[SCM] PostGIS branch master updated. 3.7.0beta1-18-gf6b40a316
Fri Jul 24 09:05:50 PDT 2026
the project "PostGIS".
       via  f6b40a31677b233a80e7543086b8267089c11f62 (commit)
       via  db2f494af5ce8dbc4f3b474cfe60c19bb0ec7397 (commit)
      from  1ba934e1f8a48188d39f88757379885e4ee3ebc5 (commit)
revisions in full, below.
commit f6b40a31677b233a80e7543086b8267089c11f62
Merge: 1ba934e1f db2f494af
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Fri Jul 24 09:05:49 2026 -0700
    Merge pull request 'ci: harden status page publishing and refresh' (!503) from Komzpa/postgis:ci/atomic-status-publish-20260724 into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/503
commit db2f494af5ce8dbc4f3b474cfe60c19bb0ec7397
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Jul 24 19:16:53 2026 +0400
diff --git a/utils/README b/utils/README
index 9bf58d10d..b2a1f876b 100644
--- a/utils/README
+++ b/utils/README
@@ -39,10 +39,17 @@ ci-status.py
 		python3 utils/ci-status.py --format html --output-dir /var/www/postgis/ci
+	For no-404 live publishing, make the live path a symbolic link to a release
+	directory and switch it with:
+		python3 utils/ci-status.py --format html --atomic-switch --output-dir /var/www/postgis/ci
 	The script writes index.html and status.json atomically, so a publishing
-	job can run periodically without leaving a half-written page behind.  A
-	red CI status is valid page content and does not make HTML generation
-	fail.
+	job can run periodically without leaving a half-written page behind.
+	`--atomic-switch` writes a complete sibling directory first and then
+	atomically replaces the output symlink, so the web server never observes the
+	live CI path as missing during publication.  A red CI status is valid page
+	content and does not make HTML generation fail.
 	Add new CI by adding a check object to utils/ci-status.json.  Retire old
 	CI by changing the check provider to `disabled`, setting `required` to
diff --git a/utils/ci-status.py b/utils/ci-status.py
index c06c99da8..7b12f6ddb 100755
--- a/utils/ci-status.py
+++ b/utils/ci-status.py
@@ -11,6 +11,7 @@ import http.client
 import json
 import os
 import pathlib
+import shutil
 import subprocess
 import sys
 import tempfile
@@ -1549,6 +1550,45 @@ def write_atomic(path, content, mode="w"):
             raise
+def relative_symlink_target(target, link_path):
+    return os.path.relpath(target, start=link_path.parent)
+def write_html_files(data, output_dir):
+    output_dir = pathlib.Path(output_dir)
+    json_text = json.dumps(data, indent=2, sort_keys=True) + "\n"
+    write_atomic(output_dir / "status.json", json_text)
+    write_atomic(output_dir / "index.html", render_html(data))
+def switch_html_output(data, output_dir):
+    output_dir.parent.mkdir(parents=True, exist_ok=True)
+    staging = pathlib.Path(tempfile.mkdtemp(prefix=f".{output_dir.name}.", dir=str(output_dir.parent)))
+    link_tmp = None
+    try:
+        write_html_files(data, staging)
+        has_output = output_dir.exists() or output_dir.is_symlink()
+        if has_output and not output_dir.is_symlink():
+            raise ConfigError(f"{output_dir} must be absent or a symbolic link for --atomic-switch")
+        if has_output:
+            link_fd, link_name = tempfile.mkstemp(prefix=f".{output_dir.name}.link.", dir=str(output_dir.parent))
+            os.close(link_fd)
+            os.unlink(link_name)
+            link_tmp = pathlib.Path(link_name)
+            os.symlink(relative_symlink_target(staging, output_dir), link_tmp)
+            os.replace(link_tmp, output_dir)
+        else:
+            os.replace(staging, output_dir)
+            staging = None
+    except Exception:
+        if link_tmp and (link_tmp.exists() or link_tmp.is_symlink()):
+            link_tmp.unlink()
+        if staging and staging.exists():
+            shutil.rmtree(staging)
+        raise
 def overall_status(branches):
     statuses = [branch["status"] for branch in branches]
     if any(status == FAILURE for status in statuses):
@@ -1778,6 +1818,32 @@ def html_required_failures(branches):
+def html_auto_refresh_script():
+    return """
+<script>
+  const page = document.querySelector("[data-generated-at]");
+  const generatedAt = page ? page.dataset.generatedAt : "";
+  const refresh = async () => {
+    try {
+      const url = new URL("status.json", window.location.href);
+      url.searchParams.set("_", Date.now().toString());
+      const response = await fetch(url, { cache: "no-store" });
+      if (!response.ok) return;
+      const data = await response.json();
+      if (data && data.generated_at && data.generated_at !== generatedAt) {
+        window.location.reload();
+    } catch (error) {
+      // Local file previews and transient publish windows can make fetch fail.
+  window.setInterval(refresh, 60000);
+</script>
 def render_html(data):
     generated = html.escape(data["generated_at"])
     page_status = overall_status(data["branches"])
@@ -2158,7 +2224,7 @@ a:hover {{ color: var(--brand-strong); }}
 </style>
 </head>
 <body>
-<main class="page">
+<main class="page" data-generated-at="{generated}">
 <header class="masthead">
 <div>
 <p class="brand">PostGIS</p>
@@ -2181,16 +2247,17 @@ a:hover {{ color: var(--brand-strong); }}
 </section>
 {''.join(details)}
 </main>
+{html_auto_refresh_script()}
 </body>
 </html>
-def write_html_output(data, output_dir):
-    output_dir = pathlib.Path(output_dir)
-    json_text = json.dumps(data, indent=2, sort_keys=True) + "\n"
-    write_atomic(output_dir / "status.json", json_text)
-    write_atomic(output_dir / "index.html", render_html(data))
+def write_html_output(data, output_dir, atomic_switch=False):
+    if atomic_switch:
+        switch_html_output(data, output_dir)
+    else:
+        write_html_files(data, output_dir)
 def load_config(path):
@@ -2223,6 +2290,11 @@ def parse_args(argv):
     parser.add_argument("--config", default=str(pathlib.Path(__file__).with_suffix(".json")))
     parser.add_argument("--format", choices=("terminal", "json", "html"), default="terminal", help="output format")
     parser.add_argument("--output-dir", default="ci-status")
+    parser.add_argument(
+        "--atomic-switch",
+        action="store_true",
+        help="write HTML output to a complete staging directory, then atomically switch the output symlink",
     parser.add_argument("--json", action="store_true", help=argparse.SUPPRESS)
     parser.add_argument("--no-color", action="store_true")
     parser.add_argument("--verbose", action="store_true", help="show all checks, including passing checks")
@@ -2246,7 +2318,7 @@ def main(argv=None):
         config = load_config(args.config)
         data = collect_status(config, args.branch, args.include_eol, args.timeout)
         if args.format == "html":
-            write_html_output(data, args.output_dir)
+            write_html_output(data, args.output_dir, atomic_switch=args.atomic_switch)
             return 0
         if args.format == "json":
             print(json.dumps(data, indent=2, sort_keys=True))
diff --git a/utils/test_ci_status.py b/utils/test_ci_status.py
index e27147347..0953686a8 100644
--- a/utils/test_ci_status.py
+++ b/utils/test_ci_status.py
@@ -1,6 +1,7 @@
 import importlib.util
 import json
 import pathlib
+import tempfile
 import unittest
 from unittest import mock
@@ -25,6 +26,22 @@ def check(name, status, *, required=True, url=None):
     return result
+def html_data():
+    return {
+        "generated_at": "2026-07-24T15:20:00+00:00",
+        "branches": [
+                "name": "master",
+                "label": "master",
+                "status": CI_STATUS.SUCCESS,
+                "checks": [
+                    check("Synthetic CI", CI_STATUS.SUCCESS),
 class RequiredFailureHtmlTest(unittest.TestCase):
     def test_woodpecker_covers_supported_release_branches(self):
         config = json.loads(MODULE_PATH.with_suffix(".json").read_text(encoding="utf-8"))
@@ -79,6 +96,46 @@ class RequiredFailureHtmlTest(unittest.TestCase):
         self.assertEqual(CI_STATUS.SUCCESS, passed["stale_base_status"])
         self.assertEqual("Stale passed", passed["status_label"])
+    def test_write_html_output_can_atomically_switch_symlink(self):
+        with tempfile.TemporaryDirectory() as tmpdir:
+            root = pathlib.Path(tmpdir)
+            old_release = root / "ci-old"
+            old_release.mkdir()
+            (old_release / "index.html").write_text("old page", encoding="utf-8")
+            live = root / "ci"
+            live.symlink_to(old_release.name)
+            CI_STATUS.write_html_output(html_data(), live, atomic_switch=True)
+            self.assertTrue(live.is_symlink())
+            self.assertTrue(old_release.exists())
+            self.assertEqual("old page", (old_release / "index.html").read_text(encoding="utf-8"))
+            self.assertIn("CI status", (live / "index.html").read_text(encoding="utf-8"))
+            status = json.loads((live / "status.json").read_text(encoding="utf-8"))
+            self.assertEqual("2026-07-24T15:20:00+00:00", status["generated_at"])
+    def test_write_html_output_atomic_switch_rejects_real_directory(self):
+            live = pathlib.Path(tmpdir) / "ci"
+            live.mkdir()
+            (live / "index.html").write_text("old page", encoding="utf-8")
+            with self.assertRaisesRegex(CI_STATUS.ConfigError, "symbolic link"):
+            self.assertEqual("old page", (live / "index.html").read_text(encoding="utf-8"))
+    def test_rendered_html_refreshes_status_json_without_breaking_on_errors(self):
+        rendered = CI_STATUS.render_html(html_data())
+        self.assertIn('data-generated-at="2026-07-24T15:20:00+00:00"', rendered)
+        self.assertIn('new URL("status.json", window.location.href)', rendered)
+        self.assertIn('fetch(url, { cache: "no-store" })', rendered)
+        self.assertIn("if (!response.ok) return;", rendered)
+        self.assertIn("window.location.reload();", rendered)
+        self.assertIn("catch (error)", rendered)
+        self.assertIn("Local file previews", rendered)
     def test_jenkins_matrix_failure_names_failing_axis(self):
         check_config = {
             "name": "Jenkins / Winnie",
Summary of changes:
 utils/README            | 13 ++++++--
 utils/ci-status.py      | 86 +++++++++++++++++++++++++++++++++++++++++++++----
 utils/test_ci_status.py | 57 ++++++++++++++++++++++++++++++++
 3 files changed, 146 insertions(+), 10 deletions(-)
hooks/post-receive
