[SCM] PostGIS branch stable-3.6 updated. 3.6.4-62-g8f0265779
git at osgeo.org
git at osgeo.org
Tue Jul 7 04:13:06 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
via 8f0265779255ca22f440e383973ce8b6618ef55c (commit)
from ae1c72fa7c510767dff7be53ce0653170b7876a1 (commit)
revisions in full, below.
commit 8f0265779255ca22f440e383973ce8b6618ef55c
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Jul 7 15:07:59 2026 +0400
upgrade: escape version regex literals
Use explicit escape string syntax for the version parsing regular expressions emitted by create_upgrade.pl. This keeps downgrade checks quiet and parser-stable when standard_conforming_strings is off.
Closes #6094 for PostGIS 3.6
Closes https://github.com/postgis/postgis/pull/1158
diff --git a/NEWS b/NEWS
index 0dbd1265e..cecfe2fad 100644
--- a/NEWS
+++ b/NEWS
@@ -34,6 +34,8 @@ PostGIS 3.6.5
cancellation state (Darafei Praliaskouski)
- #5948, [topology] Prevent MakeTopologyPrecise from erasing edges when
grid size exceeds their extent (Darafei Praliaskouski)
+- #6094, [upgrade] Avoid legacy string literal warnings in downgrade checks
+ with standard_conforming_strings off (Darafei Praliaskouski)
PostGIS 3.6.4
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index 38826cfe6..2f55394ed 100644
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -1022,11 +1022,11 @@ BEGIN
) SELECT
upgraded as scripts_upgraded,
installed as scripts_installed,
- pg_catalog.substring(upgraded, '([0-9]+)\.')::int * 100 +
- pg_catalog.substring(upgraded, '[0-9]+\.([0-9]+)(\.|$)')::int
+ pg_catalog.substring(upgraded, E'([0-9]+)\\.')::int * 100 +
+ pg_catalog.substring(upgraded, E'[0-9]+\\.([0-9]+)(\\.|$)')::int
as version_to_num,
- pg_catalog.substring(installed, '([0-9]+)\.')::int * 100 +
- pg_catalog.substring(installed, '[0-9]+\.([0-9]+)(\.|$)')::int
+ pg_catalog.substring(installed, E'([0-9]+)\\.')::int * 100 +
+ pg_catalog.substring(installed, E'[0-9]+\\.([0-9]+)(\\.|$)')::int
as version_from_num,
installed ~ 'dev|alpha|beta'
as version_from_isdev
@@ -1062,4 +1062,3 @@ END
LANGUAGE 'plpgsql';
Summary of changes:
NEWS | 2 ++
utils/create_upgrade.pl | 9 ++++-----
2 files changed, 6 insertions(+), 5 deletions(-)
hooks/post-receive
