[SCM] PostGIS branch master updated. 3.7.0alpha1-666-g8483c4d63
git at osgeo.org
git at osgeo.org
Mon Jul 20 11:42:11 PDT 2026
the project "PostGIS".
via 8483c4d6367e0cd535ab1e8b78bea64cb10d9cf3 (commit)
from 8bafa43152c07f386224f6ae0c2052b570b2fd82 (commit)
revisions in full, below.
commit 8483c4d6367e0cd535ab1e8b78bea64cb10d9cf3
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 20 11:42:10 2026 -0700
docs: render native solid examples as faces (!478)
Fix the generated visual-example renderer for native geometry output so unitary solid/surface values are decomposed into faces before SVG projection and 3D styling.
After HEXEWKB/native geometry output replaced ST_AsText in examples, the visual payload used ST_NumGeometries/ST_GeometryN to split render parts. For a unitary POLYHEDRALSURFACE or TIN, ST_NumGeometries returns one object, so the doc renderer lost the per-face depth, shading, and hidden-edge data needed by the 3D SVG view.
This keeps the generated images path and changes the visual payload to use ST_Dump, preserving face-level rendering while still using ST_AsSVG for the final 2D path fragments. ST_AsSVG itself already emits multi-path output for TIN/POLYHEDRALSURFACE; the missing piece was the doc renderer part decomposition.
References https://trac.osgeo.org/postgis/ticket/6105.
Tests:
- python3 utils/test_postgis_exampletest.py
- git diff --check
- make -C doc check
- make -C regress visual-examples
- SQL smoke: ST_NumGeometries(POLYHEDRALSURFACE)=1 while ST_Dump yields polygon faces
Co-authored-by: Darafei Praliaskouski <me at komzpa.net>
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/478
diff --git a/utils/postgis_exampletest.py b/utils/postgis_exampletest.py
index d79d7839f..9c730ac50 100755
--- a/utils/postgis_exampletest.py
+++ b/utils/postgis_exampletest.py
@@ -2028,13 +2028,10 @@ WITH raw AS (
COALESCE(total_points, ST_NPoints(framed.geom)) AS total_points,
marker_scale,
GeometryType(framed.geom) AS root_type,
- part.geom
+ dumped.geom
FROM framed
- CROSS JOIN LATERAL generate_series(1, ST_NumGeometries(framed.geom)) AS part_num(n)
- CROSS JOIN LATERAL (
- SELECT ST_GeometryN(framed.geom, part_num.n) AS geom
- ) AS part
- WHERE NOT ST_IsEmpty(part.geom)
+ CROSS JOIN LATERAL ST_Dump(framed.geom) AS dumped(path, geom)
+ WHERE NOT ST_IsEmpty(dumped.geom)
), translated_parts AS (
SELECT ord, source, label, row_num, column_num, parts.frame, source_point_count,
total_points, marker_scale, root_type,
diff --git a/utils/test_postgis_exampletest.py b/utils/test_postgis_exampletest.py
index f79d30287..46d368b89 100644
--- a/utils/test_postgis_exampletest.py
+++ b/utils/test_postgis_exampletest.py
@@ -1386,10 +1386,10 @@ class VisualExampleTest(unittest.TestCase):
self.assertIn("'has_z'", queries[0])
self.assertIn("'points_xyz'", queries[0])
self.assertIn("CROSS JOIN LATERAL", queries[0])
- self.assertIn("generate_series(1, ST_NumGeometries(framed.geom))", queries[0])
- self.assertIn("ST_GeometryN(framed.geom, part_num.n) AS geom", queries[0])
- self.assertIn("WHERE NOT ST_IsEmpty(part.geom)", queries[0])
- self.assertNotIn("CROSS JOIN LATERAL ST_Dump", queries[0])
+ self.assertIn("CROSS JOIN LATERAL ST_Dump(framed.geom)", queries[0])
+ self.assertIn("WHERE NOT ST_IsEmpty(dumped.geom)", queries[0])
+ self.assertNotIn("generate_series(1, ST_NumGeometries(framed.geom))", queries[0])
+ self.assertNotIn("ST_GeometryN(framed.geom, part_num.n) AS geom", queries[0])
self.assertNotIn("WHERE GeometryType(framed.geom) = 'CURVEPOLYGON'", queries[0])
self.assertNotIn("WHERE GeometryType(framed.geom) <> 'CURVEPOLYGON'", queries[0])
self.assertIn("geom AS render_geom", queries[0])
Summary of changes:
utils/postgis_exampletest.py | 9 +++------
utils/test_postgis_exampletest.py | 8 ++++----
2 files changed, 7 insertions(+), 10 deletions(-)
hooks/post-receive
