[SCM] PostGIS branch master updated. 3.7.0alpha1-665-g8bafa4315
Mon Jul 20 06:14:21 PDT 2026
the project "PostGIS".
       via  8bafa43152c07f386224f6ae0c2052b570b2fd82 (commit)
       via  9697dd43f5f7f355df1b4a67a0d0fc411dbb3af2 (commit)
      from  e38d9450b77ac106efd404465cf1e62749837401 (commit)
revisions in full, below.
commit 8bafa43152c07f386224f6ae0c2052b570b2fd82
Merge: e38d9450b 9697dd43f
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 20 06:14:20 2026 -0700
    Merge pull request 'docs: keep generated visual examples sized in output' (!474) from Komzpa/postgis:fix/docs-rendering-regina-20260720 into master
commit 9697dd43f5f7f355df1b4a67a0d0fc411dbb3af2
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Jul 20 16:35:21 2026 +0400
diff --git a/doc/html/style.css b/doc/html/style.css
index c81074c38..47b24c6a8 100644
--- a/doc/html/style.css
+++ b/doc/html/style.css
@@ -624,6 +624,13 @@ table.postgis-example-grid td {
     width: auto;
+.postgis-geometry-figure-fallback {
+    display: block;
+    height: auto;
+    max-width: 100%;
+    width: 100%;
 .postgis-geometry-literal {
     border-radius: 0.16em;
     transition: background-color 90ms ease;
diff --git a/doc/xsl/postgis-dblatex-block-labels.xsl b/doc/xsl/postgis-dblatex-block-labels.xsl
index c78a0cde2..29670a408 100644
--- a/doc/xsl/postgis-dblatex-block-labels.xsl
+++ b/doc/xsl/postgis-dblatex-block-labels.xsl
@@ -89,6 +89,15 @@
 		    <xsl:value-of select="translate(., '┌┐└┘├┤┬┴┼─│', '+++++++++-|')"/>
 		    <xsl:text>
\end{lstlisting}
\endgroup
</xsl:text>
 		  </xsl:when>
+		  <xsl:when test="(contains(@xml:id, 'st-buffer-example-') or contains(@id, 'st-buffer-example-')) and contains(., ',')">
+		    <xsl:text>
\begingroup\lstset{basicstyle=\ttfamily\scriptsize}
</xsl:text>
+		    <xsl:text>\noindent\ttfamily\scriptsize{}</xsl:text>
+		    <xsl:call-template name="postgis-dblatex-breakable-geometry">
+		      <xsl:with-param name="text" select="."/>
+		    </xsl:call-template>
+		    <xsl:text>\par
</xsl:text>
+		    <xsl:text>
\endgroup
</xsl:text>
+		  </xsl:when>
 		  <xsl:when test="contains($role.tokens, ' text-primary ') or string-length(normalize-space(.)) > 600">
 		    <xsl:text>
</xsl:text>
 		    <xsl:apply-imports/>
diff --git a/doc/xsl/postgis-html-block-labels.xsl b/doc/xsl/postgis-html-block-labels.xsl
index 81b79a75b..a92a9cb85 100644
--- a/doc/xsl/postgis-html-block-labels.xsl
+++ b/doc/xsl/postgis-html-block-labels.xsl
@@ -354,7 +354,19 @@
         </div>
       </div>
+      <xsl:variable name="visual.src">
+        <xsl:value-of select="concat($img.src.path, 'images/visual-examples/', $visual.id, '.svg')"/>
+        <xsl:if test="$postgis.visual.version != ''">
+          <xsl:value-of select="concat('?v=', $postgis.visual.version)"/>
+        </xsl:if>
+      </xsl:variable>
       <object type="image/svg+xml">
+        <xsl:if test="$manifest.visual/@width">
+          <xsl:attribute name="width"><xsl:value-of select="$manifest.visual/@width"/></xsl:attribute>
+        </xsl:if>
+        <xsl:if test="$manifest.visual/@height">
+          <xsl:attribute name="height"><xsl:value-of select="$manifest.visual/@height"/></xsl:attribute>
+        </xsl:if>
         <xsl:attribute name="class">
           <xsl:text>postgis-geometry-figure-body</xsl:text>
           <xsl:if test="$manifest.visual/@kind = 'image-output'">
@@ -362,12 +374,14 @@
           </xsl:if>
         </xsl:attribute>
         <xsl:attribute name="data">
-          <xsl:value-of select="concat($img.src.path, 'images/visual-examples/', $visual.id, '.svg')"/>
-          <xsl:if test="$postgis.visual.version != ''">
-            <xsl:value-of select="concat('?v=', $postgis.visual.version)"/>
-          </xsl:if>
+          <xsl:value-of select="$visual.src"/>
         </xsl:attribute>
-        <xsl:text>Geometry figure for </xsl:text><xsl:value-of select="$visual.id"/>
+        <img class="postgis-geometry-figure-fallback">
+          <xsl:attribute name="src"><xsl:value-of select="$visual.src"/></xsl:attribute>
+          <xsl:attribute name="alt">
+            <xsl:text>Geometry figure for </xsl:text><xsl:value-of select="$visual.id"/>
+          </xsl:attribute>
+        </img>
       </object>
     </div>
   </xsl:if>
diff --git a/utils/postgis_exampletest.py b/utils/postgis_exampletest.py
index 700f51b00..d79d7839f 100755
--- a/utils/postgis_exampletest.py
+++ b/utils/postgis_exampletest.py
@@ -3186,6 +3186,10 @@ SELECT json_build_object(
                     raise RuntimeError(f"Duplicate or missing visual example id: {visual['id']!r}")
                 seen.add(visual["id"])
                 (temporary / f"{visual['id']}.svg").write_text(visual["svg"], encoding="utf-8")
+                svg_match = re.search(
+                    r'<svg\b[^>]*\bwidth="([^"]+)"[^>]*\bheight="([^"]+)"',
+                    visual["svg"],
                 manifest_item = {
                     "id": visual["id"],
                     "kind": visual["kind"],
@@ -3194,6 +3198,8 @@ SELECT json_build_object(
                     "refentry": visual["refentry"],
                     "screen": visual["screen"],
                     "source": visual["source"],
+                    "width": svg_match.group(1) if svg_match else None,
+                    "height": svg_match.group(2) if svg_match else None,
                     "layers": visual.get("layers", []),
                 if visual.get("native_output"):
diff --git a/utils/test_postgis_exampletest.py b/utils/test_postgis_exampletest.py
index fd3724809..f79d30287 100644
--- a/utils/test_postgis_exampletest.py
+++ b/utils/test_postgis_exampletest.py
@@ -2514,6 +2514,7 @@ class VisualExampleTest(unittest.TestCase):
                     "id": "one", "kind": "geometry-output", "preferred": True,
                     "refentry": "ST_Buffer", "screen": 1, "source": "ST_Buffer:1",
                     "output_omitted": False,
+                    "width": None, "height": None,
                     "native_output": "01010000000000000000000000000000000000000000",
                     "layers": [{
                         "id": "one-code-1", "source": "Code", "label": "center",
@@ -2530,6 +2531,26 @@ class VisualExampleTest(unittest.TestCase):
             self.assertIn('<layer id="one-code-1" source="Code" label="center"', manifest_xml)
             self.assertIn('dimension="0" srid="0" frame="Overlay"', manifest_xml)
+    def test_publish_visual_examples_records_svg_dimensions(self):
+        with tempfile.TemporaryDirectory() as directory:
+            target = Path(directory) / "visual-examples"
+            self.tester.publish_visual_examples(
+                target,
+                    "id": "one", "source": "ST_Buffer:1",
+                    "svg": '<svg xmlns="http://www.w3.org/2000/svg" width="600" height="402"></svg>\n',
+                    "kind": "geometry-output", "preferred": True,
+                    "refentry": "ST_Buffer", "screen": 1, "output_omitted": False,
+                    "layers": [],
+            manifest_json = json.loads((target / "manifest.json").read_text(encoding="utf-8"))
+            self.assertEqual("600", manifest_json[0]["width"])
+            self.assertEqual("402", manifest_json[0]["height"])
+            manifest_xml = (target / "manifest.xml").read_text(encoding="utf-8")
+            self.assertIn('width="600"', manifest_xml)
+            self.assertIn('height="402"', manifest_xml)
 if __name__ == "__main__":
     unittest.main()
Summary of changes:
 doc/html/style.css                       |  7 +++++++
 doc/xsl/postgis-dblatex-block-labels.xsl |  9 +++++++++
 doc/xsl/postgis-html-block-labels.xsl    | 24 +++++++++++++++++++-----
 utils/postgis_exampletest.py             |  6 ++++++
 utils/test_postgis_exampletest.py        | 21 +++++++++++++++++++++
 5 files changed, 62 insertions(+), 5 deletions(-)
hooks/post-receive
