[SCM] PostGIS branch master updated. 3.7.0beta1-69-g031ce41879
git at osgeo.org
git at osgeo.org
Mon Jul 27 11:11:08 PDT 2026
the project "PostGIS".
via 031ce41879e6635874edcfdcc925da55ae5c76fc (commit)
via c1f681540c2e20189815f6eabbc6edfb31bf3b1f (commit)
from bd7aa23a5c9e357f4b5041fc5498a4f015478f92 (commit)
revisions in full, below.
commit 031ce41879e6635874edcfdcc925da55ae5c76fc
Merge: bd7aa23a5c c1f681540c
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 27 11:11:07 2026 -0700
Merge pull request 'Harden GSERIALIZED readers against malformed payload counts' (!522) from Komzpa/postgis:codex/gserialized-reader-harden-20260726 into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/522
commit c1f681540c2e20189815f6eabbc6edfb31bf3b1f
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jul 26 14:43:56 2026 +0400
Harden GSERIALIZED payload readers
diff --git a/NEWS b/NEWS
index 6d3526076a..d1961a513f 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,8 @@ These are only changes since 3.7.0beta1.
spend unbounded time on them (Darafei Praliaskouski)
- GT-484, Use column-level SELECT privileges for metadata views
(Arthur Bazin)
+ - GT-521, Reject malformed GSERIALIZED payload counts before deserializing
+ geometry data (Darafei Praliaskouski)
* Enhancements *
diff --git a/liblwgeom/cunit/cu_gserialized1.c b/liblwgeom/cunit/cu_gserialized1.c
index 545b83a5bb..2c215f1e22 100644
--- a/liblwgeom/cunit/cu_gserialized1.c
+++ b/liblwgeom/cunit/cu_gserialized1.c
@@ -1228,6 +1228,47 @@ test_gserialized1_peek_first_point(void)
CU_ASSERT(peek1_point_helper("POLYGON((0 0, 1 1, 1 0, 0 0))", &p) == LW_FAILURE);
+static void
+assert_gserialized1_malformed_rejected(GSERIALIZED *g)
+ LWGEOM *geom;
+ GBOX box;
+ POINT4D point;
+ memset(&box, 0, sizeof(box));
+ memset(&point, 0, sizeof(point));
+ cu_error_msg_reset();
+ geom = lwgeom_from_gserialized1(g);
+ CU_ASSERT_PTR_NULL(geom);
+ CU_ASSERT_NOT_EQUAL(strlen(cu_error_msg), 0);
+ CU_ASSERT_TRUE(gserialized1_is_empty(g));
+ CU_ASSERT_EQUAL(gserialized1_peek_gbox_p(g, &box), LW_FAILURE);
+ CU_ASSERT_EQUAL(gserialized1_peek_first_point(g, &point), LW_FAILURE);
+static void
+test_gserialized1_malformed_declared_size(void)
+ LWGEOM *lwgeom = lwgeom_from_wkt("POINT(1 1)", LW_PARSER_CHECK_NONE);
+ GSERIALIZED *g;
+ size_t size = 0;
+ CU_ASSERT_PTR_NOT_NULL_FATAL(lwgeom);
+ g = gserialized1_from_lwgeom(lwgeom, &size);
+ CU_ASSERT_PTR_NOT_NULL_FATAL(g);
+ LWSIZE_SET(g->size, 0);
+ assert_gserialized1_malformed_rejected(g);
+ LWSIZE_SET(g->size, offsetof(GSERIALIZED, data) - 1);
+ lwfree(g);
+ lwgeom_free(lwgeom);
** Used by test harness to register the tests in this file.
@@ -1261,4 +1302,5 @@ void gserialized1_suite_setup(void)
PG_ADD_TEST(suite, test_gbox_same_2d);
PG_ADD_TEST(suite, test_signum_macro);
PG_ADD_TEST(suite, test_gserialized1_peek_first_point);
+ PG_ADD_TEST(suite, test_gserialized1_malformed_declared_size);
diff --git a/liblwgeom/cunit/cu_gserialized2.c b/liblwgeom/cunit/cu_gserialized2.c
index dd32828c75..6ffdc5badc 100644
--- a/liblwgeom/cunit/cu_gserialized2.c
+++ b/liblwgeom/cunit/cu_gserialized2.c
@@ -509,6 +509,133 @@ test_gserialized2_peek_first_point(void)
CU_ASSERT(peek2_point_helper("POLYGON((0 0, 1 1, 1 0, 0 0))", &p) == LW_FAILURE);
+static GSERIALIZED *
+gserialized2_from_hexbytes(const char *hex)
+ uint8_t *bytes;
+ size_t size;
+ GSERIALIZED *g;
+ size = strlen(hex) / 2;
+ bytes = bytes_from_hexbytes(hex, strlen(hex));
+ g = lwalloc(size);
+ memcpy(g, bytes, size);
+ lwfree(bytes);
+ return g;
+static void
+test_gserialized2_malformed_collection_count(void)
+ const char *hex =
+ "8001000000000044000000000000803f0000000000000040"
+ "070000000200000001000000f03f000000000000f03f";
+ GSERIALIZED *g = gserialized2_from_hexbytes(hex);
+ LWGEOM *geom;
+ geom = lwgeom_from_gserialized2(g);
+ lwfree(g);
+static void
+assert_gserialized2_malformed_rejected(GSERIALIZED *g)
+ LWGEOM *geom;
+ GBOX box;
+ POINT4D point;
+ CU_ASSERT_TRUE(gserialized2_is_empty(g));
+ CU_ASSERT_EQUAL(gserialized2_peek_gbox_p(g, &box), LW_FAILURE);
+ CU_ASSERT_EQUAL(gserialized2_peek_first_point(g, &point), LW_FAILURE);
+static void
+test_gserialized2_malformed_declared_size(void)
+ const char *declared_size_0 =
+ "0000000000000044000000000000803f0000000000000040"
+ const char *declared_size_23 =
+ "5c00000000000044000000000000803f0000000000000040"
+ GSERIALIZED *g;
+ g = gserialized2_from_hexbytes(declared_size_0);
+ assert_gserialized2_malformed_rejected(g);
+ lwfree(g);
+ g = gserialized2_from_hexbytes(declared_size_23);
+ lwfree(g);
+static void
+test_gserialized2_malformed_short_allocation(void)
+#if defined(POSTGIS_ASAN_ALLOCATOR_SIZE)
+ const char *hex = "8001000000000044";
+ uint8_t *bytes = bytes_from_hexbytes(hex, strlen(hex));
+ GSERIALIZED *g = malloc(strlen(hex) / 2);
+ memcpy(g, bytes, strlen(hex) / 2);
+ free(g);
+ lwfree(bytes);
+#else
+ CU_PASS("shorter-than-declared allocation validation requires AddressSanitizer allocation metadata");
+#endif
+static void
+test_gserialized2_wkb_roundtrip_float_rounded_box(void)
+ const char *hex =
+ "0102000000030000000000000000000000000000f03f0000000000000040"
+ "0101000000000000000f03f0000000000000040000000000000f03f";
+ size_t wkb_size = strlen(hex) / 2;
+ uint8_t *wkb = bytes_from_hexbytes(hex, strlen(hex));
+ LWGEOM *input = lwgeom_from_wkb(wkb, wkb_size, LW_PARSER_CHECK_NONE);
+ GSERIALIZED *serialized;
+ LWGEOM *roundtrip;
+ size_t serialized_size = 0;
+ GBOX input_box;
+ GBOX roundtrip_box;
+ CU_ASSERT_PTR_NOT_NULL_FATAL(input);
+ serialized = gserialized2_from_lwgeom(input, &serialized_size);
+ CU_ASSERT_PTR_NOT_NULL_FATAL(serialized);
+ roundtrip = lwgeom_from_gserialized2(serialized);
+ CU_ASSERT_PTR_NOT_NULL_FATAL(roundtrip);
+ CU_ASSERT_EQUAL(serialized_size, LWSIZE_GET(serialized->size));
+ CU_ASSERT_PTR_NOT_NULL(input->bbox);
+ CU_ASSERT_PTR_NOT_NULL(roundtrip->bbox);
+ CU_ASSERT_FALSE(gbox_same(input->bbox, roundtrip->bbox));
+ CU_ASSERT_EQUAL(lwgeom_calculate_gbox_cartesian(input, &input_box), LW_SUCCESS);
+ CU_ASSERT_EQUAL(lwgeom_calculate_gbox_cartesian(roundtrip, &roundtrip_box), LW_SUCCESS);
+ CU_ASSERT_TRUE(gbox_same(&input_box, &roundtrip_box));
+ lwgeom_free(input);
+ lwgeom_free(roundtrip);
+ lwfree(serialized);
+ lwfree(wkb);
@@ -527,4 +654,8 @@ void gserialized2_suite_setup(void)
PG_ADD_TEST(suite, test_gserialized2_peek_gbox_p_fails_for_unsupported_cases);
PG_ADD_TEST(suite, test_gserialized2_extended_flags);
PG_ADD_TEST(suite, test_gserialized2_peek_first_point);
+ PG_ADD_TEST(suite, test_gserialized2_malformed_collection_count);
+ PG_ADD_TEST(suite, test_gserialized2_malformed_declared_size);
+ PG_ADD_TEST(suite, test_gserialized2_malformed_short_allocation);
+ PG_ADD_TEST(suite, test_gserialized2_wkb_roundtrip_float_rounded_box);
diff --git a/liblwgeom/gserialized1.c b/liblwgeom/gserialized1.c
index 6a34cf1f6b..4528a790f2 100644
--- a/liblwgeom/gserialized1.c
+++ b/liblwgeom/gserialized1.c
@@ -30,13 +30,37 @@
#include "gserialized1.h"
#include <stddef.h>
+#if defined(__has_feature)
+#if __has_feature(address_sanitizer)
+#define POSTGIS_ASAN_ALLOCATOR_SIZE 1
+#endif
+#endif
+#if defined(__SANITIZE_ADDRESS__)
+#endif
+#include <sanitizer/allocator_interface.h>
+#endif
* GSERIALIZED metadata utility functions.
static int gserialized1_read_gbox_p(const GSERIALIZED *g, GBOX *gbox);
+static int gserialized1_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end);
+static int gserialized1_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size);
+static size_t
+gserialized1_buffer_size(const GSERIALIZED *g)
+ size_t gsize = LWSIZE_GET(g->size);
+ size_t allocated_size = __sanitizer_get_allocated_size(g);
+ if (allocated_size > 0 && allocated_size < gsize)
+ return allocated_size;
+#endif
+ return gsize;
lwflags_t gserialized1_get_lwflags(const GSERIALIZED *g)
@@ -132,6 +156,13 @@ static uint32_t gserialized1_header_size(const GSERIALIZED *gser)
uint32_t gserialized1_get_type(const GSERIALIZED *g)
uint32_t *ptr;
+ size_t hsz = gserialized1_header_size(g);
+ size_t gsize = gserialized1_buffer_size(g);
+ if (gsize < hsz + sizeof(uint32_t))
+ lwerror("%s: GSERIALIZED too small for geometry type", __func__);
+ return 0;
ptr = (uint32_t*)(g->data);
if ( G1FLAGS_GET_BBOX(g->gflags) )
@@ -142,19 +173,19 @@ uint32_t gserialized1_get_type(const GSERIALIZED *g)
int32_t gserialized1_get_srid(const GSERIALIZED *s)
- int32_t srid = 0;
- srid = srid | (s->srid[0] << 16);
- srid = srid | (s->srid[1] << 8);
- srid = srid | s->srid[2];
- /* Only the first 21 bits are set. Slide up and back to pull
- the negative bits down, if we need them. */
- srid = (srid<<11)>>11;
+ uint32_t srid = 0;
+ srid = srid | ((uint32_t)s->srid[0] << 16);
+ srid = srid | ((uint32_t)s->srid[1] << 8);
+ srid = srid | (uint32_t)s->srid[2];
+ /* Only the first 21 bits are set. Sign-extend without signed shift UB. */
+ if (srid & 0x00100000)
+ srid |= 0xFFE00000;
/* 0 is our internal unknown value. We'll map back and forth here for now */
if ( srid == 0 )
return SRID_UNKNOWN;
else
- return srid;
+ return (int32_t)srid;
void gserialized1_set_srid(GSERIALIZED *s, int32_t srid)
@@ -173,6 +204,204 @@ void gserialized1_set_srid(GSERIALIZED *s, int32_t srid)
s->srid[2] = (srid & 0x000000FF);
+static int
+gserialized1_range_available(const uint8_t *ptr, const uint8_t *end, size_t len)
+ return ptr <= end && len <= (size_t)(end - ptr);
+static int
+gserialized1_checked_mul(size_t a, size_t b, size_t *out)
+ if (a != 0 && b > SIZE_MAX / a)
+ return LW_FAILURE;
+ *out = a * b;
+ return LW_SUCCESS;
+static int
+gserialized1_checked_add(size_t a, size_t b, size_t *out)
+ if (b > SIZE_MAX - a)
+ *out = a + b;
+static int
+gserialized1_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end)
+ size_t hsz;
+ size_t gsize;
+ if (!g)
+ hsz = gserialized1_header_size(g);
+ gsize = gserialized1_buffer_size(g);
+ if (gsize < hsz)
+ if (start)
+ *start = (uint8_t *)g + hsz;
+ if (end)
+ *end = (uint8_t *)g + gsize;
+static uint32_t
+gserialized1_read_uint32_checked(uint8_t *ptr, uint8_t *end, const char *field)
+ uint32_t value = 0;
+ if (!gserialized1_range_available(ptr, end, sizeof(uint32_t)))
+ lwerror("%s: GSERIALIZED too small for %s", __func__, field);
+ return 0;
+ memcpy(&value, ptr, sizeof(uint32_t));
+ return value;
+static int
+gserialized1_pointarray_payload_size(uint32_t npoints, lwflags_t lwflags, size_t *nbytes)
+ if (gserialized1_checked_mul((size_t)npoints, sizeof(double) * FLAGS_NDIMS(lwflags), nbytes) == LW_FAILURE)
+ lwerror("%s: GSERIALIZED point count overflows payload size", __func__);
+static int
+gserialized1_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size)
+ uint32_t type, count;
+ size_t consumed = 0;
+ if (!gserialized1_range_available(data_ptr, data_end, 2 * sizeof(uint32_t)))
+ lwerror("%s: GSERIALIZED geometry payload is too short", __func__);
+ type = gserialized1_read_uint32_checked(data_ptr, data_end, "geometry type");
+ count = gserialized1_read_uint32_checked(data_ptr + sizeof(uint32_t), data_end, "geometry count");
+ switch (type)
+ case POINTTYPE:
+ if (count > 1)
+ lwerror("%s: invalid point count %u", __func__, count);
+ /* fall through */
+ case LINETYPE:
+ case CIRCSTRINGTYPE:
+ case TRIANGLETYPE: {
+ size_t point_bytes;
+ if (gserialized1_pointarray_payload_size(count, lwflags, &point_bytes) == LW_FAILURE)
+ consumed = 2 * sizeof(uint32_t) + point_bytes;
+ break;
+ case POLYGONTYPE: {
+ size_t ring_counts_size, ring_counts_padded_size, point_bytes_sum = 0;
+ uint8_t *ring_counts = data_ptr + 2 * sizeof(uint32_t);
+ uint32_t i;
+ if (gserialized1_checked_mul((size_t)count, sizeof(uint32_t), &ring_counts_size) == LW_FAILURE)
+ lwerror("%s: GSERIALIZED ring count overflows payload size", __func__);
+ ring_counts_padded_size = ring_counts_size + ((count % 2) ? sizeof(uint32_t) : 0);
+ if (!gserialized1_range_available(ring_counts, data_end, ring_counts_padded_size))
+ lwerror("%s: GSERIALIZED polygon ring table exceeds payload size", __func__);
+ for (i = 0; i < count; i++)
+ size_t ring_point_bytes;
+ uint32_t npoints = gserialized1_read_uint32_checked(
+ ring_counts + i * sizeof(uint32_t), data_end, "ring point count");
+ if (gserialized1_pointarray_payload_size(npoints, lwflags, &ring_point_bytes) == LW_FAILURE)
+ if (gserialized1_checked_add(point_bytes_sum, ring_point_bytes, &point_bytes_sum) == LW_FAILURE)
+ lwerror("%s: GSERIALIZED polygon coordinate size overflows", __func__);
+ consumed = 2 * sizeof(uint32_t) + ring_counts_padded_size;
+ if (gserialized1_checked_add(consumed, point_bytes_sum, &consumed) == LW_FAILURE)
+ lwerror("%s: GSERIALIZED polygon size overflows", __func__);
+ break;
+ case MULTIPOINTTYPE:
+ case MULTILINETYPE:
+ case MULTIPOLYGONTYPE:
+ case COMPOUNDTYPE:
+ case CURVEPOLYTYPE:
+ case MULTICURVETYPE:
+ case MULTISURFACETYPE:
+ case POLYHEDRALSURFACETYPE:
+ case TINTYPE:
+ case COLLECTIONTYPE: {
+ uint32_t i;
+ uint8_t *subgeom_ptr = data_ptr + 2 * sizeof(uint32_t);
+ lwflags_t subflags = lwflags;
+ FLAGS_SET_BBOX(subflags, 0);
+ size_t subsize = 0;
+ uint32_t subtype =
+ gserialized1_read_uint32_checked(subgeom_ptr, data_end, "collection subtype");
+ if (!lwcollection_allows_subtype(type, subtype))
+ lwerror("Invalid subtype (%s) for collection type (%s)",
+ lwtype_name(subtype),
+ lwtype_name(type));
+ if (gserialized1_validate_geometry_buffer(subgeom_ptr, data_end, subflags, &subsize) ==
+ LW_FAILURE)
+ if (subsize == 0)
+ lwerror("%s: GSERIALIZED collection member has zero size", __func__);
+ subgeom_ptr += subsize;
+ consumed = (size_t)(subgeom_ptr - data_ptr);
+ break;
+ default:
+ lwerror("Unknown geometry type: %d - %s", type, lwtype_name(type));
+ if (!gserialized1_range_available(data_ptr, data_end, consumed))
+ lwerror("%s: GSERIALIZED geometry payload exceeds declared size", __func__);
+ if (size)
+ *size = consumed;
static size_t gserialized1_is_empty_recurse(const uint8_t *p, int *isempty);
@@ -203,13 +432,17 @@ static size_t gserialized1_is_empty_recurse(const uint8_t *p, int *isempty)
int gserialized1_is_empty(const GSERIALIZED *g)
- uint8_t *p = (uint8_t*)g;
+ uint8_t *p, *end;
int isempty = 0;
assert(g);
- p += 8; /* Skip varhdr and srid/flags */
- if(gserialized1_has_bbox(g))
- p += gserialized1_box_size(g); /* Skip the box */
+ if (gserialized1_payload_bounds(g, &p, &end) == LW_FAILURE)
+ lwerror("%s: invalid GSERIALIZED header size", __func__);
+ return LW_TRUE;
+ if (gserialized1_validate_geometry_buffer(p, end, gserialized1_get_lwflags(g), NULL) == LW_FAILURE)
+ return LW_TRUE;
gserialized1_is_empty_recurse(p, &isempty);
return isempty;
@@ -254,6 +487,8 @@ int gserialized1_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
/* Null input! */
if ( ! ( g && gbox ) ) return LW_FAILURE;
+ if (gserialized1_buffer_size(g) < offsetof(GSERIALIZED, data) + gserialized1_box_size(g))
/* Initialize the flags on the box */
gbox->flags = gserialized1_get_lwflags(g);
@@ -298,7 +533,16 @@ int gserialized1_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
int
gserialized1_peek_gbox_p(const GSERIALIZED *g, GBOX *gbox)
- uint32_t type = gserialized1_get_type(g);
+ uint32_t type;
+ uint8_t *geometry_start = NULL;
+ uint8_t *geometry_end = NULL;
+ if (gserialized1_payload_bounds(g, &geometry_start, &geometry_end) == LW_FAILURE)
+ if (gserialized1_validate_geometry_buffer(geometry_start, geometry_end, gserialized1_get_lwflags(g), NULL) ==
+ LW_FAILURE)
+ type = gserialized1_get_type(g);
/* Peeking doesn't help if you already have a box or are geodetic */
if ( G1FLAGS_GET_GEODETIC(g->gflags) || G1FLAGS_GET_BBOX(g->gflags) )
@@ -491,11 +735,14 @@ gserialized1_copy_point(double *dptr, lwflags_t flags, POINT4D *out_point)
int
gserialized1_peek_first_point(const GSERIALIZED *g, POINT4D *out_point)
- uint8_t *geometry_start = ((uint8_t *)g->data);
- if (gserialized1_has_bbox(g))
- geometry_start += gserialized1_box_size(g);
+ LW_FAILURE)
uint32_t isEmpty = (((uint32_t *)geometry_start)[1]) == 0;
if (isEmpty)
@@ -1454,14 +1701,19 @@ LWGEOM* lwgeom_from_gserialized1(const GSERIALIZED *g)
assert(g);
srid = gserialized1_get_srid(g);
- lwtype = gserialized1_get_type(g);
lwflags = gserialized1_get_lwflags(g);
- LWDEBUGF(4, "Got type %d (%s), srid=%d", lwtype, lwtype_name(lwtype), srid);
+ if (gserialized1_payload_bounds(g, &data_ptr, NULL) == LW_FAILURE)
+ return NULL;
+ data_ptr, (uint8_t *)g + gserialized1_buffer_size(g), lwflags, NULL) == LW_FAILURE)
+ return NULL;
+ lwtype = gserialized1_get_type(g);
- data_ptr = (uint8_t*)g->data;
- if (FLAGS_GET_BBOX(lwflags))
- data_ptr += gbox_serialized_size(lwflags);
+ LWDEBUGF(4, "Got type %d (%s), srid=%d", lwtype, lwtype_name(lwtype), srid);
lwgeom = lwgeom_from_gserialized1_buffer(data_ptr, lwflags, &size);
@@ -1495,6 +1747,8 @@ const float * gserialized1_get_float_box_p(const GSERIALIZED *g, size_t *ndims)
*ndims = G1FLAGS_NDIMS_BOX(g->gflags);
if (!g) return NULL;
if (!G1FLAGS_GET_BBOX(g->gflags)) return NULL;
+ return NULL;
return (const float *)(g->data);
@@ -1604,4 +1858,3 @@ GSERIALIZED* gserialized1_drop_gbox(GSERIALIZED *g)
return g_out;
diff --git a/liblwgeom/gserialized2.c b/liblwgeom/gserialized2.c
index 08962ae876..813098c77a 100644
--- a/liblwgeom/gserialized2.c
+++ b/liblwgeom/gserialized2.c
@@ -48,18 +48,43 @@
#include "gserialized2.h"
#include <stddef.h>
+#endif
+#endif
+#endif
+#endif
static int gserialized2_read_gbox_p(const GSERIALIZED *g, GBOX *gbox);
+static int gserialized2_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end);
+static int gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size);
+static size_t
+gserialized2_buffer_size(const GSERIALIZED *g)
+#endif
+ return gsize;
lwflags_t gserialized2_get_lwflags(const GSERIALIZED *g)
lwflags_t lwflags = 0;
uint8_t gflags = g->gflags;
+ size_t gsize = gserialized2_buffer_size(g);
FLAGS_SET_Z(lwflags, G2FLAGS_GET_Z(gflags));
FLAGS_SET_M(lwflags, G2FLAGS_GET_M(gflags));
FLAGS_SET_BBOX(lwflags, G2FLAGS_GET_BBOX(gflags));
@@ -67,6 +92,11 @@ lwflags_t gserialized2_get_lwflags(const GSERIALIZED *g)
if (G2FLAGS_GET_EXTENDED(gflags))
uint64_t xflags = 0;
+ if (gsize < offsetof(GSERIALIZED, data) + sizeof(uint64_t))
+ lwerror("%s: GSERIALIZED too small for extended flags", __func__);
+ return lwflags;
memcpy(&xflags, g->data, sizeof(uint64_t));
FLAGS_SET_SOLID(lwflags, xflags & G2FLAG_X_SOLID);
@@ -185,24 +215,31 @@ uint32_t gserialized2_max_header_size(void)
uint32_t gserialized2_get_type(const GSERIALIZED *g)
uint8_t *ptr = gserialized2_get_geometry_p(g);
+ size_t hsz = gserialized2_header_size(g);
+ return 0;
return *((uint32_t*)(ptr));
int32_t gserialized2_get_srid(const GSERIALIZED *g)
- int32_t srid = 0;
- srid = srid | (g->srid[0] << 16);
- srid = srid | (g->srid[1] << 8);
- srid = srid | (g->srid[2]);
+ srid = srid | ((uint32_t)g->srid[0] << 16);
+ srid = srid | ((uint32_t)g->srid[1] << 8);
+ srid = srid | (uint32_t)g->srid[2];
if (srid == 0)
else
- return srid;
void gserialized2_set_srid(GSERIALIZED *g, int32_t srid)
@@ -221,6 +258,235 @@ void gserialized2_set_srid(GSERIALIZED *g, int32_t srid)
g->srid[2] = (srid & 0x000000FF);
+static int
+gserialized2_range_available(const uint8_t *ptr, const uint8_t *end, size_t len)
+static int
+gserialized2_checked_mul(size_t a, size_t b, size_t *out)
+ *out = a * b;
+static int
+gserialized2_checked_add(size_t a, size_t b, size_t *out)
+ *out = a + b;
+static int
+gserialized2_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end)
+ size_t hsz;
+ size_t gsize;
+ if (!g)
+ hsz = gserialized2_header_size(g);
+ gsize = gserialized2_buffer_size(g);
+ if (gsize < hsz)
+ if (start)
+ if (end)
+static uint32_t
+gserialized2_read_uint32_checked(uint8_t *ptr, uint8_t *end, const char *field)
+ if (!gserialized2_range_available(ptr, end, sizeof(uint32_t)))
+ return 0;
+ return value;
+static int
+gserialized2_pointarray_payload_size(uint32_t npoints, lwflags_t lwflags, size_t *nbytes)
+ if (gserialized2_checked_mul((size_t)npoints, sizeof(double) * FLAGS_NDIMS(lwflags), nbytes) == LW_FAILURE)
+static int
+gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size)
+ if (!gserialized2_range_available(data_ptr, data_end, 2 * sizeof(uint32_t)))
+ type = gserialized2_read_uint32_checked(data_ptr, data_end, "geometry type");
+ count = gserialized2_read_uint32_checked(data_ptr + sizeof(uint32_t), data_end, "geometry count");
+ switch (type)
+ case POINTTYPE:
+ if (count > 1)
+ case LINETYPE:
+ if (gserialized2_pointarray_payload_size(count, lwflags, &point_bytes) == LW_FAILURE)
+ break;
+ uint32_t i;
+ if (gserialized2_checked_mul((size_t)count, sizeof(uint32_t), &ring_counts_size) == LW_FAILURE)
+ if (!gserialized2_range_available(ring_counts, data_end, ring_counts_padded_size))
+ uint32_t npoints = gserialized2_read_uint32_checked(
+ if (gserialized2_pointarray_payload_size(npoints, lwflags, &ring_point_bytes) == LW_FAILURE)
+ if (gserialized2_checked_add(point_bytes_sum, ring_point_bytes, &point_bytes_sum) == LW_FAILURE)
+ if (gserialized2_checked_add(consumed, point_bytes_sum, &consumed) == LW_FAILURE)
+ break;
+ case TINTYPE:
+ uint32_t i;
+ gserialized2_read_uint32_checked(subgeom_ptr, data_end, "collection subtype");
+ if (gserialized2_validate_geometry_buffer(subgeom_ptr, data_end, subflags, &subsize) ==
+ LW_FAILURE)
+ if (subsize == 0)
+ break;
+ case NURBSCURVETYPE: {
+ uint32_t nweights, nknots;
+ size_t weight_bytes, knot_bytes, point_bytes;
+ consumed = 6 * sizeof(uint32_t);
+ if (!gserialized2_range_available(data_ptr, data_end, consumed))
+ lwerror("%s: GSERIALIZED NURBS header exceeds payload size", __func__);
+ nweights =
+ gserialized2_read_uint32_checked(data_ptr + 3 * sizeof(uint32_t), data_end, "NURBS weight count");
+ nknots =
+ gserialized2_read_uint32_checked(data_ptr + 4 * sizeof(uint32_t), data_end, "NURBS knot count");
+ if (gserialized2_checked_mul((size_t)nweights, sizeof(double), &weight_bytes) == LW_FAILURE ||
+ gserialized2_checked_mul((size_t)nknots, sizeof(double), &knot_bytes) == LW_FAILURE)
+ lwerror("%s: GSERIALIZED NURBS vector size overflows", __func__);
+ if (gserialized2_checked_add(consumed, weight_bytes, &consumed) == LW_FAILURE ||
+ gserialized2_checked_add(consumed, knot_bytes, &consumed) == LW_FAILURE ||
+ gserialized2_checked_add(consumed, point_bytes, &consumed) == LW_FAILURE)
+ lwerror("%s: GSERIALIZED NURBS size overflows", __func__);
+ break;
+ default:
+ if (size)
+ *size = consumed;
static size_t gserialized2_is_empty_recurse(const uint8_t *p, int *isempty);
@@ -292,7 +558,14 @@ static size_t gserialized2_is_empty_recurse(const uint8_t *p, int *isempty)
int gserialized2_is_empty(const GSERIALIZED *g)
int isempty = LW_TRUE;
- uint8_t *p = gserialized2_get_geometry_p(g);
+ uint8_t *p, *end;
+ if (gserialized2_payload_bounds(g, &p, &end) == LW_FAILURE)
+ return LW_TRUE;
+ if (gserialized2_validate_geometry_buffer(p, end, gserialized2_get_lwflags(g), NULL) == LW_FAILURE)
+ return LW_TRUE;
gserialized2_is_empty_recurse(p, &isempty);
return isempty;
@@ -340,13 +613,21 @@ const float * gserialized2_get_float_box_p(const GSERIALIZED *g, size_t *ndims)
uint8_t *ptr = (uint8_t*)(g->data);
size_t bndims = G2FLAGS_NDIMS_BOX(g->gflags);
+ size_t box_offset = offsetof(GSERIALIZED, data);
+ size_t box_size = gserialized2_box_size(g);
if (ndims)
*ndims = bndims;
/* Advance past optional extended flags */
if (gserialized2_has_extended(g))
ptr += 8;
+ box_offset += 8;
+ if (gserialized2_buffer_size(g) < box_offset + box_size)
+ return NULL;
return (const float *)(ptr);
@@ -366,6 +647,8 @@ int gserialized2_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
int i = 0;
const float *fbox = gserialized2_get_float_box_p(g, NULL);
+ if (!fbox)
gbox->xmin = fbox[i++];
gbox->xmax = fbox[i++];
gbox->ymin = fbox[i++];
@@ -401,10 +684,20 @@ int gserialized2_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
int
gserialized2_peek_gbox_p(const GSERIALIZED *g, GBOX *gbox)
- uint32_t type = gserialized2_get_type(g);
- uint8_t *geometry_start = gserialized2_get_geometry_p(g);
- double *dptr = (double *)(geometry_start);
- int32_t *iptr = (int32_t *)(geometry_start);
+ uint32_t type;
+ double *dptr = NULL;
+ int32_t *iptr = NULL;
+ if (gserialized2_payload_bounds(g, &geometry_start, &geometry_end) == LW_FAILURE)
+ if (gserialized2_validate_geometry_buffer(geometry_start, geometry_end, gserialized2_get_lwflags(g), NULL) ==
+ LW_FAILURE)
+ type = gserialized2_get_type(g);
+ dptr = (double *)(geometry_start);
+ iptr = (int32_t *)(geometry_start);
if (G2FLAGS_GET_GEODETIC(g->gflags) || G2FLAGS_GET_BBOX(g->gflags))
@@ -589,7 +882,14 @@ gserialized2_copy_point(double *dptr, lwflags_t flags, POINT4D *out_point)
int
gserialized2_peek_first_point(const GSERIALIZED *g, POINT4D *out_point)
+ LW_FAILURE)
if (isEmpty)
@@ -2077,22 +2377,19 @@ LWGEOM* lwgeom_from_gserialized2(const GSERIALIZED *g)
assert(g);
srid = gserialized2_get_srid(g);
- lwtype = gserialized2_get_type(g);
lwflags = gserialized2_get_lwflags(g);
- /* Skip optional flags */
- if (G2FLAGS_GET_EXTENDED(g->gflags))
+ if (gserialized2_payload_bounds(g, &data_ptr, NULL) == LW_FAILURE)
- data_ptr += sizeof(uint64_t);
+ return NULL;
+ data_ptr, (uint8_t *)g + gserialized2_buffer_size(g), lwflags, NULL) == LW_FAILURE)
+ return NULL;
+ lwtype = gserialized2_get_type(g);
- /* Skip over optional bounding box */
lwgeom = lwgeom_from_gserialized2_buffer(data_ptr, lwflags, &size, srid);
Summary of changes:
NEWS | 2 +
liblwgeom/cunit/cu_gserialized1.c | 42 +++++
liblwgeom/cunit/cu_gserialized2.c | 131 ++++++++++++++
liblwgeom/gserialized1.c | 301 ++++++++++++++++++++++++++++++---
liblwgeom/gserialized2.c | 347 +++++++++++++++++++++++++++++++++++---
5 files changed, 774 insertions(+), 49 deletions(-)
hooks/post-receive
