[PostGIS] #6102: berrie, berrie64, bessie all showing FAIL: contributor validation requires a full, non-shallow Git history
trac at osgeo.org
Fri Jul 17 13:37:05 PDT 2026
Reporter: robe | Owner: komzpa
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.7.0
Component: QA/buildbots | Version: 3.6.x
Resolution: | Keywords:
Changes (by robe):
* owner: robe => komzpa
Comment:
to fix this I changed in the jenkins config:
https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run
-git fetch --no-tags --depth=10 origin $reference
+git fetch --no-tags origin $reference
But still failing on bessie (FreeBSD) with
6:22:01 grep -v lwin_wkt_lex.c | \
16:22:01 grep -v lwin_wkt_parse | \
16:22:01 grep -v lookup3 | \
16:22:01 grep -v vector_tile.pb-c | \
16:22:01 grep -v postgis/sqldefines.h | \
16:22:01 grep -v deps/ | \
16:22:01 xargs grep -n '[[:space:]]$'
16:22:01 ./utils/check_news.sh .
16:22:01 PASS: NEWS file release headings are unique
16:22:02 PASS: NEWS file entries are in good order
16:22:02 /bin/sh: python3: not found
16:22:02 gmake[1]: *** [GNUmakefile:102: check-contributor-credits] Error
127
16:22:02 gmake[1]: Leaving directory
'/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/4c311beade3ce06f61ce44c004edb333e8921c20'
16:22:02 *** Error code 2
We really need to control when these tests are run and I'm not happy with
an introduction of python dependency in our tooling especially if it's
assumed
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6102#comment:4>
