[SCM] PostGIS branch stable-3.4 updated. 3.4.6-94-g3d3838b7fd
Mon Jul 27 12:09:03 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  3d3838b7fde93c855196c9999f100ae9c302e5aa (commit)
       via  b362e2aabde96a22e48477640375e637b98f6e2e (commit)
       via  07ae8056f975a0c4e3814adf3e5652272ad93e1d (commit)
       via  99fc6cbe36d91846a8ceb1dad3d01758b6f688e4 (commit)
       via  647b63371b38aec45562c9392ac02585acd79851 (commit)
       via  5340f153229d7f09b838bfade912d6754fe79f71 (commit)
      from  5371c9a8c938b55a2a58dd713fe60cadb8f2d3df (commit)
revisions in full, below.
commit 3d3838b7fde93c855196c9999f100ae9c302e5aa
Merge: 5371c9a8c9 b362e2aabd
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 12:09:02 2026 -0700
    Merge pull request 'Backport safety fixes to stable-3.4' (!539) from Komzpa/postgis:backport/20260726-stable-3.4-safety-fixes into stable-3.4
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/539
commit b362e2aabde96a22e48477640375e637b98f6e2e
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Jul 27 03:10:27 2026 +0400
    ci: fix stable 3.4 docs pull request dependency
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index ad5fa038ad..88a0b50612 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -31,7 +31,7 @@ steps:
       - make postgis_revision.h
       - xmllint --version
     when:
-        - event: push
+        - event: [tag, pull_request, push]
           path: *when_path_full
   check-xml:
commit 07ae8056f975a0c4e3814adf3e5652272ad93e1d
Date:   Sun Jul 26 21:35:41 2026 +0400
    Drop master-only NURBS validator from stable GSERIALIZED port
    Stable branches do not define NURBSCURVETYPE, so the NURBS-specific validator from the master GSERIALIZED hardening patch is not a branch-capability match. Keep the payload checks for geometry types present on the stable line.
    (cherry picked from commit de00ccc19b0fee48f8dbbc8b521510382624c099)
    (cherry picked from commit b241acf16f81d6812e64144b368f23a55e62454d)
diff --git a/liblwgeom/gserialized2.c b/liblwgeom/gserialized2.c
index 6e37273117..98054d735b 100644
--- a/liblwgeom/gserialized2.c
+++ b/liblwgeom/gserialized2.c
@@ -440,37 +440,6 @@ gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwfl
 		break;
-	case NURBSCURVETYPE: {
-		uint32_t nweights, nknots;
-		size_t weight_bytes, knot_bytes, point_bytes;
-		consumed = 6 * sizeof(uint32_t);
-		if (!gserialized2_range_available(data_ptr, data_end, consumed))
-			lwerror("%s: GSERIALIZED NURBS header exceeds payload size", __func__);
-			return LW_FAILURE;
-		nweights =
-		    gserialized2_read_uint32_checked(data_ptr + 3 * sizeof(uint32_t), data_end, "NURBS weight count");
-		nknots =
-		    gserialized2_read_uint32_checked(data_ptr + 4 * sizeof(uint32_t), data_end, "NURBS knot count");
-		if (gserialized2_checked_mul((size_t)nweights, sizeof(double), &weight_bytes) == LW_FAILURE ||
-		    gserialized2_checked_mul((size_t)nknots, sizeof(double), &knot_bytes) == LW_FAILURE)
-			lwerror("%s: GSERIALIZED NURBS vector size overflows", __func__);
-		if (gserialized2_pointarray_payload_size(count, lwflags, &point_bytes) == LW_FAILURE)
-		if (gserialized2_checked_add(consumed, weight_bytes, &consumed) == LW_FAILURE ||
-		    gserialized2_checked_add(consumed, knot_bytes, &consumed) == LW_FAILURE ||
-		    gserialized2_checked_add(consumed, point_bytes, &consumed) == LW_FAILURE)
-			lwerror("%s: GSERIALIZED NURBS size overflows", __func__);
-		break;
 	default:
 		lwerror("Unknown geometry type: %d - %s", type, lwtype_name(type));
 		return LW_FAILURE;
commit 99fc6cbe36d91846a8ceb1dad3d01758b6f688e4
Date:   Sun Jul 26 04:15:53 2026 +0400
    Guard largest empty circle boundary inputs
    (cherry picked from commit 8d143e4b549567d362edd0e80349bd5de29a4c1e)
    (cherry picked from commit 42a45ea889ec7ca371bcd1b9f9272ab10bcd21d3)
    (cherry picked from commit 10ae25ce9dda6999dcb4196616d90cfb1a018cdd)
diff --git a/NEWS b/NEWS
index c8c5bb914b..17e4b51e17 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,8 @@ PostGIS 3.4.7
     geometry data (Darafei Praliaskouski)
   - GT-523, [raster] Fix invalid reads in geotransform property access
+  - GT-519, Reject invalid ST_LargestEmptyCircle boundaries before GEOS can
+    spend unbounded time on them (Darafei Praliaskouski)
   - #6094, [upgrade] Avoid legacy string literal warnings in downgrade checks
     with standard_conforming_strings off (Darafei Praliaskouski)
   - #6042, Skip downgrade checks when source extension libraries cannot
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 8692212faa..a2c8e43842 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1652,6 +1652,7 @@ LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11
       <refsection>
         <title>Description</title>
         <para>Finds the largest circle which does not overlap a set of point and line obstacles. (Polygonal geometries may be included as obstacles, but only their boundary lines are used.) The center of the circle is constrained to lie inside a polygonal boundary, which by default is the convex hull of the input geometry. The circle center is the point in the interior of the boundary which has the farthest distance from the obstacles. The circle itself is provided by the center point and a nearest point lying on an obstacle detemining the circle radius.</para>
+        <para>If a boundary is supplied it must be a valid polygonal geometry with positive area.</para>
         <para>The circle center is determined to a given  accuracy specified by a distance tolerance, using an iterative algorithm. If the accuracy distance is not specified a reasonable default is used.</para>
         <para>Returns a record with fields:</para>
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index c008df1842..aa7384c369 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -507,8 +507,18 @@ Datum ST_LargestEmptyCircle(PG_FUNCTION_ARGS)
 		GEOSGeometry *ginput, *gcircle, *gcenter, *gnearest;
 		GEOSGeometry *gboundary = NULL;
 		double width, height, size;
-		GBOX gbox;
-		LWGEOM *lwg;
+		double boundary_area;
+		GBOX gbox, boundary_gbox;
+		LWGEOM *lwg, *lwboundary;
+		if (hasBoundary &&
+		    (!gserialized_get_gbox_p(boundary, &boundary_gbox) ||
+		     !(boundary_gbox.xmax > boundary_gbox.xmin && boundary_gbox.ymax > boundary_gbox.ymin)))
+			lwpgerror("Boundary geometry must have positive area");
+			PG_RETURN_NULL();
 		lwg = lwgeom_from_gserialized(geom);
 		if (!lwgeom_isfinite(lwg))
@@ -529,6 +539,24 @@ Datum ST_LargestEmptyCircle(PG_FUNCTION_ARGS)
 			tolerance = size / 1000.0;
+		if (hasBoundary)
+			lwboundary = lwgeom_from_gserialized(boundary);
+			if (!lwgeom_isfinite(lwboundary))
+				lwgeom_free(lwboundary);
+				lwpgerror("Boundary geometry contains invalid coordinates");
+				PG_RETURN_NULL();
+			boundary_area = lwgeom_area(lwboundary);
+			if (!(boundary_area > 0.0))
+				PG_RETURN_NULL();
 		initGEOS(lwpgnotice, lwgeom_geos_error);
 		ginput = POSTGIS2GEOS(geom);
@@ -537,9 +565,24 @@ Datum ST_LargestEmptyCircle(PG_FUNCTION_ARGS)
 		if (hasBoundary)
+			char boundary_valid;
 			gboundary = POSTGIS2GEOS(boundary);
 			if (!gboundary)
 				HANDLE_GEOS_ERROR("Boundary could not be converted to GEOS");
+			boundary_valid = GEOSisValid(gboundary);
+			if (boundary_valid == 2)
+				GEOSGeom_destroy(ginput);
+				GEOSGeom_destroy(gboundary);
+				HANDLE_GEOS_ERROR("GEOSisValid");
+			if (!boundary_valid)
+				lwpgerror("Boundary geometry is invalid");
+				PG_RETURN_NULL();
 		gcircle = GEOSLargestEmptyCircle(ginput, gboundary, tolerance);
diff --git a/regress/core/geos39.sql b/regress/core/geos39.sql
index 9d5e025538..ab55d198ec 100644
--- a/regress/core/geos39.sql
+++ b/regress/core/geos39.sql
@@ -52,3 +52,9 @@ SELECT 'lec-1', round(radius::numeric,3),
   ST_AsText(nearest,3) AS nearest
 FROM ST_LargestEmptyCircle(
   'MULTIPOINT ((4 3), (7 6), (4 6))');
+SELECT 'lec-invalid-boundary', radius
+FROM ST_LargestEmptyCircle(
+  'POINT(0 0)'::geometry,
+  20.1,
+  'POLYGON((1 2,1 2,1 2,1 2,3 2,1 2))'::geometry);
diff --git a/regress/core/geos39_expected b/regress/core/geos39_expected
index cc507a7f4e..ba385d2029 100644
--- a/regress/core/geos39_expected
+++ b/regress/core/geos39_expected
@@ -10,3 +10,4 @@ rp-2|POINT(1 19)
 rp-3|POINT(0 20)
 ERROR:  Geometry contains invalid coordinates
 lec-1|2.121|POINT(5.5 4.5)|POINT(4 3)
+ERROR:  Boundary geometry must have positive area
commit 647b63371b38aec45562c9392ac02585acd79851
Date:   Sun Jul 26 16:14:42 2026 +0300
    Fix raster geotransform invalid reads
    Port the stable-applicable part of the Valgrind finding: RASTER_getGeotransform read raster offsets after destroying the deserialized raster. The rt_band_init_value zero-cell fix from master does not apply because stable-3.5 does not have that helper.
    Ported-from: https://gitea.osgeo.org/postgis/postgis/commit/5692dfe21b854899ee738f278651e58e63532652
    (cherry picked from commit 0181cd4411467c12ac96a935bacb7da98ddac027)
    (cherry picked from commit 9a28f6f533371ab341ef560cca869b235e839812)
index 4fd6f52ce5..c8c5bb914b 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,8 @@ PostGIS 3.4.7
   - GT-522, Reject malformed GSERIALIZED payload counts before deserializing
+  - GT-523, [raster] Fix invalid reads in geotransform property access
+    (Darafei Praliaskouski)
diff --git a/raster/rt_pg/rtpg_raster_properties.c b/raster/rt_pg/rtpg_raster_properties.c
index 032e4975e9..c2717585e0 100644
--- a/raster/rt_pg/rtpg_raster_properties.c
+++ b/raster/rt_pg/rtpg_raster_properties.c
@@ -445,10 +445,8 @@ Datum RASTER_getGeotransform(PG_FUNCTION_ARGS)
     double jmag;
     double theta_i;
     double theta_ij;
     double xoffset;
     double yoffset;
     TupleDesc result_tuple; /* for returning a composite */
     Datum values[VALUES_LENGTH];
@@ -478,6 +476,8 @@ Datum RASTER_getGeotransform(PG_FUNCTION_ARGS)
             rt_raster_get_y_skew(raster),
             rt_raster_get_y_scale(raster),
             &imag, &jmag, &theta_i, &theta_ij) ;
+    xoffset = rt_raster_get_x_offset(raster);
+    yoffset = rt_raster_get_y_offset(raster);
     rt_raster_destroy(raster);
     PG_FREE_IF_COPY(pgraster, 0);
@@ -501,8 +501,8 @@ Datum RASTER_getGeotransform(PG_FUNCTION_ARGS)
     values[1] = Float8GetDatum(jmag);
     values[2] = Float8GetDatum(theta_i);
     values[3] = Float8GetDatum(theta_ij);
-    values[4] = Float8GetDatum(rt_raster_get_x_offset(raster));
-    values[5] = Float8GetDatum(rt_raster_get_y_offset(raster));
+    values[4] = Float8GetDatum(xoffset);
+    values[5] = Float8GetDatum(yoffset);
     memset(nulls, FALSE, sizeof(bool) * VALUES_LENGTH);
commit 5340f153229d7f09b838bfade912d6754fe79f71
Date:   Sun Jul 26 14:43:56 2026 +0400
    Harden GSERIALIZED payload readers
    (cherry picked from commit 62cff7ebdd8a76e61231b379026a41dd6e49b436)
index b62241c5d9..4fd6f52ce5 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,8 @@ PostGIS 3.4.7
 * Bug Fixes *
+  - GT-522, Reject malformed GSERIALIZED payload counts before deserializing
+    geometry data (Darafei Praliaskouski)
diff --git a/liblwgeom/cunit/cu_gserialized1.c b/liblwgeom/cunit/cu_gserialized1.c
index 66cc0a55e8..4afe2294c7 100644
--- a/liblwgeom/cunit/cu_gserialized1.c
+++ b/liblwgeom/cunit/cu_gserialized1.c
@@ -1252,6 +1252,47 @@ test_gserialized1_peek_first_point(void)
 	CU_ASSERT(peek1_point_helper("POLYGON((0 0, 1 1, 1 0, 0 0))", &p) == LW_FAILURE);
+static void
+assert_gserialized1_malformed_rejected(GSERIALIZED *g)
+	LWGEOM *geom;
+	GBOX box;
+	POINT4D point;
+	memset(&box, 0, sizeof(box));
+	memset(&point, 0, sizeof(point));
+	cu_error_msg_reset();
+	geom = lwgeom_from_gserialized1(g);
+	CU_ASSERT_PTR_NULL(geom);
+	CU_ASSERT_NOT_EQUAL(strlen(cu_error_msg), 0);
+	CU_ASSERT_TRUE(gserialized1_is_empty(g));
+	CU_ASSERT_EQUAL(gserialized1_peek_gbox_p(g, &box), LW_FAILURE);
+	CU_ASSERT_EQUAL(gserialized1_peek_first_point(g, &point), LW_FAILURE);
+static void
+test_gserialized1_malformed_declared_size(void)
+	LWGEOM *lwgeom = lwgeom_from_wkt("POINT(1 1)", LW_PARSER_CHECK_NONE);
+	GSERIALIZED *g;
+	size_t size = 0;
+	CU_ASSERT_PTR_NOT_NULL_FATAL(lwgeom);
+	g = gserialized1_from_lwgeom(lwgeom, &size);
+	CU_ASSERT_PTR_NOT_NULL_FATAL(g);
+	LWSIZE_SET(g->size, 0);
+	assert_gserialized1_malformed_rejected(g);
+	LWSIZE_SET(g->size, offsetof(GSERIALIZED, data) - 1);
+	lwfree(g);
+	lwgeom_free(lwgeom);
 ** Used by test harness to register the tests in this file.
@@ -1286,4 +1327,5 @@ void gserialized1_suite_setup(void)
 	PG_ADD_TEST(suite, test_gbox_same_2d);
 	PG_ADD_TEST(suite, test_signum_macro);
 	PG_ADD_TEST(suite, test_gserialized1_peek_first_point);
+	PG_ADD_TEST(suite, test_gserialized1_malformed_declared_size);
diff --git a/liblwgeom/cunit/cu_gserialized2.c b/liblwgeom/cunit/cu_gserialized2.c
index 6f8217c15a..3dc36a09a4 100644
--- a/liblwgeom/cunit/cu_gserialized2.c
+++ b/liblwgeom/cunit/cu_gserialized2.c
@@ -509,6 +509,133 @@ test_gserialized2_peek_first_point(void)
 	CU_ASSERT(peek2_point_helper("POLYGON((0 0, 1 1, 1 0, 0 0))", &p) == LW_FAILURE);
+static GSERIALIZED *
+gserialized2_from_hexbytes(const char *hex)
+	uint8_t *bytes;
+	size_t size;
+	GSERIALIZED *g;
+	size = strlen(hex) / 2;
+	bytes = bytes_from_hexbytes(hex, strlen(hex));
+	g = lwalloc(size);
+	memcpy(g, bytes, size);
+	lwfree(bytes);
+	return g;
+static void
+test_gserialized2_malformed_collection_count(void)
+	const char *hex =
+	    "8001000000000044000000000000803f0000000000000040"
+	    "070000000200000001000000f03f000000000000f03f";
+	GSERIALIZED *g = gserialized2_from_hexbytes(hex);
+	LWGEOM *geom;
+	geom = lwgeom_from_gserialized2(g);
+	lwfree(g);
+static void
+assert_gserialized2_malformed_rejected(GSERIALIZED *g)
+	LWGEOM *geom;
+	GBOX box;
+	POINT4D point;
+	CU_ASSERT_TRUE(gserialized2_is_empty(g));
+	CU_ASSERT_EQUAL(gserialized2_peek_gbox_p(g, &box), LW_FAILURE);
+	CU_ASSERT_EQUAL(gserialized2_peek_first_point(g, &point), LW_FAILURE);
+static void
+test_gserialized2_malformed_declared_size(void)
+	const char *declared_size_0 =
+	    "0000000000000044000000000000803f0000000000000040"
+	const char *declared_size_23 =
+	    "5c00000000000044000000000000803f0000000000000040"
+	GSERIALIZED *g;
+	g = gserialized2_from_hexbytes(declared_size_0);
+	assert_gserialized2_malformed_rejected(g);
+	lwfree(g);
+	g = gserialized2_from_hexbytes(declared_size_23);
+	lwfree(g);
+static void
+test_gserialized2_malformed_short_allocation(void)
+#if defined(POSTGIS_ASAN_ALLOCATOR_SIZE)
+	const char *hex = "8001000000000044";
+	uint8_t *bytes = bytes_from_hexbytes(hex, strlen(hex));
+	GSERIALIZED *g = malloc(strlen(hex) / 2);
+	memcpy(g, bytes, strlen(hex) / 2);
+	free(g);
+	lwfree(bytes);
+#else
+	CU_PASS("shorter-than-declared allocation validation requires AddressSanitizer allocation metadata");
+#endif
+static void
+test_gserialized2_wkb_roundtrip_float_rounded_box(void)
+	const char *hex =
+	    "0102000000030000000000000000000000000000f03f0000000000000040"
+	    "0101000000000000000f03f0000000000000040000000000000f03f";
+	size_t wkb_size = strlen(hex) / 2;
+	uint8_t *wkb = bytes_from_hexbytes(hex, strlen(hex));
+	LWGEOM *input = lwgeom_from_wkb(wkb, wkb_size, LW_PARSER_CHECK_NONE);
+	GSERIALIZED *serialized;
+	LWGEOM *roundtrip;
+	size_t serialized_size = 0;
+	GBOX input_box;
+	GBOX roundtrip_box;
+	CU_ASSERT_PTR_NOT_NULL_FATAL(input);
+	serialized = gserialized2_from_lwgeom(input, &serialized_size);
+	CU_ASSERT_PTR_NOT_NULL_FATAL(serialized);
+	roundtrip = lwgeom_from_gserialized2(serialized);
+	CU_ASSERT_PTR_NOT_NULL_FATAL(roundtrip);
+	CU_ASSERT_EQUAL(serialized_size, LWSIZE_GET(serialized->size));
+	CU_ASSERT_PTR_NOT_NULL(input->bbox);
+	CU_ASSERT_PTR_NOT_NULL(roundtrip->bbox);
+	CU_ASSERT_FALSE(gbox_same(input->bbox, roundtrip->bbox));
+	CU_ASSERT_EQUAL(lwgeom_calculate_gbox_cartesian(input, &input_box), LW_SUCCESS);
+	CU_ASSERT_EQUAL(lwgeom_calculate_gbox_cartesian(roundtrip, &roundtrip_box), LW_SUCCESS);
+	CU_ASSERT_TRUE(gbox_same(&input_box, &roundtrip_box));
+	lwgeom_free(input);
+	lwgeom_free(roundtrip);
+	lwfree(serialized);
+	lwfree(wkb);
@@ -527,4 +654,8 @@ void gserialized2_suite_setup(void)
 	PG_ADD_TEST(suite, test_gserialized2_peek_gbox_p_fails_for_unsupported_cases);
 	PG_ADD_TEST(suite, test_gserialized2_extended_flags);
 	PG_ADD_TEST(suite, test_gserialized2_peek_first_point);
+	PG_ADD_TEST(suite, test_gserialized2_malformed_collection_count);
+	PG_ADD_TEST(suite, test_gserialized2_malformed_declared_size);
+	PG_ADD_TEST(suite, test_gserialized2_malformed_short_allocation);
+	PG_ADD_TEST(suite, test_gserialized2_wkb_roundtrip_float_rounded_box);
diff --git a/liblwgeom/gserialized1.c b/liblwgeom/gserialized1.c
index 1a87ccf527..e4f7c57ce3 100644
--- a/liblwgeom/gserialized1.c
+++ b/liblwgeom/gserialized1.c
@@ -30,13 +30,37 @@
 #include "gserialized1.h"
 #include <stddef.h>
+#if defined(__has_feature)
+#if __has_feature(address_sanitizer)
+#define POSTGIS_ASAN_ALLOCATOR_SIZE 1
+#endif
+#endif
+#if defined(__SANITIZE_ADDRESS__)
+#endif
+#include <sanitizer/allocator_interface.h>
+#endif
 * GSERIALIZED metadata utility functions.
 static int gserialized1_read_gbox_p(const GSERIALIZED *g, GBOX *gbox);
+static int gserialized1_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end);
+static int gserialized1_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size);
+static size_t
+gserialized1_buffer_size(const GSERIALIZED *g)
+	size_t gsize = LWSIZE_GET(g->size);
+	size_t allocated_size = __sanitizer_get_allocated_size(g);
+	if (allocated_size > 0 && allocated_size < gsize)
+		return allocated_size;
+#endif
+	return gsize;
 lwflags_t gserialized1_get_lwflags(const GSERIALIZED *g)
@@ -132,6 +156,13 @@ static uint32_t gserialized1_header_size(const GSERIALIZED *gser)
 uint32_t gserialized1_get_type(const GSERIALIZED *g)
 	uint32_t *ptr;
+	size_t hsz = gserialized1_header_size(g);
+	size_t gsize = gserialized1_buffer_size(g);
+	if (gsize < hsz + sizeof(uint32_t))
+		lwerror("%s: GSERIALIZED too small for geometry type", __func__);
+		return 0;
 	ptr = (uint32_t*)(g->data);
 	if ( G1FLAGS_GET_BBOX(g->gflags) )
@@ -142,19 +173,19 @@ uint32_t gserialized1_get_type(const GSERIALIZED *g)
 int32_t gserialized1_get_srid(const GSERIALIZED *s)
-	int32_t srid = 0;
-	srid = srid | (s->srid[0] << 16);
-	srid = srid | (s->srid[1] << 8);
-	srid = srid | s->srid[2];
-	/* Only the first 21 bits are set. Slide up and back to pull
-	   the negative bits down, if we need them. */
-	srid = (srid<<11)>>11;
+	uint32_t srid = 0;
+	srid = srid | ((uint32_t)s->srid[0] << 16);
+	srid = srid | ((uint32_t)s->srid[1] << 8);
+	srid = srid | (uint32_t)s->srid[2];
+	/* Only the first 21 bits are set. Sign-extend without signed shift UB. */
+	if (srid & 0x00100000)
+		srid |= 0xFFE00000;
 	/* 0 is our internal unknown value. We'll map back and forth here for now */
 	if ( srid == 0 )
 		return SRID_UNKNOWN;
 	else
-		return srid;
+		return (int32_t)srid;
 void gserialized1_set_srid(GSERIALIZED *s, int32_t srid)
@@ -173,6 +204,204 @@ void gserialized1_set_srid(GSERIALIZED *s, int32_t srid)
 	s->srid[2] = (srid & 0x000000FF);
+static int
+gserialized1_range_available(const uint8_t *ptr, const uint8_t *end, size_t len)
+	return ptr <= end && len <= (size_t)(end - ptr);
+static int
+gserialized1_checked_mul(size_t a, size_t b, size_t *out)
+	if (a != 0 && b > SIZE_MAX / a)
+		return LW_FAILURE;
+	*out = a * b;
+	return LW_SUCCESS;
+static int
+gserialized1_checked_add(size_t a, size_t b, size_t *out)
+	if (b > SIZE_MAX - a)
+	*out = a + b;
+static int
+gserialized1_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end)
+	size_t hsz;
+	size_t gsize;
+	if (!g)
+	hsz = gserialized1_header_size(g);
+	gsize = gserialized1_buffer_size(g);
+	if (gsize < hsz)
+	if (start)
+		*start = (uint8_t *)g + hsz;
+	if (end)
+		*end = (uint8_t *)g + gsize;
+static uint32_t
+gserialized1_read_uint32_checked(uint8_t *ptr, uint8_t *end, const char *field)
+	uint32_t value = 0;
+	if (!gserialized1_range_available(ptr, end, sizeof(uint32_t)))
+		lwerror("%s: GSERIALIZED too small for %s", __func__, field);
+		return 0;
+	memcpy(&value, ptr, sizeof(uint32_t));
+	return value;
+static int
+gserialized1_pointarray_payload_size(uint32_t npoints, lwflags_t lwflags, size_t *nbytes)
+	if (gserialized1_checked_mul((size_t)npoints, sizeof(double) * FLAGS_NDIMS(lwflags), nbytes) == LW_FAILURE)
+		lwerror("%s: GSERIALIZED point count overflows payload size", __func__);
+static int
+gserialized1_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size)
+	uint32_t type, count;
+	size_t consumed = 0;
+	if (!gserialized1_range_available(data_ptr, data_end, 2 * sizeof(uint32_t)))
+		lwerror("%s: GSERIALIZED geometry payload is too short", __func__);
+	type = gserialized1_read_uint32_checked(data_ptr, data_end, "geometry type");
+	count = gserialized1_read_uint32_checked(data_ptr + sizeof(uint32_t), data_end, "geometry count");
+	switch (type)
+	case POINTTYPE:
+		if (count > 1)
+			lwerror("%s: invalid point count %u", __func__, count);
+		/* fall through */
+	case LINETYPE:
+	case CIRCSTRINGTYPE:
+	case TRIANGLETYPE: {
+		size_t point_bytes;
+		if (gserialized1_pointarray_payload_size(count, lwflags, &point_bytes) == LW_FAILURE)
+		consumed = 2 * sizeof(uint32_t) + point_bytes;
+		break;
+	case POLYGONTYPE: {
+		size_t ring_counts_size, ring_counts_padded_size, point_bytes_sum = 0;
+		uint8_t *ring_counts = data_ptr + 2 * sizeof(uint32_t);
+		uint32_t i;
+		if (gserialized1_checked_mul((size_t)count, sizeof(uint32_t), &ring_counts_size) == LW_FAILURE)
+			lwerror("%s: GSERIALIZED ring count overflows payload size", __func__);
+		ring_counts_padded_size = ring_counts_size + ((count % 2) ? sizeof(uint32_t) : 0);
+		if (!gserialized1_range_available(ring_counts, data_end, ring_counts_padded_size))
+			lwerror("%s: GSERIALIZED polygon ring table exceeds payload size", __func__);
+		for (i = 0; i < count; i++)
+			size_t ring_point_bytes;
+			uint32_t npoints = gserialized1_read_uint32_checked(
+			    ring_counts + i * sizeof(uint32_t), data_end, "ring point count");
+			if (gserialized1_pointarray_payload_size(npoints, lwflags, &ring_point_bytes) == LW_FAILURE)
+			if (gserialized1_checked_add(point_bytes_sum, ring_point_bytes, &point_bytes_sum) == LW_FAILURE)
+				lwerror("%s: GSERIALIZED polygon coordinate size overflows", __func__);
+		consumed = 2 * sizeof(uint32_t) + ring_counts_padded_size;
+		if (gserialized1_checked_add(consumed, point_bytes_sum, &consumed) == LW_FAILURE)
+			lwerror("%s: GSERIALIZED polygon size overflows", __func__);
+		break;
+	case MULTIPOINTTYPE:
+	case MULTILINETYPE:
+	case MULTIPOLYGONTYPE:
+	case COMPOUNDTYPE:
+	case CURVEPOLYTYPE:
+	case MULTICURVETYPE:
+	case MULTISURFACETYPE:
+	case POLYHEDRALSURFACETYPE:
+	case TINTYPE:
+	case COLLECTIONTYPE: {
+		uint32_t i;
+		uint8_t *subgeom_ptr = data_ptr + 2 * sizeof(uint32_t);
+		lwflags_t subflags = lwflags;
+		FLAGS_SET_BBOX(subflags, 0);
+			size_t subsize = 0;
+			uint32_t subtype =
+			    gserialized1_read_uint32_checked(subgeom_ptr, data_end, "collection subtype");
+			if (!lwcollection_allows_subtype(type, subtype))
+				lwerror("Invalid subtype (%s) for collection type (%s)",
+					lwtype_name(subtype),
+					lwtype_name(type));
+			if (gserialized1_validate_geometry_buffer(subgeom_ptr, data_end, subflags, &subsize) ==
+			    LW_FAILURE)
+			if (subsize == 0)
+				lwerror("%s: GSERIALIZED collection member has zero size", __func__);
+			subgeom_ptr += subsize;
+		consumed = (size_t)(subgeom_ptr - data_ptr);
+		break;
+	default:
+		lwerror("Unknown geometry type: %d - %s", type, lwtype_name(type));
+	if (!gserialized1_range_available(data_ptr, data_end, consumed))
+		lwerror("%s: GSERIALIZED geometry payload exceeds declared size", __func__);
+	if (size)
+		*size = consumed;
 static size_t gserialized1_is_empty_recurse(const uint8_t *p, int *isempty);
@@ -203,13 +432,17 @@ static size_t gserialized1_is_empty_recurse(const uint8_t *p, int *isempty)
 int gserialized1_is_empty(const GSERIALIZED *g)
-	uint8_t *p = (uint8_t*)g;
+	uint8_t *p, *end;
 	int isempty = 0;
 	assert(g);
-	p += 8; /* Skip varhdr and srid/flags */
-	if(gserialized1_has_bbox(g))
-		p += gserialized1_box_size(g); /* Skip the box */
+	if (gserialized1_payload_bounds(g, &p, &end) == LW_FAILURE)
+		lwerror("%s: invalid GSERIALIZED header size", __func__);
+		return LW_TRUE;
+	if (gserialized1_validate_geometry_buffer(p, end, gserialized1_get_lwflags(g), NULL) == LW_FAILURE)
+		return LW_TRUE;
 	gserialized1_is_empty_recurse(p, &isempty);
 	return isempty;
@@ -254,6 +487,8 @@ int gserialized1_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
 	/* Null input! */
 	if ( ! ( g && gbox ) ) return LW_FAILURE;
+	if (gserialized1_buffer_size(g) < offsetof(GSERIALIZED, data) + gserialized1_box_size(g))
 	/* Initialize the flags on the box */
 	gbox->flags = gserialized1_get_lwflags(g);
@@ -298,7 +533,16 @@ int gserialized1_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
 int
 gserialized1_peek_gbox_p(const GSERIALIZED *g, GBOX *gbox)
-	uint32_t type = gserialized1_get_type(g);
+	uint32_t type;
+	uint8_t *geometry_start = NULL;
+	uint8_t *geometry_end = NULL;
+	if (gserialized1_payload_bounds(g, &geometry_start, &geometry_end) == LW_FAILURE)
+	if (gserialized1_validate_geometry_buffer(geometry_start, geometry_end, gserialized1_get_lwflags(g), NULL) ==
+	    LW_FAILURE)
+	type = gserialized1_get_type(g);
 	/* Peeking doesn't help if you already have a box or are geodetic */
 	if ( G1FLAGS_GET_GEODETIC(g->gflags) || G1FLAGS_GET_BBOX(g->gflags) )
@@ -491,11 +735,14 @@ gserialized1_copy_point(double *dptr, lwflags_t flags, POINT4D *out_point)
 int
 gserialized1_peek_first_point(const GSERIALIZED *g, POINT4D *out_point)
-	uint8_t *geometry_start = ((uint8_t *)g->data);
-	if (gserialized1_has_bbox(g))
-		geometry_start += gserialized1_box_size(g);
+	    LW_FAILURE)
 	uint32_t isEmpty = (((uint32_t *)geometry_start)[1]) == 0;
 	if (isEmpty)
@@ -1454,14 +1701,19 @@ LWGEOM* lwgeom_from_gserialized1(const GSERIALIZED *g)
 	assert(g);
 	srid = gserialized1_get_srid(g);
-	lwtype = gserialized1_get_type(g);
 	lwflags = gserialized1_get_lwflags(g);
-	LWDEBUGF(4, "Got type %d (%s), srid=%d", lwtype, lwtype_name(lwtype), srid);
+	if (gserialized1_payload_bounds(g, &data_ptr, NULL) == LW_FAILURE)
+		return NULL;
+		data_ptr, (uint8_t *)g + gserialized1_buffer_size(g), lwflags, NULL) == LW_FAILURE)
+		return NULL;
+	lwtype = gserialized1_get_type(g);
-	data_ptr = (uint8_t*)g->data;
-	if (FLAGS_GET_BBOX(lwflags))
-		data_ptr += gbox_serialized_size(lwflags);
+	LWDEBUGF(4, "Got type %d (%s), srid=%d", lwtype, lwtype_name(lwtype), srid);
 	lwgeom = lwgeom_from_gserialized1_buffer(data_ptr, lwflags, &size);
@@ -1495,6 +1747,8 @@ const float * gserialized1_get_float_box_p(const GSERIALIZED *g, size_t *ndims)
 		*ndims = G1FLAGS_NDIMS_BOX(g->gflags);
 	if (!g) return NULL;
 	if (!G1FLAGS_GET_BBOX(g->gflags)) return NULL;
+		return NULL;
 	return (const float *)(g->data);
@@ -1604,4 +1858,3 @@ GSERIALIZED* gserialized1_drop_gbox(GSERIALIZED *g)
 	return g_out;
index 9c582798d3..6e37273117 100644
@@ -48,18 +48,43 @@
 #include "gserialized2.h"
 #include <stddef.h>
+#endif
+#endif
+#endif
+#endif
 static int gserialized2_read_gbox_p(const GSERIALIZED *g, GBOX *gbox);
+static int gserialized2_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end);
+static int gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size);
+static size_t
+gserialized2_buffer_size(const GSERIALIZED *g)
+#endif
+	return gsize;
 lwflags_t gserialized2_get_lwflags(const GSERIALIZED *g)
 	lwflags_t lwflags = 0;
 	uint8_t gflags = g->gflags;
+	size_t gsize = gserialized2_buffer_size(g);
 	FLAGS_SET_Z(lwflags, G2FLAGS_GET_Z(gflags));
 	FLAGS_SET_M(lwflags, G2FLAGS_GET_M(gflags));
 	FLAGS_SET_BBOX(lwflags, G2FLAGS_GET_BBOX(gflags));
@@ -67,6 +92,11 @@ lwflags_t gserialized2_get_lwflags(const GSERIALIZED *g)
 	if (G2FLAGS_GET_EXTENDED(gflags))
 		uint64_t xflags = 0;
+		if (gsize < offsetof(GSERIALIZED, data) + sizeof(uint64_t))
+			lwerror("%s: GSERIALIZED too small for extended flags", __func__);
+			return lwflags;
 		memcpy(&xflags, g->data, sizeof(uint64_t));
 		FLAGS_SET_SOLID(lwflags, xflags & G2FLAG_X_SOLID);
@@ -185,24 +215,31 @@ uint32_t gserialized2_max_header_size(void)
 uint32_t gserialized2_get_type(const GSERIALIZED *g)
 	uint8_t *ptr = gserialized2_get_geometry_p(g);
+	size_t hsz = gserialized2_header_size(g);
+		return 0;
 	return *((uint32_t*)(ptr));
 int32_t gserialized2_get_srid(const GSERIALIZED *g)
-	int32_t srid = 0;
-	srid = srid | (g->srid[0] << 16);
-	srid = srid | (g->srid[1] << 8);
-	srid = srid | (g->srid[2]);
+	srid = srid | ((uint32_t)g->srid[0] << 16);
+	srid = srid | ((uint32_t)g->srid[1] << 8);
+	srid = srid | (uint32_t)g->srid[2];
 	if (srid == 0)
 	else
-		return srid;
 void gserialized2_set_srid(GSERIALIZED *g, int32_t srid)
@@ -221,6 +258,235 @@ void gserialized2_set_srid(GSERIALIZED *g, int32_t srid)
 	g->srid[2] = (srid & 0x000000FF);
+static int
+gserialized2_range_available(const uint8_t *ptr, const uint8_t *end, size_t len)
+static int
+gserialized2_checked_mul(size_t a, size_t b, size_t *out)
+	*out = a * b;
+static int
+gserialized2_checked_add(size_t a, size_t b, size_t *out)
+	*out = a + b;
+static int
+gserialized2_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end)
+	size_t hsz;
+	size_t gsize;
+	if (!g)
+	hsz = gserialized2_header_size(g);
+	gsize = gserialized2_buffer_size(g);
+	if (gsize < hsz)
+	if (start)
+	if (end)
+static uint32_t
+gserialized2_read_uint32_checked(uint8_t *ptr, uint8_t *end, const char *field)
+	if (!gserialized2_range_available(ptr, end, sizeof(uint32_t)))
+		return 0;
+	return value;
+static int
+gserialized2_pointarray_payload_size(uint32_t npoints, lwflags_t lwflags, size_t *nbytes)
+	if (gserialized2_checked_mul((size_t)npoints, sizeof(double) * FLAGS_NDIMS(lwflags), nbytes) == LW_FAILURE)
+static int
+gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size)
+	if (!gserialized2_range_available(data_ptr, data_end, 2 * sizeof(uint32_t)))
+	type = gserialized2_read_uint32_checked(data_ptr, data_end, "geometry type");
+	count = gserialized2_read_uint32_checked(data_ptr + sizeof(uint32_t), data_end, "geometry count");
+	switch (type)
+	case POINTTYPE:
+		if (count > 1)
+	case LINETYPE:
+		if (gserialized2_pointarray_payload_size(count, lwflags, &point_bytes) == LW_FAILURE)
+		break;
+		uint32_t i;
+		if (gserialized2_checked_mul((size_t)count, sizeof(uint32_t), &ring_counts_size) == LW_FAILURE)
+		if (!gserialized2_range_available(ring_counts, data_end, ring_counts_padded_size))
+			uint32_t npoints = gserialized2_read_uint32_checked(
+			if (gserialized2_pointarray_payload_size(npoints, lwflags, &ring_point_bytes) == LW_FAILURE)
+			if (gserialized2_checked_add(point_bytes_sum, ring_point_bytes, &point_bytes_sum) == LW_FAILURE)
+		if (gserialized2_checked_add(consumed, point_bytes_sum, &consumed) == LW_FAILURE)
+		break;
+	case TINTYPE:
+		uint32_t i;
+			    gserialized2_read_uint32_checked(subgeom_ptr, data_end, "collection subtype");
+			if (gserialized2_validate_geometry_buffer(subgeom_ptr, data_end, subflags, &subsize) ==
+			    LW_FAILURE)
+			if (subsize == 0)
+		break;
+	case NURBSCURVETYPE: {
+		uint32_t nweights, nknots;
+		size_t weight_bytes, knot_bytes, point_bytes;
+		consumed = 6 * sizeof(uint32_t);
+		if (!gserialized2_range_available(data_ptr, data_end, consumed))
+			lwerror("%s: GSERIALIZED NURBS header exceeds payload size", __func__);
+		nweights =
+		    gserialized2_read_uint32_checked(data_ptr + 3 * sizeof(uint32_t), data_end, "NURBS weight count");
+		nknots =
+		    gserialized2_read_uint32_checked(data_ptr + 4 * sizeof(uint32_t), data_end, "NURBS knot count");
+		if (gserialized2_checked_mul((size_t)nweights, sizeof(double), &weight_bytes) == LW_FAILURE ||
+		    gserialized2_checked_mul((size_t)nknots, sizeof(double), &knot_bytes) == LW_FAILURE)
+			lwerror("%s: GSERIALIZED NURBS vector size overflows", __func__);
+		if (gserialized2_checked_add(consumed, weight_bytes, &consumed) == LW_FAILURE ||
+		    gserialized2_checked_add(consumed, knot_bytes, &consumed) == LW_FAILURE ||
+		    gserialized2_checked_add(consumed, point_bytes, &consumed) == LW_FAILURE)
+			lwerror("%s: GSERIALIZED NURBS size overflows", __func__);
+		break;
+	default:
+	if (size)
+		*size = consumed;
 static size_t gserialized2_is_empty_recurse(const uint8_t *p, int *isempty);
@@ -285,7 +551,14 @@ static size_t gserialized2_is_empty_recurse(const uint8_t *p, int *isempty)
 int gserialized2_is_empty(const GSERIALIZED *g)
 	int isempty = LW_TRUE;
-	uint8_t *p = gserialized2_get_geometry_p(g);
+	uint8_t *p, *end;
+	if (gserialized2_payload_bounds(g, &p, &end) == LW_FAILURE)
+		return LW_TRUE;
+	if (gserialized2_validate_geometry_buffer(p, end, gserialized2_get_lwflags(g), NULL) == LW_FAILURE)
+		return LW_TRUE;
 	gserialized2_is_empty_recurse(p, &isempty);
 	return isempty;
@@ -329,6 +602,8 @@ const float * gserialized2_get_float_box_p(const GSERIALIZED *g, size_t *ndims)
 	uint8_t *ptr = (uint8_t*)(g->data);
 	size_t bndims = G2FLAGS_NDIMS_BOX(g->gflags);
+	size_t box_offset = offsetof(GSERIALIZED, data);
+	size_t box_size = gserialized2_box_size(g);
 	if (ndims)
 		*ndims = bndims;
@@ -339,7 +614,13 @@ const float * gserialized2_get_float_box_p(const GSERIALIZED *g, size_t *ndims)
 	/* Advance past optional extended flags */
 	if (gserialized2_has_extended(g))
 		ptr += 8;
+		box_offset += 8;
+	if (gserialized2_buffer_size(g) < box_offset + box_size)
+		return NULL;
 	return (const float *)(ptr);
@@ -358,6 +639,8 @@ int gserialized2_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
 		int i = 0;
 		const float *fbox = gserialized2_get_float_box_p(g, NULL);
+		if (!fbox)
 		gbox->xmin = fbox[i++];
 		gbox->xmax = fbox[i++];
 		gbox->ymin = fbox[i++];
@@ -393,10 +676,20 @@ int gserialized2_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
 int
 gserialized2_peek_gbox_p(const GSERIALIZED *g, GBOX *gbox)
-	uint32_t type = gserialized2_get_type(g);
-	uint8_t *geometry_start = gserialized2_get_geometry_p(g);
-	double *dptr = (double *)(geometry_start);
-	int32_t *iptr = (int32_t *)(geometry_start);
+	uint32_t type;
+	double *dptr = NULL;
+	int32_t *iptr = NULL;
+	if (gserialized2_payload_bounds(g, &geometry_start, &geometry_end) == LW_FAILURE)
+	if (gserialized2_validate_geometry_buffer(geometry_start, geometry_end, gserialized2_get_lwflags(g), NULL) ==
+	    LW_FAILURE)
+	type = gserialized2_get_type(g);
+	dptr = (double *)(geometry_start);
+	iptr = (int32_t *)(geometry_start);
 	if (G2FLAGS_GET_GEODETIC(g->gflags) || G2FLAGS_GET_BBOX(g->gflags))
@@ -581,7 +874,14 @@ gserialized2_copy_point(double *dptr, lwflags_t flags, POINT4D *out_point)
 int
 gserialized2_peek_first_point(const GSERIALIZED *g, POINT4D *out_point)
+	    LW_FAILURE)
 	if (isEmpty)
@@ -1540,22 +1840,19 @@ LWGEOM* lwgeom_from_gserialized2(const GSERIALIZED *g)
 	assert(g);
 	srid = gserialized2_get_srid(g);
-	lwtype = gserialized2_get_type(g);
 	lwflags = gserialized2_get_lwflags(g);
-	/* Skip optional flags */
-	if (G2FLAGS_GET_EXTENDED(g->gflags))
+	if (gserialized2_payload_bounds(g, &data_ptr, NULL) == LW_FAILURE)
-		data_ptr += sizeof(uint64_t);
+		return NULL;
+		data_ptr, (uint8_t *)g + gserialized2_buffer_size(g), lwflags, NULL) == LW_FAILURE)
+		return NULL;
+	lwtype = gserialized2_get_type(g);
-	/* Skip over optional bounding box */
 	lwgeom = lwgeom_from_gserialized2_buffer(data_ptr, lwflags, &size, srid);
Summary of changes:
 .woodpecker/docs.yml                  |   2 +-
 NEWS                                  |   6 +
 doc/reference_processing.xml          |   1 +
 liblwgeom/cunit/cu_gserialized1.c     |  42 +++++
 liblwgeom/cunit/cu_gserialized2.c     | 131 ++++++++++++++
 liblwgeom/gserialized1.c              | 301 +++++++++++++++++++++++++++++---
 liblwgeom/gserialized2.c              | 316 +++++++++++++++++++++++++++++++---
 postgis/lwgeom_geos.c                 |  47 ++++-
 raster/rt_pg/rtpg_raster_properties.c |   8 +-
 regress/core/geos39.sql               |   6 +
 regress/core/geos39_expected          |   1 +
 11 files changed, 805 insertions(+), 56 deletions(-)
hooks/post-receive
