[SCM] PostGIS branch master updated. 3.7.0alpha1-265-g321c33cc4
Fri Jul 10 03:39:22 PDT 2026
the project "PostGIS".
       via  321c33cc45c83e5c8faf032fb59b61df4fa1fc63 (commit)
      from  9e003e1c1ad6d0b5747a0c9766c99beb9a7e0bb4 (commit)
revisions in full, below.
commit 321c33cc45c83e5c8faf032fb59b61df4fa1fc63
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Fri Jul 10 09:32:43 2026 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 95.0% (5748 of 6049 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 0ca9deaf2..f27f0c2b7 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2026-07-05 04:20+0000\n"
-"PO-Revision-Date: 2026-07-10 06:08+0000\n"
+"PO-Revision-Date: 2026-07-10 10:39+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
 "manual/ja/>\n"
@@ -22982,6 +22982,12 @@ msgid ""
 "necessary geometry can be projected into WGS84 using <xref "
 "linkend=\"ST_Transform\"/>: <code>ST_Transform(geom, 4326 )</code>."
 msgstr ""
+"GeoJSON仕様では右手系を使っていて、このポリゴンの向きが前提のクライアントもあ"
+"ります。これは<xref linkend=\"ST_ForcePolygonCCW\"/>を使うことでこの向きを確"
+"実にできます。またGeoJSON仕様ではジオメトリーはWGS84座標系 (SRID=4326)である"
+"必要があります。必要なら<xref linkend=\"ST_Transform\"/>を使うことで"
+"ジオメトリーをWGS84に座標変換できます。<code>ST_Transform(geom, 4326 )</code>"
+"といったように使います。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 8 +++++++-
 1 file changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
