[SCM] PostGIS branch master updated. 3.7.0beta2-119-g8077e8218
Sat Aug 22 15:23:14 PDT 2026
the project "PostGIS".
       via  8077e8218ce113774d33926b01ab5daa55664f05 (commit)
       via  4ac786abbfa78b9e284b71c1a6beaf54d44e5142 (commit)
      from  99f9ff5396e9ac19e5f66c7638f42668ca001d0e (commit)
revisions in full, below.
commit 8077e8218ce113774d33926b01ab5daa55664f05
Merge: 99f9ff539 4ac786abb
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sat Aug 22 15:23:13 2026 -0700
    Merge pull request 'ci: cache GitHub rate-limit results with revisions' (!767) from Komzpa/postgis:ci/github-rate-cache-20260823 into master
    ## Summary
    - reuse an exact-branch-head cached GitHub Actions result when the GitHub API returns a rate-limit `403`
    - preserve the cached workflow status and commit revision instead of falling back to a revisionless badge
    - keep ordinary `403` responses on the existing badge fallback
    This prevents anonymous API rate exhaustion from turning a current CI row into a revisionless or misleading badge result. Cache reuse still requires the same branch, check, provider, required flag, and freshly resolved canonical branch head.
    ## Validation
    - `python3 utils/docs/tests/test_ci_status.py` (41 tests)
    - `git diff --check upstream/master...HEAD`
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/767
commit 4ac786abbfa78b9e284b71c1a6beaf54d44e5142
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Aug 23 01:43:17 2026 +0400
diff --git a/utils/docs/ci_status/report.py b/utils/docs/ci_status/report.py
index 8f322c069..a5aa0cc35 100644
--- a/utils/docs/ci_status/report.py
+++ b/utils/docs/ci_status/report.py
@@ -297,13 +297,38 @@ def github_runs_for_workflow(repo, branch, workflow, token, timeout):
     return data.get("workflow_runs", []), url
-def github_actions_check(check, branch, timeout):
+def github_rate_limit_error(exc):
+    if not isinstance(exc, urllib.error.HTTPError) or exc.code != 403:
+        return False
+    remaining = exc.headers.get("X-RateLimit-Remaining") if exc.headers else None
+    if remaining == "0":
+        exc.close()
+        return True
+    try:
+        body = json.loads(exc.read().decode("utf-8"))
+    except (AttributeError, UnicodeDecodeError, json.JSONDecodeError, OSError):
+        return False
+    finally:
+        exc.close()
+    message = body.get("message") if isinstance(body, dict) else None
+    return isinstance(message, str) and message.startswith("API rate limit exceeded")
+def github_actions_check(check, branch, timeout, cached_result=None):
     workflow = check["workflow"]
     repo = check.get("repo", "postgis/postgis")
     token = os.environ.get("GITHUB_TOKEN") or os.environ.get("GH_TOKEN")
     try:
         runs, debug_url = github_runs_for_workflow(repo, branch, workflow, token, timeout)
     except RECOVERABLE_PROVIDER_ERRORS as exc:
+        if github_rate_limit_error(exc) and cached_result:
+            result = dict(cached_result)
+            result["cached"] = True
+            result["message"] = (
+                f"{result.get('message') or 'cached GitHub Actions result'} "
+                "(cached; GitHub API rate limit exceeded)"
+            return result
         return github_badge_check(check, branch, repo, workflow, timeout, api_error=exc)
     if not runs:
         try:
@@ -1439,6 +1464,35 @@ def cached_success_result(branch, check, cache, cache_heads):
     return result
+def cached_current_result(branch, check, cache, cache_heads):
+    """Return an exact-head cached provider result for rate-limit fallback."""
+    if not cache:
+        return None
+    cached = cache["checks"].get((branch["name"], check["name"]))
+    if not cached:
+        return None
+    if cached.get("branch") != branch["name"] or cached.get("check") != check["name"]:
+        return None
+    if cached.get("provider") != check.get("provider"):
+        return None
+    if cached.get("required") != bool(check.get("required", True)):
+        return None
+    if cached.get("status") not in STATUS_DISPLAY_ORDER:
+        return None
+    revision = cached.get("revision")
+    if not revision or revision != cache_heads.get(branch["name"]):
+        return None
+    result = dict(cached)
+    result.update({
+        "branch": branch["name"],
+        "branch_label": branch["label"],
+        "check": check["name"],
+        "provider": check.get("provider"),
+        "required": bool(check.get("required", True)),
+    return result
 def stale_after_hours(config, check):
     value = check.get("stale_after_hours", config.get("stale_after_hours"))
     if value is None:
@@ -1566,7 +1620,12 @@ async def collect_status_async(config, selected_branch=None, include_eol=False,
         if provider is None:
             raise ConfigError(f"unsupported provider for {check['name']}: {check.get('provider')}")
         try:
-            return apply_staleness(provider(check, branch, timeout), config, check, cache_heads)
+            cached_fallback = cached_current_result(branch, check, cache, cache_heads)
+            if check.get("provider") == "github_actions":
+                result = provider(check, branch, timeout, cached_fallback)
+            else:
+                result = provider(check, branch, timeout)
+            return apply_staleness(result, config, check, cache_heads)
             return result_from_exception(check, branch, exc)
diff --git a/utils/docs/tests/test_ci_status.py b/utils/docs/tests/test_ci_status.py
index bb8d013d7..4469dbb6f 100644
--- a/utils/docs/tests/test_ci_status.py
+++ b/utils/docs/tests/test_ci_status.py
@@ -5,6 +5,7 @@ import subprocess
 import sys
 import tempfile
 import unittest
+import urllib.error
 from unittest import mock
@@ -667,6 +668,56 @@ class CIStatusTest(unittest.TestCase):
             http_json.call_args.args[0],
+    def test_github_actions_rate_limit_uses_exact_head_cached_result(self):
+        check_config = {
+            "name": "GitHub Actions / Linux",
+            "provider": "github_actions",
+            "required": True,
+            "workflow": "ci.yml",
+        branch = {"name": "master", "label": "master"}
+        revision = "a" * 40
+        cached = {
+            "branch": "master",
+            "branch_label": "master",
+            "check": check_config["name"],
+            "required": True,
+            "status": CI_STATUS.SUCCESS,
+            "revision": revision,
+            "message": "current Linux run",
+        headers = {"X-RateLimit-Remaining": "0"}
+        error = urllib.error.HTTPError("https://api.github.com", 403, "forbidden", headers, io.BytesIO(b"{}"))
+        with mock.patch.object(CI_STATUS, "github_runs_for_workflow", side_effect=error):
+            result = CI_STATUS.github_actions_check(check_config, branch, timeout=5, cached_result=cached)
+        self.assertEqual(CI_STATUS.SUCCESS, result["status"])
+        self.assertEqual(revision, result["revision"])
+        self.assertTrue(result["cached"])
+        self.assertIn("rate limit exceeded", result["message"])
+    def test_github_actions_ordinary_forbidden_does_not_use_cache(self):
+        check_config = {
+            "required": True,
+            "https://api.github.com", 403, "forbidden", {"X-RateLimit-Remaining": "1"}, io.BytesIO(b"{}")
+        badge = {"status": CI_STATUS.FAILURE, "message": "badge: failing"}
+        with (
+            mock.patch.object(CI_STATUS, "github_runs_for_workflow", side_effect=error),
+            mock.patch.object(CI_STATUS, "github_badge_check", return_value=badge) as fallback,
+            result = CI_STATUS.github_actions_check(check_config, branch, timeout=5, cached_result={"revision": "a" * 40})
+        fallback.assert_called_once()
+        self.assertEqual(badge, result)
     def test_github_actions_does_not_share_one_hundred_runs_between_workflows(self):
         linux = {"name": "GitHub Actions / Linux", "provider": "github_actions", "required": True, "workflow": "ci.yml"}
Summary of changes:
 utils/docs/ci_status/report.py     | 63 ++++++++++++++++++++++++++++++++++++--
 utils/docs/tests/test_ci_status.py | 51 ++++++++++++++++++++++++++++++
 2 files changed, 112 insertions(+), 2 deletions(-)
hooks/post-receive
