[PostGIS] #6097: false positive values from topology.findvertexsegmentpairsbelowdistance ?
trac at osgeo.org
Sat Jul 11 02:46:06 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: topology | Version:
Keywords: |
I have simple topology with 4 nodes and and edges that return 4 rows when
running attached test_findvertexsegmentpairsbelowdistance tha I do not
under stand why.
this is tested on (source code seems be like in master)
POSTGIS="3.7.0dev 3.6.0rc2-473-g260127869" [EXTENSION] PGSQL="160"
GEOS="3.14.1-CAPI-1.20.5" PROJ="9.8.1 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/Users/lop/Library/Application Support/proj
DATABASE_PATH=/opt/homebrew/Cellar/proj/9.8.1/share/proj/proj.db"
(compiled against PROJ 9.8.1) LIBXML="2.9.13" LIBJSON="0.18"
LIBPROTOBUF="1.5.2" WAGYU="0.5.0 (Internal)" TOPOLOGY
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6097>
