[SCM] PostGIS branch master updated. 3.7.0alpha1-21-g0936d3fa9
git at osgeo.org
git at osgeo.org
Mon Jul 6 04:14:27 PDT 2026
the project "PostGIS".
via 0936d3fa9a7d8e170d4c1806ca522e188f79a681 (commit)
via 1983ba2ddbef5128c34ef2f9f6a3542be898209c (commit)
via afbfd0120136fea9cfabe7bcb0ccb34ece6e6fc4 (commit)
via 12afc1d465c14008848ededffe76aac533e50bc4 (commit)
via 425b52962c1d11ff3643da740e6ac7846c3cfce8 (commit)
from 333d896e75c3d61887e80c506f5879fd558b1a2c (commit)
revisions in full, below.
commit 0936d3fa9a7d8e170d4c1806ca522e188f79a681
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Jul 6 15:04:28 2026 +0400
NEWS: add entries for GH-1146 and GH-1150
References https://github.com/postgis/postgis/pull/1146
References https://github.com/postgis/postgis/pull/1150
diff --git a/NEWS b/NEWS
index 78ad37d49..70a3dc001 100644
--- a/NEWS
+++ b/NEWS
@@ -11,11 +11,15 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
ring-orientation precision regressions (Darafei Praliaskouski)
- GH-1143, [topology] Clean up TopoRingIsCCW early returns
+ - GH-1146, Reset interrupt callbacks when PostgreSQL clears
+ cancellation state (Darafei Praliaskouski)
- GH-1147, [doc] Fix localized EPUB help target (Darafei Praliaskouski)
- GH-1148, [utils] Create upgrade-check tempdir safely
- GH-1149, [topology] Fix corrupt column fallback variables
+ - GH-1150, Free polygon orientation inputs in ST_IsPolygonCW/CCW
+ (Darafei Praliaskouski)
- GH-1153, [topology] Preserve large ids from edge wrappers
commit 1983ba2ddbef5128c34ef2f9f6a3542be898209c
Merge: afbfd0120 425b52962
Date: Mon Jul 6 15:04:16 2026 +0400
Merge pull request https://github.com/postgis/postgis/pull/1150
postgis: free polygon orientation inputs
Closes https://github.com/postgis/postgis/pull/1150
commit afbfd0120136fea9cfabe7bcb0ccb34ece6e6fc4
Merge: 333d896e7 12afc1d46
Merge pull request https://github.com/postgis/postgis/pull/1146
postgis: reset interrupt callbacks when clear
Closes https://github.com/postgis/postgis/pull/1146
commit 12afc1d465c14008848ededffe76aac533e50bc4
Date: Mon Jul 6 11:38:04 2026 +0400
diff --git a/postgis/postgis_module.c b/postgis/postgis_module.c
index 8d79254ab..29f01423a 100644
--- a/postgis/postgis_module.c
+++ b/postgis/postgis_module.c
@@ -70,6 +70,10 @@ static void interrupt_geos_callback(void)
GEOS_interruptRequest();
+ else
+ GEOS_interruptCancel();
static void interrupt_liblwgeom_callback(void)
@@ -89,6 +93,10 @@ static void interrupt_liblwgeom_callback(void)
lwgeom_request_interrupt();
+ else
+ lwgeom_cancel_interrupt();
@@ -139,5 +147,3 @@ _PG_fini(void)
elog(NOTICE, "Goodbye from PostGIS %s", POSTGIS_VERSION);
diff --git a/raster/rt_pg/rtpostgis.c b/raster/rt_pg/rtpostgis.c
index 663fe8552..76327b197 100644
--- a/raster/rt_pg/rtpostgis.c
+++ b/raster/rt_pg/rtpostgis.c
@@ -159,6 +159,8 @@ rtpg_interrupt_liblwgeom_callback(void)
#endif
if (QueryCancelPending || ProcDiePending)
+ else
static lwinterrupt_callback *prev_liblwgeom_interrupt_callback = NULL;
commit 425b52962c1d11ff3643da740e6ac7846c3cfce8
Date: Mon Jul 6 11:29:32 2026 +0400
diff --git a/postgis/lwgeom_functions_analytic.c b/postgis/lwgeom_functions_analytic.c
index c424ba177..30a21e9aa 100644
--- a/postgis/lwgeom_functions_analytic.c
+++ b/postgis/lwgeom_functions_analytic.c
@@ -901,12 +901,18 @@ PG_FUNCTION_INFO_V1(ST_IsPolygonCW);
Datum ST_IsPolygonCW(PG_FUNCTION_ARGS)
GSERIALIZED* geom;
+ LWGEOM *lwgeom;
+ bool is_cw;
if (PG_ARGISNULL(0))
PG_RETURN_NULL();
geom = PG_GETARG_GSERIALIZED_P(0);
- PG_RETURN_BOOL(lwgeom_has_orientation(lwgeom_from_gserialized(geom), LW_CLOCKWISE));
+ lwgeom = lwgeom_from_gserialized(geom);
+ is_cw = lwgeom_has_orientation(lwgeom, LW_CLOCKWISE);
+ lwgeom_free(lwgeom);
+ PG_FREE_IF_COPY(geom, 0);
+ PG_RETURN_BOOL(is_cw);
@@ -919,12 +925,16 @@ PG_FUNCTION_INFO_V1(ST_IsPolygonCCW);
Datum ST_IsPolygonCCW(PG_FUNCTION_ARGS)
GSERIALIZED* geom;
+ LWGEOM *lwgeom;
+ bool is_ccw;
PG_RETURN_NULL();
- geom = PG_GETARG_GSERIALIZED_P(0);
- PG_RETURN_BOOL(lwgeom_has_orientation(lwgeom_from_gserialized(geom), LW_COUNTERCLOCKWISE));
+ is_ccw = lwgeom_has_orientation(lwgeom, LW_COUNTERCLOCKWISE);
+ PG_RETURN_BOOL(is_ccw);
Summary of changes:
NEWS | 4 ++++
postgis/lwgeom_functions_analytic.c | 18 ++++++++++++++----
postgis/postgis_module.c | 10 ++++++++--
raster/rt_pg/rtpostgis.c | 2 ++
4 files changed, 28 insertions(+), 6 deletions(-)
hooks/post-receive
