[SCM] postgis.net branch website updated. clarity-final-252-g365dff4
Sat Aug 15 10:00:42 PDT 2026
the project "postgis.net".
The branch, website has been updated
       via  365dff45fb6f003f30ec1c7e3ffdf127ec073de4 (commit)
       via  f4fdaac7da0705ab97dd78e1cd3f4c047a0a542a (commit)
      from  9880272a4d458061571cf615fac69e512fc14e3e (commit)
revisions in full, below.
commit 365dff45fb6f003f30ec1c7e3ffdf127ec073de4
Merge: 9880272 f4fdaac
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sat Aug 15 10:00:42 2026 -0700
    Merge pull request 'Fix release checksum source links' (!32) from Komzpa/postgis.net:fix/release-md5-source-links-20260812 into website
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis.net/pulls/32
commit f4fdaac7da0705ab97dd78e1cd3f4c047a0a542a
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Wed Aug 12 13:54:07 2026 +0400
    fix: match release checksum sources
diff --git a/layouts/shortcodes/sourcelinks.html b/layouts/shortcodes/sourcelinks.html
index 4f029c2..5befcb4 100644
--- a/layouts/shortcodes/sourcelinks.html
+++ b/layouts/shortcodes/sourcelinks.html
@@ -11,7 +11,11 @@
 		{{ $key := .tag }}
 <li>
 <a href="{{ $.Site.Params.postgis.release_source }}/postgis-{{ $key }}.tar.gz"><b>postgis-{{ $key }}.tar.gz {{ if .eol}} EOL{{ end }}</b></a> [
-<a href="{{$.Site.Params.postgis.dev_download}}/postgis-{{ $key }}.tar.gz.md5">md5</a>
+{{ if .eol }}
+<a href="{{ $.Site.Params.postgis.dev_download }}/postgis-{{ $key }}.tar.gz.md5">md5</a>
+{{ else }}
+<a href="{{ $.Site.Params.postgis.release_source }}/postgis-{{ $key }}.tar.gz.md5">md5</a>
+{{ end }}
 <!-- | <a href="{{ $.Site.Params.postgis.release_docs }}/postgis-{{ $key}}.pdf">pdf</a> -->
 <!-- | <a href="{{$.Site.Params.postgis.release_docs}}/doc-html-{{ $key }}.tar.gz">html</a> -->
 | <a href="{{ $.Site.Params.postgis.release_notes }}/{{ $key }}/NEWS">Release Notes</a>
@@ -21,4 +25,4 @@
 {{end}}
 {{ end }}
-</ul>
\ No newline at end of file
+</ul>
diff --git a/utils/check_releases_md5.sh b/utils/check_releases_md5.sh
index 90c67b8..1674ce1 100755
--- a/utils/check_releases_md5.sh
+++ b/utils/check_releases_md5.sh
@@ -3,27 +3,32 @@
 WORKDIR=$PWD/releases-check
 API=https://git.osgeo.org/gitea/api/v1
 DOWNLOAD_BASE=https://download.osgeo.org/postgis/source
-MD5_BASE=https://postgis.net/stuff
+DEV_DOWNLOAD_BASE=https://postgis.net/stuff
 CONFIG=$(cd $(dirname $0)/../; pwd)/config.toml
 mkdir -p ${WORKDIR}
 cd ${WORKDIR}
 echo "Fetching list of published releases"
-tomlq -r '.params.postgis.releases[] | select( .is_dev != true ) | .tag' \
+tomlq -r '.params.postgis.releases[] | select( .is_dev != true ) | [.tag, (.eol // false)] | @tsv' \
   ${CONFIG} > checked_releases.txt
-while read REL; do
+while read REL EOL; do
   relname=postgis-${REL}.tar.gz
   md5name=${relname}.md5
+  md5base=${DOWNLOAD_BASE}
+  if [ "${EOL}" = "true" ]; then
+    md5base=${DEV_DOWNLOAD_BASE}
+  fi
   echo -n "Checking ${relname} ... "
   curl -s ${DOWNLOAD_BASE}/${relname} -o ${relname} || {
     echo "unable to download ${relname} from ${DOWNLOAD_BASE}"
     exit 1
-  curl -s ${MD5_BASE}/${md5name} -o ${md5name} || {
-    echo "unable to download ${md5name} from ${MD5_BASE}"
+  curl -s ${md5base}/${md5name} -o ${md5name} || {
+    echo "unable to download ${md5name} from ${md5base}"
     exit 1
   md5sum ${relname} | diff - ${md5name} > /dev/null 2>&1 || {
Summary of changes:
 layouts/shortcodes/sourcelinks.html |  8 ++++++--
 utils/check_releases_md5.sh         | 15 ++++++++++-----
 2 files changed, 16 insertions(+), 7 deletions(-)
hooks/post-receive
postgis.net
