[SCM] PostGIS branch master updated. 3.7.0alpha1-654-g8fe1b52b5
Sun Jul 19 23:26:21 PDT 2026
the project "PostGIS".
       via  8fe1b52b5e32598d807da1e7d8ae3704f9952dcc (commit)
       via  e8f2be193d3518a5bafe9aeec1835ed85457666b (commit)
       via  9c9850bff8384f437f7955f4f29e4ab02a0af1ea (commit)
      from  590881519946958409ed9cdc9f9f459ab34027d5 (commit)
revisions in full, below.
commit 8fe1b52b5e32598d807da1e7d8ae3704f9952dcc
Merge: 590881519 e8f2be193
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Jul 19 23:26:19 2026 -0700
    Merge pull request 'ci: show queued Jenkins branch checks' (!466) from Komzpa/postgis:ci/jenkins-queue-dashboard into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/466
commit e8f2be193d3518a5bafe9aeec1835ed85457666b
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Jul 20 10:25:34 2026 +0400
    ci: limit Winnie dashboard checks to active jobs
diff --git a/utils/ci-status.json b/utils/ci-status.json
index 7d2306ab8..56a3004d5 100644
--- a/utils/ci-status.json
+++ b/utils/ci-status.json
@@ -133,7 +133,12 @@
       "name": "Jenkins / Winnie",
       "provider": "jenkins",
       "required": true,
-      "job_url": "https://winnie.postgis.net/view/PostGIS/job/PostGIS_${version_or_trunk}/"
+      "job_url": "https://winnie.postgis.net/view/PostGIS/job/PostGIS_${version_or_trunk}/",
+      "branches": [
+        "master",
+        "stable-3.6",
+        "stable-3.5"
       "name": "Jenkins / Bessie",
commit 9c9850bff8384f437f7955f4f29e4ab02a0af1ea
Date:   Mon Jul 20 10:19:46 2026 +0400
diff --git a/utils/ci-status.py b/utils/ci-status.py
index e9c4b0a9b..d6659a47c 100755
--- a/utils/ci-status.py
+++ b/utils/ci-status.py
@@ -641,6 +641,74 @@ def jenkins_matches_branch(build, check, branch):
     return any(value == expected for name, value in params.items() if name == branch_parameter or name.lower() == branch_parameter.lower())
+def jenkins_queue_url(job_url):
+    parsed = urllib.parse.urlparse(job_url)
+    if parsed.scheme not in ("http", "https") or not parsed.netloc:
+        raise ConfigError(f"cannot build Jenkins queue URL for {job_url}")
+    return urllib.parse.urlunparse((parsed.scheme, parsed.netloc, "/queue/api/json", "", "", ""))
+def jenkins_project_url(job_url):
+    path = parsed.path.rstrip("/") + "/"
+    if path.startswith("/view/") and "/job/" in path:
+        path = "/job/" + path.split("/job/", 1)[1]
+    if "/label=" in path:
+        path = path.split("/label=", 1)[0].rstrip("/") + "/"
+    return urllib.parse.urlunparse((parsed.scheme, parsed.netloc, path, "", "", ""))
+def jenkins_queue_items(job_url, timeout):
+    tree = (
+        "items[id,task[name,url],why,params,inQueueSince,url,blocked,buildable,stuck,"
+        "actions[parameters[name,value]]]"
+    url = jenkins_queue_url(job_url) + "?" + urllib.parse.urlencode({"tree": tree})
+    return http_json(url, timeout=timeout).get("items") or []
+def jenkins_queue_item_matches(item, job_url, check, branch):
+    task = item.get("task") or {}
+    task_url = (task.get("url") or "").rstrip("/") + "/"
+    if task_url != jenkins_project_url(job_url):
+        return False
+    branch_parameter = check.get("branch_parameter")
+    if not branch_parameter:
+        return True
+    expected = f"refs/heads/{branch['name']}"
+    params = jenkins_parameters(item)
+    return any(value == expected for name, value in params.items() if name == branch_parameter or name.lower() == branch_parameter.lower())
+def jenkins_queued_check(check, branch, job_url, timeout):
+    if not check.get("branch_parameter"):
+        return None
+    try:
+        queued = [
+            item for item in jenkins_queue_items(job_url, timeout)
+            if jenkins_queue_item_matches(item, job_url, check, branch)
+    except RECOVERABLE_PROVIDER_ERRORS:
+        return None
+    if not queued:
+        return None
+    item = sorted(queued, key=lambda value: value.get("inQueueSince") or 0)[0]
+    message = f"queued item {item.get('id')}"
+    if item.get("why"):
+        message = f"{message}: {item['why']}"
+    return make_result(
+        check,
+        branch,
+        IN_PROGRESS,
+        url=job_url,
+        debug_url=jenkins_queue_url(job_url),
+        revision=params.get("after") or params.get("BRANCH"),
+        completed_at=item.get("inQueueSince"),
+        message=message,
 def jenkins_builds(job_url, check, timeout):
     try:
         limit = int(check.get("build_scan_limit", 200 if check.get("branch_parameter") else 25))
@@ -722,6 +790,7 @@ def jenkins_badge_check(check, branch, job_url, timeout, api_error=None):
 def jenkins_check(check, branch, timeout):
     job_url = render_template(check["job_url"], branch).rstrip("/") + "/"
+    queued_result = jenkins_queued_check(check, branch, job_url, timeout)
     try:
         builds = [
             build for build in jenkins_builds(job_url, check, timeout)
@@ -730,6 +799,8 @@ def jenkins_check(check, branch, timeout):
     except RECOVERABLE_PROVIDER_ERRORS as exc:
         return jenkins_badge_check(check, branch, job_url, timeout, api_error=exc)
     if not builds:
+        if queued_result:
+            return queued_result
         badge_result = jenkins_badge_check(check, branch, job_url, timeout)
         if badge_result["status"] != UNKNOWN or badge_result.get("status_label") == "Not run":
             return badge_result
@@ -737,6 +808,9 @@ def jenkins_check(check, branch, timeout):
     current = builds[0]
     previous = next((build for build in builds[1:] if not build.get("building")), None)
+    if queued_result and not current.get("building"):
+        queued_result.update(previous_fields(normalize_jenkins_status(current), current))
     result = make_result(
         check,
         branch,
Summary of changes:
 utils/ci-status.json |  7 ++++-
 utils/ci-status.py   | 74 ++++++++++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 80 insertions(+), 1 deletion(-)
hooks/post-receive
