[SCM] PostGIS branch stable-3.3 updated. 3.3.10-85-gdd5f18e59
git at osgeo.org
git at osgeo.org
Thu Jul 23 13:00:46 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
via dd5f18e59eb69953a625ebce5c13889856df2540 (commit)
via 6a37ecd9adcad85bcf84f3ed15a510c6ad3f5487 (commit)
from e8ac394a16b235bbf350c015b74d51562c08b8b4 (commit)
revisions in full, below.
commit dd5f18e59eb69953a625ebce5c13889856df2540
Merge: e8ac394a1 6a37ecd9a
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Thu Jul 23 13:00:45 2026 -0700
Merge pull request 'Fix PostgreSQL 19 GeoJSON output builds on stable 3.3' (!494) from Komzpa/postgis:pr/stable33-pg19-geojson into stable-3.3
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/494
commit 6a37ecd9adcad85bcf84f3ed15a510c6ad3f5487
Author: Regina Obe <lr at pcorp.us>
Date: Thu Jul 3 12:20:34 2025 -0400
Get rid of pg version conditional for geojson so works on PG 19
(cherry picked from commit 02839b684ecd8d555fce6ff21fa7f30533e614d4)
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 8b4883ec5..71536cf63 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -100,7 +100,7 @@ steps:
upgradecheck-pg11:
image: *test-image
- depends_on: build-pg11
+ depends_on: installcheck-pg11
environment:
PGVER: 11
commands:
@@ -111,7 +111,7 @@ steps:
upgradecheck-pg15:
image: *test-image
- depends_on: build-pg15
+ depends_on: installcheck-pg15
environment:
PGVER: 15
commands:
diff --git a/NEWS b/NEWS
index faa044b1d..dedcfa402 100644
--- a/NEWS
+++ b/NEWS
@@ -23,6 +23,7 @@ PostGIS 3.3.11
GDAL compatibility (Darafei Praliaskouski)
- GH-895, Qualify pg_class lookup during SRID/PROJ validation
+ - Fix PostgreSQL 19 GeoJSON output builds (Regina Obe)
- GH-897, [topology] Harden topology helper functions and
maintenance SQL against identifier, tolerance, bigint, and cleanup
regressions (Darafei Praliaskouski)
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index 31b097fd7..1e84ccaca 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -32,22 +32,20 @@
#include "lwgeom_log.h"
#include "liblwgeom.h"
-#if POSTGIS_PGSQL_VERSION < 180
-typedef enum /* type categories for datum_to_json */
+typedef enum /* type categories for datum_to_json */
- JSONTYPE_NULL, /* null, so we didn't bother to identify */
- JSONTYPE_BOOL, /* boolean (built-in types only) */
- JSONTYPE_NUMERIC, /* numeric (ditto) */
- JSONTYPE_DATE, /* we use special formatting for datetimes */
+ JSONTYPE_NULL, /* null, so we didn't bother to identify */
+ JSONTYPE_BOOL, /* boolean (built-in types only) */
+ JSONTYPE_NUMERIC, /* numeric (ditto) */
+ JSONTYPE_DATE, /* we use special formatting for datetimes */
JSONTYPE_TIMESTAMP,
JSONTYPE_TIMESTAMPTZ,
- JSONTYPE_JSON, /* JSON itself (and JSONB) */
- JSONTYPE_ARRAY, /* array */
- JSONTYPE_COMPOSITE, /* composite */
- JSONTYPE_CAST, /* something with an explicit cast to JSON */
- JSONTYPE_OTHER /* all else */
+ JSONTYPE_JSON, /* JSON itself (and JSONB) */
+ JSONTYPE_ARRAY, /* array */
+ JSONTYPE_COMPOSITE, /* composite */
+ JSONTYPE_CAST, /* something with an explicit cast to JSON */
+ JSONTYPE_OTHER /* all else */
} JsonTypeCategory;
-#endif
static void array_dim_to_json(StringInfo result, int dim, int ndims, int *dims,
Datum *vals, bool *nulls, int *valcount,
@@ -65,14 +63,12 @@ static void composite_to_geojson(FunctionCallInfo fcinfo,
Oid geog_oid);
static void composite_to_json(Datum composite, StringInfo result,
bool use_line_feeds);
-static void datum_to_json(Datum val, bool is_null, StringInfo result,
- JsonTypeCategory tcategory, Oid outfuncoid,
- bool key_scalar);
+static void
+datum_to_json(Datum val, bool is_null, StringInfo result, JsonTypeCategory tcategory, Oid outfuncoid, bool key_scalar);
static void json_categorize_type(Oid typoid,
JsonTypeCategory *tcategory,
Oid *outfuncoid);
-#endif
static char * postgis_JsonEncodeDateTime(char *buf, Datum value, Oid typid);
static int postgis_time2tm(TimeADT time, struct pg_tm *tm, fsec_t *fsec);
static int postgis_timetz2tm(TimeTzADT *time, struct pg_tm *tm, fsec_t *fsec, int *tzp);
@@ -244,7 +240,6 @@ composite_to_geojson(FunctionCallInfo fcinfo,
* output function OID. If the returned category is JSONTYPE_CAST, we
* return the OID of the type->JSON cast function instead.
static void
@@ -337,7 +332,6 @@ json_categorize_type(Oid typoid,
break;
-#endif
* Turn a Datum into JSON text, appending the string to "result".
Summary of changes:
.woodpecker/regress.yml | 4 ++--
NEWS | 1 +
postgis/lwgeom_out_geojson.c | 32 +++++++++++++-------------------
3 files changed, 16 insertions(+), 21 deletions(-)
hooks/post-receive
