[PostGIS] #6099: winnie failing on create_upgrade_replaced_function_errors_check
trac at osgeo.org
Sat Jul 11 19:06:37 PDT 2026
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.7.0
Component: QA/buildbots | Version: master
Keywords: |
I'm not sure when this started. Definitely sometime after July 7th.
make[2]: Leaving directory '/projects/postgis/branches/3.7/loader/cunit'
make[1]: Leaving directory '/projects/postgis/branches/3.7/loader'
---- Making check-unit in utils
make: TMPDIR value
/projects/postgis/tmp/3.7.0dev_pg19_geos3.15_gdal3.13.1w64: No such file
or directory
make: using default temporary directory '/tmp'
make[1]: Entering directory '/projects/postgis/branches/3.7/utils'
comm -12 postgis_restore_data.hardcoded postgis_restore_data.generated >
postgis_restore_data.needlessly-hardcoded
srcdir=. PERL=/usr/bin/perl /bin/sh
./check_create_upgrade_replaced_function_errors.sh
mktemp: failed to create directory via template
‘/projects/postgis/tmp/3.7.0dev_pg19_geos3.15_gdal3.13.1w64/check_create_upgrade_replaced_function_errors.XXXXXX’:
No such file or directory
make[1]: *** [Makefile:127: create_upgrade_replaced_function_errors_check]
Error 1
make[1]: Leaving directory '/projects/postgis/branches/3.7/utils'
make: *** [GNUmakefile:36: check-unit] Error 1
Assuming this most be some sort of windows / linux different in processing
in that it's looking for the wrong path
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6099>
