[PostGIS] #6093: Fails to build on ppc64el (error: detected recursion whilst expanding macro ‘vector’)
PostGIS trac at osgeo.org
Tue Jul 7 04:26:45 PDT 2026
‘vector’)
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  closed
  Priority:  medium          |  Milestone:  PostGIS 3.7.0
 Component:  build           |    Version:  master
Resolution:  fixed           |   Keywords:
Changes (by Darafei Praliaskouski <me@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"b9cf4e3021a3eb9d17d91d02f17b33d930e35bd8/git" b9cf4e3/git]:
 {{{#!CommitTicketReference repository="git"
 revision="b9cf4e3021a3eb9d17d91d02f17b33d930e35bd8"
 Avoid ppc64el vector macro in NURBS SQL comments
 The ppc64el toolchain can define vector for AltiVec, which makes the SQL
 preprocessor try to expand bare comment text while building postgis.sql.
 Reword the NURBS SQL comments so the preprocessor no longer sees that
 token.
 Closes #6093
 Closes https://github.com/postgis/postgis/pull/1159
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6093#comment:1>
