[SCM] PostGIS branch master updated. 3.7.0beta2-117-g99f9ff539
git at osgeo.org
git at osgeo.org
Sat Aug 22 12:31:23 PDT 2026
the project "PostGIS".
via 99f9ff5396e9ac19e5f66c7638f42668ca001d0e (commit)
via 7f1a212e95a5680e217660cfdfa7215985b6abe6 (commit)
via 448670d5b96dd07cf5bb1ba85c7cb9320638578d (commit)
via 3d96989d303de93bb6c271420fe700accb441926 (commit)
via 78c4f16f3d7b10c06cf5815794326fb1b0c830f3 (commit)
from b2d575041cbbb33402ed52c90284e93e7c649248 (commit)
revisions in full, below.
commit 99f9ff5396e9ac19e5f66c7638f42668ca001d0e
Merge: b2d575041 7f1a212e9
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Aug 22 12:31:22 2026 -0700
Merge pull request 'ci: do not report old running revisions as current' (!766) from Komzpa/postgis:fix/ci-current-running-revision-20260822 into master
## Summary
- Mark an in-progress CI run from an older revision as `unknown`, rather than current running coverage.
- Keep the revision-distance diagnostic and leave a current-head running job unchanged.
## Rationale
A provider can still be executing an older checkout after the target branch advances. That run cannot establish the status of the current branch head.
## Tests
- `python3 -m unittest utils.docs.tests.test_ci_status`
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/766
commit 7f1a212e95a5680e217660cfdfa7215985b6abe6
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Aug 22 22:45:36 2026 +0400
Fail closed on revisionless running CI
diff --git a/utils/docs/ci_status/report.py b/utils/docs/ci_status/report.py
index 76fb9f42f..8f322c069 100644
--- a/utils/docs/ci_status/report.py
+++ b/utils/docs/ci_status/report.py
@@ -1463,32 +1463,36 @@ def stale_running_result(result, distance_count=None, distance_ref=None, detail=
return stale
+def exact_head_distance(result, exact_head):
+ revision = result.get("revision")
+ branch_name = result.get("branch")
+ if not revision or not exact_head or not branch_name:
+ return None, None
+ return git_commit_distance(revision, exact_head), branch_name
def apply_staleness(result, config, check, branch_heads=None):
threshold = stale_after_hours(config, check)
- distance_count, distance_ref = result_revision_distance(config, result)
exact_head = None
if branch_heads is not None:
exact_head = branch_heads.get(result.get("branch"))
exact_head_required = bool(config.get("cache_head_remote"))
- if result["status"] == IN_PROGRESS and result.get("revision") and exact_head_required and not exact_head:
- return stale_running_result(
- result,
- distance_count=distance_count,
- distance_ref=distance_ref,
- detail="branch head unavailable",
- if (
- result["status"] == IN_PROGRESS
- and exact_head
- and result.get("revision")
- and result["revision"].lower() != exact_head.lower()
- result,
- detail=f"not at {result['branch']} head",
+ if result["status"] == IN_PROGRESS and exact_head_required:
+ if not result.get("revision"):
+ return stale_running_result(result, detail="running revision unavailable")
+ if not exact_head:
+ return stale_running_result(result, detail="branch head unavailable")
+ if result["revision"].lower() != exact_head.lower():
+ distance_count, distance_ref = exact_head_distance(result, exact_head)
+ result,
+ distance_count=distance_count,
+ distance_ref=distance_ref,
+ detail=f"not at {result['branch']} head",
+ return result
+ distance_count, distance_ref = result_revision_distance(config, result)
if result["status"] == IN_PROGRESS and distance_count and distance_count > 0:
return stale_running_result(result, distance_count=distance_count, distance_ref=distance_ref)
if result["status"] != IN_PROGRESS and distance_count and distance_count > 0:
diff --git a/utils/docs/tests/test_ci_status.py b/utils/docs/tests/test_ci_status.py
index bf2ad90e5..bb8d013d7 100644
--- a/utils/docs/tests/test_ci_status.py
+++ b/utils/docs/tests/test_ci_status.py
@@ -278,6 +278,80 @@ class CIStatusTest(unittest.TestCase):
self.assertEqual("Stale running", result["status_label"])
self.assertIn("branch head unavailable", result["message"])
+ def test_collect_status_running_result_fails_closed_when_revision_unavailable(self):
+ config = {
+ "cache_head_remote": "https://example.test/postgis.git",
+ "branches": [{"name": "master", "label": "master"}],
+ "checks": [{
+ "name": "Synthetic CI",
+ "provider": "synthetic",
+ "required": True,
+ provider = mock.Mock(return_value={
+ "branch": "master",
+ "branch_label": "master",
+ "check": "Synthetic CI",
+ "required": True,
+ "status": CI_STATUS.IN_PROGRESS,
+ "message": "badge: running",
+ with (
+ mock.patch.dict(CI_STATUS.PROVIDERS, {"synthetic": provider}),
+ mock.patch.object(CI_STATUS, "resolve_cache_heads", return_value={"master": "f" * 40}),
+ data = CI_STATUS.collect_status(config)
+ result = data["branches"][0]["checks"][0]
+ self.assertEqual(CI_STATUS.UNKNOWN, result["status"])
+ self.assertEqual(CI_STATUS.IN_PROGRESS, result["stale_base_status"])
+ self.assertIn("running revision unavailable", result["message"])
+ def test_collect_status_running_mismatch_uses_canonical_sha_distance_only(self):
+ config = {
+ "checks": [{
+ "required": True,
+ "required": True,
+ "revision": "e" * 40,
+ "message": "build 8178; running: Winnie",
+ def fake_distance(revision, ref):
+ if ref == "b" * 40:
+ return 7
+ return 999
+ with (
+ mock.patch.object(CI_STATUS, "git_commit_distance", side_effect=fake_distance),
+ CI_STATUS,
+ "resolve_cache_heads",
+ return_value={"master": "b" * 40},
+ self.assertEqual(7, result["revision_commits_behind"])
+ self.assertEqual("7 commits behind master", result["revision_distance"])
+ self.assertIn("7 commits behind master", result["message"])
def test_cache_head_lookup_queries_remote_once_for_all_branches(self):
config = {"cache_head_remote": "https://example.test/postgis.git"}
branches = [
@@ -518,6 +592,7 @@ class CIStatusTest(unittest.TestCase):
def test_apply_staleness_marks_running_result_unknown_when_exact_head_differs(self):
config = {
"stale_after_hours": 168,
@@ -533,7 +608,7 @@ class CIStatusTest(unittest.TestCase):
- with mock.patch.object(CI_STATUS, "result_revision_distance", return_value=(0, "master")):
+ with mock.patch.object(CI_STATUS, "git_commit_distance", return_value=None):
stale = CI_STATUS.apply_staleness(running, config, stale_check, {"master": "4" * 40})
self.assertEqual(CI_STATUS.UNKNOWN, stale["status"])
@@ -542,6 +617,30 @@ class CIStatusTest(unittest.TestCase):
self.assertNotIn("revision_distance", stale)
self.assertIn("not at master head", stale["message"])
+ def test_apply_staleness_marks_running_result_unknown_when_revision_unavailable(self):
+ config = {
+ "stale_after_hours": 168,
+ stale_check = {"name": "Synthetic CI"}
+ running = {
+ "required": True,
+ stale = CI_STATUS.apply_staleness(running, config, stale_check, {"master": "4" * 40})
+ self.assertEqual(CI_STATUS.UNKNOWN, stale["status"])
+ self.assertEqual(CI_STATUS.IN_PROGRESS, stale["stale_base_status"])
+ self.assertEqual("Stale running", stale["status_label"])
+ self.assertIn("running revision unavailable", stale["message"])
def test_github_actions_requests_history_for_the_named_workflow(self):
check_config = {
"name": "GitHub Actions / Linux",
commit 448670d5b96dd07cf5bb1ba85c7cb9320638578d
Date: Sat Aug 22 22:41:07 2026 +0400
Normalize canonical running SHA checks
index 8cd3f9609..76fb9f42f 100644
@@ -1449,6 +1449,20 @@ def stale_after_hours(config, check):
raise ConfigError(f"invalid stale_after_hours for {check['name']}: {value}")
+def stale_running_result(result, distance_count=None, distance_ref=None, detail=None):
+ stale = dict(result)
+ stale["stale_base_status"] = result["status"]
+ stale["status"] = UNKNOWN
+ stale["status_label"] = "Stale running"
+ if distance_count and distance_count > 0:
+ stale["revision_commits_behind"] = distance_count
+ stale["revision_compare_ref"] = distance_ref
+ stale["revision_distance"] = revision_distance_text(distance_count, distance_ref)
+ message_detail = stale.get("revision_distance") or detail
+ stale["message"] = f"{result.get('message', 'CI run')} ({message_detail})"
+ return stale
@@ -1457,44 +1471,26 @@ def apply_staleness(result, config, check, branch_heads=None):
- stale = dict(result)
- stale["stale_base_status"] = result["status"]
- stale["status"] = UNKNOWN
- stale["status_label"] = "Stale running"
- if distance_count and distance_count > 0:
- stale["revision_commits_behind"] = distance_count
- stale["revision_compare_ref"] = distance_ref
- stale["revision_distance"] = revision_distance_text(distance_count, distance_ref)
- detail = stale.get("revision_distance") or "branch head unavailable"
- stale["message"] = f"{result.get('message', 'CI run')} ({detail})"
- return stale
+ result,
+ detail="branch head unavailable",
if (
and exact_head
- and result["revision"] != exact_head
+ and result["revision"].lower() != exact_head.lower()
- detail = stale.get("revision_distance") or f"not at {result['branch']} head"
- return stale
+ result,
- stale["message"] = f"{result.get('message', 'CI run')} ({stale['revision_distance']})"
- return stale
+ return stale_running_result(result, distance_count=distance_count, distance_ref=distance_ref)
index bf95a427a..bf2ad90e5 100644
@@ -492,6 +492,30 @@ class CIStatusTest(unittest.TestCase):
self.assertNotIn("stale_base_status", current)
self.assertNotIn("revision_distance", current)
+ def test_apply_staleness_keeps_running_result_at_branch_head_case_insensitively(self):
+ config = {
+ running = {
+ "required": True,
+ "revision": "ab" * 20,
+ "message": "build 8186; running: Winnie",
+ with mock.patch.object(CI_STATUS, "result_revision_distance", return_value=(0, "master")):
+ current = CI_STATUS.apply_staleness(running, config, stale_check, {"master": ("AB" * 20)})
+ self.assertEqual(CI_STATUS.IN_PROGRESS, current["status"])
+ self.assertNotIn("stale_base_status", current)
+ self.assertNotIn("revision_distance", current)
config = {
commit 3d96989d303de93bb6c271420fe700accb441926
Date: Sat Aug 22 22:37:27 2026 +0400
Use canonical heads for running CI rows
index 19529ed40..8cd3f9609 100644
@@ -1376,23 +1376,13 @@ def load_status_cache(path):
def resolve_cache_heads(config, work, cache, timeout):
- if not cache:
- return {}
remote = config.get("cache_head_remote")
if not remote:
return {}
parsed = urllib.parse.urlparse(remote)
if parsed.scheme not in ("https", "http") or not parsed.netloc or remote.startswith("-"):
raise ConfigError("cache_head_remote must be an HTTP(S) URL")
- branch_names = sorted({
- branch["name"]
- for branch, _check in work
- if any(
- cached.get("status") == SUCCESS
- for (cached_branch, _cached_check), cached in cache["checks"].items()
- if cached_branch == branch["name"]
+ branch_names = sorted({branch["name"] for branch, _check in work})
if not branch_names:
return {}
refs = [f"refs/heads/{name}" for name in branch_names]
@@ -1459,9 +1449,42 @@ def stale_after_hours(config, check):
-def apply_staleness(result, config, check):
+def apply_staleness(result, config, check, branch_heads=None):
+ exact_head = None
+ if branch_heads is not None:
+ exact_head = branch_heads.get(result.get("branch"))
+ exact_head_required = bool(config.get("cache_head_remote"))
+ if result["status"] == IN_PROGRESS and result.get("revision") and exact_head_required and not exact_head:
+ detail = stale.get("revision_distance") or "branch head unavailable"
+ stale["message"] = f"{result.get('message', 'CI run')} ({detail})"
+ return stale
+ if (
+ result["status"] == IN_PROGRESS
+ and exact_head
+ and result.get("revision")
+ and result["revision"] != exact_head
+ detail = stale.get("revision_distance") or f"not at {result['branch']} head"
+ return stale
@@ -1538,12 +1561,12 @@ async def collect_status_async(config, selected_branch=None, include_eol=False,
branch, check = item
cached = cached_success_result(branch, check, cache, cache_heads)
if cached:
- return apply_staleness(cached, config, check)
+ return apply_staleness(cached, config, check, cache_heads)
provider = PROVIDERS.get(check.get("provider"))
if provider is None:
raise ConfigError(f"unsupported provider for {check['name']}: {check.get('provider')}")
try:
- return apply_staleness(provider(check, branch, timeout), config, check)
+ return apply_staleness(provider(check, branch, timeout), config, check, cache_heads)
except RECOVERABLE_PROVIDER_ERRORS as exc:
return result_from_exception(check, branch, exc)
index 345d8d4af..bf95a427a 100644
@@ -164,6 +164,7 @@ class CIStatusTest(unittest.TestCase):
def test_cache_uses_fresh_remote_head_not_stale_local_ref(self):
config = {
"checks": [{
@@ -203,6 +204,80 @@ class CIStatusTest(unittest.TestCase):
provider.assert_called_once()
self.assertEqual(CI_STATUS.FAILURE, data["branches"][0]["checks"][0]["status"])
+ def test_collect_status_exact_remote_head_marks_stale_running_unknown_despite_zero_distance(self):
+ config = {
+ "checks": [{
+ "required": True,
+ "required": True,
+ with (
+ mock.patch.object(CI_STATUS, "git_commit_distance", return_value=0),
+ CI_STATUS,
+ provider.assert_called_once()
+ self.assertEqual("Stale running", result["status_label"])
+ self.assertNotIn("revision_distance", result)
+ self.assertIn("not at master head", result["message"])
+ def test_collect_status_running_result_fails_closed_when_branch_head_missing(self):
+ config = {
+ "checks": [{
+ "required": True,
+ "required": True,
+ "revision": "f" * 40,
+ "message": "build 8180; running: Winnie",
+ with (
+ mock.patch.object(CI_STATUS, "resolve_cache_heads", return_value={}),
+ self.assertIn("branch head unavailable", result["message"])
branches = [
@@ -411,12 +486,38 @@ class CIStatusTest(unittest.TestCase):
- current = CI_STATUS.apply_staleness(running, config, stale_check)
+ current = CI_STATUS.apply_staleness(running, config, stale_check, {"master": "2" * 40})
+ def test_apply_staleness_marks_running_result_unknown_when_exact_head_differs(self):
+ config = {
+ running = {
+ "required": True,
+ "revision": "3" * 40,
+ self.assertNotIn("revision_distance", stale)
+ self.assertIn("not at master head", stale["message"])
check_config = {
commit 78c4f16f3d7b10c06cf5815794326fb1b0c830f3
Date: Sat Aug 22 22:29:21 2026 +0400
Fix stale running CI revision handling
index ac75c704e..19529ed40 100644
@@ -1461,9 +1461,17 @@ def stale_after_hours(config, check):
- distance_count, distance_ref = None, None
- if result["status"] != IN_PROGRESS:
+ if result["status"] == IN_PROGRESS and distance_count and distance_count > 0:
+ stale["message"] = f"{result.get('message', 'CI run')} ({stale['revision_distance']})"
+ return stale
index 0c4cb87a2..345d8d4af 100644
@@ -366,6 +366,57 @@ class CIStatusTest(unittest.TestCase):
self.assertEqual(CI_STATUS.STALE_PASSED, recent_passed["status"])
self.assertIn("3 commits behind stable-synthetic", recent_passed["message"])
+ def test_apply_staleness_marks_running_result_from_old_revision_unknown(self):
+ config = {
+ running = {
+ "required": True,
+ "revision": "1" * 40,
+ with mock.patch.object(CI_STATUS, "result_revision_distance", return_value=(467, "master")):
+ stale = CI_STATUS.apply_staleness(running, config, stale_check)
+ self.assertEqual(467, stale["revision_commits_behind"])
+ self.assertEqual("467 commits behind master", stale["revision_distance"])
+ self.assertIn("467 commits behind master", stale["message"])
+ def test_apply_staleness_keeps_running_result_at_branch_head(self):
+ config = {
+ running = {
+ "required": True,
+ "revision": "2" * 40,
+ "message": "build 8185; running: Winnie",
+ current = CI_STATUS.apply_staleness(running, config, stale_check)
check_config = {
Summary of changes:
utils/docs/ci_status/report.py | 65 ++++++---
utils/docs/tests/test_ci_status.py | 275 +++++++++++++++++++++++++++++++++++++
2 files changed, 323 insertions(+), 17 deletions(-)
hooks/post-receive
