[PostGIS] #6106: berrie64 fails being unable to generate examples in the manual
PostGIS trac at osgeo.org
Thu Jul 23 21:22:55 PDT 2026
 Reporter:  strk          |      Owner:  komzpa
     Type:  defect        |     Status:  assigned
 Priority:  high          |  Milestone:  PostGIS 3.7.0
Component:  QA/buildbots  |    Version:  master
 Keywords:  berrie        |
 From
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64/8035/console:
 04:05:47 ../utils/postgis_exampletest.py --run --database
 postgis_exampletest ../doc/postgis-out.xml \
 04:05:47        --keep-going \
 04:05:47        --render-dir
 /home/jenkins/workspace/PostGIS_Worker_Run/label/berrie64/dcae3e42e53bec92c265846f8656997afed5b35e/doc/html/images
 /visual-examples
 04:05:50 Manual example test environment check failed: PROJ grid
 au_icsm_GDA94_GDA2020_conformal_and_distortion.tif
 04:05:50 Install the PROJ data package containing
 au_icsm_GDA94_GDA2020_conformal_and_distortion.tif, or fetch it with
 projsync so the PostgreSQL/PostGIS PROJ search path can find it.
 04:05:50 psql failed for query:
 04:05:50 SELECT ST_AsText(ST_TransformPipeline(
 04:05:50     'SRID=4939;POINT(143.0 -37.0)'::geometry,
 04:05:50     'urn:ogc:def:coordinateOperation:EPSG::8447'
 04:05:50 ))
 04:05:50 ERROR:  transform: No inverse operation (4098)
 04:05:50 CONTEXT:  SQL function "st_transformpipeline" statement 1
 04:05:50
 04:05:51 make[2]: *** [Makefile:172: exampletest-run] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6106>
