[SCM] PostGIS branch stable-3.6 updated. 3.6.4-139-g304fb41ff
git at osgeo.org
git at osgeo.org
Fri Aug 21 04:49:55 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
via 304fb41ff9ed03c4acdb4667b46c794a0131911f (commit)
via fd411b65d2dfa51807ade8c0d1c7dbdb1cb01f49 (commit)
via c3284cf8279c8879dd727e719342c0ea0eb4e664 (commit)
via e00c592e8d7f9aee4414e67184b91fe726991b41 (commit)
from bef1bf6b2aa21a6e92af072aae8b19f39e6520e4 (commit)
revisions in full, below.
commit 304fb41ff9ed03c4acdb4667b46c794a0131911f
Merge: bef1bf6b2 fd411b65d
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Fri Aug 21 04:49:54 2026 -0700
Merge pull request 'regress: keep interrupt relate assertions bounded' (!752) from Komzpa/postgis:fix/interrupt-relation-timeout-3.6-20260821 into stable-3.6
The local-baseline calls run the pathological predicate without a statement timeout, so every stable-3.6 regression workflow stalls before it reaches the interruption assertion.
Use the established stable-3.4 form: retain all eight 100 ms statement_timeout checks and their 500 ms timing assertions, while removing only the unbounded baseline calls.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/752
commit fd411b65d2dfa51807ade8c0d1c7dbdb1cb01f49
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Fri Aug 21 15:30:32 2026 +0400
test(core): align 3.6 interrupt relate expected output
diff --git a/regress/core/interrupt_relate_expected b/regress/core/interrupt_relate_expected
index 2c29d8991..354753a1f 100644
--- a/regress/core/interrupt_relate_expected
+++ b/regress/core/interrupt_relate_expected
@@ -1,8 +1,16 @@
-contains interrupted on time
-covers interrupted on time
-coveredby interrupted on time
-crosses interrupted on time
-equals interrupted on time
-intersects interrupted on time
-overlaps interrupted on time
-relate interrupted on time
+ERROR: canceling statement due to statement timeout
+contains interrupted
+covers interrupted
+coveredby interrupted
+crosses interrupted
+equals interrupted
+intersects interrupted
+overlaps interrupted
+relate interrupted
commit c3284cf8279c8879dd727e719342c0ea0eb4e664
Date: Fri Aug 21 15:17:10 2026 +0400
Update interrupt_relate expected output for interrupted predicates
index d050570bf..2c29d8991 100644
@@ -1,16 +1,8 @@
-ERROR: canceling statement due to statement timeout
commit e00c592e8d7f9aee4414e67184b91fe726991b41
Date: Fri Aug 21 13:46:07 2026 +0400
diff --git a/regress/core/interrupt_relate.sql b/regress/core/interrupt_relate.sql
index 65271e5d6..9bafbda16 100644
--- a/regress/core/interrupt_relate.sql
+++ b/regress/core/interrupt_relate.sql
@@ -16,69 +16,29 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
-- IM9 based predicates
-DO $$
-BEGIN
- PERFORM _timecheck_start();
- PERFORM ST_Contains(g,g) FROM _inputs WHERE id = 1;
- PERFORM _timecheck_baseline('contains');
-END;
BEGIN;
SET LOCAL statement_timeout TO 100;
select ST_Contains(g,g) from _inputs WHERE id = 1; -- 6+ seconds
ROLLBACK;
-SELECT _timecheck('contains');
-DO $$
-BEGIN
- PERFORM ST_Covers(g,g) FROM _inputs WHERE id = 1;
- PERFORM _timecheck_baseline('covers');
-END;
+SELECT _timecheck('contains', '500ms');
BEGIN;
select ST_Covers(g,g) from _inputs WHERE id = 1; -- 6+ seconds
ROLLBACK;
-SELECT _timecheck('covers');
-DO $$
-BEGIN
- PERFORM ST_CoveredBy(g,g) FROM _inputs WHERE id = 1;
- PERFORM _timecheck_baseline('coveredby');
-END;
+SELECT _timecheck('covers', '500ms');
BEGIN;
select ST_CoveredBy(g,g) from _inputs WHERE id = 1; -- 6+ seconds
ROLLBACK;
-SELECT _timecheck('coveredby');
-DO $$
-BEGIN
- PERFORM ST_Crosses(g,g) FROM _inputs WHERE id = 1;
- PERFORM _timecheck_baseline('crosses');
-END;
+SELECT _timecheck('coveredby', '500ms');
BEGIN;
select ST_Crosses(g,g) from _inputs WHERE id = 1; -- 6+ seconds
ROLLBACK;
-SELECT _timecheck('crosses');
-DO $$
-BEGIN
- PERFORM ST_Equals(g,st_reverse(g)) FROM _inputs WHERE id = 1;
- PERFORM _timecheck_baseline('equals');
-END;
+SELECT _timecheck('crosses', '500ms');
BEGIN;
@@ -86,15 +46,7 @@ SET LOCAL statement_timeout TO 100;
-- short-circuit described in #3226
select ST_Equals(g,st_reverse(g)) from _inputs WHERE id = 1; -- 6+ seconds
ROLLBACK;
-SELECT _timecheck('equals');
-DO $$
-BEGIN
- PERFORM ST_Intersects(g,ST_Segmentize(g,1e-4)) FROM _inputs WHERE id = 1;
- PERFORM _timecheck_baseline('intersects');
-END;
+SELECT _timecheck('equals', '500ms');
BEGIN;
@@ -102,38 +54,22 @@ SET LOCAL statement_timeout TO 100;
-- input to make it slower
select ST_Intersects(g,ST_Segmentize(g,1e-4)) from _inputs WHERE id = 1; -- 6+ seconds
ROLLBACK;
-SELECT _timecheck('intersects');
-DO $$
-BEGIN
- PERFORM ST_Overlaps(g,g) FROM _inputs WHERE id = 1;
- PERFORM _timecheck_baseline('overlaps');
-END;
+SELECT _timecheck('intersects', '500ms');
BEGIN;
select ST_Overlaps(g,g) from _inputs WHERE id = 1; -- 6+ seconds
ROLLBACK;
-SELECT _timecheck('overlaps');
-DO $$
-BEGIN
- PERFORM ST_Relate(g,g) FROM _inputs WHERE id = 1;
- PERFORM _timecheck_baseline('relate');
-END;
+SELECT _timecheck('overlaps', '500ms');
BEGIN;
select ST_Relate(g,g) from _inputs WHERE id = 1; -- 6+ seconds
ROLLBACK;
-SELECT _timecheck('relate');
+SELECT _timecheck('relate', '500ms');
-DROP FUNCTION _timecheck(text);
DROP FUNCTION _timecheck(text, interval);
+DROP FUNCTION _timecheck(text);
DROP FUNCTION _timecheck_baseline(text);
DROP FUNCTION _timecheck_start();
DROP TABLE _inputs;
Summary of changes:
regress/core/interrupt_relate.sql | 82 ++++------------------------------
regress/core/interrupt_relate_expected | 16 +++----
2 files changed, 17 insertions(+), 81 deletions(-)
hooks/post-receive
