[SCM] PostGIS branch master updated. 3.7.0beta2-102-g8c2127c5f
Fri Aug 21 11:01:43 PDT 2026
the project "PostGIS".
       via  8c2127c5f2f50824fdcdba20a71edf74134290a6 (commit)
       via  4fcf6f959a16242255f79ce28334787f72e36015 (commit)
      from  428a7b7e6869bf7058ff1e22d848618ce7fc20d8 (commit)
revisions in full, below.
commit 8c2127c5f2f50824fdcdba20a71edf74134290a6
Merge: 428a7b7e6 4fcf6f959
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Fri Aug 21 11:01:42 2026 -0700
    Merge pull request 'ci: link Jenkins failures to leaf consoles' (!757) from Komzpa/postgis:fix/ci-status-github-refresh-20260821 into master
    Mark a provider result stale immediately when its known revision is behind the tracked branch.
    For a failed Jenkins matrix configuration, follow the bounded Parameterized Trigger chain in its console and publish the terminal failed build plus its `/console` URL. With multiple failed leaves, retain each leaf link separately instead of choosing one arbitrarily.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/757
commit 4fcf6f959a16242255f79ce28334787f72e36015
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Aug 21 20:34:40 2026 +0400
diff --git a/utils/docs/ci_status/report.py b/utils/docs/ci_status/report.py
index c2eaab039..46774780c 100644
--- a/utils/docs/ci_status/report.py
+++ b/utils/docs/ci_status/report.py
@@ -25,6 +25,7 @@ STALE_FAILED = "stale-fail"
 DISABLED = "disabled"
 NOT_APPLICABLE = "not_applicable"
 JENKINS_STALE_QUEUE_HOURS = 4
+JENKINS_DOWNSTREAM_DEPTH = 4
 STATUS_DISPLAY_ORDER = {
     FAILURE: 0,
@@ -1095,6 +1096,78 @@ def jenkins_matrix_configuration_label(configuration, selected):
     return configuration.get("name") or configuration.get("url") or "configuration"
+def jenkins_console_url(build_url):
+    return build_url.rstrip("/") + "/console"
+def jenkins_console_text_url(build_url):
+    return build_url.rstrip("/") + "/consoleText"
+def jenkins_downstream_build_url(parent_url, job_name, build_number):
+    parsed = urllib.parse.urlparse(parent_url)
+    if parsed.scheme not in ("http", "https") or not parsed.netloc:
+        return None
+    job_parts = job_name.split("/")
+    if not job_parts or any(not part for part in job_parts):
+        return None
+    path = "/job/" + "/job/".join(
+        urllib.parse.quote(part, safe="") for part in job_parts
+    ) + f"/{build_number}/"
+    return urllib.parse.urlunparse((parsed.scheme, parsed.netloc, path, "", "", ""))
+def jenkins_failed_downstream_builds(console_text):
+    marker = " completed. Result was "
+    failures = []
+    for line in console_text.splitlines():
+        before, separator, result = line.partition(marker)
+        if not separator or result.strip() != "FAILURE":
+            continue
+        job_name, separator, build_number = before.rpartition(" #")
+        if not separator or not job_name or not build_number.isdecimal():
+            continue
+        failures.append((job_name, int(build_number)))
+    return failures
+def jenkins_terminal_failures(build_url, timeout, depth=JENKINS_DOWNSTREAM_DEPTH, seen=None, job=None):
+    if depth < 0 or build_url in (seen or set()):
+        return None
+    try:
+        console_text = http_text(jenkins_console_text_url(build_url), timeout=timeout)
+    except RECOVERABLE_PROVIDER_ERRORS:
+        return None
+    failed = jenkins_failed_downstream_builds(console_text)
+    if not failed:
+        if "Finished: FAILURE" not in console_text:
+            return None
+        return [{
+            "url": build_url,
+            "console_url": jenkins_console_url(build_url),
+            "job": job,
+    leaves = []
+    next_seen = set(seen or ())
+    next_seen.add(build_url)
+    for job_name, build_number in failed:
+        child_url = jenkins_downstream_build_url(build_url, job_name, build_number)
+        if not child_url:
+            return None
+        child_leaves = jenkins_terminal_failures(
+            child_url,
+            timeout,
+            depth - 1,
+            next_seen,
+            f"{job_name} #{build_number}",
+        if child_leaves is None:
+            return None
+        leaves.extend(child_leaves)
+    return leaves
 def jenkins_matrix_details(job_url, timeout, parent_build_number):
     try:
         configurations = jenkins_matrix_configurations(job_url, timeout)
@@ -1139,11 +1212,32 @@ def jenkins_matrix_details(job_url, timeout, parent_build_number):
         for status in (FAILURE, IN_PROGRESS, UNKNOWN)
         for item in by_status.get(status) or []
-    url = non_success[0][1].get("url") if len(non_success) == 1 else None
-    return {
+    details = {
         "message": "; ".join(parts),
-        "url": url,
+    failures = []
+    for label, build in by_status[FAILURE]:
+        build_url = build.get("url")
+        if not build_url:
+            continue
+        leaves = jenkins_terminal_failures(build_url, timeout)
+        if leaves is None:
+            continue
+        for failure in leaves:
+            failure["label"] = ": ".join(
+                part for part in (label, failure.pop("job", None)) if part
+            failures.append(failure)
+    if failures:
+        details["failures"] = failures
+    if len(non_success) == 1:
+        build_url = non_success[0][1].get("url")
+        if build_url:
+            failure = failures[0] if len(failures) == 1 else {"url": build_url}
+            details["url"] = failure["url"]
+            if failure.get("console_url"):
+                details["console_url"] = failure["console_url"]
+    return details
 def jenkins_badge_url(job_url, check, branch):
@@ -1239,6 +1333,10 @@ def jenkins_check(check, branch, timeout):
             result["message"] = f"{result['message']}; {details['message']}"
             if details.get("url"):
                 result["url"] = details["url"]
+            if details.get("console_url"):
+                result["console_url"] = details["console_url"]
+            if details.get("failures"):
+                result["failure_details"] = details["failures"]
     if previous:
         result.update(previous_fields(normalize_jenkins_status(previous), previous))
     return result
@@ -1414,7 +1512,7 @@ def apply_staleness(result, config, check):
     distance_count, distance_ref = None, None
     if result["status"] != IN_PROGRESS:
         distance_count, distance_ref = result_revision_distance(config, result)
-    if result["status"] not in (IN_PROGRESS, SUCCESS) and distance_count and distance_count > 0:
+    if result["status"] != IN_PROGRESS and distance_count and distance_count > 0:
         stale = dict(result)
         stale["revision_commits_behind"] = distance_count
         stale["revision_compare_ref"] = distance_ref
@@ -1710,7 +1808,7 @@ def safe_http_href(value):
 def result_url(check):
-    return safe_http_href(check.get("url") or check.get("debug_url") or "")
+    return safe_http_href(check.get("console_url") or check.get("url") or check.get("debug_url") or "")
 def terminal_link(text, url, enabled):
@@ -1797,6 +1895,10 @@ def print_terminal(data, use_color=True, verbose=False):
         if check.get("message"):
             message = " ".join(str(check["message"]).split())
             print(terminal_field("message", message, use_color))
+        for failure in check.get("failure_details") or []:
+            label = failure.get("label") or "failed child"
+            url = safe_http_href(failure.get("console_url") or failure.get("url") or "")
+            print(terminal_field("failure", terminal_link(label, url, use_color), use_color))
         print()
diff --git a/utils/docs/tests/test_ci_status.py b/utils/docs/tests/test_ci_status.py
index 2e7127a92..ea00c5b1e 100644
--- a/utils/docs/tests/test_ci_status.py
+++ b/utils/docs/tests/test_ci_status.py
@@ -348,6 +348,12 @@ class CIStatusTest(unittest.TestCase):
                 "completed_at": "2026-07-01T00:00:00Z",
                 "message": "build 2",
             }, config, stale_check)
+            recent_passed = CI_STATUS.apply_staleness({
+                **base,
+                "status": CI_STATUS.SUCCESS,
+                "completed_at": CI_STATUS.utc_now().isoformat(),
+                "message": "build 3",
+            }, config, stale_check)
         self.assertEqual(CI_STATUS.STALE_FAILED, failed["status"])
         self.assertEqual(CI_STATUS.FAILURE, failed["stale_base_status"])
@@ -357,6 +363,8 @@ class CIStatusTest(unittest.TestCase):
         self.assertEqual(CI_STATUS.STALE_PASSED, passed["status"])
         self.assertEqual(CI_STATUS.SUCCESS, passed["stale_base_status"])
         self.assertEqual("Stale passed", passed["status_label"])
+        self.assertEqual(CI_STATUS.STALE_PASSED, recent_passed["status"])
+        self.assertIn("3 commits behind stable-synthetic", recent_passed["message"])
     def test_jenkins_matrix_failure_names_failing_axis(self):
         check_config = {
@@ -398,16 +406,30 @@ class CIStatusTest(unittest.TestCase):
+        child_console = (
+            "Waiting for the completion of PostGIS_2_windows_PGVERSION_winnie\n"
+            "PostGIS_2_windows_PGVERSION_winnie #20003 completed. Result was FAILURE\n"
         with (
             mock.patch.object(CI_STATUS, "jenkins_queued_check", return_value=None),
             mock.patch.object(CI_STATUS, "jenkins_builds", return_value=[current]),
             mock.patch.object(CI_STATUS, "jenkins_matrix_configurations", return_value=matrix),
+            mock.patch.object(CI_STATUS, "http_text", side_effect=[child_console, "Finished: FAILURE\n"]),
             result = CI_STATUS.jenkins_check(check_config, branch, timeout=5)
         self.assertEqual(CI_STATUS.FAILURE, result["status"])
         self.assertEqual("build 5284; failed: PG19", result["message"])
-        self.assertEqual("https://ci.example.test/job/PostGIS_trunk/PG_VER=19/5284/", result["url"])
+        self.assertEqual("https://ci.example.test/job/PostGIS_2_windows_PGVERSION_winnie/20003/", result["url"])
+        self.assertEqual(
+            "https://ci.example.test/job/PostGIS_2_windows_PGVERSION_winnie/20003/console",
+            result["console_url"],
+        self.assertEqual(result["console_url"], CI_STATUS.result_url(result))
+        self.assertEqual(
+            "PG19: PostGIS_2_windows_PGVERSION_winnie #20003",
+            result["failure_details"][0]["label"],
         self.assertEqual("a" * 40, result["revision"])
     def test_jenkins_single_configuration_matrix_keeps_parent_message(self):
@@ -451,6 +473,35 @@ class CIStatusTest(unittest.TestCase):
         self.assertEqual("build 7808", result["message"])
         self.assertEqual("https://ci.example.test/job/PostGIS_Make_Dist/7808/", result["url"])
+    def test_jenkins_downstream_parse_failure_keeps_matrix_build(self):
+        build_url = "https://ci.example.test/job/PostGIS_3.5/PG_VER=17/208/"
+        with mock.patch.object(CI_STATUS, "http_text", return_value="unstructured failure"):
+            result = CI_STATUS.jenkins_terminal_failures(build_url, timeout=5)
+        self.assertIsNone(result)
+    def test_jenkins_downstream_failure_fanout_keeps_each_leaf_console(self):
+        parent_console = (
+            "PostGIS_EDB_Regress_winnie #23462 completed. Result was FAILURE\n"
+        leaf_console = "Finished: FAILURE\n"
+            CI_STATUS, "http_text", side_effect=[parent_console, leaf_console, leaf_console]
+            failures = CI_STATUS.jenkins_terminal_failures(build_url, timeout=5)
+        self.assertEqual(2, len(failures))
+        self.assertEqual(
+            failures[0]["console_url"],
+        self.assertEqual(
+            "https://ci.example.test/job/PostGIS_EDB_Regress_winnie/23462/console",
+            failures[1]["console_url"],
     def test_jenkins_matrix_ignores_another_parent_build(self):
         check_config = {
             "name": "Jenkins / Debbie main",
Summary of changes:
 utils/docs/ci_status/report.py     | 112 +++++++++++++++++++++++++++++++++++--
 utils/docs/tests/test_ci_status.py |  53 +++++++++++++++++-
 2 files changed, 159 insertions(+), 6 deletions(-)
hooks/post-receive
