[PostGIS] #6095: add fixVertexSegmentPairsBelowDistance (was: add fixVertexSegmentPairsBelowDistanc)
PostGIS trac at osgeo.org
Fri Jul 10 03:20:57 PDT 2026
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  enhancement        |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS Fund Me
 Component:  topology           |    Version:
Resolution:                     |   Keywords:
Changes (by strk):
 * milestone:  PostGIS 3.6.5 => PostGIS Fund Me
 * summary:  add fixVertexSegmentPairsBelowDistanc => add
 * version:  3.6.x =>
Old description:
> In the attached dump we this case
> [local] lop at t1=# SELECT * FROM
> topology.FindVertexSegmentPairsBelowDistance('grunnkart_037',1e-15);
>  seg_edge | segno | vert_edge | vertno |                     vert_geom
>         7 |    59 |        31 |      2 |
> 0101000020A2100000767C04140DD7164009093C79AE774D40
> the problem here that when covert this topology to simple feature we get
> this error
> SELECT
> ST_ISvalid(ST_GeomFromEWKT(ST_AsEWKT(topology.ST_GetFaceGeometry('grunnkart_037',20),8)));
> NOTICE:  00000: Self-intersection at or near point 5.7100108290768832
> 58.935012010161067
> LOCATION:  pg_notice, lwgeom_pg.c:389
>  st_isvalid
>  f
> (1 row)
> Then we run this code
> DO $$
> DECLARE
>                 r RECORD;
> BEGIN
>                 FOR r IN
>                                 SELECT DISTINCT ON (vs.vert_geom,
> e.edge_id)
>                                                         e.geom,
>                                                         vs.vert_geom
>                                 FROM
> 'grunnkart_037',
>        1e-15
>                                                 ) AS vs
>                                 JOIN grunnkart_037.edge e
>                                         ON e.edge_id = vs.seg_edge
>                                 ORDER BY vs.vert_geom, e.edge_id
>                 LOOP
>                                 BEGIN
>                                                 PERFORM
> topology.TopoGeo_addLinestring( 'grunnkart_037', ST_ShortestLine(r.geom,
> r.vert_geom), -1 );
>                                 EXCEPTION
>                                                 WHEN OTHERS THEN
>        RAISE
> WARNING 'Failed: %, error: %',
> ST_AsText(r.vert_geom),
> SQLERRM;
>                                 END;
>                 END LOOP;
> END;
> and the face geom is valid
> SELECT
>  st_isvalid
>  t
> (1 row)
> tested on
> POSTGIS="3.7.0dev 3.6.0rc2-473-g260127869" [EXTENSION] PGSQL="160"
> GEOS="3.14.1-CAPI-1.20.5" PROJ="9.8.1 NETWORK_ENABLED=OFF
> URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/Users/lop/Library/Application Support/proj
> DATABASE_PATH=/opt/homebrew/Cellar/proj/9.8.1/share/proj/proj.db"
> (compiled against PROJ 9.8.1) LIBXML="2.9.13" LIBJSON="0.18"
> LIBPROTOBUF="1.5.2" WAGYU="0.5.0 (Internal)" TOPOLOGY
New description:
 In the attached dump we have this case
         7 |    59 |        31 |      2 |
 this error
 SELECT
 58.935012010161067
  st_isvalid
  f
 (1 row)
 DO $$
 DECLARE
                 r RECORD;
 BEGIN
                 FOR r IN
 e.edge_id)
                                                         e.geom,
                                                         vs.vert_geom
                                 FROM
 'grunnkart_037',
        1e-15
                                                 ) AS vs
                 LOOP
                                 BEGIN
                                                 PERFORM
 r.vert_geom), -1 );
                                 EXCEPTION
                                                 WHEN OTHERS THEN
        RAISE
 SQLERRM;
                                 END;
                 END LOOP;
 END;
 SELECT
  st_isvalid
  t
 (1 row)
 tested on
Comment:
 Any new function will have to wait for 3.8.0
 May I recommend to NOT use WKT in your excercise ? The loss of precision
 you get is the reason why your simple feature constructed from face
 geometry becomes invalid. Verify by just calling
 `ST_IsValid(topology.ST_GetFaceGeometry(...))`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6095#comment:2>
