatgeobuf_magicbytes[i])
ctx->ctx->offset += FLATGEOBUF_MAGICBYTES_SIZE;
-static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values, bool *isnull)
+void
+flatgeobuf_check_sizeprefix(flatgeobuf_ctx *ctx)
+ uint64_t remaining;
+ uint32_t size;
+ if (ctx->offset > ctx->size)
+ elog(ERROR, "flatgeobuf: read past end of input");
+ remaining = ctx->size - ctx->offset;
+ if (remaining < sizeof(uint32_t))
+ elog(ERROR, "flatgeobuf: truncated size prefix");
+ size = flatgeobuf_read_le32(ctx->buf + ctx->offset);
+ if ((uint64_t)size > remaining - sizeof(uint32_t))
+ elog(ERROR, "flatgeobuf: size prefix exceeds remaining input");
+static void
+decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values, bool *isnull)
uint16_t i, ci;
flatgeobuf_column *column;
@@ -290,10 +446,11 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
if (size > 0 && size < (sizeof(uint16_t) + sizeof(uint8_t)))
elog(ERROR, "flatgeobuf: decode_properties: Unexpected properties data size %d", size);
- while (offset + 1 < size) {
+ while (offset + 1 < size)
if (offset + sizeof(uint16_t) > size)
elog(ERROR, "flatgeobuf: decode_properties: Unexpected offset %d", offset);
- memcpy(&i, data + offset, sizeof(uint16_t));
+ i = flatgeobuf_read_le16(data + offset);
ci = i + 2;
offset += sizeof(uint16_t);
if (i >= ctx->ctx->columns_size)
@@ -301,7 +458,8 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
column = ctx->ctx->columns[i];
type = column->type;
isnull[ci] = false;
- switch (type) {
+ switch (type)
case flatgeobuf_column_type_bool: {
uint8_t value;
if (offset + sizeof(uint8_t) > size)
@@ -333,7 +491,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
int16_t value;
if (offset + sizeof(int16_t) > size)
elog(ERROR, "flatgeobuf: decode_properties: Invalid size for short value");
- memcpy(&value, data + offset, sizeof(int16_t));
+ value = (int16_t)flatgeobuf_read_le16(data + offset);
values[ci] = Int16GetDatum(value);
offset += sizeof(int16_t);
break;
@@ -342,7 +500,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
uint16_t value;
elog(ERROR, "flatgeobuf: decode_properties: Invalid size for ushort value");
- memcpy(&value, data + offset, sizeof(uint16_t));
+ value = flatgeobuf_read_le16(data + offset);
values[ci] = UInt16GetDatum(value);
break;
@@ -351,7 +509,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
int32_t value;
if (offset + sizeof(int32_t) > size)
elog(ERROR, "flatgeobuf: decode_properties: Invalid size for int value");
- memcpy(&value, data + offset, sizeof(int32_t));
+ value = (int32_t)flatgeobuf_read_le32(data + offset);
values[ci] = Int32GetDatum(value);
offset += sizeof(int32_t);
break;
@@ -360,8 +518,8 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
uint32_t value;
if (offset + sizeof(uint32_t) > size)
elog(ERROR, "flatgeobuf: decode_properties: Invalid size for uint value");
- memcpy(&value, data + offset, sizeof(uint32_t));
- values[ci] = Int64GetDatum((int64_t)(uint64_t) value);
+ value = flatgeobuf_read_le32(data + offset);
+ values[ci] = Int64GetDatum((int64_t)(uint64_t)value);
offset += sizeof(uint32_t);
break;
@@ -369,7 +527,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
int64_t value;
if (offset + sizeof(int64_t) > size)
elog(ERROR, "flatgeobuf: decode_properties: Invalid size for long value");
- memcpy(&value, data + offset, sizeof(int64_t));
+ value = (int64_t)flatgeobuf_read_le64(data + offset);
values[ci] = Int64GetDatum(value);
offset += sizeof(int64_t);
break;
@@ -378,7 +536,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
uint64_t value;
if (offset + sizeof(uint64_t) > size)
elog(ERROR, "flatgeobuf: decode_properties: Invalid size for ulong value");
- memcpy(&value, data + offset, sizeof(uint64_t));
+ value = flatgeobuf_read_le64(data + offset);
values[ci] = UInt64GetDatum(value);
offset += sizeof(uint64_t);
break;
@@ -387,7 +545,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
float value;
if (offset + sizeof(float) > size)
elog(ERROR, "flatgeobuf: decode_properties: Invalid size for float value");
- memcpy(&value, data + offset, sizeof(float));
+ value = flatgeobuf_read_float_le(data + offset);
values[ci] = Float4GetDatum(value);
offset += sizeof(float);
break;
@@ -396,7 +554,7 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
double value;
if (offset + sizeof(double) > size)
elog(ERROR, "flatgeobuf: decode_properties: Invalid size for double value");
- memcpy(&value, data + offset, sizeof(double));
+ value = flatgeobuf_read_double_le(data + offset);
values[ci] = Float8GetDatum(value);
offset += sizeof(double);
break;
@@ -405,9 +563,11 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
uint32_t len;
if (offset + sizeof(len) > size)
elog(ERROR, "flatgeobuf: decode_properties: Invalid size for string value");
- memcpy(&len, data + offset, sizeof(uint32_t));
+ len = flatgeobuf_read_le32(data + offset);
- values[ci] = PointerGetDatum(cstring_to_text_with_len((const char *) data + offset, len));
+ if (len > size - offset)
+ elog(ERROR, "flatgeobuf: decode_properties: string length exceeds buffer");
+ values[ci] = PointerGetDatum(cstring_to_text_with_len((const char *)data + offset, len));
offset += len;
break;
@@ -424,12 +584,15 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
int tzp;
TimestampTz dttz;
- elog(ERROR, "flatgeobuf: decode_properties: Invalid size for string value");
+ elog(ERROR, "flatgeobuf: decode_properties: Invalid size for datetime value");
- buf = palloc0(len + 1);
- memcpy(buf, (const char *) data + offset, len);
- ParseDateTime((const char *) buf, workbuf, sizeof(workbuf), field, ftype, MAXDATEFIELDS, &nf);
+ elog(ERROR, "flatgeobuf: decode_properties: datetime length exceeds buffer");
+ buf = palloc0((Size)len + 1);
+ memcpy(buf, (const char *)data + offset, len);
+ ParseDateTime((const char *)buf, workbuf, sizeof(workbuf), field, ftype, MAXDATEFIELDS, &nf);
DecodeDateTime(field, ftype, nf, &dtype, tm, &fsec, &tzp);
tm2timestamp(tm, fsec, &tzp, &dttz);
values[ci] = TimestampTzGetDatum(dttz);
@@ -449,27 +612,33 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
elog(ERROR, "flatgeobuf: decode_properties: Unknown type %d", type);
-void flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx)
+void
+flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx)
HeapTuple heapTuple;
uint32_t natts = ctx->tupdesc->natts;
Datum *values = palloc0(natts * sizeof(Datum));
- bool *isnull = palloc0(natts * sizeof(bool));
- for (uint32_t j = 0; j < natts; j++) isnull[j] = true;
+ bool *isnull = palloc(natts * sizeof(bool));
+ for (uint32_t j = 0; j < natts; j++)
+ isnull[j] = true;
isnull[0] = false;
values[0] = Int32GetDatum(ctx->fid);
+ flatgeobuf_check_sizeprefix(ctx->ctx);
if (flatgeobuf_decode_feature(ctx->ctx))
elog(ERROR, "flatgeobuf_decode_feature: unsuccessful");
- if (ctx->ctx->lwgeom != NULL) {
+ if (ctx->ctx->lwgeom != NULL)
values[1] = PointerGetDatum(geometry_serialize(ctx->ctx->lwgeom));
isnull[1] = false;
- } else {
+ else
POSTGIS_DEBUG(3, "geometry is null");
isnull[1] = true;
@@ -483,8 +652,12 @@ void flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx)
POSTGIS_DEBUGF(3, "fid now %d", ctx->fid);
- if (ctx->ctx->offset == ctx->ctx->size) {
- POSTGIS_DEBUGF(3, "reached end at %ld", ctx->ctx->offset);
+ if (ctx->ctx->offset > ctx->ctx->size)
+ elog(ERROR, "flatgeobuf_decode_row: read past end of input");
+ if (ctx->ctx->offset == ctx->ctx->size)
+ POSTGIS_DEBUGF(3, "reached end at %lld", ctx->ctx->offset);
ctx->done = true;
@@ -492,7 +665,8 @@ void flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx)
* Initialize aggregation context.
-struct flatgeobuf_agg_ctx *flatgeobuf_agg_ctx_init(const char *geom_name, const bool create_index)
+struct flatgeobuf_agg_ctx *
+flatgeobuf_agg_ctx_init(const char *geom_name, const bool create_index)
struct flatgeobuf_agg_ctx *ctx;
size_t size = VARHDRSZ + FLATGEOBUF_MAGICBYTES_SIZE;
@@ -516,7 +690,8 @@ struct flatgeobuf_agg_ctx *flatgeobuf_agg_ctx_init(const char *geom_name, const
* Allocates a new feature, increment feature counter and
* encode properties into it.
-void flatgeobuf_agg_transfn(struct flatgeobuf_agg_ctx *ctx)
+void
+flatgeobuf_agg_transfn(struct flatgeobuf_agg_ctx *ctx)
LWGEOM *lwgeom = NULL;
bool isnull = false;
@@ -527,8 +702,9 @@ void flatgeobuf_agg_transfn(struct flatgeobuf_agg_ctx *ctx)
inspect_table(ctx);
datum = GetAttributeByNum(ctx->row, ctx->geom_index + 1, &isnull);
- if (!isnull) {
- gs = (GSERIALIZED *) PG_DETOAST_DATUM_COPY(datum);
+ if (!isnull)
+ gs = (GSERIALIZED *)PG_DETOAST_DATUM_COPY(datum);
lwgeom = lwgeom_from_gserialized(gs);
ctx->ctx->lwgeom = lwgeom;
@@ -547,21 +723,24 @@ void flatgeobuf_agg_transfn(struct flatgeobuf_agg_ctx *ctx)
* Encode into Data message and return it packed as a bytea.
-uint8_t *flatgeobuf_agg_finalfn(struct flatgeobuf_agg_ctx *ctx)
+uint8_t *
+flatgeobuf_agg_finalfn(struct flatgeobuf_agg_ctx *ctx)
- POSTGIS_DEBUGF(3, "called at offset %ld", ctx->ctx->offset);
+ POSTGIS_DEBUGF(3, "called at offset %lld", ctx->ctx->offset);
if (ctx == NULL)
flatgeobuf_agg_ctx_init(NULL, false);
// header only result
flatgeobuf_encode_header(ctx->ctx);
- } else if (ctx->ctx->create_index) {
+ else if (ctx->ctx->create_index)
ctx->ctx->index_node_size = 16;
flatgeobuf_create_index(ctx->ctx);
if (ctx->tupdesc != NULL)
ReleaseTupleDesc(ctx->tupdesc);
SET_VARSIZE(ctx->ctx->buf, ctx->ctx->offset);
- POSTGIS_DEBUGF(3, "returning at offset %ld", ctx->ctx->offset);
return ctx->ctx->buf;
diff --git a/postgis/flatgeobuf.h b/postgis/flatgeobuf.h
index c3b13cb6cc..ddad548556 100644
--- a/postgis/flatgeobuf.h
+++ b/postgis/flatgeobuf.h
@@ -43,8 +43,7 @@
#include "lwgeom_log.h"
#include "flatgeobuf_c.h"
-typedef struct flatgeobuf_agg_ctx
+typedef struct flatgeobuf_agg_ctx {
flatgeobuf_ctx *ctx;
const char *geom_name;
uint32_t geom_index;
@@ -52,13 +51,11 @@ typedef struct flatgeobuf_agg_ctx
HeapTupleHeader row;
} flatgeobuf_agg_ctx;
flatgeobuf_agg_ctx *flatgeobuf_agg_ctx_init(const char *geom_name, const bool create_index);
void flatgeobuf_agg_transfn(flatgeobuf_agg_ctx *ctx);
uint8_t *flatgeobuf_agg_finalfn(flatgeobuf_agg_ctx *ctx);
-typedef struct flatgeobuf_decode_ctx
+typedef struct flatgeobuf_decode_ctx {
TupleDesc tupdesc;
Datum result;
@@ -68,6 +65,7 @@ typedef struct flatgeobuf_decode_ctx
} flatgeobuf_decode_ctx;
void flatgeobuf_check_magicbytes(struct flatgeobuf_decode_ctx *ctx);
+void flatgeobuf_check_sizeprefix(flatgeobuf_ctx *ctx);
void flatgeobuf_decode_row(struct flatgeobuf_decode_ctx *ctx);
#endif
diff --git a/postgis/lwgeom_in_flatgeobuf.c b/postgis/lwgeom_in_flatgeobuf.c
index 9b8f538747..64e932c16a 100644
--- a/postgis/lwgeom_in_flatgeobuf.c
+++ b/postgis/lwgeom_in_flatgeobuf.c
@@ -209,6 +209,11 @@ Datum pgis_fromflatgeobuf(PG_FUNCTION_ARGS)
errmsg("function returning record called in context "
"that cannot accept type record")));
+ if (PG_ARGISNULL(1)) {
+ MemoryContextSwitchTo(oldcontext);
+ SRF_RETURN_DONE(funcctx);
data = PG_GETARG_BYTEA_PP(1);
ctx = palloc0(sizeof(*ctx));
@@ -231,6 +236,7 @@ Datum pgis_fromflatgeobuf(PG_FUNCTION_ARGS)
flatgeobuf_check_magicbytes(ctx);
flatgeobuf_decode_header(ctx->ctx);
POSTGIS_DEBUGF(2, "header decoded now at offset %ld", ctx->ctx->offset);
diff --git a/regress/core/flatgeobuf.sql b/regress/core/flatgeobuf.sql
index df46eca1e4..6d8ba9148e 100644
--- a/regress/core/flatgeobuf.sql
+++ b/regress/core/flatgeobuf.sql
@@ -158,6 +158,35 @@ select 'E1', id, bool_1, ST_AsText(geom), bool_2 from ST_FromFlatGeobuf(null::fl
) q)
+select '--- Type mismatch detection ---';
+-- Setup: a long (bigint) column and a text column in separate tables
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_mm_long', (select ST_AsFlatGeobuf(q) fgb from (select
+ null::geometry, null::bigint as val) q));
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_mm_text', (select ST_AsFlatGeobuf(q) fgb from (select
+ null::geometry, null::text as val) q));
+select ST_FromFlatGeobufToTable('public', 'flatgeobuf_mm_twocols', (select ST_AsFlatGeobuf(q) fgb from (select
+ null::geometry, null::bigint as val1, null::bigint as val2) q));
+-- Type mismatch: file has bigint (long), target expects text
+select 'MM1' from ST_FromFlatGeobuf(null::flatgeobuf_mm_text, (
+ select ST_AsFlatGeobuf(q) fgb from (select null::geometry, 42::bigint as val) q));
+-- Count mismatch: file has 2 property columns, target type has 1
+select 'MM2' from ST_FromFlatGeobuf(null::flatgeobuf_mm_long, (
+ select ST_AsFlatGeobuf(q) fgb from (select null::geometry, 42::bigint as val1, 43::bigint as val2) q));
+select '--- Malformed input detection ---';
+-- Magic bytes plus a truncated size prefix.
+select 'MI1' from ST_FromFlatGeobuf(null::flatgeobuf_t1, '\x6667620366676201010203'::bytea);
+-- Valid magic bytes plus a header size prefix that exceeds the remaining input.
+select 'MI2' from ST_FromFlatGeobuf(null::flatgeobuf_t1, '\x6667620366676201ffffffff'::bytea);
+-- NULL bytea input should be handled by STRICT rather than reaching the C decoder.
+select 'MI3', count(*) from ST_FromFlatGeobuf(null::flatgeobuf_t1, null::bytea);
select '--- Quoted identifiers ---';
-- Verify that special characters in column names are properly quoted
@@ -181,3 +210,6 @@ drop table if exists public.flatgeobuf_t1;
drop table if exists public.flatgeobuf_a1;
drop table if exists public.flatgeobuf_e1;
drop table if exists public.flatgeobuf_qi;
+drop table if exists public.flatgeobuf_mm_long;
+drop table if exists public.flatgeobuf_mm_text;
+drop table if exists public.flatgeobuf_mm_twocols;
diff --git a/regress/core/flatgeobuf_expected b/regress/core/flatgeobuf_expected
index 0d90e78822..11745677a1 100644
--- a/regress/core/flatgeobuf_expected
+++ b/regress/core/flatgeobuf_expected
@@ -24,6 +24,13 @@ ERROR: mixed geometry type is not supported
A1|0||t|1|2|3|4|1.2|1.3|2016-06-23 03:44:52.134125+00|hello
--- Exotic roundtrips ---
E1|0|t|POINT(1.1 2.1)|f
+--- Type mismatch detection ---
+ERROR: flatgeobuf: column "val" type mismatch: file type "Long" is not compatible with PostgreSQL type text
+ERROR: flatgeobuf: column count mismatch: file has 2 columns, target type has 1
+--- Malformed input detection ---
+ERROR: flatgeobuf: truncated size prefix
+ERROR: flatgeobuf: size prefix exceeds remaining input
+MI3|0
QI1
QI2
Summary of changes:
NEWS | 5 +-
deps/flatgeobuf/flatgeobuf_c.cpp | 556 ++++++++++++++++++++-----------------
deps/flatgeobuf/geometryreader.cpp | 296 ++++++++++++--------
postgis/flatgeobuf.c | 339 ++++++++++++++++------
postgis/flatgeobuf.h | 8 +-
postgis/lwgeom_in_flatgeobuf.c | 6 +
regress/core/flatgeobuf.sql | 32 +++
regress/core/flatgeobuf_expected | 7 +
8 files changed, 786 insertions(+), 463 deletions(-)
hooks/post-receive
