[SCM] PostGIS branch master updated. 3.7.0alpha1-632-ga136c7cae
git at osgeo.org
git at osgeo.org
Sun Jul 19 04:26:48 PDT 2026
the project "PostGIS".
via a136c7caec18b589295d4477e9207a0fc36eb7fc (commit)
via c9d23c747bc710f051f76693bd4eb28e0fa72d57 (commit)
via fbd5c75bc35275472438f29c5791a41a24cde281 (commit)
from 4fd9124747f5b669c5a764ed32ca82887ebf9467 (commit)
revisions in full, below.
commit a136c7caec18b589295d4477e9207a0fc36eb7fc
Merge: 4fd912474 c9d23c747
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Jul 19 04:26:46 2026 -0700
Merge pull request 'ci: repair release dashboard status sources' (!400) from Komzpa/postgis:ci/retire-gitlab-mirror-status into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/400
commit c9d23c747bc710f051f76693bd4eb28e0fa72d57
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jul 19 03:10:25 2026 +0400
ci: use push pipelines for Woodpecker status
diff --git a/utils/ci-status.py b/utils/ci-status.py
index 4ddef3801..543d60a89 100755
--- a/utils/ci-status.py
+++ b/utils/ci-status.py
@@ -364,15 +364,31 @@ def normalize_woodpecker_status(value):
return mapping.get(str(value).lower(), UNKNOWN)
+def woodpecker_matches_branch(build, check, branch):
+ if build.get("branch") != branch["name"]:
+ return False
+ event = check.get("event", "push")
+ if event and build.get("event") != event:
+ return False
+ expected_ref = render_template(check.get("ref", "refs/heads/${branch}"), branch)
+ return build.get("ref") in (None, expected_ref)
def woodpecker_check(check, branch, timeout):
- query = urllib.parse.urlencode({"branch": branch["name"], "limit": "20"})
+ query = urllib.parse.urlencode({
+ "branch": branch["name"],
+ "event": check.get("event", "push"),
+ "limit": "20",
api_url = check["api_url"]
separator = "&" if "?" in api_url else "?"
url = f"{api_url}{separator}{query}"
builds = http_json(url, timeout=timeout)
if isinstance(builds, dict):
builds = builds.get("builds") or builds.get("pipelines") or builds.get("data") or []
- builds = [build for build in builds if build.get("branch") == branch["name"]]
+ builds = [build for build in builds if woodpecker_matches_branch(build, check, branch)]
if not builds:
return make_result(check, branch, UNKNOWN, message="no Woodpecker builds found", debug_url=url)
commit fbd5c75bc35275472438f29c5791a41a24cde281
Date: Sun Jul 19 02:56:51 2026 +0400
ci: retire GitLab mirror status checks
diff --git a/utils/ci-status.json b/utils/ci-status.json
index f4a1dba2c..7d2306ab8 100644
--- a/utils/ci-status.json
+++ b/utils/ci-status.json
@@ -165,36 +165,17 @@
"name": "GitLab mirror",
- "provider": "gitlab",
- "required": true,
- "api_url": "https://gitlab.com/api/v4",
- "project": "postgis/postgis",
- "web_url": "https://gitlab.com/postgis/postgis/-/commits/${branch}",
- "branches": [
- "master",
- "stable-3.6",
- "stable-3.5",
- "stable-3.4",
- "stable-3.3",
- "stable-3.2"
+ "provider": "disabled",
+ "required": false,
+ "status": "retired",
+ "message": "The GitLab.com mirror is out of CI minutes, so release gating uses GitHub Actions, Woodie, and Jenkins."
"name": "INAF GitLab mirror",
- "required": true,
- "api_url": "https://www.ict.inaf.it/gitlab/api/v4",
- "web_url": "https://www.ict.inaf.it/gitlab/postgis/postgis/-/commits/${branch}",
- "branches": [
- "master",
- "stable-3.6",
- "stable-3.5",
- "stable-3.4",
- "stable-3.3",
- "stable-3.2"
- "message": "The legacy Trac badges use release labels, but the INAF GitLab API exposes pipelines under stable-X.Y refs."
+ "message": "The INAF GitLab mirror is stale and no longer provides a current release-gating signal."
Summary of changes:
utils/ci-status.json | 35 ++++++++---------------------------
utils/ci-status.py | 20 ++++++++++++++++++--
2 files changed, 26 insertions(+), 29 deletions(-)
hooks/post-receive
