[SCM] PostGIS branch master updated. 3.7.0beta1-84-g8a7bf4fe01
git at osgeo.org
git at osgeo.org
Mon Jul 27 13:13:40 PDT 2026
the project "PostGIS".
via 8a7bf4fe01ddf247a4d056e6e3feaaae512134b0 (commit)
via f0db4a4e9addcde9c7e75b8befa5ad51df8dc889 (commit)
via 7f3fd06c5097fddb94f76a69414856892b11114b (commit)
from bbf00872510c92d78b1bdaae297652378b353f95 (commit)
revisions in full, below.
commit 8a7bf4fe01ddf247a4d056e6e3feaaae512134b0
Merge: bbf0087251 f0db4a4e9a
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 27 13:13:38 2026 -0700
Merge pull request 'Add malformed WKB and TWKB parser tests' (!542) from Komzpa/postgis:test/parser-malformed-wkb-twkb-20260726 into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/542
commit f0db4a4e9addcde9c7e75b8befa5ad51df8dc889
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Jul 27 02:53:30 2026 +0400
Tighten malformed WKB and TWKB parser oracles
diff --git a/liblwgeom/cunit/cu_in_twkb.c b/liblwgeom/cunit/cu_in_twkb.c
index e0e653173d..17c1f85354 100644
--- a/liblwgeom/cunit/cu_in_twkb.c
+++ b/liblwgeom/cunit/cu_in_twkb.c
@@ -243,7 +243,7 @@ test_twkb_in_truncated_extended_dims(void)
* out-of-buffer read while constructing the header.
ASSERT_STRING_EQUAL(cu_error_msg, "twkb_parse_state_advance: TWKB structure does not match expected size!");
- CU_ASSERT_PTR_NOT_NULL(geom);
+ CU_ASSERT_PTR_NULL(geom);
if (geom != NULL)
lwgeom_free(geom);
cu_error_msg_reset();
@@ -275,6 +275,7 @@ test_twkb_in_overlong_varint(void)
* than the C type width before the parser could report malformed input.
ASSERT_STRING_EQUAL(cu_error_msg, "varint_u64_decode: varint exceeds 64 bits");
if (geom != NULL)
lwgeom_free(geom);
@@ -303,6 +304,7 @@ test_twkb_in_count_exceeds_payload(void)
"twkb_parse_state_has_min_bytes: TWKB element count exceeds remaining payload");
if (geom != NULL)
lwgeom_free(geom);
@@ -359,6 +361,7 @@ test_twkb_in_coordinate_delta_wraparound(void)
* wrap hostile inputs into the int64_t accumulator range.
CU_ASSERT(strstr(cu_error_msg, "called with n=0 and npoints=0") != NULL);
if (geom != NULL)
lwgeom_free(geom);
diff --git a/liblwgeom/cunit/cu_in_wkb.c b/liblwgeom/cunit/cu_in_wkb.c
index 2566567ab0..64cbff40e0 100644
--- a/liblwgeom/cunit/cu_in_wkb.c
+++ b/liblwgeom/cunit/cu_in_wkb.c
@@ -332,6 +332,7 @@ test_wkb_in_invalid_endian_flag(void)
geom = lwgeom_from_wkb(wkb, sizeof(wkb), LW_PARSER_CHECK_NONE);
ASSERT_STRING_EQUAL(cu_error_msg, "Invalid endian flag value encountered.");
if (geom != NULL)
lwgeom_free(geom);
diff --git a/liblwgeom/lwin_twkb.c b/liblwgeom/lwin_twkb.c
index ad5dcd0c62..dc5ebd6ec9 100644
--- a/liblwgeom/lwin_twkb.c
+++ b/liblwgeom/lwin_twkb.c
@@ -54,6 +54,7 @@ typedef struct
uint8_t has_z;
uint8_t has_m;
uint8_t is_empty;
+ uint8_t error;
/* Precision factors to convert ints to double */
double factor;
@@ -86,10 +87,14 @@ LWGEOM* lwgeom_from_twkb_state(twkb_parse_state *s);
static inline void twkb_parse_state_advance(twkb_parse_state *s, size_t next)
- if (next > (size_t)(s->twkb_end - s->pos))
+ size_t remaining = (s->pos <= s->twkb_end) ? (size_t)(s->twkb_end - s->pos) : 0;
+ if (next > remaining)
+ s->error = LW_TRUE;
lwerror("%s: TWKB structure does not match expected size!", __func__);
- // lwnotice("TWKB structure does not match expected size!");
+ s->pos = s->twkb_end;
+ return;
s->pos += next;
@@ -99,6 +104,8 @@ static inline int64_t twkb_parse_state_varint(twkb_parse_state *s)
size_t size;
int64_t val = varint_s64_decode(s->pos, s->twkb_end, &size);
+ if (size == 0)
twkb_parse_state_advance(s, size);
return val;
@@ -107,6 +114,8 @@ static inline uint64_t twkb_parse_state_uvarint(twkb_parse_state *s)
size_t size;
uint64_t val = varint_u64_decode(s->pos, s->twkb_end, &size);
+ if (size == 0)
return val;
@@ -115,6 +124,8 @@ static inline double twkb_parse_state_double(twkb_parse_state *s, double factor)
size_t size;
+ if (size == 0)
return val / factor;
@@ -124,7 +135,10 @@ static inline void twkb_parse_state_varint_skip(twkb_parse_state *s)
size_t size = varint_size(s->pos, s->twkb_end);
if ( ! size )
lwerror("%s: no varint to skip", __func__);
return;
@@ -137,6 +151,7 @@ twkb_parse_state_uvarint32(twkb_parse_state *s)
if (val > UINT32_MAX)
lwerror("%s: TWKB count exceeds uint32_t", __func__);
return 0;
@@ -155,6 +170,7 @@ twkb_parse_state_has_min_bytes(twkb_parse_state *s, uint32_t count, size_t min_b
if (min_bytes != 0 && count > remaining / min_bytes)
lwerror("%s: TWKB element count exceeds remaining payload", __func__);
return LW_FALSE;
@@ -727,10 +743,17 @@ LWGEOM* lwgeom_from_twkb_state(twkb_parse_state *s)
break;
/* Unknown type! */
default:
lwerror("%s: Unsupported geometry type: %s", __func__, lwtype_name(s->lwtype));
break;
+ if (s->error)
+ lwgeom_free(geom);
+ return NULL;
if (has_bbox && geom)
geom->bbox = gbox_clone(&bbox);
diff --git a/liblwgeom/lwin_wkb.c b/liblwgeom/lwin_wkb.c
index de82d2376c..02a7ad90df 100644
--- a/liblwgeom/lwin_wkb.c
+++ b/liblwgeom/lwin_wkb.c
@@ -398,7 +398,10 @@ static void wkb_swap_bytes(wkb_parse_state *s)
lwerror("Invalid endian flag value encountered.");
if( wkb_little_endian != 1 && wkb_little_endian != 0 )
/* Check the endianness of our input */
s->swap_bytes = LW_FALSE;
commit 7f3fd06c5097fddb94f76a69414856892b11114b
Date: Sun Jul 26 20:22:16 2026 +0300
index 9b2097e0fc..e0e653173d 100644
@@ -387,6 +387,24 @@ test_twkb_in_linestring_coordinate_delta_wraparound(void)
+static void
+test_twkb_in_unsupported_type(void)
+ const uint8_t twkb[] = {0x08, /* unsupported TWKB type with default precision. */
+ 0x00};
+ LWGEOM *geom;
+ cu_error_msg_reset();
+ geom = lwgeom_from_twkb(twkb, sizeof(twkb), LW_PARSER_CHECK_NONE);
+ ASSERT_STRING_EQUAL(cu_error_msg, "lwgeom_from_twkb_state: Unsupported geometry type: Unknown");
+ if (geom != NULL)
** Used by test harness to register the tests in this file.
@@ -408,4 +426,5 @@ void twkb_in_suite_setup(void)
PG_ADD_TEST(suite, test_twkb_in_deep_collection);
PG_ADD_TEST(suite, test_twkb_in_coordinate_delta_wraparound);
PG_ADD_TEST(suite, test_twkb_in_linestring_coordinate_delta_wraparound);
+ PG_ADD_TEST(suite, test_twkb_in_unsupported_type);
index 2d7438c4c1..2566567ab0 100644
@@ -319,6 +319,24 @@ test_wkb_in_nurbscurve_count_exceeds_payload(void)
+static void
+test_wkb_in_invalid_endian_flag(void)
+ const uint8_t wkb[] = {0x02, /* invalid endian flag */
+ 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
+ LWGEOM *geom;
+ geom = lwgeom_from_wkb(wkb, sizeof(wkb), LW_PARSER_CHECK_NONE);
+ ASSERT_STRING_EQUAL(cu_error_msg, "Invalid endian flag value encountered.");
+ if (geom != NULL)
@@ -342,4 +360,5 @@ void wkb_in_suite_setup(void)
PG_ADD_TEST(suite, test_wkb_fuzz);
PG_ADD_TEST(suite, test_wkb_in_linestring_zm_count_exceeds_payload);
PG_ADD_TEST(suite, test_wkb_in_nurbscurve_count_exceeds_payload);
+ PG_ADD_TEST(suite, test_wkb_in_invalid_endian_flag);
Summary of changes:
liblwgeom/cunit/cu_in_twkb.c | 24 +++++++++++++++++++++++-
liblwgeom/cunit/cu_in_wkb.c | 20 ++++++++++++++++++++
liblwgeom/lwin_twkb.c | 27 +++++++++++++++++++++++++--
liblwgeom/lwin_wkb.c | 3 +++
4 files changed, 71 insertions(+), 3 deletions(-)
hooks/post-receive
