[PostGIS] #6094: downgrade error on berrie64 when standard conforming strings off
PostGIS trac at osgeo.org
Tue Jul 7 04:12:54 PDT 2026
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.6.5
 Component:  upgrade  |    Version:  3.6.x
Resolution:  fixed    |   Keywords:
Changes (by Darafei Praliaskouski <me@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"a5411841bd4b063d4c7ca6e371e14eaae61af85a/git" a541184/git]:
 {{{#!CommitTicketReference repository="git"
 revision="a5411841bd4b063d4c7ca6e371e14eaae61af85a"
 upgrade: escape version regex literals
 Use explicit escape string syntax for the version parsing regular
 expressions emitted by create_upgrade.pl. This keeps downgrade checks
 quiet and parser-stable when standard_conforming_strings is off.
 Closes #6094 for PostGIS 3.7
 Closes https://github.com/postgis/postgis/pull/1158
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6094#comment:1>
