[PostGIS] #6089: wrong node used when adding a new long line
trac at osgeo.org
Wed Jul 1 00:24:22 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone:
Component: topology | Version: master
Resolution: | Keywords: snap
Comment (by strk):
Replying to [comment:8 Lars Aksel Opsahl]:
> What happens is that lower node is used i my testcase.
When I test this _BOTH_ nodes are used, not ONLY the lower one. And that's
because _BOTH_ nodes are within the given tolerance.
> I also assume in this case the result should be equal when I run
tolerance -1 or 1e-07 , related what nodes that are selected in this case.
Running with -1 it snaps to upper node and not the lower node as when
using 1e-07.
Passing -1 asks PostGIS to compute the "minimum distance that can be
represented with a 64bit floating point number between the further-from-0
vertex outward". I guess such distance (which I didn't check what it is)
must be bigger than the distance between the incoming line and the upper
node (which is computed by PostGIS as 0).
> The problem is not invalid topology, but that result i sliver topology
that I have to remove later again.
At least you can spot and remove that sliver !
What I'm saying is that this is all expected behavior, not a bug, not
"wrong".
If you want to turn this ticket to a feature request we can keep it open,
but maybe it would be cleaner to file a new ticket when there's a clear
plan.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6089#comment:9>
