[PostGIS] #6094: downgrade error on berrie64 when standard conforming strings off
trac at osgeo.org
Tue Jul 7 04:13:09 PDT 2026
Reporter: robe | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 3.6.5
Component: upgrade | Version: 3.6.x
Resolution: fixed | Keywords:
Comment (by Darafei Praliaskouski <me@…>):
In [changeset:"8f0265779255ca22f440e383973ce8b6618ef55c/git"
8f026577/git]:
{{{#!CommitTicketReference repository="git"
revision="8f0265779255ca22f440e383973ce8b6618ef55c"
upgrade: escape version regex literals
Use explicit escape string syntax for the version parsing regular
expressions emitted by create_upgrade.pl. This keeps downgrade checks
quiet and parser-stable when standard_conforming_strings is off.
Closes #6094 for PostGIS 3.6
Closes https://github.com/postgis/postgis/pull/1158
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6094#comment:6>
