[SCM] PostGIS branch stable-3.4 updated. 3.4.6-82-g636a58a9e
git at osgeo.org
git at osgeo.org
Mon Jul 20 01:40:45 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
via 636a58a9ed509d6ebfbfa25539646dc09eb4fe8b (commit)
via 8249c33eac95b912caa552b450fe70b5ebc11991 (commit)
via 56a3c6e3099d1e7da4326400779b23b8e3e7c634 (commit)
from ad11b27e2021d48eae913a9d5b09ac95f8a8cd8d (commit)
revisions in full, below.
commit 636a58a9ed509d6ebfbfa25539646dc09eb4fe8b
Merge: ad11b27e2 8249c33ea
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 20 01:40:44 2026 -0700
Merge pull request 'regress: fix stable 3.4 GEOS 3.15 and PG18 tests' (#470)
commit 8249c33eac95b912caa552b450fe70b5ebc11991
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Jul 20 12:38:58 2026 +0400
regress: drop invalid coverage union case on stable 3.4
GEOS 3.15 rejects the incorrectly noded input used by the union 2 case with a TopologyException. Stable 3.5 already removed this case as part of b2cb17fa069861f658d80d67ce34f98a354e23fd; keep this stable 3.4 backport test-only and leave the unrelated ST_IsCollection runtime changes out.
diff --git a/regress/core/coverage.sql b/regress/core/coverage.sql
index f0d1f5a9b..2e069cd73 100644
--- a/regress/core/coverage.sql
+++ b/regress/core/coverage.sql
@@ -52,20 +52,6 @@ SELECT 'three partition b' AS test,
id, ST_Area(ST_CoverageUnion(geom))
FROM coverage GROUP BY id ORDER BY id;
-TRUNCATE coverage;
-INSERT INTO coverage VALUES
-(4, 1, 'POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0))'),
-(4, 2, 'POLYGON ((1 0, 0.9 1, 2 1, 2 0, 1 0))');
-WITH u AS (
- SELECT ST_CoverageUnion(geom) AS geom FROM coverage
-SELECT 'union 2' AS test,
- ST_Area(geom), ST_GeometryType(geom)
-FROM u;
TRUNCATE coverage;
(5, 1, 'POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0))'),
@@ -100,4 +86,3 @@ SELECT 'grid squares', i, j, ST_Area(ST_CoverageUnion(geom))
FROM squares
GROUP BY i, j
ORDER By i, j;
diff --git a/regress/core/coverage_expected b/regress/core/coverage_expected
index 5d19e968a..2b456107a 100644
--- a/regress/core/coverage_expected
+++ b/regress/core/coverage_expected
@@ -15,7 +15,6 @@ three partition a|3|2|||
three partition b|1|200
three partition b|2|200
three partition b|3|
-union 2|2.05|ST_MultiPolygon
union 3|2|ST_Polygon
grid lanes|0|110000
grid lanes|1|110000
commit 56a3c6e3099d1e7da4326400779b23b8e3e7c634
Author: Regina Obe <lr at pcorp.us>
Date: Mon Mar 3 00:38:17 2025 -0500
Fix regress error on pg18
Explain now returns fractional for actual rows for some reason
Closes #5851 for PostGIS 3.5.3
(cherry picked from commit 8b1bb8316bab89f0433cf36ee085974b5acdeec8)
diff --git a/regress/core/regress_index.sql b/regress/core/regress_index.sql
index 494ef9ec5..9c9697b74 100644
--- a/regress/core/regress_index.sql
+++ b/regress/core/regress_index.sql
@@ -57,11 +57,11 @@ BEGIN
-- TODO: rewrite using json output ?
EXECUTE 'EXPLAIN ANALYZE ' || qry INTO anl;
- SELECT regexp_matches(anl, ' rows=([0-9]*) .* rows=([0-9]*) ')
+ SELECT regexp_matches(anl, ' rows=([0-9]*) .* rows=([0-9\.]*) ')
INTO mat;
est := mat[1];
- act := mat[2];
+ act := mat[2]::numeric::integer;
err = abs(est-act);
Summary of changes:
regress/core/coverage.sql | 15 ---------------
regress/core/coverage_expected | 1 -
regress/core/regress_index.sql | 4 ++--
3 files changed, 2 insertions(+), 18 deletions(-)
hooks/post-receive
