[SCM] PostGIS branch master updated. 3.7.0alpha1-627-gc86243a20
Sun Jul 19 04:11:55 PDT 2026
the project "PostGIS".
       via  c86243a205a0e5bb04442dc404c6acb86e8b8ee6 (commit)
       via  9857bb67211f7611371e21598c9387e804eaa82b (commit)
       via  556f8ac393e71694c1898df8e483a1713e96fa4f (commit)
       via  acab13994fea79079af8e139785647b5d6230cd2 (commit)
       via  2101ee4ba20810a59bb9f2bed774e9f0ad6ddff0 (commit)
      from  1af231a14f0f5c4e9352e2e5788ac12cf577c8c3 (commit)
revisions in full, below.
commit c86243a205a0e5bb04442dc404c6acb86e8b8ee6
Merge: 1af231a14 9857bb672
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Jul 19 04:11:50 2026 -0700
    Merge pull request 'doc: render localized HTML in parallel' (!401) from Komzpa/postgis:fix/docs-parallel-localized-html into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/401
commit 9857bb67211f7611371e21598c9387e804eaa82b
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Jul 19 07:11:40 2026 +0400
    ci: use available CPUs for localized HTML
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index cf3f3628f..414d5f316 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -15,6 +15,14 @@ export PGPATH=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
 export PATH="${PGPATH}/bin:$PATH"
 export LD_LIBRARY_PATH="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/lib:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/lib:${PGPATH}/lib"
+LOCALIZED_HTML_JOBS=${LOCALIZED_HTML_JOBS:-$(nproc)}
+case "${LOCALIZED_HTML_JOBS}" in
+  ''|*[!0-9]*|0)
+    echo "LOCALIZED_HTML_JOBS must be a positive integer" >&2
+    exit 1
+esac
 release_docs_tmpdir=
 release_docs_pgdata=
@@ -128,7 +136,7 @@ fi
 make cheatsheets
 make -e chunked-html # TODO: do we really want this too in the doc-html-*.tar.gz package ?
-make -j2 html-localized # TODO: do we really want this too in the doc-html-*.tar.gz package ?
+make -j"${LOCALIZED_HTML_JOBS}" html-localized # TODO: do we really want this too in the doc-html-*.tar.gz package ?
 package="doc-html-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.tar.gz"
 tar -czf "$package" --exclude='static' --exclude='wkt' --exclude '*.o' html
@@ -139,7 +147,7 @@ make html-assets-install
 make html-install
 make html-install-localized
 make chunked-html-install
-make -j2 chunked-html-install-localized
+make -j"${LOCALIZED_HTML_JOBS}" chunked-html-install-localized
 make cheatsheet-install
 make cheatsheet-install-localized
commit 556f8ac393e71694c1898df8e483a1713e96fa4f
Date:   Sun Jul 19 04:18:43 2026 +0400
    doc: parallelize localized chunked HTML installs
index 884a46969..cf3f3628f 100644
@@ -139,7 +139,7 @@ make html-assets-install
 make html-install
-make chunked-html-install-localized
+make -j2 chunked-html-install-localized
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 2155c64e7..4c257a886 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -500,12 +500,16 @@ review-html: html ## Compare this manual with REVIEW_HTML_BASE using synchronize
 # directory.  Build and validate those files once before recursive render
 # targets can run in parallel.
 localized_html_targets = $(addprefix html-localized-,$(translations))
+localized_chunked_install_targets = $(addprefix chunked-html-install-localized-,$(translations))
-.PHONY: html-localized localized-html-ready
+.PHONY: html-localized chunked-html-install-localized localized-html-ready
 html-localized: $(localized_html_targets) ## Generate a single-file html/postgis-<lang>.html for supported languages
+chunked-html-install-localized: $(localized_chunked_install_targets) ## Install multi-file html for supported languages
 # Localized builds share the English reference index installed alongside all
 # manuals.  Build it once before fan-out; recursive localized makes only read
 # it and never race to replace it with a translated index.
@@ -516,6 +520,10 @@ html-localized-%: | localized-html-ready
 	@echo "Making html for language $*..."
 	$(MAKE) -C po/$* local-html
+chunked-html-install-localized-%: | $(HTML_REF_INDEX)
+	@echo "Making chunked-html-install for language $*..."
+	$(MAKE) -C po/$* local-chunked-html-install
 %-localized:
 	rule=$(patsubst %-localized,%,$@); \
 	for lang in $(translations); do \
commit acab13994fea79079af8e139785647b5d6230cd2
Date:   Sun Jul 19 04:06:20 2026 +0400
    doc: keep the shared reference index English
index 1dcdb1c7b..2155c64e7 100644
@@ -141,6 +141,11 @@ POSTGIS_BLOCK_LABELS_COMMON_XSL=$(abs_srcdir)/xsl/postgis-block-labels-common.xs
 HTML_REF_INDEX_JSON=$(html_builddir)/postgis-ref-index.json
 HTML_REF_INDEX_JS=$(html_builddir)/postgis-ref-index.js
 HTML_REF_INDEX=$(HTML_REF_INDEX_JSON) $(HTML_REF_INDEX_JS)
+ifeq ($(DOCSUFFIX),-en)
+HTML_REF_INDEX_DEPS=$(HTML_REF_INDEX)
+else
+endif
 # DBLatex's dblatex script for PDF generation from DocBook
 DBLATEX=@DBLATEX@
@@ -460,7 +465,7 @@ $(HTML_REF_INDEX_JS): $(HTML_REF_INDEX_JSON)
 		$(MAKE) $(HTML_REF_INDEX_JSON); \
 	fi
-$(html_builddir)/postgis$(DOCSUFFIX)/index.html: postgis-out.xml Makefile $(CHUNK_HTML_DOCBOOK_XSL) $(HTML_REF_INDEX) $(HTML_RUNTIME_ASSETS) | visual-examples
+$(html_builddir)/postgis$(DOCSUFFIX)/index.html: postgis-out.xml Makefile $(CHUNK_HTML_DOCBOOK_XSL) $(HTML_REF_INDEX_DEPS) $(HTML_RUNTIME_ASSETS) | visual-examples
 	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
 		$(XSLTPROC_CHUNKED_HTML_OPTS) \
 		--stringparam postgis.visual.manifest "$(visual_examples_manifest)" \
@@ -496,18 +501,18 @@ review-html: html ## Compare this manual with REVIEW_HTML_BASE using synchronize
-.PHONY: html-localized refresh-html-ref-index
+.PHONY: html-localized localized-html-ready
-# Localized builds share one installed reference index.  Keep its English
-# contents newer than the translated XML files so recursive builds only read
-# it while rendering in parallel.
-refresh-html-ref-index: check-localized $(HTML_REF_INDEX)
-	touch $(HTML_REF_INDEX)
+# Localized builds share the English reference index installed alongside all
+# manuals.  Build it once before fan-out; recursive localized makes only read
+# it and never race to replace it with a translated index.
+localized-html-ready: check-localized $(HTML_REF_INDEX)
-html-localized-%: | refresh-html-ref-index
+html-localized-%: | localized-html-ready
@@ -518,7 +523,7 @@ html-localized-%: | refresh-html-ref-index
     $(MAKE) -C po/$$lang local-$$rule || exit 1; \
   done
-$(html_builddir)/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile $(HTML_DOCBOOK_XSL) $(HTML_REF_INDEX) $(HTML_RUNTIME_ASSETS) | visual-examples
+$(html_builddir)/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile $(HTML_DOCBOOK_XSL) $(HTML_REF_INDEX_DEPS) $(HTML_RUNTIME_ASSETS) | visual-examples
 		--stringparam html.stylesheet style.css?v=$(HTML_ASSET_VERSION) \
 		--stringparam html.script "postgis-ref-index.js?v=$(HTML_ASSET_VERSION) example-blocks.js?v=$(HTML_ASSET_VERSION)" \
commit 2101ee4ba20810a59bb9f2bed774e9f0ad6ddff0
Date:   Sun Jul 19 02:57:42 2026 +0400
index 7887b1cb7..884a46969 100644
@@ -128,7 +128,7 @@ fi
 make cheatsheets
-make html-localized # TODO: do we really want this too in the doc-html-*.tar.gz package ?
+make -j2 html-localized # TODO: do we really want this too in the doc-html-*.tar.gz package ?
index 86fad47ac..1dcdb1c7b 100644
@@ -494,7 +494,22 @@ review-html: html ## Compare this manual with REVIEW_HTML_BASE using synchronize
 # Localized render targets share translated XML files in each language
-html-localized: check-localized ## Generate a single-file html/postgis-<lang>.html for supported languages
+localized_html_targets = $(addprefix html-localized-,$(translations))
+.PHONY: html-localized refresh-html-ref-index
+html-localized: $(localized_html_targets) ## Generate a single-file html/postgis-<lang>.html for supported languages
+# Localized builds share one installed reference index.  Keep its English
+# contents newer than the translated XML files so recursive builds only read
+# it while rendering in parallel.
+refresh-html-ref-index: check-localized $(HTML_REF_INDEX)
+	touch $(HTML_REF_INDEX)
+html-localized-%: | refresh-html-ref-index
+	@echo "Making html for language $*..."
+	$(MAKE) -C po/$* local-html
 %-localized:
Summary of changes:
 ci/debbie/postgis_release_docs.sh | 12 ++++++++++--
 doc/Makefile.in                   | 34 +++++++++++++++++++++++++++++++---
 2 files changed, 41 insertions(+), 5 deletions(-)
hooks/post-receive
