[SCM] PostGIS branch stable-3.5 updated. 3.5.7-74-ge0adbb804
git at osgeo.org
git at osgeo.org
Sun Jul 19 23:40:35 PDT 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
via e0adbb804e561767223482fec5c70d1315fa7de1 (commit)
via 54bcbe637e38366a06861beffcbf775b295d4469 (commit)
from 6b351402efd21a4cd1d3a9bb4da4caf51fe1f513 (commit)
revisions in full, below.
commit e0adbb804e561767223482fec5c70d1315fa7de1
Merge: 6b351402e 54bcbe637
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Jul 19 23:40:34 2026 -0700
Merge pull request 'doc: avoid overlong GraphicsMagick draw options on stable 3.5' (!462) from Komzpa/postgis:fix/stable-3.5-doc-generator-gm-drawfile into stable-3.5
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/462
commit 54bcbe637e38366a06861beffcbf775b295d4469
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Jul 20 08:33:21 2026 +0400
diff --git a/doc/html/images/generator.c b/doc/html/images/generator.c
index 0ada4e581..8a3f6a773 100644
--- a/doc/html/images/generator.c
+++ b/doc/html/images/generator.c
@@ -98,6 +98,8 @@ typedef struct generator_job {
const char *converter_cli;
LAYERSTYLE *styles;
stringbuffer_t command;
+ const char *tmpdir;
+ unsigned int draw_num;
} generator_job;
static void
@@ -107,6 +109,8 @@ generator_job_init(generator_job *job, const generator_options *options)
job->converter_cli = NULL;
job->styles = NULL;
stringbuffer_init(&job->command);
+ job->tmpdir = NULL;
+ job->draw_num = 0;
static void
@@ -123,6 +127,8 @@ generator_job_reset(generator_job *job)
typedef struct draw_context_t {
LAYERSTYLE *style;
+ unsigned int *draw_num;
} GEOMETRY_DRAW_CONTEXT;
static GEOMETRY_DRAW_CONTEXT
@@ -130,6 +136,8 @@ geometry_draw_context_init(void)
GEOMETRY_DRAW_CONTEXT ctx;
ctx.style = NULL;
+ ctx.tmpdir = NULL;
+ ctx.draw_num = NULL;
return ctx;
@@ -160,6 +168,20 @@ checked_system(const char *cmd)
+static void
+cleanup_temp_dir(const char *dir)
+ stringbuffer_t command;
+ if (!dir)
+ return;
+ stringbuffer_init(&command);
+ stringbuffer_aprintf(&command, "rm -rf %s", dir);
+ checked_system(stringbuffer_getstring(&command));
+ stringbuffer_release(&command);
* Locate executables in PATH using liblwgeom's stringbuffer helpers so the
* probing logic can be promoted to the raster tooling if it ever needs the
@@ -354,6 +376,39 @@ pointarrayToBuffer(stringbuffer_t *output, POINTARRAY *pa)
+static int
+append_draw_file(stringbuffer_t *output, GEOMETRY_DRAW_CONTEXT *ctx, const char *draw_command)
+ stringbuffer_t draw_path;
+ FILE *draw_file;
+ if (!ctx->tmpdir || !ctx->draw_num)
+ lwerror("Temporary draw-file context is not initialized");
+ return -1;
+ stringbuffer_init(&draw_path);
+ stringbuffer_aprintf(&draw_path, "%s/draw%u", ctx->tmpdir, (*ctx->draw_num)++);
+ draw_file = fopen(stringbuffer_getstring(&draw_path), "w");
+ if (!draw_file)
+ perror(stringbuffer_getstring(&draw_path));
+ stringbuffer_release(&draw_path);
+ return -1;
+ fputs(draw_command, draw_file);
+ fclose(draw_file);
+ stringbuffer_append(output, "-draw '@");
+ stringbuffer_append(output, stringbuffer_getstring(&draw_path));
+ stringbuffer_append(output, "' ");
+ return 0;
* Draws a point in a POINTARRAY to a char* using GraphicsMagick SVG for styling.
@@ -483,9 +538,11 @@ drawLineString(stringbuffer_t *output, LWLINE *lwl, GEOMETRY_DRAW_CONTEXT *ctx)
pointarrayToBuffer(&path, lwl->points);
stringbuffer_append(&path, "'");
- stringbuffer_append(output, "-draw \"");
- stringbuffer_append(output, stringbuffer_getstring(&path));
- stringbuffer_append(output, "\" ");
+ if (append_draw_file(output, ctx, stringbuffer_getstring(&path)) < 0)
+ stringbuffer_release(&path);
+ return;
@@ -530,9 +587,11 @@ drawPolygon(stringbuffer_t *output, LWPOLY *lwp, GEOMETRY_DRAW_CONTEXT *ctx)
+ return;
@@ -666,6 +725,8 @@ append_layers(generator_job *job, FILE *source)
LWDEBUGF(4, "geom = %s", lwgeom_to_ewkt(lwgeom));
ctx.style = getStyle(job->styles, style_name);
+ ctx.tmpdir = job->tmpdir;
+ ctx.draw_num = &job->draw_num;
if (!ctx.style)
lwgeom_free(lwgeom);
@@ -740,6 +801,7 @@ generator_render(const generator_options *options, const char *source_path, cons
char *target_path = NULL;
int rc = -1;
+ char tempdir_template[] = "generator-temp-XXXXXX";
generator_job_init(&job, options);
@@ -751,6 +813,12 @@ generator_render(const generator_options *options, const char *source_path, cons
goto cleanup;
job.converter_cli = converter_cli;
+ job.tmpdir = mkdtemp(tempdir_template);
+ if (!job.tmpdir)
+ perror("generator-temp");
+ goto cleanup;
source = fopen(source_path, "r");
if (!source)
@@ -800,6 +868,7 @@ cleanup:
lwfree(styles_path);
if (target_path)
lwfree(target_path);
+ cleanup_temp_dir(job.tmpdir);
generator_job_reset(&job);
return rc;
Summary of changes:
doc/html/images/generator.c | 81 +++++++++++++++++++++++++++++++++++++++++----
1 file changed, 75 insertions(+), 6 deletions(-)
hooks/post-receive
