[SCM] PostGIS branch stable-3.2 updated. 3.2.10-79-g184fc31b6
git at osgeo.org
git at osgeo.org
Sun Jul 19 20:35:56 PDT 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
via 184fc31b65e84cffba35bf54bcb9e0cc265ff0cd (commit)
via e35add6612836948744edfe087b7f750092f9986 (commit)
via 6fbbfcd29abbd27ff954c3fae4f4e6671fb95b64 (commit)
via f2bf57388f2fcbb7bdb7f69344e535b9e98c6db6 (commit)
from 31612cd7bb39311cb06eafae3348641b51b91df8 (commit)
revisions in full, below.
commit 184fc31b65e84cffba35bf54bcb9e0cc265ff0cd
Merge: 31612cd7b e35add661
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Jul 19 20:35:55 2026 -0700
Merge pull request 'ci: fix stable 3.2 Bessie worker gating' (!460) from Komzpa/postgis:fix/stable-3.2-bessie-private-postgres into stable-3.2
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/460
commit e35add6612836948744edfe087b7f750092f9986
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Jul 20 06:57:01 2026 +0400
ci: skip Bessie when stable 3.2 lacks supported PostgreSQL
PostGIS 3.2 intentionally rejects PostgreSQL versions newer than 15. Prefer a supported pg_config on Bessie when one exists, but turn the PG18-only host into an explicit skip instead of a release-blocking false failure.
diff --git a/ci/bessie/postgis_regress.sh b/ci/bessie/postgis_regress.sh
index 75f6d1466..6afde5d72 100644
--- a/ci/bessie/postgis_regress.sh
+++ b/ci/bessie/postgis_regress.sh
@@ -1,6 +1,43 @@
#BRANCH is passed in via jenkins which is set via svn hook
export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
+pg_config_major()
+ "$1" --version 2>/dev/null | sed -n 's/^PostgreSQL \([0-9][0-9]*\).*/\1/p'
+find_supported_pg_config()
+ for candidate in \
+ "${PG_CONFIG:-}" \
+ /usr/local/bin/pg_config15 \
+ /usr/local/pgsql15/bin/pg_config \
+ /usr/local/pgsql-15/bin/pg_config \
+ /usr/local/postgresql15/bin/pg_config \
+ "$(command -v pg_config || true)"
+ do
+ test -n "${candidate}" || continue
+ test -x "${candidate}" || continue
+ major=$(pg_config_major "${candidate}")
+ test -n "${major}" || continue
+ if test "${major}" -le 15; then
+ printf '%s\n' "${candidate}"
+ return 0
+ fi
+ done
+ return 1
+PG_CONFIG_PATH=$(find_supported_pg_config || true)
+if test -z "${PG_CONFIG_PATH}"; then
+ pg_config_version=$(pg_config --version 2>/dev/null || true)
+ echo "Skipping Bessie: PostGIS 3.2 supports PostgreSQL <= 15, but no supported pg_config was found. Default pg_config: ${pg_config_version:-missing}."
+ exit 0
+fi
+PG_BINDIR=$(dirname "${PG_CONFIG_PATH}")
+export PATH="${PG_BINDIR}:${PATH}"
PGIS_TMP_ROOT=$(mktemp -d "${TMPDIR:-/tmp}/postgis-bessie.XXXXXX")
export PGDATA="${PGIS_TMP_ROOT}/data"
export PGHOST="${PGIS_TMP_ROOT}"
@@ -27,6 +64,7 @@ trap 'exit 1' HUP INT TERM
sh autogen.sh
./configure \
+ --with-pgconfig="${PG_CONFIG_PATH}" \
--with-projdir=/usr/local \
--with-libiconv=/usr/local \
--without-interrupt-tests \
commit 6fbbfcd29abbd27ff954c3fae4f4e6671fb95b64
Date: Mon Jul 20 06:43:21 2026 +0400
Avoid pqsignal return value on PostgreSQL 18
Backport the interrupt callback pattern used by newer stable branches so this older branch no longer depends on pqsignal returning the previous handler.
References #5841
diff --git a/postgis/postgis_module.c b/postgis/postgis_module.c
index c82284b36..ffb6e0a3f 100644
--- a/postgis/postgis_module.c
+++ b/postgis/postgis_module.c
@@ -25,9 +25,9 @@
#include "postgres.h"
#include "fmgr.h"
+#include "miscadmin.h"
#include "utils/elog.h"
#include "utils/guc.h"
-#include "libpq/pqsignal.h"
#include "../postgis_config.h"
@@ -44,15 +44,39 @@
PG_MODULE_MAGIC;
-static pqsigfunc coreIntHandler = 0;
-static void handleInterrupt(int sig);
+static void interrupt_geos_callback()
#ifdef WIN32
-static void interruptCallback() {
- if (UNBLOCKED_SIGNAL_QUEUE())
- pgwin32_dispatch_queued_signals();
+ if (UNBLOCKED_SIGNAL_QUEUE())
+ pgwin32_dispatch_queued_signals();
#endif
+ * If PgSQL global flags show interrupt,
+ * flip the pending flag in GEOS
+ * to end current query.
+ if (QueryCancelPending || ProcDiePending)
+ GEOS_interruptRequest();
+ else
+ GEOS_interruptCancel();
+static void interrupt_liblwgeom_callback()
+#ifdef WIN32
+#endif
+ * flip the pending flag in liblwgeom
+ lwgeom_request_interrupt();
+ else
+ lwgeom_cancel_interrupt();
* Module load callback
@@ -61,12 +85,12 @@ void _PG_init(void);
void
_PG_init(void)
- coreIntHandler = pqsignal(SIGINT, handleInterrupt);
-#ifdef WIN32
- GEOS_interruptRegisterCallback(interruptCallback);
- lwgeom_register_interrupt_callback(interruptCallback);
-#endif
+ * Hook up interrupt checking to call back here and examine the PgSQL
+ * interrupt state variables.
+ GEOS_interruptRegisterCallback(interrupt_geos_callback);
+ lwgeom_register_interrupt_callback(interrupt_liblwgeom_callback);
/* install PostgreSQL handlers */
pg_install_lwgeom_handlers();
@@ -80,31 +104,4 @@ void
_PG_fini(void)
elog(NOTICE, "Goodbye from PostGIS %s", POSTGIS_VERSION);
- pqsignal(SIGINT, coreIntHandler);
-static void
-handleInterrupt(int sig)
- /* NOTE: printf here would be dangerous, see
- * https://trac.osgeo.org/postgis/ticket/3644
- * TODO: block interrupts during execution, to fix the problem
- /* printf("Interrupt requested\n"); fflush(stdout); */
- GEOS_interruptRequest();
-#ifdef HAVE_LIBPROTOBUF
- /* Taking out per #5385 crash */
- //lwgeom_wagyu_interruptRequest();
-#endif
- /* request interruption of liblwgeom as well */
- lwgeom_request_interrupt();
- if ( coreIntHandler ) {
- (*coreIntHandler)(sig);
commit f2bf57388f2fcbb7bdb7f69344e535b9e98c6db6
Date: Sun Jul 19 00:36:58 2026 +0400
ci: isolate the Bessie PostgreSQL cluster
(cherry picked from commit 23a1f5deddb5947c830ec6cc54d4e44dc19ebbdc)
index 7057d0649..75f6d1466 100644
@@ -1,5 +1,30 @@
+PGIS_TMP_ROOT=$(mktemp -d "${TMPDIR:-/tmp}/postgis-bessie.XXXXXX")
+export PGDATA="${PGIS_TMP_ROOT}/data"
+export PGHOST="${PGIS_TMP_ROOT}"
+export PGUSER=postgres
+export PGIS_REG_TMPDIR="${PGIS_TMP_ROOT}/regress"
+PGLOG="${PGIS_TMP_ROOT}/postgresql.log"
+cleanup() {
+ status=$?
+ trap - EXIT
+ if test -s "${PGDATA}/postmaster.pid"; then
+ pg_ctl -D "${PGDATA}" -m immediate stop >/dev/null 2>&1 || true
+ fi
+ if test "${status}" -ne 0 && test -s "${PGLOG}"; then
+ echo "PostgreSQL log follows:" >&2
+ tail -n 100 "${PGLOG}" >&2
+ fi
+ rm -rf -- "${PGIS_TMP_ROOT}"
+ exit "${status}"
+trap cleanup EXIT
+trap 'exit 1' HUP INT TERM
sh autogen.sh
./configure \
@@ -8,9 +33,17 @@ sh autogen.sh
--with-library-minor-version
make clean
make
-export PGUSER=postgres
-export PGIS_REG_TMPDIR=~/tmp/pgis_reg_${BRANCH}
-psql -c "DROP DATABASE IF EXISTS postgis_reg;"
+initdb -N --no-data-checksums -U "${PGUSER}" -D "${PGDATA}"
+printf '%s\n' \
+ 'fsync = off' \
+ 'full_page_writes = off' \
+ 'synchronous_commit = off' \
+ >> "${PGDATA}/postgresql.conf"
+pg_ctl -D "${PGDATA}" -l "${PGLOG}" \
+ -o "-F -c listen_addresses='' -c unix_socket_directories='${PGHOST}'" start
+mkdir -p "${PGIS_REG_TMPDIR}"
make check RUNTESTFLAGS="-v"
sudo make install
make check RUNTESTFLAGS="-v --extension"
Summary of changes:
ci/bessie/postgis_regress.sh | 77 ++++++++++++++++++++++++++++++++++++++++++--
postgis/postgis_module.c | 77 +++++++++++++++++++++-----------------------
2 files changed, 111 insertions(+), 43 deletions(-)
hooks/post-receive
