[SCM] PostGIS branch master updated. 3.7.0alpha1-640-ge2794c236
git at osgeo.org
git at osgeo.org
Sun Jul 19 08:37:49 PDT 2026
the project "PostGIS".
via e2794c236e2811023c3423f90099ec9f9e59f50b (commit)
via 262efd9656603b12c20a24635504efe89db3a25d (commit)
via 63950b0740870b892fd8b45d79c7af90b2a089ef (commit)
from da401396910c2e24e403eb2c97a2cfac2c6bfbd0 (commit)
revisions in full, below.
commit e2794c236e2811023c3423f90099ec9f9e59f50b
Merge: da4013969 262efd965
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Jul 19 08:37:47 2026 -0700
Merge pull request 'ci: show required failures in status banner' (!442) from Komzpa/postgis:ci/rollup-failure-attribution into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/442
commit 262efd9656603b12c20a24635504efe89db3a25d
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jul 19 18:41:00 2026 +0400
ci: simplify failure attribution banner
diff --git a/utils/ci-status.py b/utils/ci-status.py
index 3ce1d74ae..7c036ba63 100755
--- a/utils/ci-status.py
+++ b/utils/ci-status.py
@@ -1353,10 +1353,7 @@ def html_required_failures(branches):
if not failures:
return ""
- count = sum(len(checks) for _, checks in failures)
- branch_count = len(failures)
- branch_word = "branch" if branch_count == 1 else "branches"
- rows = []
+ groups = []
for branch_label, checks in failures:
check_links = []
for check in checks:
@@ -1365,15 +1362,13 @@ def html_required_failures(branches):
check_links.append(
f"<a href='{html.escape(link)}'>{check_name}</a>" if link else check_name
- rows.append(
- f"<li><strong>{html.escape(branch_label)}</strong> — {', '.join(check_links)}</li>"
+ groups.append(
+ f"<strong>{html.escape(branch_label)}</strong> — {', '.join(check_links)}"
return (
- "<div class='failure-attribution' aria-label='Required CI failures'>"
- f"<div class='failure-attribution-title'>Required failures "
- f"({count} across {branch_count} {branch_word})</div>"
- f"<ul>{''.join(rows)}</ul></div>"
+ " <span aria-label='Required CI failures'>· <strong>Required:</strong> "
+ f"{' · '.join(groups)}</span>"
@@ -1383,11 +1378,6 @@ def render_html(data):
page_summary_text = summary_text({"status": page_status, "checks": [
check for branch in data["branches"] for check in branch["checks"]
- if page_status == FAILURE:
- page_summary_text = (
- "Failing means one or more required checks failed on a supported branch. "
- + page_summary_text
page_summary = html.escape(page_summary_text)
failure_attribution = html_required_failures(data["branches"])
rows = []
@@ -1503,22 +1493,6 @@ h1 {{
color: var(--muted);
font-size: 14px;
-.failure-attribution {{
- border-top: 1px solid #ffc9cf;
- margin-top: 10px;
- padding-top: 10px;
-.failure-attribution-title {{
- color: var(--failure);
- font-weight: 650;
-.failure-attribution ul {{
- margin: 8px 0 0;
- padding-left: 22px;
-.failure-attribution li + li {{
- margin-top: 4px;
.panel {{
background: var(--panel);
border: 1px solid var(--line);
@@ -1770,8 +1744,7 @@ a:hover {{ color: var(--brand-strong); }}
<span class="status-dot" aria-hidden="true"></span>
<div>
<div class="banner-title"><span aria-hidden="true">{html.escape(status_mark(page_status))}</span> {html.escape(html_status_label(page_status))}</div>
-<div class="banner-summary">{page_summary}</div>
-{failure_attribution}
+<div class="banner-summary">{page_summary}{failure_attribution}</div>
</div>
</section>
<section class="panel" aria-label="Supported branch status">
diff --git a/utils/test_ci_status.py b/utils/test_ci_status.py
index a947887bf..8241ac5ba 100644
--- a/utils/test_ci_status.py
+++ b/utils/test_ci_status.py
@@ -50,7 +50,7 @@ class RequiredFailureHtmlTest(unittest.TestCase):
summary = CI_STATUS.html_required_failures(branches)
- self.assertIn("Required failures (2 across 1 branch)", summary)
+ self.assertIn("<strong>Required:</strong>", summary)
self.assertIn("Jenkins / Alpha", summary)
self.assertIn("https://ci.example.test/a", summary)
self.assertIn("Woodie / Beta", summary)
@@ -76,18 +76,17 @@ class RequiredFailureHtmlTest(unittest.TestCase):
"branches": [branch],
- self.assertIn(
- "1 OK; 1 failure; 1 running",
- rendered,
- self.assertIn("Required failures (1 across 1 branch)", rendered)
+ self.assertIn("1 OK; 1 failure; 1 running", rendered)
+ self.assertIn("<strong>Required:</strong>", rendered)
banner_start = rendered.index('<section class="status-banner')
banner_end = rendered.index("</section>", banner_start)
- failure_start = rendered.index("<div class='failure-attribution'", banner_start)
+ failure_start = rendered.index("aria-label='Required CI failures'", banner_start)
self.assertLess(failure_start, banner_end)
+ banner = rendered[banner_start:banner_end]
+ self.assertNotIn("Failing means", banner)
+ self.assertNotIn("<ul>", banner)
- def test_failure_summary_pluralizes_branches(self):
+ def test_failure_summary_keeps_multiple_branches_inline(self):
branches = [
"name": f"stable-synthetic-{index}",
@@ -101,7 +100,8 @@ class RequiredFailureHtmlTest(unittest.TestCase):
- self.assertIn("Required failures (2 across 2 branches)", summary)
+ self.assertIn("Synthetic 1", summary)
+ self.assertIn("· <strong>Synthetic 2</strong>", summary)
def test_failure_block_is_absent_without_required_failures(self):
branch = {
@@ -117,7 +117,7 @@ class RequiredFailureHtmlTest(unittest.TestCase):
"generated_at": "2026-07-19T00:00:00+00:00",
- self.assertNotIn("<div class='failure-attribution'", rendered)
+ self.assertNotIn("aria-label='Required CI failures'", rendered)
if __name__ == "__main__":
commit 63950b0740870b892fd8b45d79c7af90b2a089ef
Date: Sun Jul 19 16:06:28 2026 +0400
ci: attribute required failures in status banner
index 543d60a89..3ce1d74ae 100755
@@ -1173,6 +1173,18 @@ def overall_status(branches):
return NOT_APPLICABLE
+def required_failures(branches):
+ failures = []
+ for branch in branches:
+ checks = [
+ check for check in branch["checks"]
+ if check.get("required") and check["status"] == FAILURE
+ if checks:
+ failures.append((branch["label"], checks))
+ return failures
def html_status_label(status):
return {
SUCCESS: "Passing",
@@ -1336,12 +1348,48 @@ def html_check_table(problem_checks, passing_checks=None):
+def html_required_failures(branches):
+ failures = required_failures(branches)
+ if not failures:
+ return ""
+ count = sum(len(checks) for _, checks in failures)
+ branch_count = len(failures)
+ branch_word = "branch" if branch_count == 1 else "branches"
+ rows = []
+ for branch_label, checks in failures:
+ check_links = []
+ for check in checks:
+ check_name = html.escape(check["check"])
+ link = result_url(check)
+ check_links.append(
+ f"<a href='{html.escape(link)}'>{check_name}</a>" if link else check_name
+ rows.append(
+ f"<li><strong>{html.escape(branch_label)}</strong> — {', '.join(check_links)}</li>"
+ return (
+ "<div class='failure-attribution' aria-label='Required CI failures'>"
+ f"<div class='failure-attribution-title'>Required failures "
+ f"({count} across {branch_count} {branch_word})</div>"
+ f"<ul>{''.join(rows)}</ul></div>"
generated = html.escape(data["generated_at"])
page_status = overall_status(data["branches"])
- page_summary = html.escape(summary_text({"status": page_status, "checks": [
+ page_summary_text = summary_text({"status": page_status, "checks": [
+ if page_status == FAILURE:
+ page_summary_text = (
+ "Failing means one or more required checks failed on a supported branch. "
+ + page_summary_text
+ page_summary = html.escape(page_summary_text)
+ failure_attribution = html_required_failures(data["branches"])
rows = []
details = []
for branch in data["branches"]:
@@ -1455,6 +1503,22 @@ h1 {{
font-size: 14px;
+.failure-attribution {{
+ border-top: 1px solid #ffc9cf;
+ margin-top: 10px;
+ padding-top: 10px;
+.failure-attribution-title {{
+ color: var(--failure);
+ font-weight: 650;
+.failure-attribution ul {{
+ margin: 8px 0 0;
+ padding-left: 22px;
+.failure-attribution li + li {{
+ margin-top: 4px;
.panel {{
@@ -1707,6 +1771,7 @@ a:hover {{ color: var(--brand-strong); }}
<div>
+{failure_attribution}
</div>
</section>
new file mode 100644
index 000000000..a947887bf
--- /dev/null
@@ -0,0 +1,124 @@
+import importlib.util
+import pathlib
+import unittest
+MODULE_PATH = pathlib.Path(__file__).with_name("ci-status.py")
+SPEC = importlib.util.spec_from_file_location("ci_status", MODULE_PATH)
+CI_STATUS = importlib.util.module_from_spec(SPEC)
+SPEC.loader.exec_module(CI_STATUS)
+def check(name, status, *, required=True, url=None):
+ result = {
+ "branch": "stable-synthetic",
+ "branch_label": "Synthetic",
+ "check": name,
+ "provider": "synthetic",
+ "required": required,
+ "status": status,
+ if url:
+ result["url"] = url
+ return result
+class RequiredFailureHtmlTest(unittest.TestCase):
+ def test_failure_summary_names_only_required_failed_checks(self):
+ branches = [
+ "name": "stable-synthetic",
+ "label": "Synthetic",
+ "status": CI_STATUS.FAILURE,
+ "failures": 2,
+ "checks": [
+ check("Jenkins / Alpha", CI_STATUS.FAILURE, url="https://ci.example.test/a"),
+ check("Woodie / Beta", CI_STATUS.FAILURE, url="https://ci.example.test/b"),
+ check("Optional / Gamma", CI_STATUS.FAILURE, required=False),
+ check("Required / Waiting", CI_STATUS.UNKNOWN),
+ check("Required / Passing", CI_STATUS.SUCCESS),
+ "name": "stable-disabled",
+ "label": "Disabled",
+ "status": CI_STATUS.NOT_APPLICABLE,
+ "failures": 0,
+ "checks": [check("Retired / Delta", CI_STATUS.DISABLED)],
+ summary = CI_STATUS.html_required_failures(branches)
+ self.assertIn("Required failures (2 across 1 branch)", summary)
+ self.assertIn("Jenkins / Alpha", summary)
+ self.assertIn("https://ci.example.test/a", summary)
+ self.assertIn("Woodie / Beta", summary)
+ self.assertNotIn("Optional / Gamma", summary)
+ self.assertNotIn("Required / Waiting", summary)
+ self.assertNotIn("Retired / Delta", summary)
+ def test_page_explains_rollup_scope(self):
+ branch = {
+ "failures": 1,
+ "checks": [
+ check("Jenkins / Alpha", CI_STATUS.FAILURE),
+ check("Required / Waiting", CI_STATUS.IN_PROGRESS),
+ rendered = CI_STATUS.render_html({
+ "generated_at": "2026-07-19T00:00:00+00:00",
+ "branches": [branch],
+ self.assertIn(
+ "1 OK; 1 failure; 1 running",
+ rendered,
+ self.assertIn("Required failures (1 across 1 branch)", rendered)
+ banner_start = rendered.index('<section class="status-banner')
+ banner_end = rendered.index("</section>", banner_start)
+ failure_start = rendered.index("<div class='failure-attribution'", banner_start)
+ self.assertLess(failure_start, banner_end)
+ def test_failure_summary_pluralizes_branches(self):
+ branches = [
+ "name": f"stable-synthetic-{index}",
+ "label": f"Synthetic {index}",
+ "failures": 1,
+ "checks": [check(f"Required / Failed {index}", CI_STATUS.FAILURE)],
+ for index in (1, 2)
+ self.assertIn("Required failures (2 across 2 branches)", summary)
+ def test_failure_block_is_absent_without_required_failures(self):
+ branch = {
+ "status": CI_STATUS.UNKNOWN,
+ "failures": 0,
+ "checks": [check("Required / Waiting", CI_STATUS.UNKNOWN)],
+ self.assertEqual("", CI_STATUS.html_required_failures([branch]))
+ self.assertNotIn("<div class='failure-attribution'", rendered)
+if __name__ == "__main__":
+ unittest.main()
Summary of changes:
utils/ci-status.py | 44 +++++++++++++++--
utils/test_ci_status.py | 124 ++++++++++++++++++++++++++++++++++++++++++++++++
2 files changed, 165 insertions(+), 3 deletions(-)
create mode 100644 utils/test_ci_status.py
hooks/post-receive
