[SCM] PostGIS branch master updated. 3.7.0beta2-13-g3e477a4cb
git at osgeo.org
git at osgeo.org
Mon Aug 10 12:52:39 PDT 2026
the project "PostGIS".
via 3e477a4cbce5e2823eebe4308ad31ceb02a17e5e (commit)
via 568fc4b7c1dd99b542d6cd59310610a401caf71e (commit)
via dc9e4fd2bc217c4fb58eaee14d4c605646b462c5 (commit)
from 2b8bb15d7a3a872ce9f0f6f4e680f9edd8b7415a (commit)
revisions in full, below.
commit 3e477a4cbce5e2823eebe4308ad31ceb02a17e5e
Merge: 2b8bb15d7 568fc4b7c
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Aug 10 12:52:37 2026 -0700
Merge pull request 'ci: harden developer tooling edge cases' (!719) from Komzpa/postgis:fix/security-findings-tooling-20260810 into master
This hardens several developer and CI surfaces that can otherwise produce misleading validation or unsafe local troubleshooting behavior.
Changes included:
- Key GitHub Actions concurrency by pull request number for pull_request events so same-named branches in different forks cannot cancel each other's runs.
- Replay only checked-in fuzzer seed corpora during `make -C fuzzers check-corpus` instead of trusting arbitrary `*_seed_corpus.zip` files from `FUZZER_OUT`.
- Treat root `spatial_ref_sys.sql` as upgrade-visible input for CI path gating and upgrade-surface checks.
- Reject XML `DOCTYPE` declarations in the stdlib DocBook parser wrapper before SAX can expand internal entities.
- Validate `cache_head_remote` as HTTP(S) and pass `--` to `git ls-remote`; count all stale terminal statuses in the terminal branch table's unknown column.
- Keep explicit-precision Hausdorff tolerance for documented 2D WKT only, so Z/M examples require rounded textual equality.
- Make local developer docs safer for Woodie token setup, documentation review servers, Docker PostgreSQL passwords, and `geometry_columns` wording.
Validation:
- `python3 -m unittest utils.docs.tests.test_ci_status utils.docs.tests.test_docbook_qa utils.docs.tests.test_postgis_exampletest`
- `git diff --check upstream/master...HEAD`
- scope gate: `git diff --name-only upstream/master...HEAD` contains only workflow, CI/tooling, fuzzer Makefile, and documentation/test files; generated/build artifact scan passed.
- direct path-filter negative control: `spatial_ref_sys.sql` now matches both `ci_need_suite.py` and `check_upgrade_surface.py` upgrade-visible patterns.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/719
commit 568fc4b7c1dd99b542d6cd59310610a401caf71e
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Aug 10 23:21:33 2026 +0400
regress: fix geometry_columns count message
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 3f14eaac4..deb4c3a95 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1852,7 +1852,7 @@ BEGIN
SELECT count(*) INTO n FROM geometry_columns
WHERE f_table_schema = 'test6110';
IF n <> 2002 THEN
- RETURN 'FAIL: count=' || n || ' (expected 1000)';
+ RETURN 'FAIL: count=' || n || ' (expected 2002)';
END IF;
t0 := clock_timestamp();
commit dc9e4fd2bc217c4fb58eaee14d4c605646b462c5
Date: Mon Aug 10 23:15:34 2026 +0400
diff --git a/.github/workflows/ci-freebsd.yml b/.github/workflows/ci-freebsd.yml
index 6906e059c..162412ac5 100644
--- a/.github/workflows/ci-freebsd.yml
+++ b/.github/workflows/ci-freebsd.yml
@@ -8,7 +8,7 @@ on:
pull_request: ~
concurrency:
- group: ${{ github.workflow }}-${{ github.head_ref || github.ref }}
+ group: ${{ github.workflow }}-${{ github.event.pull_request.number || github.ref }}
cancel-in-progress: true
jobs:
diff --git a/.github/workflows/ci-macos.yml b/.github/workflows/ci-macos.yml
index 954468fe1..dbaa9ee8e 100644
--- a/.github/workflows/ci-macos.yml
+++ b/.github/workflows/ci-macos.yml
@@ -8,7 +8,7 @@ on:
pull_request: ~
concurrency:
jobs:
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index dd2686ead..707beab9a 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -10,7 +10,7 @@ on:
pull_request: ~
concurrency:
jobs:
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index d87640e06..d6792c403 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -5,7 +5,7 @@ on:
pull_request: ~
concurrency:
permissions:
diff --git a/.github/workflows/codespell.yml b/.github/workflows/codespell.yml
index 164cc8ae1..d75ca2f01 100644
--- a/.github/workflows/codespell.yml
+++ b/.github/workflows/codespell.yml
@@ -7,7 +7,7 @@ on:
pull_request: ~
concurrency:
jobs:
diff --git a/.github/workflows/contributor-credits.yml b/.github/workflows/contributor-credits.yml
index c5237153f..3fd68fa8f 100644
--- a/.github/workflows/contributor-credits.yml
+++ b/.github/workflows/contributor-credits.yml
@@ -10,7 +10,7 @@ permissions:
contents: read
concurrency:
jobs:
diff --git a/.github/workflows/msys.yml b/.github/workflows/msys.yml
index 8e9e204df..1a06602b4 100644
--- a/.github/workflows/msys.yml
+++ b/.github/workflows/msys.yml
@@ -4,7 +4,7 @@ on:
pull_request: ~
concurrency:
jobs:
diff --git a/ci/ci_need_suite.py b/ci/ci_need_suite.py
index 75547bee8..9f0a122b5 100755
--- a/ci/ci_need_suite.py
+++ b/ci/ci_need_suite.py
@@ -64,6 +64,7 @@ LOADER_GLOBS = (
UPGRADE_GLOBS = (
"Version.config",
+ "spatial_ref_sys.sql",
"extensions/**",
"postgis/*.sql.in",
"raster/rt_pg/*.sql.in",
diff --git a/doc/development/environment/docker.md b/doc/development/environment/docker.md
index 6ee062e52..c453df502 100644
--- a/doc/development/environment/docker.md
+++ b/doc/development/environment/docker.md
@@ -64,13 +64,16 @@ the cluster:
```sh
export PGVER=15
export PGPORT="$(grep ^port /etc/postgresql/${PGVER}/main/postgresql.conf | awk '{print $3}')"
+read -rs POSTGIS_DEV_PASSWORD
+printf '\n'
psql -d postgres -c "ALTER SYSTEM SET listen_addresses='*';"
printf '%s\n' "host all all 0.0.0.0/0 scram-sha-256" >> "/etc/postgresql/${PGVER}/main/pg_hba.conf"
-psql -d postgres -c "ALTER ROLE postgres PASSWORD 'change-me';"
+psql -d postgres -v password="$POSTGIS_DEV_PASSWORD" -c "ALTER ROLE postgres PASSWORD :'password';"
+unset POSTGIS_DEV_PASSWORD
service postgresql restart "${PGVER}"
-Use a stronger password and narrower `pg_hba.conf` rule on shared hosts. The
+Use a strong password and narrower `pg_hba.conf` rule on shared hosts. The
example is intended for a short-lived local development container.
From the host, connect to the PostgreSQL version whose container port you
diff --git a/doc/development/manual.md b/doc/development/manual.md
index 3249af9f4..5937159d4 100644
--- a/doc/development/manual.md
+++ b/doc/development/manual.md
@@ -35,7 +35,7 @@ the old HTML directory:
```sh
make -C /path/to/old-postgis/doc html
make -C doc review-html REVIEW_HTML_BASE=/path/to/old-postgis/doc/html
-python3 -m http.server --directory . 8000
+python3 -m http.server --bind 127.0.0.1 --directory . 8000
Open `http://127.0.0.1:8000/doc/html/review/`. The page keeps the old manual on
diff --git a/doc/development/testing/ci.md b/doc/development/testing/ci.md
index 319302543..95e6ac98b 100644
--- a/doc/development/testing/ci.md
+++ b/doc/development/testing/ci.md
@@ -194,9 +194,8 @@ before changing a pipeline:
read -rs WOODPECKER_TOKEN
printf '\n'
umask 077
-woodpecker-cli setup --context osgeo \
- --server https://woodie.osgeo.org \
- --token "$WOODPECKER_TOKEN"
+WOODPECKER_TOKEN="$WOODPECKER_TOKEN" woodpecker-cli setup --context osgeo \
+ --server https://woodie.osgeo.org
unset WOODPECKER_TOKEN
woodpecker-cli context use osgeo
woodpecker-cli info
diff --git a/doc/reference_management.xml b/doc/reference_management.xml
index 9cbe37ec2..739a81efd 100644
--- a/doc/reference_management.xml
+++ b/doc/reference_management.xml
@@ -231,8 +231,8 @@ WHERE f_table_name = 'my_spatial_table' AND f_table_schema = 'my_schema';</progr
<title>Description</title>
<para>Removes a geometry column from a spatial table. Note that
- schema_name will need to match the f_table_schema field of the table's
- row in the geometry_columns table.</para>
+ schema_name will need to match the f_table_schema field shown by the
+ <varname>geometry_columns</varname> view.</para>
<warning>
<para><function>DropGeometryColumn</function> is retained for backward
diff --git a/fuzzers/Makefile b/fuzzers/Makefile
index 491d3de23..348cbaeac 100644
--- a/fuzzers/Makefile
+++ b/fuzzers/Makefile
@@ -78,7 +78,7 @@ check-corpus: dummyfuzzers
rm -rf "$(FUZZER_WORK)"; \
mkdir -p "$(FUZZER_WORK)"; \
trap 'rm -rf "$(FUZZER_WORK)"' EXIT HUP INT TERM; \
- for corpus in $(SEED_CORPORA) "$(FUZZER_OUT)"/*_seed_corpus.zip __none__; do \
+ for corpus in $(SEED_CORPORA) __none__; do \
if [ "$${corpus}" = "__none__" ] || [ ! -e "$${corpus}" ]; then \
continue; \
fi; \
diff --git a/utils/check_upgrade_surface.py b/utils/check_upgrade_surface.py
index a6d88074f..199f42853 100755
--- a/utils/check_upgrade_surface.py
+++ b/utils/check_upgrade_surface.py
@@ -18,6 +18,7 @@ from pathlib import Path
SQL_VISIBLE_GLOBS = (
"Version.config",
"extensions/**",
"postgis/*.sql.in",
diff --git a/utils/docs/ci_status/report.py b/utils/docs/ci_status/report.py
index b0644ed7a..c2eaab039 100644
--- a/utils/docs/ci_status/report.py
+++ b/utils/docs/ci_status/report.py
@@ -1331,6 +1331,9 @@ def resolve_cache_heads(config, work, cache, timeout):
remote = config.get("cache_head_remote")
if not remote:
return {}
+ parsed = urllib.parse.urlparse(remote)
+ if parsed.scheme not in ("https", "http") or not parsed.netloc or remote.startswith("-"):
+ raise ConfigError("cache_head_remote must be an HTTP(S) URL")
branch_names = sorted({
branch["name"]
for branch, _check in work
@@ -1345,7 +1348,7 @@ def resolve_cache_heads(config, work, cache, timeout):
refs = [f"refs/heads/{name}" for name in branch_names]
try:
completed = subprocess.run(
- ["git", "ls-remote", "--exit-code", "--heads", remote, *refs],
+ ["git", "ls-remote", "--exit-code", "--heads", "--", remote, *refs],
check=True,
capture_output=True,
text=True,
@@ -1738,7 +1741,7 @@ def print_branch_table(branches, use_color):
print(terminal_style("-" * len(header), dim=True, enabled=use_color))
for branch in branches:
counts = check_counts(branch)
- unknown = counts[UNKNOWN] + counts[STALE]
+ unknown = counts[UNKNOWN] + counts[STALE] + counts[STALE_PASSED] + counts[STALE_FAILED]
label = f"{branch['label']:<10}"
print(
f"{label} "
diff --git a/utils/docs/postgis_exampletest.py b/utils/docs/postgis_exampletest.py
index 301c4f17e..af3611c47 100755
--- a/utils/docs/postgis_exampletest.py
+++ b/utils/docs/postgis_exampletest.py
@@ -461,7 +461,7 @@ class ExampleTester:
def documented_wkt_uses_explicit_z_token(self, expected_wkt):
return bool(re.search(
- rf"\b(?:{WKT_TYPES})\s+Z(?:M)?\s*(?:\(|EMPTY\b)",
+ rf"\b(?:{WKT_TYPES})\s+(?:Z|M|ZM)\s*(?:\(|EMPTY\b)",
expected_wkt or "",
re.I,
@@ -575,7 +575,7 @@ class ExampleTester:
f"ST_AsText(actual, {documented_digits}) = "
f"ST_AsText(expected, {documented_digits})"
- if expected_wkt_digits is not None:
+ if expected_wkt_digits is not None and self.documented_wkt_is_2d(expected_wkt):
shape_match = (
f"({shape_match} OR "
f"ST_HausdorffDistance(actual, expected) <= {10 ** -expected_wkt_digits:.17g})"
diff --git a/utils/docs/tests/test_ci_status.py b/utils/docs/tests/test_ci_status.py
index d29a5b51a..2e7127a92 100644
--- a/utils/docs/tests/test_ci_status.py
+++ b/utils/docs/tests/test_ci_status.py
@@ -1,4 +1,5 @@
import json
+import io
import pathlib
import subprocess
import sys
@@ -241,6 +242,7 @@ class CIStatusTest(unittest.TestCase):
"ls-remote",
"--exit-code",
"--heads",
"https://example.test/postgis.git",
"refs/heads/master",
"refs/heads/stable-3.6",
@@ -251,6 +253,40 @@ class CIStatusTest(unittest.TestCase):
timeout=7,
+ def test_cache_head_lookup_rejects_option_like_remote(self):
+ config = {"cache_head_remote": "--upload-pack=sh"}
+ work = [({"name": "master", "label": "master"}, {"name": "Synthetic CI"})]
+ cache = CI_STATUS.index_status_cache({
+ "branches": [{
+ "name": "master",
+ "checks": [{
+ "check": "Synthetic CI",
+ "status": CI_STATUS.SUCCESS,
+ with self.assertRaises(CI_STATUS.ConfigError):
+ CI_STATUS.resolve_cache_heads(config, work, cache, timeout=7)
+ def test_branch_table_counts_all_stale_statuses_as_unknown(self):
+ branch = {
+ "name": "stable-synthetic",
+ "label": "Synthetic",
+ "status": CI_STATUS.UNKNOWN,
+ "checks": [
+ check("Required / Unknown", CI_STATUS.UNKNOWN),
+ check("Required / Stale", CI_STATUS.STALE),
+ check("Required / Passed", CI_STATUS.STALE_PASSED),
+ check("Required / Failed", CI_STATUS.STALE_FAILED),
+ with mock.patch("sys.stdout", new_callable=io.StringIO) as stdout:
+ CI_STATUS.print_branch_table([branch], use_color=False)
+ self.assertIn(" 4 ", stdout.getvalue())
def test_missing_optional_status_cache_starts_empty(self):
with tempfile.TemporaryDirectory() as tmpdir:
missing = pathlib.Path(tmpdir) / "status.json"
diff --git a/utils/docs/tests/test_docbook_qa.py b/utils/docs/tests/test_docbook_qa.py
index e47181021..aa550da77 100644
--- a/utils/docs/tests/test_docbook_qa.py
+++ b/utils/docs/tests/test_docbook_qa.py
@@ -25,6 +25,7 @@ from docbook_qa import (
load_xml,
main,
+from xml_tree import parse as parse_xml
DOCBOOK_OPEN = '<book xmlns="http://docbook.org/ns/docbook" xmlns:xml="http://www.w3.org/XML/1998/namespace">'
DOCBOOK_CLOSE = '</book>'
@@ -55,6 +56,18 @@ class DocBookSourceLintTest(unittest.TestCase):
self.assertCategories('<refentry xml:id="f"><programlisting>SELECT 1;</programlisting></refentry>', set())
+ def test_xml_tree_rejects_doctype(self):
+ path = write_tmp(
+ ".xml",
+ '<!DOCTYPE book [<!ENTITY expand "expanded">]>'
+ + DOCBOOK_OPEN
+ + '<para>&expand;</para>'
+ + DOCBOOK_CLOSE,
+ with self.assertRaises(Exception):
+ parse_xml(path)
def test_mixed_programlisting_dash_run_markers_and_sql_comments(self):
for output in ("left | right\n----|----\n1 | 2", "----RESULT output ---\n1"):
with self.subTest(output=output):
diff --git a/utils/docs/tests/test_postgis_exampletest.py b/utils/docs/tests/test_postgis_exampletest.py
index d323bf46d..3d120d150 100644
--- a/utils/docs/tests/test_postgis_exampletest.py
+++ b/utils/docs/tests/test_postgis_exampletest.py
@@ -520,6 +520,18 @@ SELECT 'POINT(1 2)', $$LINESTRING(0 0,1 1)$$,
self.assertIn("ST_HausdorffDistance(actual, expected) <= 9.9999999999999995e-07", query)
+ def test_explicit_geometry_output_precision_keeps_z_textual(self):
+ tester = ExampleTester.__new__(ExampleTester)
+ query = tester.geometry_comparison_query(
+ "0101000080000000000000F03F00000000000000400000000000000840",
+ expected_wkt="POINT Z (1.000000 2.000000 3.000000)",
+ actual_type="POINT",
+ expected_wkt_digits=6,
+ self.assertIn("ST_AsText(actual, 6) = ST_AsText(expected, 6)", query)
+ self.assertNotIn("ST_HausdorffDistance", query)
def test_surface_output_precision_preserves_canonical_face_comparison(self):
diff --git a/utils/docs/xml_tree.py b/utils/docs/xml_tree.py
index 203dc9a49..042a71be6 100644
--- a/utils/docs/xml_tree.py
+++ b/utils/docs/xml_tree.py
@@ -75,7 +75,21 @@ class _TreeBuilder(ContentHandler):
current.text = (current.text or "") + content
+def _reject_doctype(path):
+ with Path(path).open("rb") as handle:
+ previous = b""
+ while True:
+ chunk = handle.read(8192)
+ if not chunk:
+ return
+ haystack = previous + chunk.upper()
+ if b"<!DOCTYPE" in haystack:
+ raise xml.sax.SAXException("DOCTYPE declarations are not supported")
+ previous = haystack[-8:]
def parse(path):
+ _reject_doctype(path)
parser = xml.sax.make_parser()
parser.setFeature(feature_namespaces, True)
for feature in (feature_external_ges, feature_external_pes):
Summary of changes:
.github/workflows/ci-freebsd.yml | 2 +-
.github/workflows/ci-macos.yml | 2 +-
.github/workflows/ci.yml | 2 +-
.github/workflows/codeql.yml | 2 +-
.github/workflows/codespell.yml | 2 +-
.github/workflows/contributor-credits.yml | 2 +-
.github/workflows/msys.yml | 2 +-
ci/ci_need_suite.py | 1 +
doc/development/environment/docker.md | 7 ++++--
doc/development/manual.md | 2 +-
doc/development/testing/ci.md | 5 ++--
doc/reference_management.xml | 4 ++--
fuzzers/Makefile | 2 +-
regress/core/tickets.sql | 2 +-
utils/check_upgrade_surface.py | 1 +
utils/docs/ci_status/report.py | 7 ++++--
utils/docs/postgis_exampletest.py | 4 ++--
utils/docs/tests/test_ci_status.py | 36 ++++++++++++++++++++++++++++
utils/docs/tests/test_docbook_qa.py | 13 ++++++++++
utils/docs/tests/test_postgis_exampletest.py | 12 ++++++++++
utils/docs/xml_tree.py | 14 +++++++++++
21 files changed, 103 insertions(+), 21 deletions(-)
hooks/post-receive
