[SCM] PostGIS branch master updated. 3.7.0alpha1-618-g0febd5b33
git at osgeo.org
git at osgeo.org
Sat Jul 18 14:16:49 PDT 2026
the project "PostGIS".
via 0febd5b33e6b25d1800d9164b07e02e582443a6e (commit)
via 1fc0484ad3fd7d4c1b1088933451d497eb1e8295 (commit)
via 23a1f5deddb5947c830ec6cc54d4e44dc19ebbdc (commit)
from dd49506ad52fda156b7dee8caacabbfc414f577c (commit)
revisions in full, below.
commit 0febd5b33e6b25d1800d9164b07e02e582443a6e
Merge: dd49506ad 1fc0484ad
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Jul 18 14:16:48 2026 -0700
Merge pull request 'ci: isolate Bessie PostgreSQL and retire Bessie32' (!370) from Komzpa/postgis:fix/bessie-private-postgres into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/370
commit 1fc0484ad3fd7d4c1b1088933451d497eb1e8295
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jul 19 00:36:58 2026 +0400
ci: retire the stale Bessie32 worker
diff --git a/ci/bessie32/postgis_regress.sh b/ci/bessie32/postgis_regress.sh
deleted file mode 100644
index eba97ac78..000000000
--- a/ci/bessie32/postgis_regress.sh
+++ /dev/null
@@ -1,30 +0,0 @@
-#!/usr/bin/env bash
-set -e
-#export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
-export CC=gcc11
-export CXX=g++11
-export CXXFLAGS="-O2 -pipe -fstack-protector-strong -Wl,-rpath=/usr/local/lib/gcc11 -nostdinc++ -isystem /usr/include/c++/v1 -Wl,-rpath=/usr/local/lib/gcc11"
-export CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc"
-export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
-sh autogen.sh
-./configure \
- PKG_CONFIG=/usr/local/bin/pkgconf \
- LDFLAGS="-L/usr/local/lib" \
- --with-libiconv-prefix=/usr/local \
- --without-gui \
- --with-topology \
- --with-raster \
- --with-sfcgal=/usr/local/bin/sfcgal-config \
- --with-protobuf \
- --with-wagyu
-#make distclean
-make
-export PGUSER=postgres
-export PGIS_REG_TMPDIR=~/tmp/pgis_reg_${BRANCH}
-psql -c "DROP DATABASE IF EXISTS postgis_reg;"
-make check RUNTESTFLAGS="-v"
-sudo make install
-make check RUNTESTFLAGS="-v --extension"
diff --git a/doc/development/testing/ci.md b/doc/development/testing/ci.md
index cb63c494c..6cfeb9082 100644
--- a/doc/development/testing/ci.md
+++ b/doc/development/testing/ci.md
@@ -30,7 +30,7 @@ service that owns the behavior:
| GitHub CodeQL, codespell, and contributor-credit jobs | `.github/workflows/codeql.yml`, `.github/workflows/codespell.yml`, and `.github/workflows/contributor-credits.yml` |
| Debbie build, docs, and release jobs | `ci/debbie/`, the Debbie Jenkins jobs, and release-process notes |
| Winnie Windows jobs | `ci/winnie/` and the Winnie Jenkins jobs |
-| Bessie/Bessie32 and Berrie/Berrie64 jobs | `ci/bessie*`, `ci/berrie*`, and the corresponding Jenkins worker labels |
+| Bessie and Berrie/Berrie64 jobs | `ci/bessie/`, `ci/berrie*`, and the corresponding Jenkins worker labels |
| Docker build images used by GitHub Actions | `postgis/postgis-build-env` image tags referenced from `.github/workflows/ci.yml` |
When a dashboard row describes dependency versions, operating systems, branch
diff --git a/utils/ci-status.json b/utils/ci-status.json
index 284fe2d8f..f4a1dba2c 100644
--- a/utils/ci-status.json
+++ b/utils/ci-status.json
@@ -142,13 +142,6 @@
"job_url": "https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/",
"branch_parameter": "reference"
- "name": "Jenkins / Bessie32",
- "provider": "jenkins",
- "required": true,
- "job_url": "https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32/",
- "branch_parameter": "reference"
"name": "Jenkins / Berrie",
diff --git a/utils/ci-trac-line.sh b/utils/ci-trac-line.sh
index 29a92ac3b..c6208be34 100755
--- a/utils/ci-trac-line.sh
+++ b/utils/ci-trac-line.sh
@@ -28,8 +28,7 @@ generate_row()
|| [[Image(https://winnie.postgis.net/buildStatus/icon?job=PostGIS_${VER}, link=https://winnie.postgis.net/view/PostGIS/job/PostGIS_${VER}/, alt=status, height="20", title='PG 12-17, GDAL 3.7.1, GEOS 3.13 64-bit')]] || \\
|| [[Image(https://github.com/postgis/postgis/actions/workflows/ci.yml/badge.svg?branch=${BRANCH}, link=https://github.com/postgis/postgis/actions?query=branch%3A${BRANCH}, alt=status, height="20")]] || \\
|| [[Image(https://woodie.osgeo.org/api/badges/postgis/postgis/status.svg?branch=${BRANCH}, link=https://woodie.osgeo.org/postgis/postgis/branches/${BRANCH}, alt=status)]] || \\
-|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie&build=last:\${params.reference=refs/heads/${BRANCH}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] || \\
-|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie32&build=last:\${params.reference=refs/heads/${BRANCH}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] || \\
+|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie&build=last:\${params.reference=refs/heads/${BRANCH}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie, alt=status, height="20", title='PG 18.4, GDAL 3.11.5, GEOS 3.14.1')]] || \\
|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:\${params.reference=refs/heads/${BRANCH}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:\${params.reference=refs/heads/${BRANCH}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
|| [[Image(https://github.com/postgis/postgis/actions/workflows/ci-freebsd.yml/badge.svg?branch=${BRANCH}, link=https://github.com/postgis/postgis/actions/workflows/ci-freebsd.yml?query=branch%3A${BRANCH}, alt=status, height="20", title='FreeBSD')]] || \\
commit 23a1f5deddb5947c830ec6cc54d4e44dc19ebbdc
ci: isolate the Bessie PostgreSQL cluster
diff --git a/ci/bessie/postgis_regress.sh b/ci/bessie/postgis_regress.sh
index bec7bb73b..90b79fb7c 100644
--- a/ci/bessie/postgis_regress.sh
+++ b/ci/bessie/postgis_regress.sh
@@ -4,6 +4,31 @@ set -e
#BRANCH is passed in via jenkins which is set via webhook hook
+PGIS_TMP_ROOT=$(mktemp -d "${TMPDIR:-/tmp}/postgis-bessie.XXXXXX")
+export PGDATA="${PGIS_TMP_ROOT}/data"
+export PGHOST="${PGIS_TMP_ROOT}"
+export PGUSER=postgres
+export PGIS_REG_TMPDIR="${PGIS_TMP_ROOT}/regress"
+PGLOG="${PGIS_TMP_ROOT}/postgresql.log"
+cleanup() {
+ status=$?
+ trap - EXIT
+ if test -s "${PGDATA}/postmaster.pid"; then
+ pg_ctl -D "${PGDATA}" -m immediate stop >/dev/null 2>&1 || true
+ fi
+ if test "${status}" -ne 0 && test -s "${PGLOG}"; then
+ echo "PostgreSQL log follows:" >&2
+ tail -n 100 "${PGLOG}" >&2
+ fi
+ rm -rf -- "${PGIS_TMP_ROOT}"
+ exit "${status}"
+trap cleanup EXIT
+trap 'exit 1' HUP INT TERM
sh autogen.sh
./configure \
--with-projdir=/usr/local \
@@ -11,9 +36,17 @@ sh autogen.sh
--with-library-minor-version
#make distclean
make
+initdb -N --no-data-checksums -U "${PGUSER}" -D "${PGDATA}"
+printf '%s\n' \
+ 'fsync = off' \
+ 'full_page_writes = off' \
+ 'synchronous_commit = off' \
+ >> "${PGDATA}/postgresql.conf"
+pg_ctl -D "${PGDATA}" -l "${PGLOG}" \
+ -o "-F -c listen_addresses='' -c unix_socket_directories='${PGHOST}'" start
+mkdir -p "${PGIS_REG_TMPDIR}"
sudo make install
Summary of changes:
ci/bessie/postgis_regress.sh | 39 ++++++++++++++++++++++++++++++++++++---
ci/bessie32/postgis_regress.sh | 30 ------------------------------
doc/development/testing/ci.md | 2 +-
utils/ci-status.json | 7 -------
utils/ci-trac-line.sh | 3 +--
5 files changed, 38 insertions(+), 43 deletions(-)
delete mode 100644 ci/bessie32/postgis_regress.sh
hooks/post-receive
