[SCM] PostGIS branch master updated. 3.7.0alpha1-661-gb52a08bfb
git at osgeo.org
git at osgeo.org
Mon Jul 20 01:32:25 PDT 2026
the project "PostGIS".
via b52a08bfb7af19711e74bf987306af94cc4ad707 (commit)
via 96606a931be3b08413bfead0cc462b96cf08f042 (commit)
from 19be897cda155cde7cabe555d73a27cdc50ea6f0 (commit)
revisions in full, below.
commit b52a08bfb7af19711e74bf987306af94cc4ad707
Merge: 19be897cd 96606a931
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 20 01:32:23 2026 -0700
Merge pull request 'Fix upgrade harness tests after version bump' (#467)
commit 96606a931be3b08413bfead0cc462b96cf08f042
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Jul 20 11:07:14 2026 +0400
diff --git a/utils/test_check_all_upgrades.py b/utils/test_check_all_upgrades.py
index 3b8633d56..833098eac 100644
--- a/utils/test_check_all_upgrades.py
+++ b/utils/test_check_all_upgrades.py
@@ -12,6 +12,7 @@ import unittest
class FakePostgresTools:
def __init__(self, repo_root):
self.repo_root = repo_root
+ self.current_version = self._read_current_version()
self.temp_dir = tempfile.TemporaryDirectory()
self.root = Path(self.temp_dir.name)
self.sharedir = self.root / "pg_sharedir"
@@ -123,6 +124,19 @@ sys.exit(0)
script.write_text(body + "\n", encoding="utf-8")
script.chmod(0o755)
+ def _read_current_version(self):
+ parts = []
+ version_keys = (
+ "POSTGIS_MAJOR_VERSION",
+ "POSTGIS_MINOR_VERSION",
+ "POSTGIS_MICRO_VERSION",
+ for line in (self.repo_root / "Version.config").read_text(encoding="utf-8").splitlines():
+ key, _, value = line.partition("=")
+ if key in version_keys:
+ parts.append(value.strip())
+ return ".".join(parts)
def create_extension_files(self, extension, versions):
for version in versions:
(self.extension_dir / f"{extension}--{version}.sql").write_text("--", encoding="utf-8")
@@ -142,7 +156,7 @@ sys.exit(0)
env["PATH"] = f"{self.bin_dir}:{env['PATH']}"
env["CHECK_ALL_UPGRADES_SHAREDIR"] = str(self.sharedir)
env["CHECK_ALL_UPGRADES_PG_VERSION"] = "PostgreSQL 16.2 (Debian)"
- env["CHECK_ALL_UPGRADES_AUTO_VERSION"] = "3.7.0dev"
+ env["CHECK_ALL_UPGRADES_AUTO_VERSION"] = self.current_version
env["CHECK_ALL_UPGRADES_PSQL_PATH_MAP"] = json.dumps(self.path_map)
env["CHECK_ALL_UPGRADES_GMAKE_FAIL"] = json.dumps(self.fail_patterns)
env["CHECK_ALL_UPGRADES_PSQL_LOG"] = str(self.psql_log)
@@ -185,25 +199,26 @@ class CheckAllUpgradesHarnessTest(unittest.TestCase):
self.harness.close()
def test_default_exhaustive_runs_packaged_and_unpacked_paths(self):
- self.harness.create_extension_files("postgis", ["3.5.0", "3.6.0", "3.7.0dev"])
- self.harness.create_extension_files("postgis_topology", ["3.7.0dev"])
+ current_version = self.harness.current_version
+ self.harness.create_extension_files("postgis", ["3.5.0", "3.6.0", current_version])
+ self.harness.create_extension_files("postgis_topology", [current_version])
self.harness.create_contrib_files(["3.6.0"])
self.harness.set_path_map(
- "postgis|3.5.0|3.7.0dev": "up",
- "postgis|3.6.0|3.7.0dev": "up",
- "postgis|unpackaged|3.7.0dev": "up",
- "postgis_topology|3.7.0dev|3.7.0dev": "up",
- "postgis_topology|unpackaged|3.7.0dev": "up",
+ f"postgis|3.5.0|{current_version}": "up",
+ f"postgis|3.6.0|{current_version}": "up",
+ f"postgis|unpackaged|{current_version}": "up",
+ f"postgis_topology|{current_version}|{current_version}": "up",
+ f"postgis_topology|unpackaged|{current_version}": "up",
- result = self.harness.run("3.7.0dev")
+ result = self.harness.run(current_version)
output = result.stdout + result.stderr
self.assertEqual(0, result.returncode)
- self.assertIn("Testing postgis extension upgrade 3.5.0--3.7.0dev", output)
- self.assertIn("Testing postgis extension upgrade 3.6.0--3.7.0dev", output)
+ self.assertIn(f"Testing postgis extension upgrade 3.5.0--{current_version}", output)
+ self.assertIn(f"Testing postgis extension upgrade 3.6.0--{current_version}", output)
self.assertIn("Testing postgis script soft upgrade", output)
self.assertIn("Testing postgis script hard upgrade", output)
@@ -295,16 +310,17 @@ class CheckAllUpgradesHarnessTest(unittest.TestCase):
self.assertIn("topology/test", cmd)
def test_unpackaged_soft_and_hard_share_oldest_upgrade_source(self):
- self.harness.create_extension_files("postgis", ["3.6.0", "3.7.0dev"])
+ self.harness.create_extension_files("postgis", ["3.6.0", current_version])
self.harness.create_contrib_files(["3.5.0", "3.6.0"])
- result = self.harness.run("3.7.0dev", args=("--oldest",))
+ result = self.harness.run(current_version, args=("--oldest",))
calls = self.harness.make_calls()
Summary of changes:
utils/test_check_all_upgrades.py | 46 +++++++++++++++++++++++++++-------------
1 file changed, 31 insertions(+), 15 deletions(-)
hooks/post-receive
