[PostGIS] #6118: Out-of-bounds read in geometry_type_from_string() on an empty type modifier
PostGIS trac at osgeo.org
Mon Aug 31 09:04:14 PDT 2026
  Reporter:  eivkov    |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.6.5
 Component:  postgis   |    Version:  master
Resolution:            |   Keywords:  buffer overflow
Description changed by eivkov:
Old description:
> geometry_type_from_string() computes the last-character position as
> strlen(str) - 1 without checking for an empty string. tmpendpos and i are
> size_t, so for str == "" the subtraction wraps to SIZE_MAX and the
> trailing-space loop immediately dereferences str[SIZE_MAX].
> There is no length check on the caller side either: postgis_typmod_in()
> hands the typmod cstring straight to this function, so the empty string
> is reachable from SQL by any user.
> Reproducer: SELECT geometry_typmod_in('{""}'); — the same entry point is
> already exercised with a bad type name at
> regress/core/lwgeom_regress.sql:223, which returns a clean "Invalid
> geometry type modifier" error; the empty element does not.
> PR ready: https://github.com/postgis/postgis/pull/1176
New description:
 hands the typmod cstring straight to this function, so the empty string is
 Reproducer: SELECT geometry_typmod_in('{""}'); - the same entry point is
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6118#comment:1>
