[SCM] PostGIS branch stable-3.6 updated. 3.6.4-79-gd292323ca
Sun Jul 19 23:41:14 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  d292323caefca0f150fab3559573239b940650c0 (commit)
       via  f92c647dac4817074dab20681a7b3ef1c2b3647f (commit)
       via  829cece6452e49f99a4c41db4386f1ebb0e1a497 (commit)
      from  17f2560386892694ff7dadbdb00de62811938c98 (commit)
revisions in full, below.
commit d292323caefca0f150fab3559573239b940650c0
Merge: 17f256038 f92c647da
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Jul 19 23:41:13 2026 -0700
    Merge pull request 'ci: isolate Bessie PostgreSQL on stable 3.6' (!456) from Komzpa/postgis:fix/stable-3.6-bessie-private-postgres into stable-3.6
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/456
commit f92c647dac4817074dab20681a7b3ef1c2b3647f
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Jul 20 09:33:51 2026 +0400
    ci: rerun killed Woodie pipeline
commit 829cece6452e49f99a4c41db4386f1ebb0e1a497
Date:   Sun Jul 19 00:36:58 2026 +0400
    ci: isolate the Bessie PostgreSQL cluster
    (cherry picked from commit 23a1f5deddb5947c830ec6cc54d4e44dc19ebbdc)
diff --git a/ci/bessie/postgis_regress.sh b/ci/bessie/postgis_regress.sh
index bec7bb73b..90b79fb7c 100644
--- a/ci/bessie/postgis_regress.sh
+++ b/ci/bessie/postgis_regress.sh
@@ -4,6 +4,31 @@ set -e
 #BRANCH is passed in via jenkins which is set via webhook hook
 export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
+PGIS_TMP_ROOT=$(mktemp -d "${TMPDIR:-/tmp}/postgis-bessie.XXXXXX")
+export PGDATA="${PGIS_TMP_ROOT}/data"
+export PGHOST="${PGIS_TMP_ROOT}"
+export PGUSER=postgres
+export PGIS_REG_TMPDIR="${PGIS_TMP_ROOT}/regress"
+PGLOG="${PGIS_TMP_ROOT}/postgresql.log"
+cleanup() {
+  status=$?
+  trap - EXIT
+  if test -s "${PGDATA}/postmaster.pid"; then
+    pg_ctl -D "${PGDATA}" -m immediate stop >/dev/null 2>&1 || true
+  fi
+  if test "${status}" -ne 0 && test -s "${PGLOG}"; then
+    echo "PostgreSQL log follows:" >&2
+    tail -n 100 "${PGLOG}" >&2
+  fi
+  rm -rf -- "${PGIS_TMP_ROOT}"
+  exit "${status}"
+trap cleanup EXIT
+trap 'exit 1' HUP INT TERM
 sh autogen.sh
 ./configure \
   --with-projdir=/usr/local \
@@ -11,9 +36,17 @@ sh autogen.sh
   --with-library-minor-version
 #make distclean
 make
-export PGUSER=postgres
-export PGIS_REG_TMPDIR=~/tmp/pgis_reg_${BRANCH}
-psql -c "DROP DATABASE IF EXISTS postgis_reg;"
+initdb -N --no-data-checksums -U "${PGUSER}" -D "${PGDATA}"
+printf '%s\n' \
+  'fsync = off' \
+  'full_page_writes = off' \
+  'synchronous_commit = off' \
+  >> "${PGDATA}/postgresql.conf"
+pg_ctl -D "${PGDATA}" -l "${PGLOG}" \
+  -o "-F -c listen_addresses='' -c unix_socket_directories='${PGHOST}'" start
+mkdir -p "${PGIS_REG_TMPDIR}"
 make check RUNTESTFLAGS="-v"
 sudo make install
 make check RUNTESTFLAGS="-v --extension"
Summary of changes:
 ci/bessie/postgis_regress.sh | 39 ++++++++++++++++++++++++++++++++++++---
 1 file changed, 36 insertions(+), 3 deletions(-)
hooks/post-receive
