[PostGIS] #6103: debbie can't build docs
trac at osgeo.org
Fri Jul 17 13:27:20 PDT 2026
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.7.0
Component: QA/buildbots | Version: master
Keywords: |
/bin/xmllint --noout --nonet \
14:21:21 --valid --loaddtd \
14:21:21 --relaxng http://docbook.org/xml/5.0/rng/docbook.rng \
14:21:21 postgis-out.xml
14:21:21 postgis-out.xml:80: element subscript: validity error : Element
emphasis is not declared in subscript list of possible children
14:21:21 (<emphasis>Thu Jul 16 06:17:06 PM UTC 2026 rev. 4c311be
</emphasis>)</subscript>
14:21:21
14:21:21 postgis-out.xml:80: element title: Relax-NG validity error : Did
not expect element title there
Element book has extra content: title
14:21:21 postgis-out.xml fails to validate
14:21:21 make[2]: *** [../../Makefile:656: check-xml] Error 3
14:21:21 make[2]: Leaving directory
'/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/4c311beade3ce06f61ce44c004edb333e8921c20/doc/po/it_IT'
14:21:21 make[1]: *** [../Makefile.local:18: local-check] Error 2
14:21:21 make[1]: Leaving directory
14:21:21 make: *** [Makefile:430: check-localized] Error 1
14:21:21 Build step 'Execute shell' marked build as failure
14:21:21 [Gitea] do not publish assets due to build being non-Successfully
14:21:21 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6103>
