[PostGIS] #6102: berrie, berrie64, bessie all showing FAIL: contributor validation requires a full, non-shallow Git history
PostGIS trac at osgeo.org
Fri Jul 17 13:09:57 PDT 2026
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.7.0
 Component:  build    |    Version:  3.6.x
Resolution:           |   Keywords:
Old description:
> PASS: NEWS file release headings are unique
> 14:28:08 PASS: NEWS file entries are in good order
> 14:28:09 ...................
> 14:28:10
> 14:28:10 Ran 19 tests in 0.972s
> 14:28:10
> 14:28:10 OK
> 14:28:10 FAIL: contributor validation requires a full, non-shallow Git
> history
> 14:28:10 make: *** [GNUmakefile:102: check-contributor-credits] Error 2
> 14:28:10 Build step 'Execute shell' marked build as failure
> 14:28:16 [Gitea] do not publish assets due to build being non-
> Successfully
> 14:28:16 Finished: FAILURE
New description:
 14:28:10
 14:28:10
 14:28:10 OK
 history
 14:28:16 [Gitea] do not publish assets due to build being non-Successfully
Comment (by robe):
 Guess it's caused by this commit -
 https://gitea.osgeo.org/postgis/postgis/commit/4c311beade3ce06f61ce44c004edb333e8921c20
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6102#comment:1>
