[SCM] PostGIS branch master updated. 3.7.0alpha1-284-gb0acf7c2b
git at osgeo.org
git at osgeo.org
Fri Jul 17 15:13:16 PDT 2026
the project "PostGIS".
via b0acf7c2bb3aa74a1f49e886ef7c482302fd3d14 (commit)
from 4c311beade3ce06f61ce44c004edb333e8921c20 (commit)
revisions in full, below.
commit b0acf7c2bb3aa74a1f49e886ef7c482302fd3d14
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Fri Jul 17 15:13:15 2026 -0700
ci: make contributor credit audit explicit (!365)
## Summary
- keep `make check` / `check-lint` from running the contributor-credit validator, so ordinary builds and packaging checks do not require Python or full Git history
- add a dedicated GitHub Actions workflow that checks contributor credits with `actions/checkout` full history
- add a dedicated Woodpecker/Gitea pipeline that checks contributor credits with full-history clone settings
- restore default/shallow checkout behavior for the regular GitHub and Woodpecker build/regress/tool lanes
Follow-up to https://gitea.osgeo.org/postgis/postgis/pulls/363.
## Validation
- `python3 -B utils/test_check_contributor_credits.py`
- `python3 -B utils/check_contributor_credits.py --repo .`
- `make check-contributor-credits`
- `make -n check-lint`
- `make check-lint`
- `make -C doc check-localized`
- `git diff --check`
Co-authored-by: Darafei Praliaskouski <me at komzpa.net>
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/365
diff --git a/.github/workflows/ci-freebsd.yml b/.github/workflows/ci-freebsd.yml
index 7b8210191..601aebfc7 100644
--- a/.github/workflows/ci-freebsd.yml
+++ b/.github/workflows/ci-freebsd.yml
@@ -23,7 +23,6 @@ jobs:
steps:
- uses: actions/checkout at 11bd71901bbe5b1630ceea73d27597364c9af683 # v4.2.2
with:
- fetch-depth: 0
persist-credentials: false
- name: Cache ccache
diff --git a/.github/workflows/ci-macos.yml b/.github/workflows/ci-macos.yml
index f3c42c3ad..67c0cc1d4 100644
--- a/.github/workflows/ci-macos.yml
+++ b/.github/workflows/ci-macos.yml
@@ -20,7 +20,6 @@ jobs:
steps:
with:
- fetch-depth: 0
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 86c9f09ba..3877c2d91 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -47,8 +47,6 @@ jobs:
- name: 'Check Out'
uses: actions/checkout at v6
- with:
- fetch-depth: 0
- name: 'Prepare Image'
run: |
diff --git a/.github/workflows/contributor-credits.yml b/.github/workflows/contributor-credits.yml
new file mode 100644
index 000000000..eaeb5fb92
--- /dev/null
+++ b/.github/workflows/contributor-credits.yml
@@ -0,0 +1,24 @@
+name: Contributor Credits
+on:
+ push:
+ branches-ignore:
+ - 'main'
+ pull_request: ~
+permissions:
+ contents: read
+jobs:
+ contributor-credits:
+ runs-on: ubuntu-latest
+ steps:
+ - name: Check Out
+ uses: actions/checkout at v6
+ with:
+ fetch-depth: 0
+ persist-credentials: false
+ - name: Check Contributor Credits
+ run: make check-contributor-credits
diff --git a/.github/workflows/msys.yml b/.github/workflows/msys.yml
index 791640b2b..dff6ee645 100644
--- a/.github/workflows/msys.yml
+++ b/.github/workflows/msys.yml
@@ -23,8 +23,6 @@ jobs:
# see https://github.com/msys2/setup-msys2
- name: checkout
- with:
- fetch-depth: 0
- name: '${{ matrix.icon }} Setup MSYS2'
uses: msys2/setup-msys2 at v2
with:
diff --git a/.woodpecker/tools.yml b/.woodpecker/contributor-credits.yml
similarity index 84%
copy from .woodpecker/tools.yml
copy to .woodpecker/contributor-credits.yml
index 5ac110f84..486fe394f 100644
--- a/.woodpecker/tools.yml
+++ b/.woodpecker/contributor-credits.yml
@@ -11,8 +11,8 @@ clone:
partial: false
steps:
- build:
+ check:
image: repo.osgeo.org/postgis/build-test:debian13
pull: true
commands:
- - sh ci/dronie/postgis_tools.sh
+ - make check-contributor-credits
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 9f761bd0d..2cdaa2cc4 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -49,10 +49,10 @@ variables:
- egrep '(PASS|FAIL|SKIP|INFO|ERROR)' check.log
clone:
- - name: git
+ git:
image: woodpeckerci/plugin-git
settings:
- depth: 0
+ depth: 50
partial: false
steps:
diff --git a/.woodpecker/tools.yml b/.woodpecker/tools.yml
index 5ac110f84..90e989e43 100644
+++ b/.woodpecker/tools.yml
@@ -2,14 +2,6 @@ labels:
platform: linux/amd64
when:
event: [push, pull_request, tag]
-clone:
- - name: git
- image: woodpeckerci/plugin-git
- settings:
- depth: 0
- partial: false
steps:
build:
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 08f394362..5fad32b63 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -89,8 +89,7 @@ endif
# The "lint" tests do not depend on specific code configurations
# but solely on the source code state
-check-lint: check-no-trailing-blanks check-news check-contributor-credits \
- check-tests-enabled check-lang-enabled
+check-lint: check-no-trailing-blanks check-news check-tests-enabled check-lang-enabled
staged-install: all
$(MAKE) -C regress staged-install
@@ -98,6 +97,7 @@ staged-install: all
check-news:
$(top_srcdir)/utils/check_news.sh $(top_srcdir)
+.PHONY: check-contributor-credits
check-contributor-credits:
@if test ! -e "$(top_srcdir)/.git"; then \
echo "SKIP: contributor credits require a Git worktree"; \
diff --git a/Makefile b/Makefile
index db75fbe81..3db550077 100644
--- a/Makefile
+++ b/Makefile
@@ -25,3 +25,14 @@ all install uninstall staged-install clean distclean maintainer-clean test check
echo "You must use GNU make to build PostGIS." ; \
false; \
fi
+# This target must also work before configure, so dedicated CI can audit
+# contributor credits from a clean checkout with full Git history.
+check-contributor-credits:
+ @if test ! -e ".git"; then \
+ echo "SKIP: contributor credits require a Git worktree"; \
+ else \
+ python3 -B utils/test_check_contributor_credits.py && \
+ python3 -B utils/check_contributor_credits.py --repo .; \
+ fi
diff --git a/doc/development/testing.md b/doc/development/testing.md
index 08b246e1b..5732963d7 100644
--- a/doc/development/testing.md
+++ b/doc/development/testing.md
@@ -120,11 +120,13 @@ Other useful targets:
extension upgrade paths after `sudo make install`.
* `make installcheck` runs tests against an installed copy after
-* `make check` includes the contributor-credit validator in its source-state
- checks. It checks that every non-merge Git author, `Co-authored-by` trailer,
- and contributor named in an unreleased `NEWS` section is present in
- `doc/credits.xml`; `make check-contributor-credits` runs only this check.
- A Git worktree must have full, non-shallow history; release trees without
+* `make check-contributor-credits` runs an optional maintainer audit that checks
+ that every non-merge Git author, `Co-authored-by` trailer, and contributor
+ named in an unreleased `NEWS` section is present in `doc/credits.xml`. It is
+ not part of `make check` because it needs Python and a Git worktree with
+ full, non-shallow history. GitHub Actions and Woodpecker each run a dedicated
+ contributor-credit job with full history, keeping the audit in CI without
+ making ordinary build or packaging checks depend on it. Release trees without
`.git` skip the check. Add aliases to `.mailmap` instead of duplicating a
person under multiple names in the manual. If only a public handle can be
verified, use a linked `@handle (GitHub user)` credit. If only a partial name
diff --git a/doc/development/testing/ci.md b/doc/development/testing/ci.md
index 6f9f2f3f9..cb63c494c 100644
--- a/doc/development/testing/ci.md
+++ b/doc/development/testing/ci.md
@@ -27,7 +27,7 @@ service that owns the behavior:
| FreeBSD GitHub Actions job | `.github/workflows/ci-freebsd.yml`; see [FreeBSD development environment](../environment/freebsd.md) |
| macOS GitHub Actions job | `.github/workflows/ci-macos.yml`; see [macOS development environment](../environment/macos.md) |
| MSYS2/MinGW GitHub Actions job | `.github/workflows/msys.yml` |
-| GitHub CodeQL and codespell jobs | `.github/workflows/codeql.yml` and `.github/workflows/codespell.yml` |
+| GitHub CodeQL, codespell, and contributor-credit jobs | `.github/workflows/codeql.yml`, `.github/workflows/codespell.yml`, and `.github/workflows/contributor-credits.yml` |
| Debbie build, docs, and release jobs | `ci/debbie/`, the Debbie Jenkins jobs, and release-process notes |
| Winnie Windows jobs | `ci/winnie/` and the Winnie Jenkins jobs |
| Bessie/Bessie32 and Berrie/Berrie64 jobs | `ci/bessie*`, `ci/berrie*`, and the corresponding Jenkins worker labels |
diff --git a/utils/ci-status.json b/utils/ci-status.json
index 3ea413794..284fe2d8f 100644
--- a/utils/ci-status.json
+++ b/utils/ci-status.json
@@ -84,6 +84,16 @@
"master"
+ "name": "GitHub Actions / Contributor Credits",
+ "provider": "github_actions",
+ "required": true,
+ "workflow": "contributor-credits.yml",
+ "url": "https://github.com/postgis/postgis/actions/workflows/contributor-credits.yml",
+ "branches": [
+ "master"
"name": "GitHub Actions / CodeQL",
Summary of changes:
.github/workflows/ci-freebsd.yml | 1 -
.github/workflows/ci-macos.yml | 1 -
.github/workflows/ci.yml | 2 --
.github/workflows/contributor-credits.yml | 24 ++++++++++++++++++++++
.github/workflows/msys.yml | 2 --
.woodpecker/{tools.yml => contributor-credits.yml} | 4 ++--
.woodpecker/regress.yml | 4 ++--
.woodpecker/tools.yml | 8 --------
GNUmakefile.in | 4 ++--
Makefile | 11 ++++++++++
doc/development/testing.md | 12 ++++++-----
doc/development/testing/ci.md | 2 +-
utils/ci-status.json | 10 +++++++++
13 files changed, 59 insertions(+), 26 deletions(-)
create mode 100644 .github/workflows/contributor-credits.yml
copy .woodpecker/{tools.yml => contributor-credits.yml} (84%)
hooks/post-receive
