[SCM] PostGIS branch master updated. 3.7.0beta1-284-gd7e291c966
Sun Aug 9 13:36:17 PDT 2026
the project "PostGIS".
       via  d7e291c966e15441130306b7c4a9c02b4800818d (commit)
       via  57f1775c60e7b335e73ad3e0edbed8803dfb0bb7 (commit)
      from  3530b2ba1d37dc26ba00066cac1fd56bb7665fad (commit)
revisions in full, below.
commit d7e291c966e15441130306b7c4a9c02b4800818d
Merge: 3530b2ba1d 57f1775c60
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Aug 9 13:36:15 2026 -0700
    Merge pull request 'ci: retain non-core upgrade cleanup hooks' (!699) from Komzpa/postgis:fix/master-noncore-upgrade-cleanup-20260810 into master
    ## Summary
    - retain the generic after-upgrade cleanup hook for topology, raster, and SFCGAL script upgrades
    - keep the core-only SQL object-resolution assertions isolated to the core fixture that creates them
    ## Problem
    Master Woodpecker pipeline 6820 fails the 3.3.9 script-upgrade paths for topology, raster, and SFCGAL. Their generic cleanup hook was correctly separated from the core assertions, but the script soft- and hard-upgrade invocations still use `USERTESTFLAGS` instead of their extension-specific flags. The leftover `postgis_upgrade_test_data.locking_view` then blocks uninstall.
    ## Validation
    - `sh -n utils/check_all_upgrades.sh`
    - `git diff --check`
    - Woodpecker 6820 logs reproduce the failing 3.3.9 paths
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/699
commit 57f1775c60e7b335e73ad3e0edbed8803dfb0bb7
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Aug 10 00:33:32 2026 +0400
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 86d8b44784..cf8e4f9c34 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -502,7 +502,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
     kept_label "${test_label}" || run_soft_upgrade=0
     if test ${run_soft_upgrade} != 0; then #{
       echo "Testing ${test_label}"
-      RUNTESTFLAGS="-v --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
+      RUNTESTFLAGS="-v --upgrade-path=${UPGRADE_PATH} ${EXT_USERTESTFLAGS}" \
       ${MAKE} -C ${REGDIR} check ${MAKE_ARGS} && {
         echo "PASS: ${test_label}"
@@ -516,7 +516,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
     kept_label "${test_label}" || run_hard_upgrade=0
     if test ${run_hard_upgrade} != 0; then #{
-      RUNTESTFLAGS="-v --dumprestore --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
+      RUNTESTFLAGS="-v --dumprestore --upgrade-path=${UPGRADE_PATH} ${EXT_USERTESTFLAGS}" \
Summary of changes:
 utils/check_all_upgrades.sh | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
