[PostGIS] #6091: berrie64 ailing on xml module not found
PostGIS trac at osgeo.org
Sun Jul 5 14:22:05 PDT 2026
 Reporter:  robe          |      Owner:  robe
     Type:  defect        |     Status:  new
 Priority:  medium        |  Milestone:  PostGIS 3.7.0
Component:  QA/buildbots  |    Version:  master
 Keywords:                |
 Berrie64 is failing on garden test
 07:08:34   File
 "/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie64/54ed1c6a383d71cb013c801ee2b375b74df2c313/regress/../utils/test_postgis_exampletest.py",
 line 5, in <module>
 07:08:34     from postgis_exampletest import ExampleTester,
 parse_source_example
 07:08:34   File
 "/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie64/54ed1c6a383d71cb013c801ee2b375b74df2c313/utils/postgis_exampletest.py",
 line 8, in <module>
 07:08:34     from lxml import etree
 Looks like she just needs a python module install to run the postgis
 example tests.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6091>
