[SCM] PostGIS branch master updated. 3.7.0alpha1-634-gc93627be0
git at osgeo.org
git at osgeo.org
Sun Jul 19 06:00:09 PDT 2026
the project "PostGIS".
via c93627be0371a55ef910c96b8417c1b88ce66d3c (commit)
via f252696a336bdec65ef01b86e91318d5be6d286c (commit)
from a136c7caec18b589295d4477e9207a0fc36eb7fc (commit)
revisions in full, below.
commit c93627be0371a55ef910c96b8417c1b88ce66d3c
Merge: a136c7cae f252696a3
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Jul 19 06:00:05 2026 -0700
Merge pull request 'utils: compare upgrade versions numerically' (!437) from Komzpa/postgis:ci/semver-numeric-master-20260719T1138Z into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/437
commit f252696a336bdec65ef01b86e91318d5be6d286c
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jul 19 15:40:32 2026 +0400
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 85edc853a..14e9b51f7 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -9,6 +9,7 @@ PGVER_MAJOR=$(echo "${PGVER}" | sed 's/\.[^\.]*//' | sed 's/\(alpha\|beta\|rc\).
SKIP_LABEL_REGEXP=
ONLY_EXTENSION=
ONLY_OLDEST=0
+SELFTEST=0
echo "INFO: PostgreSQL version: ${PGVER} [${PGVER_MAJOR}]"
MAKE=$(which gmake make | head -1)
BUILDDIR=$PWD # TODO: allow override ?
@@ -28,6 +29,7 @@ usage() {
echo "\t--skip <regexp> Do not run tests with label matching given extended regexp"
echo "\t--extension <name> Only run upgrade tests for the named extension"
echo "\t--oldest Only run the oldest compatible upgrade source"
+ echo "\t--self-test Run check_all_upgrades.sh unit tests"
echo "Positional parameters:"
echo "\t<to_version> Target upgrade version. See regress/run_test.pl help on --upgrade-path <to> parameter."
@@ -43,6 +45,8 @@ while test -n "$1"; do
ONLY_EXTENSION=$1
elif test "$1" = "--oldest"; then
ONLY_OLDEST=1
+ elif test "$1" = "--self-test"; then
+ SELFTEST=1
elif test "$1" = "-h" -o "$1" = "--help"; then
usage
exit 0
@@ -55,7 +59,7 @@ while test -n "$1"; do
shift
done
-if test -z "$to_version_param"; then
+if test "${SELFTEST}" != 1 && test -z "$to_version_param"; then
usage >&2
exit 1
fi
@@ -84,6 +88,16 @@ semver_compare()
echo 1; return;
fi
V2=`echo "$V2" | cut -d. -sf2-`
+ v1_numeric=`echo "$v1" | sed 's/[^0-9].*//'`
+ v2_numeric=`echo "$v2" | sed 's/[^0-9].*//'`
+ if test -n "$v1_numeric" && test -n "$v2_numeric"; then
+ if [ "$v1_numeric" -lt "$v2_numeric" ]; then
+ echo -1; return;
+ fi
+ if [ "$v1_numeric" -gt "$v2_numeric" ]; then
+ echo 1; return;
+ fi
+ fi
# echo "v: $v1 - $v2" >&2
if expr "$v1" '<' "$v2" > /dev/null; then
echo -1; return;
@@ -250,6 +264,29 @@ report_missing_versions()
cleanup
+check_all_upgrades_selftest()
+ if test "`semver_compare 3.2.7 3.2.11dev`" != "-1"; then
+ echo "FAIL: expected 3.2.7 to compare older than 3.2.11dev" >&2
+ exit 1
+ fi
+ if test "`semver_compare 3.2.11dev 3.2.7`" != "1"; then
+ echo "FAIL: expected 3.2.11dev to compare newer than 3.2.7" >&2
+ exit 1
+ fi
+ if test "`semver_compare 3.2.11dev 3.2.11dev`" != "0"; then
+ echo "FAIL: expected identical dev versions to compare equal" >&2
+ exit 1
+ fi
+if test "${SELFTEST}" = 1; then
+ check_all_upgrades_selftest
+ exit
+fi
to_version=$to_version_param
if expr $to_version : ':auto' >/dev/null; then
Summary of changes:
utils/check_all_upgrades.sh | 39 ++++++++++++++++++++++++++++++++++++++-
1 file changed, 38 insertions(+), 1 deletion(-)
hooks/post-receive
