[PostGIS] #6095: add fixVertexSegmentPairsBelowDistanc
PostGIS trac at osgeo.org
Fri Jul 10 03:17:11 PDT 2026
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  enhancement        |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.6.5
 Component:  topology           |    Version:  3.6.x
Resolution:                     |   Keywords:
Old description:
> In the attached dump we this case
> [local] lop at t1=# SELECT * FROM
> topology.FindVertexSegmentPairsBelowDistance('grunnkart_037',1e-15);
>  seg_edge | segno | vert_edge | vertno |                     vert_geom
>         7 |    59 |        31 |      2 |
> 0101000020A2100000767C04140DD7164009093C79AE774D40
> the problem here that when covert this topology to simple feature we get
> this error
> SELECT
> ST_ISvalid(ST_GeomFromEWKT(ST_AsEWKT(topology.ST_GetFaceGeometry('grunnkart_037',20),8)));
> NOTICE:  00000: Self-intersection at or near point 5.7100108290768832
> 58.935012010161067
> LOCATION:  pg_notice, lwgeom_pg.c:389
>  st_isvalid
>  f
> (1 row)
> Then we run this code
> DO $$
> DECLARE
>                 r RECORD;
> BEGIN
>                 FOR r IN
>                                 SELECT DISTINCT ON (vs.vert_geom,
> e.edge_id)
>                                                         e.geom,
>                                                         vs.vert_geom
>                                 FROM
> 'grunnkart_037',
>        1e-15
>                                                 ) AS vs
>                                 JOIN grunnkart_037.edge e
>                                         ON e.edge_id = vs.seg_edge
>                                 ORDER BY vs.vert_geom, e.edge_id
>                 LOOP
>                                 BEGIN
>                                                 PERFORM
> topology.TopoGeo_addLinestring( 'grunnkart_037', ST_ShortestLine(r.geom,
> r.vert_geom), -1 );
>                                 EXCEPTION
>                                                 WHEN OTHERS THEN
>        RAISE
> WARNING 'Failed: %, error: %',
> ST_AsText(r.vert_geom),
> SQLERRM;
>                                 END;
>                 END LOOP;
> END;
> and the face geom is valid
> SELECT
>  st_isvalid
>  t
> (1 row)
> tested on
> POSTGIS="3.7.0dev 3.6.0rc2-473-g260127869" [EXTENSION] PGSQL="160"
> GEOS="3.14.1-CAPI-1.20.5" PROJ="9.8.1 NETWORK_ENABLED=OFF
> URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/Users/lop/Library/Application Support/proj
> DATABASE_PATH=/opt/homebrew/Cellar/proj/9.8.1/share/proj/proj.db"
> (compiled against PROJ 9.8.1) LIBXML="2.9.13" LIBJSON="0.18"
> LIBPROTOBUF="1.5.2" WAGYU="0.5.0 (Internal)" TOPOLOGY
New description:
         7 |    59 |        31 |      2 |
 this error
 SELECT
 58.935012010161067
  st_isvalid
  f
 (1 row)
 DO $$
 DECLARE
                 r RECORD;
 BEGIN
                 FOR r IN
 e.edge_id)
                                                         e.geom,
                                                         vs.vert_geom
                                 FROM
 'grunnkart_037',
        1e-15
                                                 ) AS vs
                 LOOP
                                 BEGIN
                                                 PERFORM
 r.vert_geom), -1 );
                                 EXCEPTION
                                                 WHEN OTHERS THEN
        RAISE
 SQLERRM;
                                 END;
                 END LOOP;
 END;
 SELECT
  st_isvalid
  t
 (1 row)
 tested on
Comment (by Lars Aksel Opsahl):
 Did another test on bigger dataset t2.
 We find a lot this FindVertexSegmentPairsBelowDistance we also two self
 intersection in simple feature as we see.
 SELECT 'FindVertexSegmentPairsBelowDistance before :' || count(*) FROM
                                 'grunnkart_037',
                                 1e-7
 SELECT 'invalid face before fixVertexSegmentPairsBelowDistance:'||
 count(*)
 FROM (
         SELECT
 ST_ISvalid(ST_GeomFromEWKT(ST_AsEWKT(topology.ST_GetFaceGeometry('grunnkart_037',face_id),8)))
 isvalid
         FROM grunnkart_037.face WHERE face_id > 0 ORDER by
 ST_area(topology.ST_GetFaceGeometry('grunnkart_037',face_id),true)
 ) r WHERE not isvalid;
                      ?column?
  FindVertexSegmentPairsBelowDistance before :1037
 (1 row)
 NOTICE:  00000: Self-intersection at or near point 5.7028636310767338
 58.933701939524774
 58.933701939524774
                          ?column?
  invalid face before fixVertexSegmentPairsBelowDistance:2
 We run fix
 DO $$
 DECLARE
                 r RECORD;
 BEGIN
                 FOR r IN
                                 SELECT DISTINCT ON (e.edge_id)
                                                         e.geom,
                                                         vs.vert_geom
                                 FROM
 'grunnkart_037',
        1e-7
                                                 ) AS vs
                                 ORDER BY e.edge_id, vs.vert_geom
                 LOOP
                                 BEGIN
                                                 PERFORM
 r.vert_geom), -1 );
                                 EXCEPTION
                                                 WHEN OTHERS THEN
        RAISE
 SQLERRM;
                                 END;
                 END LOOP;
 END;
 NOTICE:  00000: Empty component of noded line
 DO
 But now we seem to have more problems than before the fix
 SELECT 'FindVertexSegmentPairsBelowDistance after:' || count(*) FROM
                                 'grunnkart_037',
                                 1e-7
 SELECT 'invalid face after fixVertexSegmentPairsBelowDistance:'||count(*)
 FROM (
         SELECT
 isvalid
 SELECT * from topology.ValidateTopology('grunnkart_037');
 NOTICE:  00000: Too few points in geometry component at or near point
 5.7221960200000002 58.942031450000002
 5.7085718600000002 58.93178168
 5.7239140600000002 58.925350950000002
 5.7239140600000002 58.925350940000001
 5.7239140900000001 58.925350950000002
 5.7238169699999997 58.928892070000003
 5.71480999 58.936201019999999
 5.7142168199999999 58.935326719999999
 5.7236422300000003 58.93658525
 5.7087765800000003 58.922366529999998
 5.7044360200000002 58.922831590000001
 5.7019316699999996 58.933653839999998
 5.7028636400000003 58.933701939999999
 5.7029897099999998 58.93366056
 5.7018358600000001 58.933649299999999
 NOTICE:  00000: Self-intersection at or near point 5.7019283657189828
 58.932679461437964
 5.7014842100000003 58.932243669999998
 5.7013110999999999 58.932082100000002
 5.7012686600000002 58.932041769999998
 5.7012686600000002 58.93362501
 NOTICE:  00000: Self-intersection at or near point 5.7028636400000003
 58.933701939999999
 5.7013111099999998 58.932082100000002
 5.7012860300000003 58.93205871
 5.7012859899999997 58.932058689999998
 5.70526351 58.936307399999997
 5.7133967700000001 58.934488729999998
 5.7029828299999998 58.933654189999999
 NOTICE:  00000: Ring Self-intersection at or near point 5.7029828299999998
 58.933654189999999
 5.7027127999999996 58.933404099999997
 NOTICE:  00000: Self-intersection at or near point 5.70266684
 58.933361529999999
 5.7026668300000001 58.933361529999999
 NOTICE:  00000: Self-intersection at or near point 5.7015160700000003
 58.933634069999997
                          ?column?
  invalid face after fixVertexSegmentPairsBelowDistance:36
 (1 row)
 NOTICE:  00000: Checking for coincident nodes
 NOTICE:  00000: Checking for edges crossing nodes
 NOTICE:  00000: Checking for invalid or not-simple edges
 NOTICE:  00000: Checking for crossing edges
 NOTICE:  00000: Checking for edges start_node mismatch
 NOTICE:  00000: Checking for edges end_node mismatch
 NOTICE:  00000: Checking for faces without edges
 NOTICE:  00000: Checking edge linking
 NOTICE:  00000: Building edge rings
 NOTICE:  00000: Found 1609 rings, 1494 valid shells, 115 valid holes
 NOTICE:  00000: Constructing geometry of all faces
 NOTICE:  00000: Checking faces
 NOTICE:  00000: Checked 1495 faces
 NOTICE:  00000: Checking for holes coverage
 NOTICE:  00000: Finished checking for coverage of 115 holes
 NOTICE:  00000: Checking for node containing_face correctness
  error | id1 | id2
 (0 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6095#comment:1>
